Hi Guys,
I know this question, have been asked many times, but even with the different thread I was not able to solve it..
I'm using LIS2DH sensor with ncs 2.3.0 and have an error : "undefined reference to `__device_dts_ord_137' "
Here is how I init the sensor in main.c
void test_accelero(void){ const struct device *sensor = DEVICE_DT_GET(DT_ALIAS(accel0)); if (sensor == NULL || !device_is_ready(sensor)) { printf("Could not get accel0 device\n"); return -ENODEV; } return; }
Here is the devicetree overlay
where I manually set the status to "okay"
// To get started, press Ctrl+Space to bring up the completion menu and view the available nodes. // You can also use the buttons in the sidebar to perform actions on nodes. // Actions currently available include: // * Enabling / disabling the node // * Adding the bus to a bus // * Removing the node // * Connecting ADC channels // For more help, browse the DeviceTree documentation at https://docs.zephyrproject.org/latest/guides/dts/index.html // You can also visit the nRF DeviceTree extension documentation at https://nrfconnect.github.io/vscode-nrf-connect/devicetree/nrfdevicetree.html &uart0 { current-speed = <115200>; }; &pwm1 { status = "okay"; pinctrl-0 = <&pwm1_default>; pinctrl-1 = <&pwm1_sleep>; pinctrl-names = "default", "sleep"; }; &i2c0 { compatible = "nordic,nrf-twim"; status = "okay"; lis2dh: lis2dh@18 { compatible = "st,lis2dh12"; status = "okay"; reg = <0x18>; irq-gpios = <&gpio0 2 GPIO_ACTIVE_HIGH>,<&gpio1 15 GPIO_ACTIVE_HIGH>; disconnect-sdo-sa0-pull-up; }; }; &pinctrl { pwm0_default: pwm0_default { group1 { psels = <NRF_PSEL(PWM_OUT0, 0, 13)>, <NRF_PSEL(PWM_OUT1, 0, 14)>, <NRF_PSEL(PWM_OUT2, 0, 15)>; nordic,invert; }; }; pwm0_sleep: pwm0_sleep { group1 { psels = <NRF_PSEL(PWM_OUT0, 0, 13)>, <NRF_PSEL(PWM_OUT1, 0, 14)>, <NRF_PSEL(PWM_OUT2, 0, 15)>; low-power-enable; }; }; pwm1_default: pwm1_default { group1 { psels = <NRF_PSEL(PWM_OUT0, 0, 3)>; nordic,invert; }; }; pwm1_sleep: pwm1_sleep { group1 { psels = <NRF_PSEL(PWM_OUT0, 0, 3)>; low-power-enable; }; }; i2c0_default: i2c0_default { group1 { psels = <NRF_PSEL(TWIM_SDA, 0, 26)>, <NRF_PSEL(TWIM_SCL, 0, 27)>; }; }; i2c0_sleep: i2c0_sleep { group1 { psels = <NRF_PSEL(TWIM_SDA, 0, 26)>, <NRF_PSEL(TWIM_SCL, 0, 27)>; low-power-enable; }; }; }; /{ buzzer { compatible = "pwm-leds"; pwm1_CH0: pwm_1_channel_0 { pwms = <&pwm1 0 PWM_HZ(5000) PWM_POLARITY_INVERTED>; }; }; pwmleds { compatible = "pwm-leds"; pwm0_CH0: pwm_0_channel_0 { pwms = <&pwm0 0 PWM_HZ(1000) PWM_POLARITY_INVERTED>; }; pwm0_CH1: pwm_0_channel_1 { pwms = <&pwm0 1 PWM_HZ(1000) PWM_POLARITY_INVERTED>; }; pwm0_CH2: pwm_0_channel_2 { pwms = <&pwm0 2 PWM_HZ(1000) PWM_POLARITY_INVERTED>; }; }; aliases { pwm-ledr0 = &pwm0_CH0; pwm-ledg0 = &pwm0_CH1; pwm-ledb0 = &pwm0_CH2; pwm-buzzer = &pwm1_CH0; accel0 = &lis2dh; }; };
Here is the prj.conf
# # Copyright (c) 2019 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # CONFIG_NCS_SAMPLES_DEFAULTS=y # Deffered logging helps improve LPN power consumption # when friendship is established. CONFIG_LOG_MODE_DEFERRED=y # General configuration CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_FLASH=y CONFIG_FLASH_MAP=y CONFIG_NVS=y CONFIG_HWINFO=y CONFIG_DK_LIBRARY=y CONFIG_PM_SINGLE_IMAGE=y CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x8000 CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE=y # Set the MCUBOOT version CONFIG_MCUBOOT_IMAGE_VERSION="0.0.1" # Pairing CONFIG_BT_SMP=y CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y