Troubleshooting RTT Logging Issues with NRF52840DK in VSCode
Hi all, I'm using NRF52840DK and I want to use RTT to print logging, but I configured a lot of different configs and I can't print any information in RTT after all.
I am using printk to print self string and using
 CONFIG_LOG_PRINTK=y
b
ut as it is not working well to print any string.
CONFIG_GPIO=y
# CONFIG_KSCAN is not set
# CONFIG_WIFI is not set
CONFIG_SPI=y
CONFIG_GPIO_INIT_PRIORITY=40
# CONFIG_MODEM is not set
# CONFIG_UART_INTERRUPT_DRIVEN is not set
CONFIG_I2C=y
# CONFIG_SENSOR is not set
# CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set
CONFIG_BT_HCI_VS_EXT=y
CONFIG_BOARD="nrf52840dk_nrf52840"
CONFIG_BT_CTLR=y
CONFIG_SOC="nRF52840_QIAA"
CONFIG_SOC_SERIES="nrf52"
CONFIG_NUM_IRQS=48
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_PINCTRL=y
# CONFIG_WATCHDOG is not set
CONFIG_HEAP_MEM_POOL_SIZE=0
CONFIG_ROM_START_OFFSET=0
# CONFIG_RESET is not set
CONFIG_CLOCK_CONTROL=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_PM=y
# CONFIG_PM_DEVICE is not set
CONFIG_LOG_DOMAIN_NAME=""
CONFIG_NRF_RTC_TIMER=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_SERIAL_INIT_PRIORITY=55
CONFIG_FPU=y
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_MBEDTLS is not set
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
CONFIG_TINYCRYPT=y
CONFIG_SERIAL=y
CONFIG_MAIN_STACK_SIZE=2048
# CONFIG_SRAM_VECTOR_TABLE is not set
# CONFIG_BT_USER_PHY_UPDATE is not set
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_HAS_DTS=y
# Devicetree Info
CONFIG_DT_HAS_ARDUINO_UNO_ADC_ENABLED=y
CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y
CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED=y
CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CC310_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RTC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED=y
CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_VND_SPI_DEVICE_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# nrf (/opt/nordic/ncs/v2.2.0/nrf)
CONFIG_NEWLIB_LIBC_NANO=y
CONFIG_NUM_METAIRQ_PRIORITIES=0
# CONFIG_INIT_STACKS is not set
# Nordic nRF Connect
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_BT_BUF_CMD_TX_COUNT=2
CONFIG_ENTROPY_GENERATOR=y
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_LOG_DEFAULT_LEVEL=1
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_SECURE_BOOT_CRYPTO is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# end of Bootloader
# Bluetooth Low Energy
CONFIG_BT_MAX_CONN=1
CONFIG_BT_LL_SOFTDEVICE=y
# SoftDevice Controller
CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
CONFIG_BT_HCI_TX_STACK_SIZE=1536
CONFIG_BT_RX_STACK_SIZE=2200
# CONFIG_BT_CTLR_SDC_LLPM is not set
CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=2
CONFIG_BT_CTLR_SDC_RX_PRIO=6
# CONFIG_BT_CTLR_DF is not set
CONFIG_BT_LL_SOFTDEVICE_PERIPHERAL=y
# CONFIG_BT_LL_SOFTDEVICE_MULTIROLE is not set
CONFIG_BT_CTLR_ECDH_LIB_OBERON=y
# CONFIG_BT_CTLR_ECDH_LIB_TINYCRYPT is not set
CONFIG_BT_CTLR_ECDH_STACK_SIZE=900
# CONFIG_BT_CTLR_ECDH_IN_MPSL_WORK is not set
# CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
# CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER is not set
# end of SoftDevice Controller
# BLE Libraries
# CONFIG_BT_GATT_POOL is not set
# CONFIG_BT_GATT_DM is not set
# CONFIG_BT_ADV_PROV is not set
# CONFIG_BT_CONN_CTX is not set
# Bluetooth Services
CONFIG_BT_NRF_SERVICES=y
# CONFIG_BT_AMS_CLIENT is not set
# CONFIG_BT_ANCS_CLIENT is not set
# CONFIG_BT_BAS_CLIENT is not set
# CONFIG_BT_BMS is not set
# CONFIG_BT_CTS_CLIENT is not set
# CONFIG_BT_DFU_SMP is not set
# CONFIG_BT_GATTP is not set
# CONFIG_BT_HIDS is not set
# CONFIG_BT_HOGP is not set
CONFIG_BT_LBS=y
CONFIG_BT_LBS_POLL_BUTTON=y
# CONFIG_BT_LBS_LOG_LEVEL_OFF is not set
# CONFIG_BT_LBS_LOG_LEVEL_ERR is not set
# CONFIG_BT_LBS_LOG_LEVEL_WRN is not set
CONFIG_BT_LBS_LOG_LEVEL_INF=y
# CONFIG_BT_LBS_LOG_LEVEL_DBG is not set
CONFIG_BT_LBS_LOG_LEVEL=3
# CONFIG_BT_NUS is not set
# CONFIG_BT_NUS_CLIENT is not set
# CONFIG_BT_RSCS is not set
# CONFIG_BT_THROUGHPUT is not set
# CONFIG_BT_LATENCY is not set
# CONFIG_BT_LATENCY_CLIENT is not set
# CONFIG_BT_HRS_CLIENT is not set
# CONFIG_BT_DDFS is not set
# CONFIG_BT_MDS is not set
# CONFIG_BT_CGMS is not set
# CONFIG_BT_FAST_PAIR is not set
# CONFIG_BT_DIS is not set
CONFIG_BT_GATT_AUTO_SEC_REQ=y
CONFIG_BT_L2CAP_TX_MTU=65
CONFIG_BT_BUF_ACL_TX_SIZE=27
CONFIG_BT_BUF_ACL_RX_SIZE=69
CONFIG_BT_CTLR_DATA_LENGTH_MAX=27
# end of Bluetooth Services
# BLE over nRF RPC
# CONFIG_BT_RPC is not set
# CONFIG_BT_RPC_STACK is not set
# CONFIG_BT_CENTRAL is not set
CONFIG_BT_PERIPHERAL=y
# CONFIG_BT_OBSERVER is not set
CONFIG_BT_BROADCASTER=y
CONFIG_BT_CONN=y
# CONFIG_BT_REMOTE_VERSION is not set
CONFIG_BT_PHY_UPDATE=y
CONFIG_BT_DATA_LEN_UPDATE=y
# CONFIG_BT_EXT_ADV is not set
# CONFIG_BT_BAS is not set
# CONFIG_BT_HRS is not set
# CONFIG_BT_TPS is not set
# CONFIG_BT_IAS is not set
# CONFIG_BT_IAS_CLIENT is not set
# CONFIG_BT_IAS_LOG_LEVEL_OFF is not set
# CONFIG_BT_IAS_LOG_LEVEL_ERR is not set
# CONFIG_BT_IAS_LOG_LEVEL_WRN is not set
CONFIG_BT_IAS_LOG_LEVEL_INF=y
# CONFIG_BT_IAS_LOG_LEVEL_DBG is not set
CONFIG_BT_IAS_LOG_LEVEL=3
# CONFIG_BT_OTS is not set
# CONFIG_BT_OTS_CLIENT is not set
CONFIG_BT_BUF_ACL_TX_COUNT=3
CONFIG_BT_BUF_ACL_RX_COUNT=6
CONFIG_BT_BUF_EVT_RX_SIZE=68
CONFIG_BT_BUF_EVT_RX_COUNT=10
CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
CONFIG_BT_BUF_CMD_TX_SIZE=65
CONFIG_BT_HAS_HCI_VS=y
CONFIG_BT_HCI_VS=y
# CONFIG_BT_HCI_VS_EVT is not set
# CONFIG_BT_HCI_VS_FATAL_ERROR is not set
# CONFIG_BT_WAIT_NOP is not set
CONFIG_BT_RPA=y
CONFIG_BT_ASSERT=y
CONFIG_BT_ASSERT_VERBOSE=y
# CONFIG_BT_ASSERT_PANIC is not set
CONFIG_BT_DEBUG_NONE=y
