Unexpected warning message: partition_manager.cmake says I do not use pm_static.yml, even though it is there.
I am using a nRF5340 with mcuboot and multiple customer-specific partitions.
I did not finish creating a separate board definition yet. Currently, we are using the nRF5340-DK board definition and remove development kit specific items while adding our components. Just for reference.
Concerning the partitions, I created pm_static.yml in out project's base directory (where src/, build/ and child_image/ directories also reside). The partition handling seemed to work in our main application.
When I perform a pristine build, I receive an error message, telling me that I would not use a static partition configuration (pm_static.yml). although it is there.
[{  "resource": "/c:/ncs/v2.5.2/nrf/cmake/partition_manager.cmake",
    "owner": "nrf-connect",
    "severity": 4,
    "message": "CMake Warning at C:/ncs/v2.5.2/nrf/cmake/partition_manager.cmake:79 (message):",
    "source": "cmake",
    "startLineNumber": 79,
    "startColumn": 1,
    "endLineNumber": 79,
    "endColumn": 2147483647
...and if I double-click on the message, I see this piece of code in partition_manager.cmake:
if (NOT static_configuration AND
  (CONFIG_BOOTLOADER_MCUBOOT OR CONFIG_SECURE_BOOT))
      message(WARNING "
        --- WARNING: Using a bootloader without pm_static.yml.            ---
        --- There are cases where a deployed product can consist of       ---
        --- multiple images, and only a subset of these images can be     ---
        --- upgraded through a firmware update mechanism. In such cases,  ---
        --- the upgradable images must have partitions that are static    ---
        --- and are matching the partition map used by the bootloader     ---
        --- programmed onto the device.                                   ---
        \n"
endif()
What went wrong here? Is my pm_static.yml applied successfully?
Michael
  • Hello Michael,
    Interesting. I added this warning, so I would very much like to figure out why it is wrong.
    Could you add the following in partition_manager.cmake, just before the if()?
    message("PUT A LOT OF STUFF HERE SO WE EASILY CAN FIND THIS IN THE LOGS AAAAAAAAAAAAAAAAAAAAAAAAAAAA")
    message("Static configuration: ${static_configuration}")
    message("CONFIG_BOOTLOADER_MCUBOOT: ${CONFIG_BOOTLOADER_MCUBOOT}")
    message("CONFIG_SECURE_BOOT: ${CONFIG_SECURE_BOOT}")
    Sigurd Hellesvik
  • This message shows 3 times. The last time its all good.
    CONFIG_SECURE_BOOT:
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users//Projects/Programing/nRF/build/hci_ipc/b0n
    === child image b0n - CPUNET (inherited) end ===
    CMake Warning at C:/ncs/v2.6.0/nrf/subsys/bootloader/cmake/debug_keys.cmake:36 (message):
    --- WARNING: Using generated NSIB public/private key-pair. ---
    --- It should not be used for production. ---
    --- See CONFIG_SB_SIGNING_KEY_FILE ---
    C:/ncs/v2.6.0/nrf/subsys/bootloader/cmake/provision_hex.cmake:47 (include)
    C:/ncs/v2.6.0/nrf/subsys/CMakeLists.txt:20 (include)
    -- libmetal version: 1.4.0 (C:/ncs/v2.6.0/zephyr/samples/bluetooth/hci_ipc)
    -- Build type:
    -- Host: Windows/AMD64
    -- Target: Generic/arm
    -- Machine: arm
    -- open-amp version: 1.4.0 (C:/ncs/v2.6.0/modules/lib/open-amp/open-amp)
    -- Machine: arm
    -- C_FLAGS : -Wall -Wextra
    CONFIG_SECURE_BOOT: y
    CMake Warning at C:/ncs/v2.6.0/nrf/cmake/partition_manager.cmake:85 (message):
    C:/ncs/v2.6.0/zephyr/cmake/modules/kernel.cmake:248 (include)
    C:/ncs/v2.6.0/zephyr/cmake/modules/zephyr_default.cmake:138 (include)
    C:/ncs/v2.6.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
    C:/ncs/v2.6.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
    CMakeLists.txt:5 (find_package)
    -- Configuring done
    -- Generating done
    CONFIG_SECURE_BOOT:
    MCUBoot bootloader key file: C:/Users/ivanr2/Desktop/Projects/Programing/nRF/private.key
    -- Configuring done
    -- Generating done
  • sorry, 4 times with the last one
    Static configuration: --static-config;C:/Users/ivanr2/Desktop/Projects/Programing/nRF/pm_static.yml
    CONFIG_BOOTLOADER_MCUBOOT: y
    CONFIG_SECURE_BOOT:
    Partition 'littlefs_storage' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
  • Ah, it is because the network core build does not know that static partitioning exists.
