Hi Antony,
Could you attach the error report that you see, or mention which configurations are problematic?
Priyanka
CONFIG_PM, CONFIG_PM_STATS, CONFIG_CAF_POWER_MANAGER.... are the ones showing issue
warning: PM (defined at soc/arm/microchip_mec/mec172x/Kconfig.defconfig.series:36,
soc/arm/silabs_exx32/efr32bg22/Kconfig.defconfig.series:18,
soc/arm/silabs_exx32/efr32bg27/Kconfig.defconfig.series:18,
soc/arm/silabs_exx32/efr32mg24/Kconfig.defconfig.series:19, subsys/pm/Kconfig:13) was assigned the
value 'y' but got the value 'n'. Check these unsatisfied dependencies: (SOC_SERIES_MEC172X ||
(SOC_SERIES_EFR32BG22 && SOC_FAMILY_EXX32) || (SOC_SERIES_EFR32BG27 && SOC_FAMILY_EXX32) ||
(SOC_SERIES_EFR32MG24 && SOC_FAMILY_EXX32) || (SYS_CLOCK_EXISTS && HAS_PM)) (=n). See
docs.zephyrproject.org/.../kconfig.html and/or look up PM in the
menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
warning: PM_STATS (defined at subsys/pm/Kconfig:28) was assigned the value 'y' but got the value
'n'. Check these unsatisfied dependencies: PM (=n). See
docs.zephyrproject.org/.../kconfig.html and/or look up PM_STATS in the
THIS IS THE ERROR REPORT FOR THE FOLLOWING
Hi Antony,
As mentioned in the error report, in order to set a CONFIG to a value (y or n), you need to also satisfy the dependencies. So please make sure that the dependencies are also satisfied.
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_PM
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_PM_STATS
Priyanka
okay i will check, thank you