# CONFIG_BT_DEBUG_LOG is not set
# CONFIG_BT_DEBUG_MONITOR_UART is not set
# CONFIG_BT_DEBUG_MONITOR_RTT is not set
CONFIG_BT_LONG_WQ=y
CONFIG_BT_LONG_WQ_STACK_SIZE=1300
CONFIG_BT_LONG_WQ_PRIO=10
CONFIG_BT_HCI_HOST=y
# CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
CONFIG_BT_HCI_TX_PRIO=7
CONFIG_BT_HCI_RESERVE=0
# CONFIG_BT_RECV_BLOCKING is not set
# CONFIG_BT_RECV_WORKQ_SYS is not set
CONFIG_BT_RECV_WORKQ_BT=y
CONFIG_BT_RX_PRIO=8
CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
# CONFIG_BT_AUDIO is not set
CONFIG_BT_SETTINGS=y
CONFIG_BT_SETTINGS_CCC_LAZY_LOADING=y
CONFIG_BT_SETTINGS_CCC_STORE_ON_WRITE=y
CONFIG_BT_SETTINGS_USE_PRINTK=y
# CONFIG_BT_FILTER_ACCEPT_LIST is not set
CONFIG_BT_LIM_ADV_TIMEOUT=30
CONFIG_BT_CONN_TX_MAX=3
CONFIG_BT_AUTO_PHY_UPDATE=y
# CONFIG_BT_USER_DATA_LEN_UPDATE is not set
CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
# CONFIG_BT_REMOTE_INFO is not set
CONFIG_BT_SMP=y
# CONFIG_BT_PRIVACY is not set
# CONFIG_BT_SIGNING is not set
# CONFIG_BT_SMP_APP_PAIRING_ACCEPT is not set
# CONFIG_BT_SMP_SC_PAIR_ONLY is not set
# CONFIG_BT_SMP_SC_ONLY is not set
# CONFIG_BT_SMP_OOB_LEGACY_PAIR_ONLY is not set
# CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY is not set
# CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE is not set
# CONFIG_BT_ID_UNPAIR_MATCHING_BONDS is not set
# CONFIG_BT_ID_ALLOW_UNAUTH_OVERWRITE is not set
# CONFIG_BT_FIXED_PASSKEY is not set
# CONFIG_BT_USE_DEBUG_KEYS is not set
CONFIG_BT_BONDABLE=y
# CONFIG_BT_BONDING_REQUIRED is not set
# CONFIG_BT_STORE_DEBUG_KEYS is not set
CONFIG_BT_SMP_ENFORCE_MITM=y
# CONFIG_BT_KEYS_OVERWRITE_OLDEST is not set
CONFIG_BT_SMP_MIN_ENC_KEY_SIZE=7
CONFIG_BT_L2CAP_TX_BUF_COUNT=3
CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
# CONFIG_BT_L2CAP_DYNAMIC_CHANNEL is not set
CONFIG_BT_ATT_ENFORCE_FLOW=y
CONFIG_BT_ATT_PREPARE_COUNT=0
CONFIG_BT_ATT_RETRY_ON_SEC_ERR=y
CONFIG_BT_GATT_SERVICE_CHANGED=y
# CONFIG_BT_GATT_DYNAMIC_DB is not set
CONFIG_BT_GATT_CACHING=y
# CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
# CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
# CONFIG_BT_GATT_CLIENT is not set
CONFIG_BT_GATT_READ_MULTIPLE=y
CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42
CONFIG_BT_MAX_PAIRED=1
CONFIG_BT_CREATE_CONN_TIMEOUT=3
CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
# CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
CONFIG_BT_DEVICE_NAME="Nordic_LBS"
# CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
CONFIG_BT_DEVICE_APPEARANCE=0
CONFIG_BT_ID_MAX=1
CONFIG_BT_ECC=y
# CONFIG_BT_TINYCRYPT_ECC is not set
# CONFIG_BT_HOST_CCM is not set
# CONFIG_BT_LOG_SNIFFER_INFO is not set
# CONFIG_BT_TESTING is not set
# CONFIG_BT_BREDR is not set
# CONFIG_BT_HCI_VS_EVT_USER is not set
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
# end of Client ID (nRF Cloud Device ID)
# CONFIG_NRF_CLOUD_MQTT is not set
# CONFIG_NRF_CLOUD_FOTA is not set
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_REST is not set
# CONFIG_NRF_CLOUD_GATEWAY is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y
# CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LEVEL=3
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
# SPM
# CONFIG_SPM is not set
# CONFIG_IS_SPM is not set
# end of SPM
CONFIG_FW_INFO=y
CONFIG_FW_INFO_OFFSET=0x200
CONFIG_FW_INFO_FIRMWARE_VERSION=1
CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de
CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c
CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea
CONFIG_FW_INFO_HARDWARE_ID=52
CONFIG_FW_INFO_VERSION=2
CONFIG_FW_INFO_CRYPTO_ID=0
CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0
CONFIG_FW_INFO_MAGIC_LEN=12
CONFIG_FW_INFO_VALID_VAL=0x9102FFFF
CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y
# CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_ATLEAST_OPTIONAL is not set
# CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set
# Debug
# CONFIG_PPI_TRACE is not set
# CONFIG_CPU_LOAD is not set
# end of Debug
# CONFIG_SHELL_BT_NUS is not set
CONFIG_MPSL_FEM_API_AVAILABLE=y
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
CONFIG_MPSL_FEM_LOG_LEVEL_INF=y
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL=3
CONFIG_MPSL_THREAD_COOP_PRIO=6
CONFIG_MPSL_WORK_STACK_SIZE=1024
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
CONFIG_MPSL_LOG_LEVEL_INF=y
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL=3
# Partition Manager
# CONFIG_PARTITION_MANAGER_ENABLED is not set
# CONFIG_FLASH_MAP_CUSTOM is not set
CONFIG_SRAM_SIZE=256
CONFIG_SRAM_BASE_ADDRESS=0x20000000
# Zephyr subsystem configurations
CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x2000
CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE=0x1000
# end of Zephyr subsystem configurations
# NCS subsystem configurations
# CONFIG_PM_SINGLE_IMAGE is not set
CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
CONFIG_PM_EXTERNAL_FLASH_BASE=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x40000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# CONFIG_ZIGBEE is not set
# Full Modem Firmware Update Management(FMFU)
# CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
CONFIG_MGMT_FMFU_LOG_LEVEL_INF=y
# CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
CONFIG_MGMT_FMFU_LOG_LEVEL=3
# end of Full Modem Firmware Update Management(FMFU)
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
# Libraries
# Binary libraries
# end of Binary libraries
# CONFIG_ADP536X is not set
# CONFIG_AT_MONITOR is not set
# CONFIG_DISABLE_FLASH_PATCH is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
CONFIG_FPROTECT_BLOCK_SIZE=0x1000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CUSTOM_CMD is not set
CONFIG_DK_LIBRARY=y
CONFIG_DK_LIBRARY_BUTTON_SCAN_INTERVAL=10
CONFIG_DK_LIBRARY_DYNAMIC_BUTTON_HANDLERS=y
