HTTPS without T-FM and PSA
We are currently developing a WiFi library and just started on implementing HTTPS and ran into some issues. Since we don't have enough flash and memory for using the T-FM image, we decided to work on the secure build (without *ns).
As such we tried to get the exercise 'wififund_less5_exer2' running without PSA and T-FM, and using the CONFIG_WIFI_CREDENTIALS_BACKEND_SETTINGS as backend.
Unfortunately we always get the same error when calling connect():
[00:00:35.491,699] <inf> Lesson5_Exercise2: Network connected
[00:00:36.076,354] <inf> Lesson5_Exercise2: IPv4 address of HTTP server found 18.238.243.52
[00:00:36.100,402] <err> Lesson5_Exercise2: Connecting to server failed, err: 22, Invalid argument
[00:00:36.100,402] <err> Lesson5_Exercise2: Failed to initialize client
Which is exactly the same problem we're getting in our library.
Is it somehow possible to get HTTPS working without T-FM and PSA, using a different crypto? Or is it limited by the hardware/kernel?
Daniel Figueira
    I will look into this and return with more information on Monday.
    Sigurd Hellesvik
  • Hi Daniel,
    (Optional) To learn about the PSA Crypto API, see  Securing IoT products with PSA Certified APIs .
    One of the big upsides with the PSA Crypto API is that it should do the same both with and without TF-M, so your code should function the same (if a tad less securely) without TF-M.
    So out of the gate, I think that what you try should work.
    Can you try our HTTPS Client example without TF-M?
    Reason I ask for a sample is because that makes this easier to try and reproduce from my side.
    Here is the overlay I used for nrf7002dk_nrf5340_cpuapp.conf, which maybe work:
    # Copyright (c) 2023 Nordic Semiconductor ASA
    # General
    CONFIG_POSIX_CLOCK=y
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_HEAP_MEM_POOL_SIZE=81920
    CONFIG_NET_RX_STACK_SIZE=2048
    # Optimize Wi-Fi stack to save some memory
    CONFIG_NRF700X_RX_NUM_BUFS=16
    CONFIG_NRF700X_MAX_TX_AGGREGATION=4
    # Wi-Fi
    CONFIG_WIFI=y
    CONFIG_WIFI_NRF700X=y
    CONFIG_WIFI_NRF700X_LOG_LEVEL_ERR=y
    CONFIG_WIFI_MGMT_EXT=y
    CONFIG_WIFI_CREDENTIALS=y
    # Shell
    CONFIG_SHELL=y
    CONFIG_SHELL_STACK_SIZE=6144
    # WPA supplicant
    CONFIG_WPA_SUPP=y
    CONFIG_WPA_SUPP_LOG_LEVEL_ERR=y
    # Zephyr NET Connection Manager connectivity layer
    CONFIG_L2_WIFI_CONNECTIVITY=y
    CONFIG_L2_WIFI_CONNECTIVITY_AUTO_DOWN=n
    CONFIG_L2_WIFI_CONNECTIVITY_AUTO_CONNECT=n
    # DNS
    CONFIG_DNS_RESOLVER=y
    CONFIG_NET_SOCKETS_DNS_TIMEOUT=30000
    # NET sockets
    CONFIG_NET_NATIVE=y
    CONFIG_NET_L2_ETHERNET=y
    CONFIG_NET_TCP=y
    CONFIG_NET_TCP_WORKQ_STACK_SIZE=2048
    CONFIG_NET_UDP=y
    CONFIG_NET_SOCKETS_OFFLOAD=n
    CONFIG_NET_DHCPV4=y
    CONFIG_NET_CONTEXT_SNDTIMEO=y
    # TLS networking
    CONFIG_NET_SOCKETS_ENABLE_DTLS=n
    CONFIG_NET_SOCKETS_TLS_MAX_CONTEXTS=2
    CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
    # TLS credentials
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    CONFIG_WIFI_CREDENTIALS_BACKEND_SETTINGS=y
    CONFIG_TLS_CREDENTIALS_BACKEND_VOLATILE=y
    # mbedTLS
    CONFIG_NRF_SECURITY=y
    CONFIG_MBEDTLS=y
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_HEAP_SIZE=81920
    CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY=y
    CONFIG_PSA_WANT_RSA_KEY_SIZE_2048=y
    CONFIG_MBEDTLS_RSA_C=y
    CONFIG_MBEDTLS_TLS_LIBRARY=y
    CONFIG_WIFI_CREDENTIALS_STATIC=y
    CONFIG_WIFI_CREDENTIALS_STATIC_SSID=""
    CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD=""
    CONFIG_PM_SINGLE_IMAGE=y
    I say "maybe" because I did not get to test it yet. I planned to but then Monday happened and I do not have access to a nRF7002DK until tomorrow.
  • Hi Sigurd, tomorrow I won't be able to, but Wednesday I will give this a try see how it goes.
  • Worked for me on nrf7002dk_nrf5340_cpuapp now. That is a good sign.
    Let me know how your test goes
  • The HTTPS_client sample also seems to work for me with the configs you provided Thumbsup
    I tried to use the HTTPS_client sample to connect to the server used by 'wififund_less5_exer2' (echo.thingy.rocks) with the certificate provided for that lesson (which we've been using in our tests) and I figured out that by null-terminating that certificate like shown on the HTTPS_client sample:
    I no longer get the EINVAL error code (22) - which makes sense since I previously did not understand why connect would be returning EINVAL: https://pubs.opengroup.org/onlinepubs/9699919799/functions/connect.html
    I still get an ECONNABORTED error (113) - which is not described on the connect() function, but seems to make more sense...
    I'll try to look a bit more into it later this week. If I can't manage to connect to 'echo.thingy.rocks' (nordic server) I'll use the server (example.com) and certificates from the HTTPS_client sample instead and see how that goes.
