I have DK of nRF5340, I want to get started with it and create the development env, as well as I need to measure the sleep current for this module?
Any quick tutorial which I could follow to create development env?
Nordic has a powerprofiler kit with very precise current measurement, you can use it to power your application and measure power usage.
https://www.nordicsemi.com/Products/Development-hardware/Power-Profiler-Kit-2
Make sure to isolate other components from influencing your measurement results.
```The nRF5340 DK is typically powered via USB, but can be powered by a wide range of sources, within the supply range of 1.7 to 5.0 V. In addition to USB, it can be powered with external source, but also includes a CR2032 battery holder and a Li-Po battery connector, for in-field testing. Current consumption can be measured by using the dedicated current measurement pins, for example by using Nordic's Power Profiler Kit II.```
Berend
2024-04-23T10:50:26.463Z INFO Initialising nrfutil module: toolchain-manager |
I'm trying to create development env for nRF5340, by following the getting started guide by Nordic,
while installing the toolchain from toolchain manger as well as from vscode, I see myself running into the above same errors, which is stopping me from moving ahead with the tutorial ,
what could possibly be wrong here?
Hi Berend,
Is it necessary to use the Power Profiler Kit II, as on the DK of nRF5340 I can see something written as nRF current measurement above two pins, which made me think that there must be some sample example for this DK which I lcan load and use those pins to measure the current/power consumption when it is in sleep mode
If you remove the jumper on those pins and put a amp meter in between (a regular multimeter can do this), you can measure the current the device uses.
The powerprofiler kit is just a handy tool to measure and log current precisely.
Which OS are you using?
Im using ubuntu 22.04LTS and have no issue