CONFIG_BT_KEYS_OVERWRITE_OLDEST=y # Optionnaly, the advertising period can be adjusted CONFIG_ADV_INTERVAL_MAX=0x0780 CONFIG_ADV_INTERVAL_MIN=0x0620 # Save the settings (for example BLE Mesh keys) in the non-volatile memory CONFIG_SETTINGS=n CONFIG_BT_SETTINGS=n # Adding I2C CONFIG_I2C=y #CONFIG_I2C_NRFX=y # Add the accelerometer CONFIG_SENSOR=y CONFIG_LIS2DH=y CONFIG_LIS2DH_TRIGGER_GLOBAL_THREAD=y #CONFIG_LIS2DH_TRIGGER_OWN_THREAD=y # CONFIG_LIS2DH_ACCEL_RANGE_2G=y # CONFIG_LIS2DH_ODR_2=y #Enable PWM CONFIG_PWM=y CONFIG_PWM_LOG_LEVEL_DBG=y CONFIG_LED=y CONFIG_LED_PWM=y #MultiThread CONFIG_MULTITHREADING=y
The generated .config seems ok
CONFIG_I2C=y
CONFIG_SENSOR=y
CONFIG_DT_HAS_ST_LIS2DH12_ENABLED=y
CONFIG_GPIO=y # CONFIG_KSCAN is not set # CONFIG_WIFI is not set # CONFIG_SPI is not set CONFIG_GPIO_INIT_PRIORITY=40 # CONFIG_WATCHDOG is not set # CONFIG_MODEM is not set # CONFIG_UART_INTERRUPT_DRIVEN is not set CONFIG_I2C=y CONFIG_SENSOR=y # CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set CONFIG_BT_HCI_VS_EXT=y CONFIG_BOARD="nrf52840dk_nrf52840" CONFIG_BT_CTLR=y CONFIG_SOC="nRF52840_QIAA" CONFIG_SOC_SERIES="nrf52" CONFIG_NUM_IRQS=48 CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768 CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30 CONFIG_FLASH_SIZE=1024 CONFIG_FLASH_BASE_ADDRESS=0x0 CONFIG_ICACHE_LINE_SIZE=32 CONFIG_DCACHE_LINE_SIZE=32 CONFIG_HEAP_MEM_POOL_SIZE=0 CONFIG_ROM_START_OFFSET=0 CONFIG_PINCTRL=y # CONFIG_RESET is not set CONFIG_CLOCK_CONTROL=y CONFIG_SOC_HAS_TIMING_FUNCTIONS=y CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y CONFIG_PM=y # CONFIG_PM_DEVICE is not set CONFIG_LOG_DOMAIN_NAME="" CONFIG_NRF_RTC_TIMER=y CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768 CONFIG_BUILD_OUTPUT_HEX=y CONFIG_SERIAL_INIT_PRIORITY=55 # CONFIG_FPU is not set # CONFIG_MBEDTLS is not set # CONFIG_CODE_DATA_RELOCATION is not set # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set CONFIG_TINYCRYPT=y CONFIG_SERIAL=y CONFIG_MAIN_STACK_SIZE=2048 # CONFIG_SRAM_VECTOR_TABLE is not set CONFIG_MP_MAX_NUM_CPUS=1 CONFIG_PLATFORM_SPECIFIC_INIT=y CONFIG_HAS_DTS=y # # Devicetree Info # CONFIG_DT_HAS_ARDUINO_UNO_ADC_ENABLED=y CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED=y CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_CC310_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_RTC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_SPI_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_TIMER_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED=y CONFIG_DT_HAS_PWM_LEDS_ENABLED=y CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y CONFIG_DT_HAS_ST_LIS2DH12_ENABLED=y CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y # end of Devicetree Info # # Modules # # # Available modules. # # # nrf (C:/ncs/v2.3.0/nrf) # CONFIG_NUM_METAIRQ_PRIORITIES=0 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_LOG_BUFFER_SIZE=1024 # CONFIG_INIT_STACKS is not set # # Nordic nRF Connect # CONFIG_WARN_EXPERIMENTAL=y CONFIG_PRIVILEGED_STACK_SIZE=1024 CONFIG_MCUMGR_BUF_SIZE=384 CONFIG_BT_BUF_CMD_TX_COUNT=2 CONFIG_ENTROPY_GENERATOR=y CONFIG_INIT_ARCH_HW_AT_BOOT=y CONFIG_NORDIC_QSPI_NOR=y CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_NCS_SAMPLES_DEFAULTS=y CONFIG_LOG_DEFAULT_LEVEL=1 # # Image build variants # # CONFIG_NCS_MCUBOOT_IN_BUILD is not set # end of Image build variants # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU is not set # CONFIG_MCUMGR_SMP_BT_AUTHEN is not set # CONFIG_IMG_ERASE_PROGRESSIVELY is not set # CONFIG_OS_MGMT_MCUMGR_PARAMS is not set # CONFIG_MCUMGR_GRP_ZEPHYR_BASIC is not set CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=4 CONFIG_UPDATEABLE_IMAGE_NUMBER=1 # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set CONFIG_BT_L2CAP_TX_MTU=190 CONFIG_BT_BUF_ACL_TX_SIZE=27 CONFIG_BT_BUF_ACL_RX_SIZE=252 CONFIG_BT_CTLR_DATA_LENGTH_MAX=27 # # Bootloader # # CONFIG_BUILD_S1_VARIANT is not set # CONFIG_SECURE_BOOT is not set CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000 # CONFIG_B0_MIN_PARTITION_SIZE is not set CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000 # CONFIG_SECURE_BOOT_CRYPTO is not set # # Secure Boot firmware validation # CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483 CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1 CONFIG_SB_VALIDATION_INFO_VERSION=2 CONFIG_SB_VALIDATION_METADATA_OFFSET=0 CONFIG_SB_VALIDATE_FW_SIGNATURE=y # end of Secure Boot firmware validation # end of Bootloader # # Bluetooth Low Energy # CONFIG_BT_MAX_CONN=3 CONFIG_BT_LL_SOFTDEVICE=y # # SoftDevice Controller # CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y CONFIG_BT_HCI_TX_STACK_SIZE=1536 CONFIG_BT_RX_STACK_SIZE=4096 # CONFIG_BT_CTLR_SDC_LLPM is not set CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=3 CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500 CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3 CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2 CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3 CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=2 CONFIG_BT_CTLR_SDC_RX_PRIO=6 # CONFIG_BT_CTLR_DF is not set CONFIG_BT_LL_SOFTDEVICE_MULTIROLE=y CONFIG_BT_SDC_ADDITIONAL_MEMORY=0 CONFIG_BT_CTLR_ECDH_LIB_OBERON=y # CONFIG_BT_CTLR_ECDH_LIB_TINYCRYPT is not set CONFIG_BT_CTLR_ECDH_STACK_SIZE=900 # CONFIG_BT_CTLR_ECDH_IN_MPSL_WORK is not set # CONFIG_BT_CTLR_LE_POWER_CONTROL is not set # end of SoftDevice Controller # # BLE Libraries # # CONFIG_BT_GATT_POOL is not set # CONFIG_BT_GATT_DM is not set # CONFIG_BT_ADV_PROV is not set # CONFIG_BT_SCAN is not set # CONFIG_BT_CONN_CTX is not set # CONFIG_BT_ENOCEAN is not set # # Bluetooth mesh # # # nRF BT mesh models # CONFIG_BT_MESH_NRF_MODELS=y # # Configuration of the waiting time for acknowledged messages # CONFIG_BT_MESH_MOD_ACKD_TIMEOUT_BASE=3000 CONFIG_BT_MESH_MOD_ACKD_TIMEOUT_PER_HOP=50 # end of Configuration of the waiting time for acknowledged messages # # Vendor models # # end of Vendor models # CONFIG_BT_MESH_ONOFF_SRV is not set # CONFIG_BT_MESH_ONOFF_CLI is not set # CONFIG_BT_MESH_TIME_SRV is not set # CONFIG_BT_MESH_TIME_CLI is not set # CONFIG_BT_MESH_LVL_SRV is not set # CONFIG_BT_MESH_LVL_CLI is not set # CONFIG_BT_MESH_DTT_SRV is not set # CONFIG_BT_MESH_DTT_CLI is not set # CONFIG_BT_MESH_PONOFF_SRV is not set # CONFIG_BT_MESH_PONOFF_CLI is not set # CONFIG_BT_MESH_PLVL_SRV is not set # CONFIG_BT_MESH_PLVL_CLI is not set CONFIG_BT_MESH_BATTERY_SRV=y # CONFIG_BT_MESH_BATTERY_CLI is not set # CONFIG_BT_MESH_LOC_SRV is not set # CONFIG_BT_MESH_LOC_CLI is not set # CONFIG_BT_MESH_PROP_SRV is not set # CONFIG_BT_MESH_PROP_CLI is not set # CONFIG_BT_MESH_LIGHTNESS_SRV is not set # CONFIG_BT_MESH_LIGHTNESS_CLI is not set # CONFIG_BT_MESH_LIGHT_CTRL_REG is not set # CONFIG_BT_MESH_LIGHT_CTRL_SRV is not set # CONFIG_BT_MESH_LIGHT_CTRL_CLI is not set # CONFIG_BT_MESH_LIGHT_CTL_CLI is not set # CONFIG_BT_MESH_LIGHT_CTL_SRV is not set # CONFIG_BT_MESH_LIGHT_TEMP_SRV is not set # CONFIG_BT_MESH_LIGHT_XYL_CLI is not set # CONFIG_BT_MESH_LIGHT_XYL_SRV