# CONFIG_DK_LIBRARY_LOG_LEVEL_OFF is not set
# CONFIG_DK_LIBRARY_LOG_LEVEL_ERR is not set
# CONFIG_DK_LIBRARY_LOG_LEVEL_WRN is not set
CONFIG_DK_LIBRARY_LOG_LEVEL_INF=y
# CONFIG_DK_LIBRARY_LOG_LEVEL_DBG is not set
CONFIG_DK_LIBRARY_LOG_LEVEL=3
# CONFIG_AT_CMD_PARSER is not set
# CONFIG_MODEM_INFO is not set
CONFIG_MULTITHREADING_LOCK=y
CONFIG_RESET_ON_FATAL_ERROR=y
# CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
CONFIG_FATAL_ERROR_LOG_LEVEL_INF=y
# CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
CONFIG_FATAL_ERROR_LOG_LEVEL=3
# CONFIG_SMS is not set
# CONFIG_SUPL_CLIENT_LIB is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
# CONFIG_HW_UNIQUE_KEY_LOAD is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
# CONFIG_MODEM_JWT is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
CONFIG_ENTROPY_CC3XX=y
CONFIG_HW_CC3XX=y
# CONFIG_ETH_RTT is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
CONFIG_CLOCK_CONTROL_MPSL=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=1
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (/opt/nordic/ncs/v2.2.0/nrf)
# hostap (/opt/nordic/ncs/v2.2.0/modules/lib/hostap)
CONFIG_ZEPHYR_HOSTAP_MODULE=y
# end of hostap (/opt/nordic/ncs/v2.2.0/modules/lib/hostap)
# mcuboot (/opt/nordic/ncs/v2.2.0/bootloader/mcuboot)
# MCUboot
CONFIG_BOOT_SIGNATURE_KEY_FILE=""
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_MCUBOOT_USB_SUPPORT=y
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (/opt/nordic/ncs/v2.2.0/bootloader/mcuboot)
# mbedtls (/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
CONFIG_MBEDTLS_BUILTIN=y
# CONFIG_MBEDTLS_LIBRARY is not set
# end of mbedtls (/opt/nordic/ncs/v2.2.0/modules/crypto/mbedtls)
# trusted-firmware-m (/opt/nordic/ncs/v2.2.0/modules/tee/tf-m/trusted-firmware-m)
# CONFIG_BOOTLOADER_MCUBOOT is not set
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (/opt/nordic/ncs/v2.2.0/modules/tee/tf-m/trusted-firmware-m)
# cjson (/opt/nordic/ncs/v2.2.0/modules/lib/cjson)
# CONFIG_CJSON_LIB is not set
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (/opt/nordic/ncs/v2.2.0/modules/lib/cjson)
# azure-sdk-for-c (/opt/nordic/ncs/v2.2.0/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (/opt/nordic/ncs/v2.2.0/modules/lib/azure-sdk-for-c)
# memfault-firmware-sdk (/opt/nordic/ncs/v2.2.0/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (/opt/nordic/ncs/v2.2.0/modules/lib/memfault-firmware-sdk)
# cirrus-logic (/opt/nordic/ncs/v2.2.0/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (/opt/nordic/ncs/v2.2.0/modules/hal/cirrus-logic)
# openthread (/opt/nordic/ncs/v2.2.0/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (/opt/nordic/ncs/v2.2.0/modules/lib/openthread)
# canopennode (/opt/nordic/ncs/v2.2.0/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (/opt/nordic/ncs/v2.2.0/modules/lib/canopennode)
# chre (/opt/nordic/ncs/v2.2.0/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (/opt/nordic/ncs/v2.2.0/modules/lib/chre)
# hal_nordic (/opt/nordic/ncs/v2.2.0/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_RADIO_DRIVER is not set
# CONFIG_NRF_802154_SER_RADIO is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
# CONFIG_NRFX_CLOCK is not set
# CONFIG_NRFX_COMP is not set
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
# CONFIG_NRFX_I2S is not set
# CONFIG_NRFX_NFCT is not set
CONFIG_NRFX_NVMC=y
# CONFIG_NRFX_PDM is not set
# CONFIG_NRFX_POWER is not set
CONFIG_NRFX_PPI=y
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC is not set
CONFIG_NRFX_QSPI=y
# CONFIG_NRFX_RNG is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_RTC2 is not set
# CONFIG_NRFX_SAADC is not set
CONFIG_NRFX_SPI=y
# CONFIG_NRFX_SPI0 is not set
# CONFIG_NRFX_SPI1 is not set
CONFIG_NRFX_SPI2=y
CONFIG_NRFX_SPIM=y
CONFIG_NRFX_SPIM3=y
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TEMP is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TIMER3 is not set
# CONFIG_NRFX_TIMER4 is not set
CONFIG_NRFX_TWI=y
CONFIG_NRFX_TWI0=y
# CONFIG_NRFX_TWI1 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_USBD is not set
# CONFIG_NRFX_WDT0 is not set
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
# end of nrfx drivers
# end of hal_nordic (/opt/nordic/ncs/v2.2.0/modules/hal/nordic)
# liblc3 (/opt/nordic/ncs/v2.2.0/modules/lib/liblc3)
# CONFIG_LIBLC3 is not set
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (/opt/nordic/ncs/v2.2.0/modules/lib/liblc3)
# littlefs (/opt/nordic/ncs/v2.2.0/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (/opt/nordic/ncs/v2.2.0/modules/fs/littlefs)
# loramac-node (/opt/nordic/ncs/v2.2.0/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (/opt/nordic/ncs/v2.2.0/modules/lib/loramac-node)
# lvgl (/opt/nordic/ncs/v2.2.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (/opt/nordic/ncs/v2.2.0/modules/lib/gui/lvgl)
# lz4 (/opt/nordic/ncs/v2.2.0/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (/opt/nordic/ncs/v2.2.0/modules/lib/lz4)
# nanopb (/opt/nordic/ncs/v2.2.0/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (/opt/nordic/ncs/v2.2.0/modules/lib/nanopb)
# picolibc (/opt/nordic/ncs/v2.2.0/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (/opt/nordic/ncs/v2.2.0/modules/lib/picolibc)
# TraceRecorder (/opt/nordic/ncs/v2.2.0/modules/debug/TraceRecorder)
CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
# end of TraceRecorder (/opt/nordic/ncs/v2.2.0/modules/debug/TraceRecorder)
# uoscore-uedhoc (/opt/nordic/ncs/v2.2.0/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (/opt/nordic/ncs/v2.2.0/modules/lib/uoscore-uedhoc)
# zcbor (/opt/nordic/ncs/v2.2.0/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# CONFIG_ZCBOR is not set
# end of zcbor (/opt/nordic/ncs/v2.2.0/modules/lib/zcbor)
# zscilib (/opt/nordic/ncs/v2.2.0/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (/opt/nordic/ncs/v2.2.0/modules/lib/zscilib)
