BLE OTA DFU using external flash
I'm using the NCS 2.5.2 sdk and nrf 5340 with 7002, and I want to do BLE OTA DFU using external flash.
I've found this guide Add DFU support to your application - Software - nRF Connect SDK guides - Nordic DevZone (nordicsemi.com), and successfully  done BLE OTA DFU using internal flash, just add the commands below,
#Enable MCUBOOT bootloader build in the application
CONFIG_BOOTLOADER_MCUBOOT=y
#Include MCUMGR and the dependencies in the build
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
but I don't know how to do with external flash, I've tried looking at main.c in mcuboot, and I didn't find where to modify the code.
  • now I know what's the problem.
    when only add config_bt, it said missing dependencies config_bt_peripheral, so it didn't add config_bt_ota then build success.
    but when add config_bt_ota successfully, then build error.
    so why the errors occur?
    12/296] Generating include/generated/version.h
    -- Zephyr version: 3.4.99 (C:/ncs/v2.5.2/zephyr), build: 4b5ef270413a
    [84/296] Building C object CMakeFiles/app.dir/src/main.c.obj
    ../src/main.c:23:1: warning: multi-line comment [-Wcomment]
       23 | // #define advertising_parameter BT_LE_ADV_PARAM(BT_LE_ADV_OPT_CONNECTABLE | \
    [97/296] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/nrf_qspi_nor.c.obj
    FAILED: zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/nrf_qspi_nor.c.obj
    C:\ncs\toolchains\c57af46cb7\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPICOLIBC_INTEGER_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -IC:/ncs/v2.5.2/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.5.2/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/ncs/v2.5.2/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.5.2/zephyr/subsys/mgmt/mcumgr/util/include -IC:/ncs/v2.5.2/bootloader/mcuboot/boot/bootutil/include -IC:/ncs/v2.5.2/zephyr/subsys/mgmt/mcumgr/transport/include -IC:/ncs/v2.5.2/bootloader/mcuboot/boot/zephyr/include -IC:/ncs/v2.5.2/zephyr/subsys/bluetooth -IC:/ncs/v2.5.2/nrf/include -IC:/ncs/v2.5.2/nrf/tests/include -IC:/ncs/v2.5.2/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.5.2/zephyr/modules/cmsis/. -IC:/ncs/v2.5.2/modules/hal/nordic/nrfx -IC:/ncs/v2.5.2/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.5.2/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.5.2/zephyr/modules/hal_nordic/nrfx/. -Imodules/libmetal/libmetal/lib/include -IC:/ncs/v2.5.2/modules/lib/open-amp/open-amp/lib/include -IC:/ncs/v2.5.2/modules/debug/segger/SEGGER -IC:/ncs/v2.5.2/modules/debug/segger/Config -IC:/ncs/v2.5.2/modules/crypto/tinycrypt/lib/include -IC:/ncs/v2.5.2/modules/lib/zcbor/include -IC:/ncs/v2.5.2/nrfxlib/softdevice_controller/include -isystem C:/ncs/v2.5.2/nrfxlib/crypto/nrf_cc312_platform/include -Wshadow -fno-strict-aliasing -Os -imacros C:/nordic20240328/hello_world_1/build_8/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.5.2/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/nordic20240328/hello_world_1=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.5.2/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.5.2=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/nrf_qspi_nor.c.obj -MF zephyr\drivers\flash\CMakeFiles\drivers__flash.dir\nrf_qspi_nor.c.obj.d -o zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/nrf_qspi_nor.c.obj -c C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:69:2: error: #error "No size specified. 'size' or 'size-in-bytes' must be set"
       69 | #error "No size specified. 'size' or 'size-in-bytes' must be set"
    In file included from C:/ncs/v2.5.2/zephyr/include/zephyr/toolchain.h:50,
                     from C:/ncs/v2.5.2/zephyr/include/zephyr/sys/time_units.h:10,
                     from C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util.h:615,
                     from C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:25,
                     from C:/ncs/v2.5.2/zephyr/include/zephyr/device.h:12,
                     from C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/flash.h:28,
