Hi all,
I am trying to flash the nRF 5340 Audio DK boards with the nRF5240_audio sample. When using the buildprog.py script to flash my three boards, the script fails due to Kconfig warnings, mainly because (at least seemingly) some symbols are experimental. My assumption was that the scripts work out-of-the-box when following all the "Get-Started" guides. Please find the output below:
python ..\..\Users\user\git\sdk-nrf\applications\nrf5340_audio\tools\buildprog\buildprog.py -c both -b release -d both
| snr | snr conn | device | only reboot | core app programmed | core net programmed |
| 1050165136 | True | headset | Not selected | Selected | Selected |
| 1050103346 | True | headset | Not selected | Selected | Selected |
| 1050184586 | True | gateway | Not selected | Selected | Selected |
Invoking build step
Net core uses precompiled hex or child image
Run: west build C:\Users\user\git\sdk-nrf\applications\nrf5340_audio -b nrf5340_audio_dk_nrf5340_cpuapp -d C:\Users\user\git\sdk-nrf\applications\nrf5340_audio\build\dev_headset\build_release
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: C:/Users/user/git/sdk-nrf/applications/nrf5340_audio
-- CMake version: 3.29.2
-- Using NCS Toolchain 2.6.20240304.889616714482 for building. (C:/ncs/toolchains/cf2149caf2/cmake)
-- Cache files will be written to: C:/ncs/v2.6.0/zephyr/.cache
-- Zephyr version: 3.5.99 (C:/ncs/v2.6.0/zephyr)
-- Board: nrf5340_audio_dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.16.5 (C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.5 (C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk)
-- Found BOARD.dts: C:/ncs/v2.6.0/zephyr/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/Users/user/git/sdk-nrf/applications/nrf5340_audio/build/dev_headset/build_release/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/Users/user/git/sdk-nrf/applications/nrf5340_audio/build/dev_headset/build_release/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/Users/user/git/sdk-nrf/applications/nrf5340_audio/build/dev_headset/build_release/zephyr/dts.cmake
warning: Experimental symbol NRF5340_AUDIO is enabled.
warning: Experimental symbol SAMPLE_RATE_CONVERTER is enabled.
warning: Experimental symbol BT_ISO_PERIPHERAL is enabled.
warning: Experimental symbol BT_AUDIO is enabled.
warning: Experimental symbol BT_BAP_UNICAST_SERVER is enabled.
warning: Experimental symbol BT_VCP_VOL_REND is enabled.
warning: Experimental symbol BT_CSIP_SET_MEMBER is enabled.
warning: Experimental symbol BT_MCC is enabled.
warning: Experimental symbol BT_CAP_ACCEPTOR is enabled.
warning: BT_MCC_READ_MEDIA_STATE (defined at C:/Users/user/git/sdk-nrf/applications/nrf5340_audio\unicast_server/Kconfig.defaults:51) defined without a type
warning: BT_MCC_SET_MEDIA_CONTROL_POINT (defined at C:/Users/user/git/sdk-nrf/applications/nrf5340_audio\unicast_server/Kconfig.defaults:54) defined without a type
error: Aborting due to Kconfig warnings
Parsing C:/Users/user/git/sdk-nrf/applications/nrf5340_audio/Kconfig
Loaded configuration 'C:/ncs/v2.6.0/zephyr/boards/arm/nrf5340_audio_dk_nrf5340/nrf5340_audio_dk_nrf5340_cpuapp_defconfig'
Merged configuration 'C:/Users/user/git/sdk-nrf/applications/nrf5340_audio/prj.conf'
CMake Error at C:/ncs/v2.6.0/zephyr/cmake/modules/kconfig.cmake:358 (message):
command failed with return code: 1
C:/ncs/v2.6.0/nrf/cmake/modules/kconfig.cmake:29 (include)
C:/ncs/v2.6.0/zephyr/cmake/modules/zephyr_default.cmake:129 (include)
C:/ncs/v2.6.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/v2.6.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
CMakeLists.txt:34 (find_package)
←[91mFATAL ERROR: command exited with status 1: 'C:\Program Files\CMake\bin\cmake.EXE' -DWEST_PYTHON=C:/Draeger/Apps/Python/python.exe '-BC:\Users\user\git\sdk-nrf\applications\nrf5340_audio\build\dev_headset\build_release' -GNinja '-SC:\Users\user\git\sdk-nrf\applications\nrf5340_audio'
←[0mTraceback (most recent call last):
File "C:\Users\user\git\sdk-nrf\applications\nrf5340_audio\tools\buildprog\buildprog.py", line 417, in <module>
__main()
File "C:\Users\user\git\sdk-nrf\applications\nrf5340_audio\tools\buildprog\buildprog.py", line 400, in __main
__build_module(build_cfg, options)
File "C:\Users\user\git\sdk-nrf\applications\nrf5340_audio\tools\buildprog\buildprog.py", line 175, in __build_module
raise Exception("cmake error: " + str(ret_val))
Exception: cmake error: 1
Please provide me with some ideas on why this build fails.
Alex