is not set # CONFIG_BT_MESH_LIGHT_HSL_CLI is not set # CONFIG_BT_MESH_LIGHT_HSL_SRV is not set # CONFIG_BT_MESH_LIGHT_SAT_SRV is not set # CONFIG_BT_MESH_LIGHT_HUE_SRV is not set # CONFIG_BT_MESH_SENSOR_SRV is not set # CONFIG_BT_MESH_SENSOR_CLI is not set CONFIG_BT_MESH_SENSOR_CHANNELS_MAX=5 CONFIG_BT_MESH_SENSOR_CHANNEL_ENCODED_SIZE_MAX=4 # CONFIG_BT_MESH_SCENE_CLI is not set # CONFIG_BT_MESH_SCHEDULER_CLI is not set # CONFIG_BT_MESH_SCHEDULER_SRV is not set # end of nRF BT mesh models CONFIG_BT_MESH_DK_PROV=y CONFIG_BT_MESH_DK_PROV_OOB_BLINK=y CONFIG_BT_MESH_DK_PROV_OOB_BUTTON=y CONFIG_BT_MESH_DK_PROV_OOB_LOG=y # CONFIG_BT_MESH_DK_LEGACY_UUID_GEN is not set # CONFIG_BT_MESH_DK_PROV_LOG_LEVEL_OFF is not set # CONFIG_BT_MESH_DK_PROV_LOG_LEVEL_ERR is not set # CONFIG_BT_MESH_DK_PROV_LOG_LEVEL_WRN is not set CONFIG_BT_MESH_DK_PROV_LOG_LEVEL_INF=y # CONFIG_BT_MESH_DK_PROV_LOG_LEVEL_DBG is not set CONFIG_BT_MESH_DK_PROV_LOG_LEVEL=3 # end of Bluetooth mesh # # Bluetooth Services # # CONFIG_BT_AMS_CLIENT is not set # CONFIG_BT_ANCS_CLIENT is not set # CONFIG_BT_BAS_CLIENT is not set # CONFIG_BT_CTS_CLIENT is not set # CONFIG_BT_DFU_SMP is not set # CONFIG_BT_GATTP is not set # CONFIG_BT_HIDS is not set # CONFIG_BT_HOGP is not set # CONFIG_BT_LBS is not set # CONFIG_BT_NSMS is not set # CONFIG_BT_NUS is not set # CONFIG_BT_NUS_CLIENT is not set # CONFIG_BT_RSCS is not set # CONFIG_BT_THROUGHPUT is not set # CONFIG_BT_LATENCY is not set # CONFIG_BT_LATENCY_CLIENT is not set # CONFIG_BT_HRS_CLIENT is not set # CONFIG_BT_DDFS is not set # CONFIG_BT_MDS is not set # CONFIG_BT_CGMS is not set # CONFIG_BT_FAST_PAIR is not set # CONFIG_BT_DIS is not set CONFIG_BT_GATT_AUTO_SEC_REQ=y # end of Bluetooth Services # # BLE over nRF RPC # # CONFIG_BT_RPC_STACK is not set # CONFIG_BT_CENTRAL is not set CONFIG_BT_PERIPHERAL=y CONFIG_BT_OBSERVER=y CONFIG_BT_BROADCASTER=y CONFIG_BT_CONN=y # CONFIG_BT_REMOTE_VERSION is not set # CONFIG_BT_PHY_UPDATE is not set CONFIG_BT_DATA_LEN_UPDATE=y CONFIG_BT_EXT_ADV=y # CONFIG_BT_EXT_ADV_LEGACY_SUPPORT is not set CONFIG_BT_EXT_ADV_MAX_ADV_SET=4 # CONFIG_BT_PER_ADV is not set # CONFIG_BT_PER_ADV_SYNC is not set # CONFIG_BT_BAS is not set # CONFIG_BT_HRS is not set # CONFIG_BT_TPS is not set # CONFIG_BT_IAS is not set # CONFIG_BT_IAS_CLIENT is not set CONFIG_BT_IAS_CLIENT_LOG_LEVEL=3 CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INHERIT=y # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_OFF is not set # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_ERR is not set # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_WRN is not set # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INF is not set # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DBG is not set # CONFIG_BT_IAS_LOG_LEVEL_OFF is not set # CONFIG_BT_IAS_LOG_LEVEL_ERR is not set # CONFIG_BT_IAS_LOG_LEVEL_WRN is not set CONFIG_BT_IAS_LOG_LEVEL_INF=y # CONFIG_BT_IAS_LOG_LEVEL_DBG is not set CONFIG_BT_IAS_LOG_LEVEL=3 # CONFIG_BT_OTS is not set # CONFIG_BT_OTS_CLIENT is not set CONFIG_BT_BUF_ACL_TX_COUNT=3 CONFIG_BT_BUF_ACL_RX_COUNT=6 CONFIG_BT_BUF_EVT_RX_SIZE=255 CONFIG_BT_BUF_EVT_RX_COUNT=10 CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=58 CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=20 CONFIG_BT_BUF_CMD_TX_SIZE=255 CONFIG_BT_HAS_HCI_VS=y CONFIG_BT_HCI_VS=y # CONFIG_BT_HCI_VS_EVT is not set # CONFIG_BT_HCI_VS_FATAL_ERROR is not set # CONFIG_BT_HCI_MESH_EXT is not set # CONFIG_BT_WAIT_NOP is not set CONFIG_BT_RPA=y CONFIG_BT_ASSERT=y