                     from C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:10:
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: expected ')' before 'DT_N_INST_0_nordic_qspi_nor_PATH'
      333 | #define DT_INST(inst, compat) UTIL_CAT(DT_N_INST, DT_DASH(inst, compat))
    C:/ncs/v2.5.2/zephyr/include/zephyr/toolchain/gcc.h:81:60: note: in definition of macro 'BUILD_ASSERT'
       81 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:495:31: note: in expansion of macro 'DT_CAT'
      495 | #define DT_NODE_PATH(node_id) DT_CAT(node_id, _PATH)
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:73:22: note: in expansion of macro 'DT_NODE_PATH'
       73 |              "Node " DT_NODE_PATH(DT_DRV_INST(0)) " has both size and size-in-bytes "
    C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util_internal.h:104:26: note: in expansion of macro 'UTIL_PRIMITIVE_CAT'
      104 | #define UTIL_CAT(a, ...) UTIL_PRIMITIVE_CAT(a, __VA_ARGS__)
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:31: note: in expansion of macro 'UTIL_CAT'
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:3248:27: note: in expansion of macro 'DT_INST'
     3248 | #define DT_DRV_INST(inst) DT_INST(inst, DT_DRV_COMPAT)
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:73:35: note: in expansion of macro 'DT_DRV_INST'
    C:/ncs/v2.5.2/zephyr/include/zephyr/toolchain/gcc.h:81:50: note: to match this '('
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:72:1: note: in expansion of macro 'BUILD_ASSERT'
       72 | BUILD_ASSERT(!(DT_INST_NODE_HAS_PROP(0, size_in_bytes) && DT_INST_NODE_HAS_PROP(0, size)),
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: 'DT_N_INST_0_nordic_qspi_nor_P_sck_frequency' undeclared here (not in a function)
    C:/ncs/v2.5.2/zephyr/include/zephyr/toolchain/gcc.h:81:51: note: in definition of macro 'BUILD_ASSERT'
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:614:32: note: in expansion of macro 'DT_CAT3'
      614 | #define DT_PROP(node_id, prop) DT_CAT3(node_id, _P_, prop)
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:3450:34: note: in expansion of macro 'DT_PROP'
     3450 | #define DT_INST_PROP(inst, prop) DT_PROP(DT_DRV_INST(inst), prop)
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:3450:42: note: in expansion of macro 'DT_DRV_INST'
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:77:30: note: in expansion of macro 'DT_INST_PROP'
       77 | #define INST_0_SCK_FREQUENCY DT_INST_PROP(0, sck_frequency)
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:82:14: note: in expansion of macro 'INST_0_SCK_FREQUENCY'
       82 | BUILD_ASSERT(INST_0_SCK_FREQUENCY >= (NRF_QSPI_BASE_CLOCK_FREQ / 16),
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: expression in static assertion is not an integer
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: 'DT_N_INST_0_nordic_qspi_nor_P_cpol' undeclared here (not in a function); did you mean 'DT_N_INST_0_nordic_mbox_nrf_ipc'?
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:136:14: note: in expansion of macro 'DT_INST_PROP'
      136 | BUILD_ASSERT(DT_INST_PROP(0, cpol) == DT_INST_PROP(0, cpha),
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: 'DT_N_INST_0_nordic_qspi_nor_P_cpha' undeclared here (not in a function); did you mean 'DT_N_INST_0_nordic_mbox_nrf_ipc'?
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:136:39: note: in expansion of macro 'DT_INST_PROP'
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:144:28: error: 'JESD216_DW15_QER_VAL_DT_N_INST_0_nordic_qspi_nor_P_quad_enable_requirements_STRING_TOKEN' undeclared here (not in a function)
      144 | #define INST_0_QER _CONCAT(JESD216_DW15_QER_VAL_, \
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:160:15: note: in expansion of macro 'IS_EQUAL'
      160 | BUILD_ASSERT((IS_EQUAL(INST_0_QER, JESD216_DW15_QER_VAL_NONE)
    C:/ncs/v2.5.2/zephyr/include/zephyr/toolchain/common.h:133:23: note: in expansion of macro '_DO_CONCAT'
      133 | #define _CONCAT(x, y) _DO_CONCAT(x, y)