# nrfxlib (/opt/nordic/ncs/v2.2.0/nrfxlib)
# Nordic nrfxlib
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
CONFIG_MPSL=y
CONFIG_MPSL_BUILD_TYPE_LIB=y
# Crypto libraries for nRF5x SOCs.
CONFIG_NRFXLIB_CRYPTO=y
CONFIG_CRYPTOCELL_CC310_USABLE=y
CONFIG_CRYPTOCELL_USABLE=y
CONFIG_NRF_OBERON=y
# CONFIG_NRF_CC310_BL is not set
CONFIG_NRF_CC3XX_PLATFORM=y
# CONFIG_HW_CC3XX_INTERRUPT is not set
CONFIG_CC3XX_MUTEX_LOCK=y
# CONFIG_CC3XX_ATOMIC_LOCK is not set
# end of Crypto libraries for nRF5x SOCs.
# nrf_security module
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# end of nrf_security module
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_SW_CODEC_LC3_T2_SOFTWARE is not set
# CONFIG_LC3_PLC_DISABLED is not set
CONFIG_LC3_ENC_CHAN_MAX=1
CONFIG_LC3_DEC_CHAN_MAX=1
# Encoder sample rates
CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
# end of Encoder sample rates
# Decoder sample rates
CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
# end of Decoder sample rates
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (/opt/nordic/ncs/v2.2.0/nrfxlib)
# connectedhomeip (/opt/nordic/ncs/v2.2.0/modules/lib/matter)
# CONFIG_CHIP is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (/opt/nordic/ncs/v2.2.0/modules/lib/matter)
# Optional modules. Make sure they're installed, via the project manifest.
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_DSP is not set
# CONFIG_CMSIS_NN is not set
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_SOF is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_TINYCBOR is not set
# CONFIG_TINYCRYPT_CTR_PRNG is not set
# CONFIG_TINYCRYPT_SHA256 is not set
# CONFIG_TINYCRYPT_ECC_DH is not set
# CONFIG_TINYCRYPT_ECC_DSA is not set
CONFIG_TINYCRYPT_AES=y
# CONFIG_TINYCRYPT_AES_CBC is not set
# CONFIG_TINYCRYPT_AES_CTR is not set
# CONFIG_TINYCRYPT_AES_CCM is not set
CONFIG_TINYCRYPT_AES_CMAC=y
# CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# end of Modules
CONFIG_BOARD_REVISION=""
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_NRF52840DK_NRF52840=y
# Board Options
CONFIG_BOARD_ENABLE_DCDC=y
CONFIG_BOARD_ENABLE_DCDC_HV=y
# end of Board Options
# CONFIG_SOC_SERIES_BEETLE is not set
# CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
# CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
# CONFIG_SOC_SERIES_MPS2 is not set
# CONFIG_SOC_SERIES_MPS3 is not set
# CONFIG_SOC_SERIES_MUSCA_B1 is not set
# CONFIG_SOC_SERIES_MUSCA_S1 is not set
# CONFIG_SOC_SERIES_AST10X0 is not set
# CONFIG_SOC_SERIES_SAM3X is not set
# CONFIG_SOC_SERIES_SAM4E is not set
# CONFIG_SOC_SERIES_SAM4L is not set
# CONFIG_SOC_SERIES_SAM4S is not set
# CONFIG_SOC_SERIES_SAME70 is not set
# CONFIG_SOC_SERIES_SAMV71 is not set
# CONFIG_SOC_SERIES_SAMD20 is not set
# CONFIG_SOC_SERIES_SAMD21 is not set
# CONFIG_SOC_SERIES_SAMD51 is not set
# CONFIG_SOC_SERIES_SAME51 is not set
# CONFIG_SOC_SERIES_SAME53 is not set
# CONFIG_SOC_SERIES_SAME54 is not set
# CONFIG_SOC_SERIES_SAML21 is not set
# CONFIG_SOC_SERIES_SAMR21 is not set
# CONFIG_SOC_SERIES_SAMR34 is not set
# CONFIG_SOC_SERIES_SAMR35 is not set
# CONFIG_SOC_SERIES_VALKYRIE is not set
# CONFIG_SOC_SERIES_VIPER is not set
# CONFIG_SOC_SERIES_PSOC62 is not set
# CONFIG_SOC_SERIES_PSOC63 is not set
# CONFIG_SOC_SERIES_GD32E10X is not set
# CONFIG_SOC_SERIES_GD32E50X is not set
# CONFIG_SOC_SERIES_GD32F3X0 is not set
# CONFIG_SOC_SERIES_GD32F403 is not set
# CONFIG_SOC_SERIES_GD32F4XX is not set
# CONFIG_SOC_SERIES_XMC_4XXX is not set
# CONFIG_SOC_SERIES_CYCLONE5 is not set
# CONFIG_SOC_SERIES_MEC1501X is not set
# CONFIG_SOC_SERIES_MEC1701X is not set
# CONFIG_SOC_SERIES_MEC172X is not set
# CONFIG_SOC_SERIES_NRF51X is not set
CONFIG_SOC_SERIES_NRF52X=y
# CONFIG_SOC_SERIES_NRF53X is not set
# CONFIG_SOC_SERIES_NRF91X is not set
# CONFIG_SOC_SERIES_NPCX7 is not set
# CONFIG_SOC_SERIES_NPCX9 is not set
# CONFIG_SOC_SERIES_M48X is not set
# CONFIG_SOC_SERIES_IMX_6X_M4 is not set
# CONFIG_SOC_SERIES_IMX7_M4 is not set
# CONFIG_SOC_SERIES_IMX8ML_M7 is not set
# CONFIG_SOC_SERIES_IMX8MM_M4 is not set
# CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
# CONFIG_SOC_SERIES_IMX_RT is not set
# CONFIG_SOC_SERIES_IMX_RT5XX is not set
# CONFIG_SOC_SERIES_IMX_RT6XX is not set
# CONFIG_SOC_SERIES_KINETIS_K2X is not set
# CONFIG_SOC_SERIES_KINETIS_K6X is not set
# CONFIG_SOC_SERIES_KINETIS_K8X is not set
# CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
# CONFIG_SOC_SERIES_KINETIS_KL2X is not set
# CONFIG_SOC_SERIES_KINETIS_KV5X is not set
# CONFIG_SOC_SERIES_KINETIS_KWX is not set
# CONFIG_SOC_SERIES_LPC11U6X is not set
# CONFIG_SOC_SERIES_LPC51U68 is not set
# CONFIG_SOC_SERIES_LPC54XXX is not set
# CONFIG_SOC_SERIES_LPC55XXX is not set
# CONFIG_SOC_SERIES_S32ZE_R52 is not set
# CONFIG_SOC_EOS_S3 is not set
# CONFIG_SOC_SERIES_RCAR_GEN3 is not set
# CONFIG_SOC_SERIES_DA1469X is not set
# CONFIG_SOC_SERIES_RP2XXX is not set
# CONFIG_SOC_SERIES_EFM32GG11B is not set
# CONFIG_SOC_SERIES_EFM32HG is not set
# CONFIG_SOC_SERIES_EFM32JG12B is not set
# CONFIG_SOC_SERIES_EFM32PG12B is not set
# CONFIG_SOC_SERIES_EFM32PG1B is not set
# CONFIG_SOC_SERIES_EFM32WG is not set
# CONFIG_SOC_SERIES_EFR32BG13P is not set
# CONFIG_SOC_SERIES_EFR32FG13P is not set
# CONFIG_SOC_SERIES_EFR32FG1P is not set
# CONFIG_SOC_SERIES_EFR32MG12P is not set