CONFIG_BT_ASSERT_VERBOSE=y # CONFIG_BT_ASSERT_PANIC is not set CONFIG_BT_DEBUG_NONE=y # CONFIG_BT_DEBUG_LOG is not set # CONFIG_BT_DEBUG_MONITOR_UART is not set # CONFIG_BT_DEBUG_MONITOR_RTT is not set CONFIG_BT_LONG_WQ=y CONFIG_BT_LONG_WQ_STACK_SIZE=1300 CONFIG_BT_LONG_WQ_PRIO=10 CONFIG_BT_HCI_HOST=y # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set CONFIG_BT_HCI_TX_PRIO=7 CONFIG_BT_HCI_RESERVE=0 # CONFIG_BT_RECV_BLOCKING is not set # CONFIG_BT_RECV_WORKQ_SYS is not set CONFIG_BT_RECV_WORKQ_BT=y CONFIG_BT_RX_PRIO=8 CONFIG_BT_DRIVER_RX_HIGH_PRIO=6 CONFIG_BT_MESH=y CONFIG_BT_MESH_PROV=y CONFIG_BT_MESH_PROV_DEVICE=y # CONFIG_BT_MESH_PROV_OOB_PUBLIC_KEY is not set CONFIG_BT_MESH_PB_ADV=y CONFIG_BT_MESH_UNPROV_BEACON_INT=5 CONFIG_BT_MESH_PB_ADV_RETRANS_TIMEOUT=500 # CONFIG_BT_MESH_CDB is not set CONFIG_BT_MESH_PROXY=y CONFIG_BT_MESH_GATT=y CONFIG_BT_MESH_PROXY_MSG_LEN=66 CONFIG_BT_MESH_GATT_SERVER=y CONFIG_BT_MESH_PB_GATT_COMMON=y CONFIG_BT_MESH_PB_GATT=y CONFIG_BT_MESH_PB_GATT_USE_DEVICE_NAME=y CONFIG_BT_MESH_GATT_PROXY=y CONFIG_BT_MESH_GATT_PROXY_ENABLED=y CONFIG_BT_MESH_NODE_ID_TIMEOUT=60 CONFIG_BT_MESH_PROXY_USE_DEVICE_NAME=y CONFIG_BT_MESH_PROXY_FILTER_SIZE=16 CONFIG_BT_MESH_MAX_CONN=3 # CONFIG_BT_MESH_ACCESS_LAYER_MSG is not set # CONFIG_BT_MESH_SELF_TEST is not set # CONFIG_BT_MESH_IV_UPDATE_TEST is not set CONFIG_BT_MESH_SUBNET_COUNT=1 CONFIG_BT_MESH_APP_KEY_COUNT=1 CONFIG_BT_MESH_MODEL_KEY_COUNT=1 CONFIG_BT_MESH_MODEL_GROUP_COUNT=1 CONFIG_BT_MESH_MODEL_VND_MSG_CID_FORCE=y CONFIG_BT_MESH_LABEL_COUNT=1 CONFIG_BT_MESH_CRPL=10 CONFIG_BT_MESH_RPL_STORAGE_MODE_SETTINGS=y CONFIG_BT_MESH_MSG_CACHE_SIZE=32 CONFIG_BT_MESH_ADV_BUF_COUNT=35 # CONFIG_BT_MESH_ADV_LEGACY is not set CONFIG_BT_MESH_ADV_EXT=y CONFIG_BT_MESH_RELAY_ADV_SETS=0 # CONFIG_BT_MESH_ADV_EXT_GATT_SEPARATE is not set CONFIG_BT_MESH_IV_UPDATE_SEQ_LIMIT=0x800000 CONFIG_BT_MESH_IVU_DIVIDER=4 CONFIG_BT_MESH_TX_SEG_MSG_COUNT=1 CONFIG_BT_MESH_RX_SEG_MSG_COUNT=1 CONFIG_BT_MESH_SEG_BUFS=64 CONFIG_BT_MESH_RX_SEG_MAX=32 CONFIG_BT_MESH_TX_SEG_MAX=32 CONFIG_BT_MESH_SEG_ACK_BASE_TIMEOUT=150 CONFIG_BT_MESH_SEG_ACK_PER_HOP_TIMEOUT=50 CONFIG_BT_MESH_SEG_ACK_PER_SEGMENT_TIMEOUT=0 CONFIG_BT_MESH_DEFAULT_TTL=7 CONFIG_BT_MESH_LOOPBACK_BUFS=3 CONFIG_BT_MESH_TX_SEG_RETRANS_COUNT=4 CONFIG_BT_MESH_TX_SEG_RETRANS_TIMEOUT_UNICAST=400 CONFIG_BT_MESH_TX_SEG_RETRANS_TIMEOUT_GROUP=50 CONFIG_BT_MESH_NETWORK_TRANSMIT_COUNT=2 CONFIG_BT_MESH_NETWORK_TRANSMIT_INTERVAL=20 CONFIG_BT_MESH_RELAY=y CONFIG_BT_MESH_RELAY_ENABLED=y CONFIG_BT_MESH_RELAY_RETRANSMIT_COUNT=2 CONFIG_BT_MESH_RELAY_RETRANSMIT_INTERVAL=20 CONFIG_BT_MESH_RELAY_BUF_COUNT=32 CONFIG_BT_MESH_BEACON_ENABLED=y # CONFIG_BT_MESH_LOW_POWER is not set # CONFIG_BT_MESH_FRIEND is not set # CONFIG_BT_MESH_CFG_CLI is not set # CONFIG_BT_MESH_HEALTH_CLI is not set # CONFIG_BT_MESH_SHELL is not set # CONFIG_BT_MESH_MODEL_EXTENSIONS is not set CONFIG_BT_MESH_LOG_LEVEL=3 CONFIG_BT_MESH_LOG_LEVEL_INHERIT=y # CONFIG_BT_MESH_LOG_LEVEL_OFF is not set # CONFIG_BT_MESH_LOG_LEVEL_ERR is not set # CONFIG_BT_MESH_LOG_LEVEL_WRN is not set # CONFIG_BT_MESH_LOG_LEVEL_INF is not set # CONFIG_BT_MESH_LOG_LEVEL_DBG is not set # CONFIG_BT_AUDIO is not set # CONFIG_BT_FILTER_ACCEPT_LIST is not set CONFIG_BT_LIM_ADV_TIMEOUT=30 CONFIG_BT_CONN_TX_MAX=8 # CONFIG_BT_USER_DATA_LEN_UPDATE is not set CONFIG_BT_AUTO_DATA_LEN_UPDATE=y # CONFIG_BT_REMOTE_INFO is not set CONFIG_BT_SMP=y # CONFIG_BT_PRIVACY is not set # CONFIG_BT_SIGNING is not set # CONFIG_BT_SMP_APP_PAIRING_ACCEPT is not set # CONFIG_BT_SMP_SC_PAIR_ONLY