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:144:20: note: in expansion of macro '_CONCAT'
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:160:24: note: in expansion of macro 'INST_0_QER'
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:160:14: error: expression in static assertion is not an integer
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c: In function 'qspi_nor_init':
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: 'DT_N_INST_0_nordic_qspi_nor_BUS_IRQ_IDX_0_VAL_priority' undeclared (first use in this function)
    C:/ncs/v2.5.2/zephyr/include/zephyr/arch/arm/aarch32/irq.h:128:9: note: in expansion of macro '_CHECK_PRIO'
      128 |         _CHECK_PRIO(priority_p, flags_p) \
    C:/ncs/v2.5.2/zephyr/include/zephyr/irq.h:49:9: note: in expansion of macro 'ARCH_IRQ_CONNECT'
       49 |         ARCH_IRQ_CONNECT(irq_p, priority_p, isr_p, isr_param_p, flags_p)
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1242:9: note: in expansion of macro 'IRQ_CONNECT'
     1242 |         IRQ_CONNECT(DT_IRQN(QSPI_NODE), DT_IRQ(QSPI_NODE, priority),
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:2383:9: note: in expansion of macro 'DT_CAT5'
     2383 |         DT_CAT5(node_id, _IRQ_IDX_, idx, _VAL_, cell)
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:2410:31: note: in expansion of macro 'DT_IRQ_BY_IDX'
     2410 | #define DT_IRQ(node_id, cell) DT_IRQ_BY_IDX(node_id, 0, cell)
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1242:41: note: in expansion of macro 'DT_IRQ'
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:3190:25: note: in expansion of macro 'DT_CAT'
     3190 | #define DT_BUS(node_id) DT_CAT(node_id, _BUS)
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:3836:27: note: in expansion of macro 'DT_BUS'
     3836 | #define DT_INST_BUS(inst) DT_BUS(DT_DRV_INST(inst))
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:3836:34: note: in expansion of macro 'DT_DRV_INST'
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:140:19: note: in expansion of macro 'DT_INST_BUS'
      140 | #define QSPI_NODE DT_INST_BUS(0)
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1242:48: note: in expansion of macro 'QSPI_NODE'
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: note: each undeclared identifier is reported only once for each function it appears in
    C:/ncs/v2.5.2/zephyr/include/zephyr/arch/arm/aarch32/irq.h:105:22: error: expression in static assertion is not an integer
      105 |         BUILD_ASSERT(((flags_p & IRQ_ZERO_LATENCY) && \
    In file included from C:/ncs/v2.5.2/zephyr/include/zephyr/arch/arm/aarch32/irq.h:19,
                     from C:/ncs/v2.5.2/zephyr/include/zephyr/arch/arm/aarch32/arch.h:27,
                     from C:/ncs/v2.5.2/zephyr/include/zephyr/arch/cpu.h:19,
                     from C:/ncs/v2.5.2/zephyr/include/zephyr/kernel_includes.h:33,
                     from C:/ncs/v2.5.2/zephyr/include/zephyr/kernel.h:17,
                     from C:/ncs/v2.5.2/zephyr/include/zephyr/pm/device.h:11,
                     from C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:12:
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: 'DT_N_INST_0_nordic_qspi_nor_BUS_IRQ_IDX_0_VAL_irq' undeclared (first use in this function)
    C:/ncs/v2.5.2/zephyr/include/zephyr/sw_isr_table.h:77:26: note: in definition of macro 'Z_ISR_DECLARE'
       77 |                         {irq, flags, (void *)&func, (const void *)param}
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:2422:26: note: in expansion of macro 'DT_IRQ'
     2422 | #define DT_IRQN(node_id) DT_IRQ(node_id, irq)
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1242:21: note: in expansion of macro 'DT_IRQN'
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1242:29: note: in expansion of macro 'QSPI_NODE'
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c: At top level:
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1262:29: error: 'INST_0_BYTES' undeclared here (not in a function); did you mean 'INST_0_QER'?