# CONFIG_SOC_SERIES_EFR32MG21 is not set
# CONFIG_SOC_SERIES_STM32F0X is not set
# CONFIG_SOC_SERIES_STM32F1X is not set
# CONFIG_SOC_SERIES_STM32F2X is not set
# CONFIG_SOC_SERIES_STM32F3X is not set
# CONFIG_SOC_SERIES_STM32F4X is not set
# CONFIG_SOC_SERIES_STM32F7X is not set
# CONFIG_SOC_SERIES_STM32G0X is not set
# CONFIG_SOC_SERIES_STM32G4X is not set
# CONFIG_SOC_SERIES_STM32H7X is not set
# CONFIG_SOC_SERIES_STM32L0X is not set
# CONFIG_SOC_SERIES_STM32L1X is not set
# CONFIG_SOC_SERIES_STM32L4X is not set
# CONFIG_SOC_SERIES_STM32L5X is not set
# CONFIG_SOC_SERIES_STM32MP1X is not set
# CONFIG_SOC_SERIES_STM32U5X is not set
# CONFIG_SOC_SERIES_STM32WBX is not set
# CONFIG_SOC_SERIES_STM32WLX is not set
# CONFIG_SOC_TI_LM3S6965 is not set
# CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
# CONFIG_SOC_SERIES_CC32XX is not set
# CONFIG_SOC_SERIES_MSP432P4XX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
# CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
# Hardware Configuration
CONFIG_CPU_HAS_ARM_MPU=y
CONFIG_HAS_SWO=y
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NRF=y
CONFIG_HAS_HW_NRF_ACL=y
CONFIG_HAS_HW_NRF_CC310=y
CONFIG_HAS_HW_NRF_CCM=y
CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_ECB=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE=y
CONFIG_HAS_HW_NRF_MWU=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PPI=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
CONFIG_HAS_HW_NRF_RNG=y
CONFIG_HAS_HW_NRF_RTC0=y
CONFIG_HAS_HW_NRF_RTC1=y
CONFIG_HAS_HW_NRF_RTC2=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPI2=y
CONFIG_HAS_HW_NRF_SPIM3=y
CONFIG_HAS_HW_NRF_SWI0=y
CONFIG_HAS_HW_NRF_SWI1=y
CONFIG_HAS_HW_NRF_SWI2=y
CONFIG_HAS_HW_NRF_SWI3=y
CONFIG_HAS_HW_NRF_SWI4=y
CONFIG_HAS_HW_NRF_SWI5=y
CONFIG_HAS_HW_NRF_TEMP=y
CONFIG_HAS_HW_NRF_TIMER0=y
CONFIG_HAS_HW_NRF_TIMER1=y
CONFIG_HAS_HW_NRF_TIMER2=y
CONFIG_HAS_HW_NRF_TIMER3=y
CONFIG_HAS_HW_NRF_TIMER4=y
CONFIG_HAS_HW_NRF_TWI0=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_UARTE1=y
CONFIG_HAS_HW_NRF_USBD=y
CONFIG_HAS_HW_NRF_WDT0=y
CONFIG_NRF_HW_RTC1_RESERVED=y
CONFIG_SOC_NRF52840=y
# CONFIG_SOC_NRF52805_CAAA is not set
# CONFIG_SOC_NRF52810_QFAA is not set
# CONFIG_SOC_NRF52811_QFAA is not set
# CONFIG_SOC_NRF52820_QDAA is not set
# CONFIG_SOC_NRF52832_CIAA is not set
# CONFIG_SOC_NRF52832_QFAA is not set
# CONFIG_SOC_NRF52832_QFAB is not set
# CONFIG_SOC_NRF52833_QIAA is not set
CONFIG_SOC_NRF52840_QIAA=y
CONFIG_SOC_DCDC_NRF52X=y
CONFIG_SOC_DCDC_NRF52X_HV=y
CONFIG_GPIO_AS_PINRESET=y
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
# CONFIG_NFCT_PINS_AS_GPIOS is not set
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_TRACE_PORT is not set
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
CONFIG_SOC_LOG_LEVEL_INF=y
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL=3
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF52X=y
# ARM Options
CONFIG_ARCH="arm"
CONFIG_CPU_CORTEX=y
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
CONFIG_CPU_CORTEX_M=y
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_FAULT_DUMP=2
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_ARM_STORE_EXC_RETURN=y
CONFIG_FP_HARDABI=y
# CONFIG_FP_SOFTABI is not set
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M4=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_GEN_ISR_TABLES=y
CONFIG_ZERO_LATENCY_IRQS=y
CONFIG_ZERO_LATENCY_LEVELS=1
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
CONFIG_MPU_STACK_GUARD=y
CONFIG_MPU_STACK_GUARD_MIN_SIZE_FLOAT=128
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
CONFIG_ARCH_LOG_LEVEL_INF=y
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL=3
CONFIG_LITTLE_ENDIAN=y
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_GEN_IRQ_START_VECTOR=0
# CONFIG_EXTRA_EXCEPTION_INFO is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
CONFIG_MPU_LOG_LEVEL_INF=y
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL=3
CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# Floating Point Options
CONFIG_FPU_SHARING=y
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
CONFIG_KERNEL_LOG_LEVEL_INF=y
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_IDLE_STACK_SIZE=320
CONFIG_ISR_STACK_SIZE=2048
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
CONFIG_ERRNO=y
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Kernel Debugging and Metrics
CONFIG_BOOT_BANNER=y
CONFIG_BOOT_DELAY=0
# CONFIG_THREAD_MONITOR is not set
# CONFIG_THREAD_NAME is not set
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# Work Queue Options
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of Work Queue Options
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
CONFIG_POLL=y
# end of Timer API Options
# Other Kernel Object Options
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_PIPES is not set
CONFIG_KERNEL_MEM_POOL=y
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
CONFIG_XIP=y
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Security Options
# CONFIG_STACK_CANARIES is not set
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# SMP Options
CONFIG_MP_NUM_CPUS=1
# end of SMP Options
CONFIG_TICKLESS_KERNEL=y
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
# CONFIG_THREAD_LOCAL_STORAGE is not set
# end of General Kernel Options
# Device Options
# end of Device Options
# Virtual Memory Support
# end of Virtual Memory Support
# Device Drivers
# CONFIG_LORA is not set
CONFIG_CONSOLE=y