is not set # CONFIG_BT_SMP_SC_ONLY is not set # CONFIG_BT_SMP_OOB_LEGACY_PAIR_ONLY is not set # CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY is not set CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y # CONFIG_BT_ID_UNPAIR_MATCHING_BONDS is not set # CONFIG_BT_FIXED_PASSKEY is not set # CONFIG_BT_USE_DEBUG_KEYS is not set CONFIG_BT_BONDABLE=y # CONFIG_BT_BONDING_REQUIRED is not set # CONFIG_BT_STORE_DEBUG_KEYS is not set CONFIG_BT_SMP_ENFORCE_MITM=y CONFIG_BT_KEYS_OVERWRITE_OLDEST=y CONFIG_BT_SMP_MIN_ENC_KEY_SIZE=7 CONFIG_BT_L2CAP_TX_BUF_COUNT=8 CONFIG_BT_L2CAP_TX_FRAG_COUNT=2 # CONFIG_BT_L2CAP_DYNAMIC_CHANNEL is not set CONFIG_BT_L2CAP_LOG_LEVEL=3 CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set CONFIG_BT_ATT_ENFORCE_FLOW=y CONFIG_BT_ATT_PREPARE_COUNT=0 CONFIG_BT_ATT_RETRY_ON_SEC_ERR=y CONFIG_BT_GATT_SERVICE_CHANGED=y CONFIG_BT_GATT_DYNAMIC_DB=y CONFIG_BT_GATT_CACHING=y # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y # CONFIG_BT_GATT_CLIENT is not set CONFIG_BT_GATT_READ_MULTIPLE=y CONFIG_BT_GATT_READ_MULT_VAR_LEN=y CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24 CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40 CONFIG_BT_PERIPHERAL_PREF_LATENCY=0 CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42 CONFIG_BT_DEVICE_NAME_GATT_WRITABLE=y CONFIG_DEVICE_NAME_GATT_WRITABLE_ENCRYPT=y # CONFIG_DEVICE_NAME_GATT_WRITABLE_AUTHEN is not set CONFIG_BT_MAX_PAIRED=1 CONFIG_BT_CREATE_CONN_TIMEOUT=3 CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000 CONFIG_BT_CONN_PARAM_RETRY_COUNT=3 CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000 CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048 CONFIG_BT_BACKGROUND_SCAN_WINDOW=18 CONFIG_BT_EXT_SCAN_BUF_SIZE=229 # CONFIG_BT_SCAN_WITH_IDENTITY is not set CONFIG_BT_DEVICE_NAME_DYNAMIC=y CONFIG_BT_DEVICE_NAME_MAX=28 CONFIG_BT_DEVICE_NAME="Test_BLE" # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set CONFIG_BT_DEVICE_APPEARANCE=0 CONFIG_BT_ID_MAX=2 CONFIG_BT_ECC=y # CONFIG_BT_TINYCRYPT_ECC is not set CONFIG_BT_HOST_CCM=y # CONFIG_BT_LOG_SNIFFER_INFO is not set # CONFIG_BT_TESTING is not set # CONFIG_BT_BREDR is not set # CONFIG_BT_HCI_VS_EVT_USER is not set CONFIG_BT_CRYPTO=y # CONFIG_BT_DEBUG_CRYPTO is not set CONFIG_BT_CRYPTO_LOG_LEVEL=3 CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y # CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set # CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set # CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set # CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set # CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set # end of BLE over nRF RPC # end of Bluetooth Low Energy # # DFU # # CONFIG_DFU_MULTI_IMAGE is not set # CONFIG_DFU_TARGET is not set # end of DFU # CONFIG_ESB is not set # CONFIG_ESB_LOG_LEVEL_OFF is not set # CONFIG_ESB_LOG_LEVEL_ERR is not set # CONFIG_ESB_LOG_LEVEL_WRN is not set CONFIG_ESB_LOG_LEVEL_INF=y # CONFIG_ESB_LOG_LEVEL_DBG is not set CONFIG_ESB_LOG_LEVEL=3 # CONFIG_EMDS is not set # # Peripheral CPU DFU (PCD) # # CONFIG_PCD is not set # CONFIG_PCD_APP is not set # CONFIG_PCD_NET is not set # end of Peripheral CPU DFU (PCD) # # Networking # # # Application protocols # # # nRF Cloud # # # Client ID (nRF Cloud Device ID) # CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id" # end of Client ID (nRF Cloud Device ID) # CONFIG_NRF_CLOUD_MQTT is not set # CONFIG_NRF_CLOUD_FOTA is not set # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set # CONFIG_NRF_CLOUD_REST