App version usage in code and configuration
Hi there,
Zephyr has ability for an Application version management. Based on this, I have created a "Version" file, without any file name extension (like .txt).
Now I would like to display the version in the "Device Information Service" defined in my prj.conf like:
CONFIG_BT_DIS_FW_REV_STR=$(APP_VERSION_TWEAK_STRING)
But, this gives me: "Assignment ignored. error: Aborting due to Kconfig warnings".
How can I use the firmware version in the device information service?
Thanks for your answer in advance.
Patrick
    You need to set this in your CMakeLists.txt file. Kconfig cannot take in variables.
    set(CONFIG_SOME_CONFIG \"${APP_VERSION_TWEAK_STRING}\" CACHE INTERNAL "")
    Make sure to set this before the find_package line.
    Could you try this and see if that works as expected?
    Håkon
  • Dear Håkon,
    While testing with nRF Connect Android application, the value of the Firmware Revision String remains empty.
    Any other ideas?
    Patrick
  • Hi Patrick,
    You do not need to check with the android app, you can just go into build-folder/zephyr/.config and search for the CONFIG_.
    Or even easier; add a message in cmake:
    include(CMakePrintHelpers)
    cmake_print_variables(APP_VERSION_TWEAK_STRING)
    This will not print unless my_project/VERSION file is present. Here's an example of the content of such file:
    VERSION_MAJOR = 2
    VERSION_MINOR = 6
    PATCHLEVEL = 0
    VERSION_TWEAK = 99
    EXTRAVERSION =
    Which will print:
    -- APP_VERSION_TWEAK_STRING="2.6.0+99"
    Håkon
  • Dear Håkon,
    I have the following in the cmake:
    cmake_minimum_required(VERSION 3.20.0)
    set(CONFIG_BT_DIS_FW_REV_STR \"${APP_VERSION_TWEAK_STRING}\" CACHE INTERNAL "")
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    project(new)
    zephyr_include_directories(include)
    target_sources(app PRIVATE include/main_init.c)
    target_sources(app PRIVATE include/bluetooth.c)
    target_sources(app PRIVATE src/main.c)
    The build output in the terminal is:
    -- APP_VERSION_TWEAK_STRING=""
    Therefore the same as in the app.
    Patrick
  • Dear Patrick,
    What is the content of your VERSION file?
    edit: I see what you mean, one is set after the other, so ordering of when the CONFIG_BT_DIS_FW_REV_STR is set will make it either to be '' or the content of the prj.conf. I'll see if I can find another way around.
    Håkon
