I have a lis3dh sensor where I want to configure the interrupts. I am currently struggling to extract the information from the irq-gpios phandle to the c driver. I went through the troubleshooting page for the device tree and found a website explanation that said it should work, but I am still unable to compile the code.
I have a overlay define like this:
&i2c0 {
mysensor: mysensor@18{
compatible = "st,lis3dh";
status = "okay";
reg = < 0x18 >;
irq-gpios = <&gpio0 11 GPIO_ACTIVE_HIGH>, <&gpio1 4 GPIO_ACTIVE_HIGH>;
My driver tries to extract the data gpio information like this:
#define I2C1_NODE DT_NODELABEL(mysensor)
static const struct i2c_dt_spec dev_i2c = I2C_DT_SPEC_GET(I2C1_NODE);
//const struct gpio_dt_spec int1 = DT_IRQN_BY_IDX(DT_NODELABEL(mysensor), 0);
//const struct gpio_dt_spec int1 = GPIO_DT_SPEC_INST_GET_BY_IDX_COND(DT_NODELABEL(mysensor), irq_gpios, 0);
//const struct gpio_dt_spec int1 = GPIO_DT_SPEC_INST_GET_BY_IDX_OR(DT_NODELABEL(mysensor), irq_gpios, 0, {});
//const struct gpio_dt_spec int1 = DT_GPIO_CTLR_BY_IDX(I2C1_NODE, irq_gpios, 0);
I have received an error like this:
[50/149] Building C object CMakeFiles/app.dir/src/lis3dh/lis3dh.c.obj
FAILED: CMakeFiles/app.dir/src/lis3dh/lis3dh.c.obj
C:\ncs\toolchains\cf2149caf2\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF52840_XXAA -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.6.0/zephyr/include -IC:/nordic_play_workfolder/LIS3DH/build_nrf52840_dk/zephyr/include/generated -IC:/ncs/v2.6.0/zephyr/soc/arm/nordic_nrf/nrf52 -IC:/ncs/v2.6.0/zephyr/lib/libc/newlib/include -IC:/ncs/v2.6.0/zephyr/soc/common/nordic_nrf/. -IC:/ncs/v2.6.0/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.6.0/nrf/include -IC:/ncs/v2.6.0/nrf/tests/include -IC:/ncs/v2.6.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.6.0/zephyr/modules/cmsis/. -IC:/ncs/v2.6.0/modules/hal/nordic/nrfx -IC:/ncs/v2.6.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.6.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.6.0/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.6.0/modules/debug/segger/SEGGER -IC:/ncs/v2.6.0/modules/debug/segger/Config -IC:/ncs/v2.6.0/modules/debug/segger/SEGGER/DebugMon/include -isystem C:/ncs/v2.6.0/zephyr/lib/libc/common/include -isystem C:/ncs/v2.6.0/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Og -imacros C:/nordic_play_workfolder/LIS3DH/build_nrf52840_dk/zephyr/include/generated/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.6.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/nordic_play_workfolder/LIS3DH=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.6.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.6.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT CMakeFiles/app.dir/src/lis3dh/lis3dh.c.obj -MF CMakeFiles\app.dir\src\lis3dh\lis3dh.c.obj.d -o CMakeFiles/app.dir/src/lis3dh/lis3dh.c.obj -c C:/nordic_play_workfolder/LIS3DH/src/lis3dh/lis3dh.c
In file included from C:/ncs/v2.6.0/zephyr/include/zephyr/devicetree.h:19,
from C:/ncs/v2.6.0/zephyr/include/zephyr/arch/arm/arch.h:20,
from C:/ncs/v2.6.0/zephyr/include/zephyr/arch/cpu.h:19,
from C:/ncs/v2.6.0/zephyr/include/zephyr/kernel_includes.h:37,
from C:/ncs/v2.6.0/zephyr/include/zephyr/kernel.h:17,
from C:/nordic_play_workfolder/LIS3DH/src/lis3dh/lis3dh.c:1:
C:/nordic_play_workfolder/LIS3DH/build_nrf52840_dk/zephyr/include/generated/devicetree_generated.h:13569:70: error: 'DT_N_S_soc_S_gpio_50000000' undeclared here (not in a function); did you mean 'DT_N_S_soc_S_gpio_50000000_ORD'?
13569 | #define DT_N_S_soc_S_i2c_40003000_S_mysensor_18_P_irq_gpios_IDX_0_PH DT_N_S_soc_S_gpio_50000000
C:/ncs/v2.6.0/zephyr/include/zephyr/devicetree.h:4349:41: note: in expansion of macro 'DT_N_S_soc_S_i2c_40003000_S_mysensor_18_P_irq_gpios_IDX_0_PH'
4349 | #define DT_CAT6(a1, a2, a3, a4, a5, a6) a1 ## a2 ## a3 ## a4 ## a5 ## a6
C:/ncs/v2.6.0/zephyr/include/zephyr/devicetree.h:1592:9: note: in expansion of macro 'DT_CAT6'
1592 | DT_CAT6(node_id, _P_, prop, _IDX_, idx, _PH)
C:/ncs/v2.6.0/zephyr/include/zephyr/devicetree/gpio.h:54:9: note: in expansion of macro 'DT_PHANDLE_BY_IDX'
54 | DT_PHANDLE_BY_IDX(node_id, gpio_pha, idx)
C:/nordic_play_workfolder/LIS3DH/src/lis3dh/lis3dh.c:54:34: note: in expansion of macro 'DT_GPIO_CTLR_BY_IDX'
54 | const struct gpio_dt_spec int1 = DT_GPIO_CTLR_BY_IDX(I2C1_NODE, irq_gpios, 0);
C:/ncs/v2.6.0/zephyr/include/zephyr/devicetree.h:4341:24: note: in expansion of macro 'DT_N_NODELABEL_mysensor'
4341 | #define DT_CAT(a1, a2) a1 ## a2
C:/ncs/v2.6.0/zephyr/include/zephyr/devicetree.h:198:29: note: in expansion of macro 'DT_CAT'
198 | #define DT_NODELABEL(label) DT_CAT(DT_N_NODELABEL_, label)
C:/nordic_play_workfolder/LIS3DH/src/lis3dh/lis3dh.c:44:19: note: in expansion of macro 'DT_NODELABEL'
44 | #define I2C1_NODE DT_NODELABEL(mysensor)
C:/nordic_play_workfolder/LIS3DH/src/lis3dh/lis3dh.c:54:54: note: in expansion of macro 'I2C1_NODE'
C:/nordic_play_workfolder/LIS3DH/src/lis3dh/lis3dh.c:69:27: error: redefinition of 'int1'
69 | const struct gpio_dt_spec int1 ={
C:/nordic_play_workfolder/LIS3DH/src/lis3dh/lis3dh.c:54:27: note: previous definition of 'int1' with type 'const struct gpio_dt_spec'
[63/149] Linking C static library zephyr\arch\arch\arm\core\cortex_m\libarch__arm__core__cortex_m.a
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\cf2149caf2\opt\bin\cmake.EXE' --build 'c:\nordic_play_workfolder\LIS3DH\build_nrf52840_dk'
I can access the I2C node, that I defined but the gpio struct?
Thanks for the help!
