I didn't find any information about the Gain of the Onboard PCB Antenna of the Developement Kit, nor the effective Transmit power that is available. Where can I find it, and how can I set the desired Transmit Power?
Thanks in Advance
Thanks in Advance
You can change the TX power setting used by the BT controller on the netcore by changing the default CONFIG_BT_CTLR_TX_PWR_0 symbol to one of the other CONFIG_BT_CTRL_PWR_* symbols for your HCI_IPC build. For example, CONFIG_BT_CTLR_TX_PWR_PLUS_3=y if you want to set the RADIO output power to +3dBm. Supported power levels can be found from the TXPOWER register definition.
Instructions on how you can apply configuration changes to child images such as Bluetooth: HCI IPC are given here: Permanent configuration changes to child images.
E.g.,
├── child_image
│ └── hci_ipc.conf
where hci_ipc.conf contains this line: CONFIG_BT_CTLR_TX_PWR_PLUS_3=y if you want to set the RADIO output power to +3dBm.
If you want to verify after building sample that your configuration was applied, you can check the generated .config file in build/hci_ipc/zephyr.
The PCB antenna is supposed to be omnidirectonal so I assume its gain is close to 1, but I don't have a measured value for it.
Vidar
Edit: antenna gain should be around 0 dBi according to this post: Rated output and pcb antenna gain of nRF52-DK and this one: RE: Gain of the PCB antenna of the nRF5340-DK
Thank you very much! After Editing, I found it in the hci_ipc.conf set to the value 3dbm. However, I didn't really notice any difference between the different settings of power, no matter what I set it is around the same value if I look at the nrF connect app from my smartphone. I wonder is it because CONFIG_BT_CTLR_TX_PWR_ANTENNA is set to 0 in my final build? You can see a screenshot of the .config after build:
The CONFIG_BT_CTLR_TX_PWR_ANTENNA setting should not make any difference when you don't have an external PA/LNA (FEM) on the board. You can try to set the output power to -40 dBm to make it more noticeable.
I see, thanks a lot!