     1262 | #define LAYOUT_PAGES_COUNT (INST_0_BYTES / \
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1266:15: note: in expansion of macro 'LAYOUT_PAGES_COUNT'
     1266 |               LAYOUT_PAGES_COUNT)
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1265:14: error: expression in static assertion is not an integer
     1265 | BUILD_ASSERT((CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE *
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: expected ')' before 'DT_N_INST_0_nordic_qspi_nor_BUS_PATH'
    c:\ncs\v2.5.2\zephyr\soc\arm\nordic_nrf\common\soc_nrf_common.h:191:22: note: in expansion of macro 'DT_NODE_PATH'
      191 |                      DT_NODE_PATH(node_id) " defined without sleep state")
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1492:1: note: in expansion of macro 'NRF_DT_CHECK_NODE_HAS_PINCTRL_SLEEP'
     1492 | NRF_DT_CHECK_NODE_HAS_PINCTRL_SLEEP(QSPI_NODE);
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1492:37: note: in expansion of macro 'QSPI_NODE'
    c:\ncs\v2.5.2\zephyr\soc\arm\nordic_nrf\common\soc_nrf_common.h:189:9: note: in expansion of macro 'BUILD_ASSERT'
      189 |         BUILD_ASSERT(!IS_ENABLED(CONFIG_PM_DEVICE) ||                          \
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\nordic20240328\hello_world_1\build_8'
    In file included from C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util.h:17:
    C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/pinctrl.h:241:51: error: expected ')' before '(' token
      241 |                      Z_PINCTRL_STATE_PINS_DEFINE, (;), node_id);               \
    C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util_macro.h:418:69: note: in definition of macro 'LISTIFY'
      418 | #define LISTIFY(LEN, F, sep, ...) UTIL_CAT(Z_UTIL_LISTIFY_, LEN)(F, sep, __VA_ARGS__)
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1494:1: note: in expansion of macro 'PINCTRL_DT_DEFINE'
     1494 | PINCTRL_DT_DEFINE(QSPI_NODE);
    In file included from C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util_macro.h:34:
    C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util_macro.h:418:44: warning: implicit declaration of function 'Z_UTIL_LISTIFY_DT_N_INST_0_nordic_qspi_nor_BUS_PINCTRL_NUM' [-Wimplicit-function-declaration]
    C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util_internal.h:105:36: note: in definition of macro 'UTIL_PRIMITIVE_CAT'
      105 | #define UTIL_PRIMITIVE_CAT(a, ...) a##__VA_ARGS__
    C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util_macro.h:418:35: note: in expansion of macro 'UTIL_CAT'
    C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/pinctrl.h:172:17: note: in expansion of macro 'LISTIFY'
      172 |                 LISTIFY(DT_NUM_PINCTRL_STATES(node_id),                        \
    C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/pinctrl.h:242:9: note: in expansion of macro 'Z_PINCTRL_STATES_DEFINE'
      242 |         Z_PINCTRL_STATES_DEFINE(node_id)                                       \
    C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/pinctrl.h:173:30: error: 'Z_PINCTRL_STATE_INIT' undeclared here (not in a function)
      173 |                              Z_PINCTRL_STATE_INIT, (,), node_id)               \
    C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util_macro.h:418:66: note: in definition of macro 'LISTIFY'
    C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/pinctrl.h:173:53: error: expected expression before ',' token
    C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/pinctrl.h:173:53: warning: left-hand operand of comma expression has no effect [-Wunused-value]
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: 'DT_N_INST_0_nordic_qspi_nor_BUS' undeclared here (not in a function); did you mean 'DT_N_INST_0_nordic_mbox_nrf_ipc'?
    C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util_macro.h:418:74: note: in definition of macro 'LISTIFY'
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1494:19: note: in expansion of macro 'QSPI_NODE'
    In file included from C:/ncs/v2.5.2/zephyr/include/zephyr/toolchain/gcc.h:92:
    C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/pinctrl.h:101:17: error: '__pinctrl_dev_config__device_dts_ord_DT_N_INST_0_nordic_qspi_nor_BUS_ORD' undeclared here (not in a function); did you mean '__pinctrl_states__device_dts_ord_DT_N_INST_0_nordic_qspi_nor_BUS_ORD'?
      101 |         _CONCAT(__pinctrl_dev_config, DEVICE_DT_NAME_GET(node_id))
    C:/ncs/v2.5.2/zephyr/include/zephyr/toolchain/common.h:132:26: note: in definition of macro '_DO_CONCAT'
      132 | #define _DO_CONCAT(x, y) x ## y
    C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/pinctrl.h:101:9: note: in expansion of macro '_CONCAT'
    C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/pinctrl.h:262:45: note: in expansion of macro 'Z_PINCTRL_DEV_CONFIG_NAME'
      262 | #define PINCTRL_DT_DEV_CONFIG_GET(node_id) &Z_PINCTRL_DEV_CONFIG_NAME(node_id)
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1499:17: note: in expansion of macro 'PINCTRL_DT_DEV_CONFIG_GET'
     1499 |         .pcfg = PINCTRL_DT_DEV_CONFIG_GET(QSPI_NODE),
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: 'DT_N_INST_0_nordic_qspi_nor_P_address_size_32' undeclared here (not in a function)
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:4231:29: note: in definition of macro 'DT_CAT3'
     4231 | #define DT_CAT3(a1, a2, a3) a1 ## a2 ## a3
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1511:29: note: in expansion of macro 'DT_INST_PROP'
     1511 |                 .addrmode = DT_INST_PROP(0, address_size_32)
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: 'DT_N_INST_0_nordic_qspi_nor_P_sck_delay' undeclared here (not in a function)
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1517:30: note: in expansion of macro 'DT_INST_PROP'
     1517 |                 .sck_delay = DT_INST_PROP(0, sck_delay),
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: 'DT_N_INST_0_nordic_qspi_nor_P_jedec_id' undeclared here (not in a function); did you mean 'DT_N_INST_0_nordic_nrf_qdec'?