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
CONFIG_UART_CONSOLE=y
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
CONFIG_UART_CONSOLE_INPUT_EXPIRED=y
CONFIG_UART_CONSOLE_INPUT_EXPIRED_TIMEOUT=15000
# CONFIG_RAM_CONSOLE is not set
CONFIG_RTT_CONSOLE=y
CONFIG_RTT_TX_RETRY_CNT=2
CONFIG_RTT_TX_RETRY_DELAY_MS=2
# CONFIG_RTT_TX_RETRY_IN_INTERRUPT is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y
# CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
CONFIG_UART_CONSOLE_LOG_LEVEL=3
# CONFIG_GSM_MUX is not set
# CONFIG_EFI_CONSOLE is not set
CONFIG_HAS_SEGGER_RTT=y
CONFIG_USE_SEGGER_RTT=y
# CONFIG_SEGGER_RTT_CUSTOM_LOCKING is not set
CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
# CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
CONFIG_SEGGER_RTT_MODE=0
# CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
CONFIG_SEGGER_RTT_SECTION_NONE=y
# CONFIG_SEGGER_RTT_SECTION_DTCM is not set
# CONFIG_EC_HOST_CMD_PERIPH is not set
CONFIG_ETH_INIT_PRIORITY=80
# CONFIG_MDIO is not set
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
# CONFIG_UART_LOG_LEVEL_OFF is not set
# CONFIG_UART_LOG_LEVEL_ERR is not set
# CONFIG_UART_LOG_LEVEL_WRN is not set
CONFIG_UART_LOG_LEVEL_INF=y
# CONFIG_UART_LOG_LEVEL_DBG is not set
CONFIG_UART_LOG_LEVEL=3
CONFIG_UART_USE_RUNTIME_CONFIGURE=y
# CONFIG_UART_ASYNC_API is not set
# CONFIG_UART_LINE_CTRL is not set
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# CONFIG_UART_PIPE is not set
# Serial Drivers
CONFIG_UART_NRFX=y
CONFIG_UART_0_NRF_UARTE=y
CONFIG_UART_0_ENHANCED_POLL_OUT=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
CONFIG_UART_1_NRF_UARTE=y
CONFIG_UART_1_ENHANCED_POLL_OUT=y
# CONFIG_UART_1_NRF_PARITY_BIT is not set
CONFIG_UART_ENHANCED_POLL_OUT=y
CONFIG_NRF_UARTE_PERIPHERAL=y
# Interrupt Controllers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_INTC_LOG_LEVEL_OFF is not set
# CONFIG_INTC_LOG_LEVEL_ERR is not set
# CONFIG_INTC_LOG_LEVEL_WRN is not set
CONFIG_INTC_LOG_LEVEL_INF=y
# CONFIG_INTC_LOG_LEVEL_DBG is not set
CONFIG_INTC_LOG_LEVEL=3
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# CONFIG_INTC_ESP32 is not set
# end of Interrupt Controllers
# Timer Drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer Drivers
# CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
# CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
# CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
CONFIG_ENTROPY_LOG_LEVEL_INF=y
# CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
CONFIG_ENTROPY_LOG_LEVEL=3
CONFIG_ENTROPY_INIT_PRIORITY=50
CONFIG_ENTROPY_NRF5_RNG=y
# CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
CONFIG_ENTROPY_BT_HCI=y
CONFIG_ENTROPY_HAS_DRIVER=y
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
CONFIG_GPIO_LOG_LEVEL_INF=y
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL=3
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
CONFIG_GPIO_NRFX=y
# CONFIG_FXL6408_LOG_LEVEL_OFF is not set
# CONFIG_FXL6408_LOG_LEVEL_ERR is not set
# CONFIG_FXL6408_LOG_LEVEL_WRN is not set
CONFIG_FXL6408_LOG_LEVEL_INF=y
# CONFIG_FXL6408_LOG_LEVEL_DBG is not set
CONFIG_FXL6408_LOG_LEVEL=3
# CONFIG_SPI_ASYNC is not set
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPI_EXTENDED_MODES is not set
CONFIG_SPI_INIT_PRIORITY=70
CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
# CONFIG_SPI_LOG_LEVEL_OFF is not set
# CONFIG_SPI_LOG_LEVEL_ERR is not set
# CONFIG_SPI_LOG_LEVEL_WRN is not set
CONFIG_SPI_LOG_LEVEL_INF=y
# CONFIG_SPI_LOG_LEVEL_DBG is not set
CONFIG_SPI_LOG_LEVEL=3
CONFIG_SPI_NRFX=y
CONFIG_SPI_2_NRF_SPI=y
CONFIG_SPI_3_NRF_SPIM=y
CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
# CONFIG_SDHC is not set
# CONFIG_I2C_CALLBACK is not set
# CONFIG_I2C_TARGET is not set
CONFIG_I2C_NRFX=y
CONFIG_I2C_0_NRF_TWI=y
CONFIG_I2C_INIT_PRIORITY=50
# CONFIG_I2C_LOG_LEVEL_OFF is not set
# CONFIG_I2C_LOG_LEVEL_ERR is not set
# CONFIG_I2C_LOG_LEVEL_WRN is not set
CONFIG_I2C_LOG_LEVEL_INF=y
# CONFIG_I2C_LOG_LEVEL_DBG is not set
CONFIG_I2C_LOG_LEVEL=3
# CONFIG_I3C is not set
# CONFIG_I2S is not set
# CONFIG_DAI is not set
# CONFIG_PWM is not set
# CONFIG_PINMUX is not set
# CONFIG_ADC is not set
# CONFIG_DAC is not set
# CONFIG_W1 is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_PTP_CLOCK is not set
# CONFIG_IPM is not set
CONFIG_FLASH_HAS_DRIVER_ENABLED=y
CONFIG_FLASH_HAS_PAGE_LAYOUT=y
CONFIG_FLASH_JESD216=y
CONFIG_FLASH=y
# CONFIG_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_FLASH_LOG_LEVEL_WRN is not set
CONFIG_FLASH_LOG_LEVEL_INF=y
# CONFIG_FLASH_LOG_LEVEL_DBG is not set
CONFIG_FLASH_LOG_LEVEL=3
# CONFIG_FLASH_JESD216_API is not set
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_INIT_PRIORITY=50
CONFIG_SOC_FLASH_NRF=y
# CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE is not set
# CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
CONFIG_SOC_FLASH_NRF_TIMEOUT_MULTIPLIER=10
# CONFIG_SOC_FLASH_NRF_UICR is not set
# CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
CONFIG_NORDIC_QSPI_NOR_INIT_PRIORITY=80
CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=4