is not set # CONFIG_NRF_CLOUD_ALERTS is not set # CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_OFF is not set # CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_ERR is not set # CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_WRN is not set CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_INF=y # CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL_DBG is not set CONFIG_NRF_CLOUD_ALERTS_LOG_LEVEL=3 # CONFIG_NRF_CLOUD_GATEWAY is not set # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set CONFIG_NRF_CLOUD_LOG_LEVEL_INF=y # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set CONFIG_NRF_CLOUD_LOG_LEVEL=3 # end of nRF Cloud # CONFIG_REST_CLIENT is not set # CONFIG_DOWNLOAD_CLIENT is not set # CONFIG_AWS_IOT is not set # CONFIG_AWS_JOBS is not set # CONFIG_AZURE_IOT_HUB is not set # # Self-Registration (Zi ZHu Ce) # # end of Self-Registration (Zi ZHu Ce) # CONFIG_ICAL_PARSER is not set # CONFIG_FTP_CLIENT is not set # CONFIG_LWM2M_CLIENT_UTILS is not set # CONFIG_WIFI_CREDENTIALS is not set # CONFIG_WIFI_CREDENTIALS_STATIC is not set # CONFIG_MQTT_HELPER is not set # end of Application protocols # end of Networking # # NFC # # CONFIG_NFC_NDEF is not set # CONFIG_NFC_NDEF_PARSER is not set # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set # CONFIG_NFC_T2T_PARSER is not set # CONFIG_NFC_T4T_NDEF_FILE is not set # CONFIG_NFC_T4T_ISODEP is not set # CONFIG_NFC_T4T_APDU is not set # CONFIG_NFC_T4T_CC_FILE is not set # CONFIG_NFC_T4T_HL_PROCEDURE is not set # CONFIG_NFC_PLATFORM is not set # CONFIG_NFC_TNEP_TAG is not set # CONFIG_NFC_TNEP_POLLER is not set # CONFIG_NFC_TNEP_CH is not set # end of NFC # CONFIG_APP_EVENT_MANAGER is not set # CONFIG_NRF_PROFILER is not set # CONFIG_FW_INFO is not set # # Debug # # CONFIG_PPI_TRACE is not set # CONFIG_CPU_LOAD is not set # end of Debug # CONFIG_SHELL_BT_NUS is not set # CONFIG_MPSL_FEM_ONLY is not set CONFIG_MPSL_FEM_API_AVAILABLE=y # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set CONFIG_MPSL_FEM_LOG_LEVEL_INF=y # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set CONFIG_MPSL_FEM_LOG_LEVEL=3 CONFIG_MPSL_THREAD_COOP_PRIO=6 CONFIG_MPSL_WORK_STACK_SIZE=1024 CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0 # CONFIG_MPSL_ASSERT_HANDLER is not set # CONFIG_MPSL_LOG_LEVEL_OFF is not set # CONFIG_MPSL_LOG_LEVEL_ERR is not set # CONFIG_MPSL_LOG_LEVEL_WRN is not set CONFIG_MPSL_LOG_LEVEL_INF=y # CONFIG_MPSL_LOG_LEVEL_DBG is not set CONFIG_MPSL_LOG_LEVEL=3 # # Partition Manager # CONFIG_PARTITION_MANAGER_ENABLED=y CONFIG_FLASH_MAP_CUSTOM=y CONFIG_SRAM_SIZE=256 CONFIG_SRAM_BASE_ADDRESS=0x20000000 # # Zephyr subsystem configurations # CONFIG_PM_PARTITION_SIZE_NVS_STORAGE=0x6000 # end of Zephyr subsystem configurations # # NCS subsystem configurations # CONFIG_PM_SINGLE_IMAGE=y CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y CONFIG_PM_EXTERNAL_FLASH_BASE=0 # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set CONFIG_PM_SRAM_BASE=0x20000000 CONFIG_PM_SRAM_SIZE=0x40000 # end of Partition Manager # # nRF RPC (Remote Procedure Call) library # # end of nRF RPC (Remote Procedure Call) library # CONFIG_ZIGBEE is not set # # Full Modem Firmware Update Management(FMFU) # # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set CONFIG_MGMT_FMFU_LOG_LEVEL_INF=y # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set CONFIG_MGMT_FMFU_LOG_LEVEL=3 # end of Full Modem Firmware Update Management(FMFU) # CONFIG_CAF is not set # # Nordic IEEE 802.15.4 # # end of Nordic IEEE 