Unexpected warning message: partition_manager.cmake says I do not use pm_static.yml, even though it is there.
I am using a nRF5340 with mcuboot and multiple customer-specific partitions.
I did not finish creating a separate board definition yet. Currently, we are using the nRF5340-DK board definition and remove development kit specific items while adding our components. Just for reference.
Concerning the partitions, I created pm_static.yml in out project's base directory (where src/, build/ and child_image/ directories also reside). The partition handling seemed to work in our main application.
When I perform a pristine build, I receive an error message, telling me that I would not use a static partition configuration (pm_static.yml). although it is there.
[{  "resource": "/c:/ncs/v2.5.2/nrf/cmake/partition_manager.cmake",
    "owner": "nrf-connect",
    "severity": 4,
    "message": "CMake Warning at C:/ncs/v2.5.2/nrf/cmake/partition_manager.cmake:79 (message):",
    "source": "cmake",
    "startLineNumber": 79,
    "startColumn": 1,
    "endLineNumber": 79,
    "endColumn": 2147483647
...and if I double-click on the message, I see this piece of code in partition_manager.cmake:
if (NOT static_configuration AND
  (CONFIG_BOOTLOADER_MCUBOOT OR CONFIG_SECURE_BOOT))
      message(WARNING "
        --- WARNING: Using a bootloader without pm_static.yml.            ---
        --- There are cases where a deployed product can consist of       ---
        --- multiple images, and only a subset of these images can be     ---
        --- upgraded through a firmware update mechanism. In such cases,  ---
        --- the upgradable images must have partitions that are static    ---
        --- and are matching the partition map used by the bootloader     ---
        --- programmed onto the device.                                   ---
        \n"
endif()
What went wrong here? Is my pm_static.yml applied successfully?
Michael
  • puz_md said:
    With "production ready", I meant that the SDK version is stable and approved for shipping products to our customers based on this SDK version. We plan do deliver first samples to our customers in a couple of weeks and the software should be upgradeable, which means that at least the basic bootloader and partitioning framework should work reliably. I'm getting a bit cold feet right now...
    In this case I think I would recommend to stay at your current NCS version for now.
    Bootloader and DFU functionality will in the end be the same for both versions, so as you say: When you got working DFU now, you could always update NCS version later.
    puz_md said:
    If I understand your words correctly, this means that the net core also uses different partitions, even if we don't use dual slots there?
    Yes, the network core also have a partitioning layout:
    puz_md said:
    I assumed b0n would have a defined size, and all the remaining net core flash would be used for the net core application
    Set here, so as you see it is configurable.
    We could also technically change it on our side, although I think Nordic will strive to never do that. But you should make sure that even in an unlikely even of something like that, your project will not be impacted.
    puz_md said:
    1. You say I should add pm_static.yml to the net core. But my pm_static.yml does not define any memory space in the net core memory region, but only the slots for mcuboot and some reserved / customer specific regions in the app core's flash memory. If I remember correctly, my pm_static.yml is based on the automatically generated partitioning file, just like described in the tutorials. So, what exactly should be the content of the pm_static.yml for the net core?
    You will have two pm_static.yml files. I will list them as "COPY FROM -> COPY TO"
    • build/partitions.yml -> project/pm_static.yml
    • build/hci_rpmsg/partitions_CPUNET.yml -> ncs/zephyr/samples/bluetooth/hci_rpmsg/pm_static.yml
    puz_md said:
    2. You suggested to add pm_static.yml to ncs/zephyr/samples/bluetooth/hci_ipc/ - does this mean that when I enable Bluetooth in prj.conf, the build system compiles this sample (!!!) into my code?
    Yes. Either hci_ipc (v2.6.x and above) or hci_rpmsg (v2.5.x and lower), or potentially others. See nRF5340: Multi-image builds
    Also from build log:
    puz_md said:
    3. Can I also place the pm_static.yml into a subdirectory in my project directory, so that I don't have to modify the toolchain directory? e.g. <proj-dir>/child_image/pm_static_hci_ipc.yml or something like this?