# CONFIG_COUNTER is not set
# CONFIG_DMA is not set
# CONFIG_USB_DEVICE_DRIVER is not set
# CONFIG_CRYPTO is not set
# CONFIG_DISPLAY is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LED is not set
# CONFIG_CAN is not set
# CONFIG_AUDIO is not set
# CONFIG_NEURAL_NET_ACCEL is not set
# CONFIG_HWINFO is not set
# CONFIG_ESPI is not set
# CONFIG_PS2 is not set
# CONFIG_VIDEO is not set
# CONFIG_EEPROM is not set
# CONFIG_PECI is not set
# CONFIG_PECI_INTERRUPT_DRIVEN is not set
# CONFIG_REGULATOR is not set
# CONFIG_MEMC is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_EDAC is not set
# CONFIG_PM_CPU_OPS is not set
# Miscellaneous Drivers
# CONFIG_GROVE_LCD_RGB is not set
# end of Miscellaneous Drivers
# CONFIG_DISK_DRIVERS is not set
# CONFIG_CACHE is not set
# CONFIG_SYSCON is not set
# CONFIG_BBRAM is not set
# CONFIG_FPGA is not set
# CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
# CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
# CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
CONFIG_PINCTRL_LOG_LEVEL_INF=y
# CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
CONFIG_PINCTRL_LOG_LEVEL=3
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_MBOX is not set
# CONFIG_MM_DRV is not set
# CONFIG_POWER_DOMAIN is not set
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_LOG_LEVEL_OFF is not set
# CONFIG_USBC_LOG_LEVEL_ERR is not set
# CONFIG_USBC_LOG_LEVEL_WRN is not set
CONFIG_USBC_LOG_LEVEL_INF=y
# CONFIG_USBC_LOG_LEVEL_DBG is not set
CONFIG_USBC_LOG_LEVEL=3
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_MIPI_DSI is not set
# CONFIG_COREDUMP_DEVICE is not set
# C Library
CONFIG_SUPPORT_MINIMAL_LIBC=y
CONFIG_PICOLIBC_SUPPORTED=y
# CONFIG_MINIMAL_LIBC is not set
# CONFIG_PICOLIBC is not set
CONFIG_NEWLIB_LIBC=y
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
# CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
# CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set
CONFIG_STDOUT_CONSOLE=y
# end of C Library
# Additional libraries
# OS Support Library
# CONFIG_JSON_LIBRARY is not set
# CONFIG_RING_BUFFER is not set
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
# CONFIG_PRINTK_SYNC is not set
# CONFIG_MPSC_PBUF is not set
CONFIG_ONOFF=y
# CONFIG_SPSC_PBUF is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# CONFIG_WINSTREAM is not set
CONFIG_REBOOT=y
# CONFIG_UTF8 is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
CONFIG_CBPRINTF_FP_SUPPORT=y
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_FP_ALWAYS_A is not set
CONFIG_CBPRINTF_N_SPECIFIER=y
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF=y
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_VALIDATE is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
CONFIG_SYS_HEAP_SMALL_ONLY=y
# CONFIG_SYS_HEAP_BIG_ONLY is not set
# CONFIG_SYS_HEAP_AUTO is not set
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Heap and Memory Allocation
# end of OS Support Library
# CONFIG_GETOPT is not set
CONFIG_POSIX_MAX_FDS=4
# CONFIG_POSIX_API is not set
# CONFIG_POSIX_CLOCK is not set
CONFIG_MAX_TIMER_COUNT=5
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_EVENTFD is not set
# CONFIG_OPENAMP_RSC_TABLE is not set
# Util libraries
# CONFIG_FNMATCH is not set
# end of Util libraries
# CONFIG_SMF is not set
# end of Additional libraries
# Sub Systems and OS Services
CONFIG_BT=y
# CONFIG_BT_LOG_LEVEL_OFF is not set
# CONFIG_BT_LOG_LEVEL_ERR is not set
# CONFIG_BT_LOG_LEVEL_WRN is not set
CONFIG_BT_LOG_LEVEL_INF=y
# CONFIG_BT_LOG_LEVEL_DBG is not set
CONFIG_BT_LOG_LEVEL=3
CONFIG_BT_HCI=y
# CONFIG_BT_CUSTOM is not set
# CONFIG_BT_HCI_RAW is not set
# CONFIG_BT_HCI_RAW_H4 is not set
# CONFIG_BT_HCI_RAW_CMD_EXT is not set
CONFIG_BT_CONN_TX=y
# CONFIG_BT_PER_ADV_SYNC_TRANSFER_SENDER is not set
# Bluetooth buffer configuration
# end of Bluetooth buffer configuration
# Bluetooth Host
# L2CAP Options
# end of L2CAP Options
# ATT and GATT Options
# end of ATT and GATT Options
# GATT Services
# end of GATT Services
# end of Bluetooth Host
CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
CONFIG_BT_CTLR_ECDH_SUPPORT=y
# CONFIG_BT_LL_SW_SPLIT is not set
# BLE Controller configuration
CONFIG_BT_CTLR_CRYPTO=y
CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=""
CONFIG_BT_CTLR_AD_DATA_BACKUP=y
CONFIG_BT_CTLR_RX_BUFFERS=1
# CONFIG_BT_CTLR_TX_PWR_PLUS_8 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_7 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_6 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_5 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_4 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
CONFIG_BT_CTLR_TX_PWR_0=y
# CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
CONFIG_BT_CTLR_TX_PWR_ANTENNA=0
# CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
# BLE Controller features
CONFIG_BT_CTLR_LE_ENC=y
CONFIG_BT_CTLR_ECDH=y
CONFIG_BT_CTLR_EXT_REJ_IND=y
CONFIG_BT_CTLR_LE_PING=y
CONFIG_BT_CTLR_DATA_LENGTH=y
CONFIG_BT_CTLR_PHY=y
# CONFIG_BT_CTLR_CONN_RSSI is not set
# CONFIG_BT_CTLR_FILTER_ACCEPT_LIST is not set
# CONFIG_BT_CTLR_PRIVACY is not set
CONFIG_BT_CTLR_PHY_2M=y
# CONFIG_BT_CTLR_PHY_CODED is not set
CONFIG_BT_CTLR_CHAN_SEL_2=y
# CONFIG_BT_CTLR_ADV_EXT is not set
# CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
# CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
# CONFIG_BT_CTLR_ASSERT_HANDLER is not set
# CONFIG_BT_CTLR_TEST is not set
# CONFIG_BT_SHELL is not set
CONFIG_BT_COMPANY_ID=0x05F1