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1522:15: note: in expansion of macro 'DT_INST_PROP'
     1522 |         .id = DT_INST_PROP(0, jedec_id),
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:333:40: error: 'DT_N_INST_0_nordic_qspi_nor_FULL_NAME' undeclared here (not in a function)
    C:/ncs/v2.5.2/zephyr/include/zephyr/device.h:892:25: note: in definition of macro 'Z_DEVICE_INIT'
      892 |                 .name = name_,                                                 \
    C:/ncs/v2.5.2/zephyr/include/zephyr/device.h:981:9: note: in expansion of macro 'Z_DEVICE_BASE_DEFINE'
      981 |         Z_DEVICE_BASE_DEFINE(node_id, dev_id, name, pm, data, config, level,   \
    C:/ncs/v2.5.2/zephyr/include/zephyr/device.h:180:9: note: in expansion of macro 'Z_DEVICE_DEFINE'
      180 |         Z_DEVICE_DEFINE(node_id, Z_DEVICE_DT_DEV_ID(node_id),                  \
    C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util_internal.h:69:53: note: in expansion of macro '__DEBRACKET'
       69 | #define __GET_ARG2_DEBRACKET(ignore_this, val, ...) __DEBRACKET val
    C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET'
       64 |         __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code)
    C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE'
       59 |         __COND_CODE(_XXXX##_flag, _if_1_code, _else_code)
    C:/ncs/v2.5.2/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1'
      180 |         Z_COND_CODE_1(_flag, _if_1_code, _else_code)
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:777:9: note: in expansion of macro 'COND_CODE_1'
      777 |         COND_CODE_1(DT_NODE_HAS_PROP(node_id, prop), \
    C:/ncs/v2.5.2/zephyr/include/zephyr/device.h:146:9: note: in expansion of macro 'DT_PROP_OR'
      146 |         DT_PROP_OR(node_id, label, DT_NODE_FULL_NAME(node_id))
    C:/ncs/v2.5.2/zephyr/include/zephyr/devicetree.h:521:36: note: in expansion of macro 'DT_CAT'
      521 | #define DT_NODE_FULL_NAME(node_id) DT_CAT(node_id, _FULL_NAME)
    C:/ncs/v2.5.2/zephyr/include/zephyr/device.h:146:36: note: in expansion of macro 'DT_NODE_FULL_NAME'
    C:/ncs/v2.5.2/zephyr/include/zephyr/device.h:181:25: note: in expansion of macro 'DEVICE_DT_NAME'
      181 |                         DEVICE_DT_NAME(node_id), init_fn, pm, data, config,    \
    C:/ncs/v2.5.2/zephyr/include/zephyr/device.h:195:9: note: in expansion of macro 'DEVICE_DT_DEFINE'
      195 |         DEVICE_DT_DEFINE(DT_DRV_INST(inst), __VA_ARGS__)
    C:/ncs/v2.5.2/zephyr/include/zephyr/device.h:195:26: note: in expansion of macro 'DT_DRV_INST'
    C:/ncs/v2.5.2/zephyr/drivers/flash/nrf_qspi_nor.c:1527:1: note: in expansion of macro 'DEVICE_DT_INST_DEFINE'
     1527 | DEVICE_DT_INST_DEFINE(0, qspi_nor_init, PM_DEVICE_DT_INST_GET(0),
    C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/pinctrl.h:110:17: warning: '__pinctrl_states__device_dts_ord_DT_N_INST_0_nordic_qspi_nor_BUS_ORD' defined but not used [-Wunused-const-variable=]
      110 |         _CONCAT(__pinctrl_states, DEVICE_DT_NAME_GET(node_id))
    C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/pinctrl.h:110:9: note: in expansion of macro '_CONCAT'
    C:/ncs/v2.5.2/zephyr/include/zephyr/drivers/pinctrl.h:171:9: note: in expansion of macro 'Z_PINCTRL_STATES_NAME'
      171 |         Z_PINCTRL_STATES_NAME(node_id)[] = {                                   \
    and config_spi_nor has some problem,
    is it the reason of the error?
    Have you set up external flash in DTS?
