I have discovered a bug in the fota_download.c file contained in the SDK. I am attempting to cancel the FOTA update separately within my application code, and it goes through most of the time, however I am running into an edge case that causes the thread calling this function to be stuck in a while loop for the duration of the FOTA update. I have investigated and root caused this issue, and it seems to be caused by the resume flag being set right before I call the cancel in my application code. Since the download_with_offset function is scheduled 1s in the future, if I attempt to cancel in this 1s window it leads to the device getting stuck in this loop. This is because the fota_download_cancel assumes that the cancel goes through and waits forever for the downloading flag to be cleared. However, if the resume flag is set, the download handler doesn't call the stopped() function in which the downloading flag is cleared.
As there is no access within the application to check the flags, I don't see a clear workaround for this issue. Pls provide any feedback on how this can be dealt with
Aman