# Controller Area Network (CAN) bus subsystem
# CONFIG_ISOTP is not set
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# CONFIG_CPLUSPLUS is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
CONFIG_ASSERT=y
CONFIG_ASSERT_LEVEL=2
CONFIG_SPIN_VALIDATE=y
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
CONFIG_ASSERT_NO_COND_INFO=y
CONFIG_ASSERT_NO_MSG_INFO=y
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# end of Debugging Options
# CONFIG_DISK_ACCESS is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
# CONFIG_FCB is not set
CONFIG_NVS=y
# CONFIG_NVS_LOOKUP_CACHE is not set
# CONFIG_NVS_LOG_LEVEL_OFF is not set
# CONFIG_NVS_LOG_LEVEL_ERR is not set
# CONFIG_NVS_LOG_LEVEL_WRN is not set
CONFIG_NVS_LOG_LEVEL_INF=y
# CONFIG_NVS_LOG_LEVEL_DBG is not set
CONFIG_NVS_LOG_LEVEL=3
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# Logging
CONFIG_LOG=y
# CONFIG_LOG_MODE_DEFERRED is not set
# CONFIG_LOG_MODE_IMMEDIATE is not set
CONFIG_LOG_MODE_MINIMAL=y
CONFIG_LOG_FRONTEND=y
# CONFIG_LOG_FRONTEND_ONLY is not set
CONFIG_LOG_DEFAULT_MINIMAL=y
# CONFIG_LOG_MULTIDOMAIN is not set
# Logging levels filtering
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# end of Logging levels filtering
# Processing
# end of Processing
# Frontends
# end of Frontends
# Misc
CONFIG_LOG_USE_VLA=y
# CONFIG_LOG_ALWAYS_RUNTIME is not set
# CONFIG_LOG_FMT_SECTION is not set
# CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
# end of Misc
# CONFIG_LOG_OUTPUT is not set
# end of Logging
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_MCUMGR is not set
# CONFIG_HAWKBIT is not set
# CONFIG_UPDATEHUB is not set
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# Networking
CONFIG_NET_BUF=y
CONFIG_NET_BUF_USER_DATA_SIZE=0
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
# CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
# CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
CONFIG_NET_BUF_LOG_LEVEL_INF=y
# CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
CONFIG_NET_BUF_LOG_LEVEL=3
# CONFIG_NET_BUF_POOL_USAGE is not set
# CONFIG_NETWORKING is not set
# end of Networking
# Portability
# end of Portability
# Power Management
# CONFIG_PM_LOG_LEVEL_OFF is not set
# CONFIG_PM_LOG_LEVEL_ERR is not set
# CONFIG_PM_LOG_LEVEL_WRN is not set
CONFIG_PM_LOG_LEVEL_INF=y
# CONFIG_PM_LOG_LEVEL_DBG is not set
CONFIG_PM_LOG_LEVEL=3
# CONFIG_PM_S2RAM is not set
CONFIG_PM_POLICY_DEFAULT=y
# CONFIG_PM_POLICY_CUSTOM is not set
# end of Power Management
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
# CONFIG_USB_DEVICE_STACK is not set
# CONFIG_USBC_STACK is not set
# CONFIG_SD_STACK is not set
# CONFIG_IMG_MANAGER is not set
# Random Number Generators
# CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set
# CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set
CONFIG_XOSHIRO_RANDOM_GENERATOR=y
CONFIG_CSPRING_ENABLED=y
CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
# CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
# end of Random Number Generators
# Storage
CONFIG_FLASH_MAP=y
# CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
# CONFIG_STREAM_FLASH is not set
# end of Storage
CONFIG_SETTINGS=y
# CONFIG_SETTINGS_LOG_LEVEL_OFF is not set
# CONFIG_SETTINGS_LOG_LEVEL_ERR is not set
# CONFIG_SETTINGS_LOG_LEVEL_WRN is not set
CONFIG_SETTINGS_LOG_LEVEL_INF=y
# CONFIG_SETTINGS_LOG_LEVEL_DBG is not set
CONFIG_SETTINGS_LOG_LEVEL=3
# CONFIG_SETTINGS_RUNTIME is not set
CONFIG_SETTINGS_DYNAMIC_HANDLERS=y
CONFIG_SETTINGS_NVS=y
# CONFIG_SETTINGS_CUSTOM is not set
# CONFIG_SETTINGS_NONE is not set
CONFIG_SETTINGS_NVS_SECTOR_SIZE_MULT=1
CONFIG_SETTINGS_NVS_SECTOR_COUNT=8
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# CONFIG_RTIO is not set
# end of Sub Systems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_15=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_USE_DT_CODE_PARTITION is not set
CONFIG_FLASH_LOAD_OFFSET=0
CONFIG_FLASH_LOAD_SIZE=0
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_KERNEL_ENTRY="__start"
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
CONFIG_SRAM_OFFSET=0
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
# end of Linker Sections
# end of Linker Options
# Compiler Options
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_NATIVE_APPLICATION is not set
CONFIG_SIZE_OPTIMIZATIONS=y
# CONFIG_SPEED_OPTIMIZATIONS is not set
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# CONFIG_NO_OPTIMIZATIONS is not set
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
# CONFIG_FORTIFY_SOURCE_NONE is not set
CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
CONFIG_OUTPUT_DISASSEMBLY=y
# CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_OUTPUT_UF2 is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
# CONFIG_BUILD_OUTPUT_META is not set
# end of Build Options
CONFIG_WARN_DEPRECATED=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
# Compatibility
CONFIG_COMPAT_INCLUDES=y
# end of Compatibility
# CONFIG_LEGACY_INCLUDE_PATH is not set
# Nordic LED-Button BLE GATT service sample
CONFIG_BT_LBS_SECURITY_ENABLED=y
# end of Nordic LED-Button BLE GATT service sample
Here is my config output file, can anyone help me to view it?
If i only use the blinky pwm of the example for modifications just add
CONFIG_GPIO=y
CONFIG_FW_INFO=y
CONFIG_LOG=y
and it prints fine, which confuses me~