    I will see if I can figure out how to detect this
  • Hi Sigurd,
    sorry for the delay, I was very busy over the last weeks and just came back from a short holiday today.
    I also tried our your test code:
    CMake Warning at C:/ncs/v2.5.2/nrf/subsys/bootloader/cmake/debug_keys.cmake:36 (message):
      C:/ncs/v2.5.2/nrf/subsys/bootloader/cmake/provision_hex.cmake:47 (include)
      C:/ncs/v2.5.2/nrf/subsys/CMakeLists.txt:20 (include)
    -- libmetal version: 1.4.0 (C:/ncs/v2.5.2/zephyr/samples/bluetooth/hci_rpmsg)
    -- Build type:
    -- Machine: arm
    -- Looking for include file stdatomic.h
    -- Looking for include file stdatomic.h - found
    -- Machine: arm
    -- open-amp version: 1.4.0 (C:/ncs/v2.5.2/modules/lib/open-amp/open-amp)
    -- Looking for include file fcntl.h
    -- Looking for include file fcntl.h - found
    CMake Warning at C:/ncs/v2.5.2/nrf/cmake/partition_manager.cmake:84 (message):
      C:/ncs/v2.5.2/zephyr/cmake/modules/kernel.cmake:247 (include)
      C:/ncs/v2.5.2/zephyr/cmake/modules/zephyr_default.cmake:138 (include)
      C:/ncs/v2.5.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      C:/ncs/v2.5.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/my_project_dir/build/hci_rpmsg
    === child image hci_rpmsg - CPUNET end ===
    -- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    === child image mcuboot -  begin ===
    I wonder why secure boot is enabled in the debug output, and mcuboot is not enabled even though I use ist. I do not use TFM or non-secure code.
    This is my prj.conf:
    CONFIG_PRINTK=y
    CONFIG_ASSERT=y
    CONFIG_GPIO=y
    CONFIG_ZERO_LATENCY_IRQS=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    CONFIG_USB_DEVICE_STACK=y
    CONFIG_USB_DEVICE_PRODUCT="My Product"
    CONFIG_USB_DEVICE_MANUFACTURER="My Company"
    CONFIG_USB_DEVICE_SN="unknown"
    #CONFIG_USB_DEVICE_VID=0x2FE3
    CONFIG_USB_DEVICE_PID=0x0004
    CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=y
    CONFIG_SERIAL=y
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=y
    CONFIG_UART_LINE_CTRL=y
    CONFIG_BT=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_NAME="My Device"
    CONFIG_BT_HCI=y
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_BUILD_WITH_TFM=n
    CONFIG_MCUMGR=y
    CONFIG_MCUMGR_GRP_OS=y
    CONFIG_MCUMGR_GRP_IMG=y
    CONFIG_MCUMGR_TRANSPORT_UART=y
    # Configure dependencies for mcumgr
    CONFIG_NET_BUF=y
    CONFIG_ZCBOR=y
    CONFIG_FLASH=y
    CONFIG_IMG_MANAGER=y
    CONFIG_STREAM_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_BASE64=y
    Michael