    Unfortunally, no. Not yet.
    This will be a feature in v2.7.0 with sysbuild, but I recommend that you set it in the NCS manually first, since you say you are low on time.
    Then you can make it pretty later.
    In the end:
    If you save your whole build folder of the version you program to devices in the release, and make sure to thoroughly test an update in the lab before sending it over DFU to devices in the field, you should not get any issues with partitioning that you cannot fix later.
    Btw, do you use external flash? (I will explain why this is a bit relevant based on your answer)
  • I've put the following in CMakeLists.txt to get it working:
    # Set signature key for application core bootloader (MCUBoot)
    set(mcuboot_CONFIG_BOOT_SIGNATURE_KEY_FILE \"${CMAKE_CURRENT_SOURCE_DIR}/keys/mcuboot-private-ecdsa-p256.pem\")
    # Set signature key for network core bootloader (B0n)
    set(hci_ipc_CONFIG_SB_SIGNING_KEY_FILE \"${CMAKE_CURRENT_SOURCE_DIR}/keys/b0n-private-ecdsa-p256.pem\")
    # Set static partition manager configuration for application core
    set(PM_STATIC_YML_FILE ${CMAKE_CURRENT_SOURCE_DIR}/configuration/${BOARD}/pm_static_cpuapp.yml)
    # Set static partition manager configuration for network core
    set(hci_ipc_PM_STATIC_YML_FILE ${CMAKE_CURRENT_SOURCE_DIR}/configuration/${BOARD}/pm_static_cpunet.yml)
  • Sigurd,
    I have been working through this warning, and your suggestion of copying the file from build/hci_rpmsg/partitions_CPUNET.yml to ncs/zephyr/samples/bluetooth/hci_rpmsg/pm_static.yml does resolve the warning.
    I am using external flash and am curious as to what you were planning on explaining above.
    Thank you.
  • It is 4 months since I wrote that, so unfortunately I can no longer remember what my point was
  • Hi, let me summarize how I resolved the issue on my side:
    1. SDK v2.5.3 via multi-image build
    The only solution was to put a pm_static.yml file directly into the net core sample's directory (e.g. C:\ncs\v2.5.3\zephyr\samples\bluetooth\hci_rpmsg\pm_static.yml). This is kind of dirty because the static partitioning will be used by all projects compiled on this computer. Further, there is a risk if someone else pulls the project from the repository and forgets to update their SDK directory with the pm_static-yml, the code will link to the wrong location.
    2. SDK v2.9.0 via sysbuild
    Create the following line(s) in sysbuild.cmake in your project directory. It will use pm_static_NETCORE in your project directory as the net core's static partitioning file.
    set(hci_ipc_PM_STATIC_YML_FILE ${APPLICATION_CONFIG_DIR}/pm_static_CPUNET.yml CACHE INTERNAL "" FORCE)
    message(STATUS "sysbuild.cmake - hci_ipc_PM_STATIC_YML_FILE: ${hci_ipc_PM_STATIC_YML_FILE}")
    Further, there is a bug in the SDK that must be fixed for the lines mentioned above to work as expected: Go to C:\ncs\v2.9.0\nrf\cmake\sysbuild\partition_manager.cmake, line 126, and comment out the following instruction with a hashtag:
    #set(static_configuration)
    So there is still a bug in the SDK that would come with some risk in multi-developer teams and for filed projects, but the fix is not application-specific anymore (you can use the same fix with multiple projects that use different net core partitioning). I hope it will be included in the SDK soon. Please mind that it is not included in recend SDK v2.9.1 yet!
    Net core update problems on SDK v2.9.0 via sysbuild
    You may also want to check out my other ticket here which describes a bug in mcuboot when trying to update the net core with SDK v2.9.0 (and most likely 2.9.1).
    Good luck with your projects!
    Michael