802.15.4 # CONFIG_DM_MODULE is not set # # Libraries # # # Binary libraries # # end of Binary libraries # CONFIG_ADP536X is not set # CONFIG_AT_MONITOR is not set # CONFIG_DISABLE_FLASH_PATCH is not set # CONFIG_LTE_LINK_CONTROL is not set CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000 CONFIG_FPROTECT_BLOCK_SIZE=0x1000 # CONFIG_FPROTECT is not set # CONFIG_AT_CUSTOM_CMD is not set CONFIG_DK_LIBRARY=y CONFIG_DK_LIBRARY_BUTTON_SCAN_INTERVAL=10 CONFIG_DK_LIBRARY_DYNAMIC_BUTTON_HANDLERS=y # CONFIG_DK_LIBRARY_LOG_LEVEL_OFF is not set # CONFIG_DK_LIBRARY_LOG_LEVEL_ERR is not set # CONFIG_DK_LIBRARY_LOG_LEVEL_WRN is not set CONFIG_DK_LIBRARY_LOG_LEVEL_INF=y # CONFIG_DK_LIBRARY_LOG_LEVEL_DBG is not set CONFIG_DK_LIBRARY_LOG_LEVEL=3 # CONFIG_MODEM_INFO is not set CONFIG_MULTITHREADING_LOCK=y CONFIG_RESET_ON_FATAL_ERROR=y # CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set # CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set # CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set CONFIG_FATAL_ERROR_LOG_LEVEL_INF=y # CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set CONFIG_FATAL_ERROR_LOG_LEVEL=3 # CONFIG_SMS is not set # CONFIG_SUPL_CLIENT_LIB is not set # CONFIG_DATE_TIME is not set # CONFIG_HW_ID_LIBRARY is not set # CONFIG_RAM_POWER_DOWN_LIBRARY is not set # CONFIG_WAVE_GEN_LIB is not set # CONFIG_HW_UNIQUE_KEY_LOAD is not set CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000 # CONFIG_MODEM_JWT is not set # CONFIG_QOS is not set # CONFIG_SFLOAT is not set # CONFIG_CONTIN_ARRAY is not set # CONFIG_PCM_MIX is not set # CONFIG_TONE is not set # CONFIG_PSCM is not set # CONFIG_DATA_FIFO is not set # end of Libraries # # Device Drivers # # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set CONFIG_ENTROPY_CC3XX=y CONFIG_HW_CC3XX=y # CONFIG_ETH_RTT is not set # CONFIG_BH1749 is not set # CONFIG_SENSOR_SIM is not set # CONFIG_SENSOR_STUB is not set # CONFIG_PMW3360 is not set # CONFIG_PAW3212 is not set # CONFIG_NRF_SW_LPUART is not set CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1 CONFIG_CLOCK_CONTROL_MPSL=y CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL=y CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=1 CONFIG_TEMP_NRF5_MPSL=y # end of Device Drivers # # External libraries # # end of External libraries # # Test # CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y # CONFIG_UNITY is not set # # Mocks # # CONFIG_MOCK_NRF_MODEM_AT is not set # end of Mocks # end of Test # end of Nordic nRF Connect CONFIG_ZEPHYR_NRF_MODULE=y # end of nrf (C:/ncs/v2.3.0/nrf) # # hostap (C:/ncs/v2.3.0/modules/lib/hostap) # CONFIG_POSIX_MAX_FDS=4 CONFIG_ZEPHYR_HOSTAP_MODULE=y # end of hostap (C:/ncs/v2.3.0/modules/lib/hostap) # # mcuboot (C:/ncs/v2.3.0/bootloader/mcuboot) # # # MCUboot # CONFIG_SIGN_IMAGES=y # CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is not set # CONFIG_MCUBOOT_BUILD_STRATEGY_USE_HEX_FILE is not set # CONFIG_MCUBOOT_BUILD_STRATEGY_SKIP_BUILD is not set CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE=y CONFIG_MCUBOOT_IMAGE_VERSION="0.0.1" CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4 CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4 CONFIG_MCUBOOT_USB_SUPPORT=y # CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set # CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS is not set # end of MCUboot CONFIG_ZEPHYR_MCUBOOT_MODULE=y # end of mcuboot (C:/ncs/v2.3.0/bootloader/mcuboot) # # mbedtls (C:/ncs/v2.3.0/modules/crypto/mbedtls) # CONFIG_ZEPHYR_MBEDTLS_MODULE=y CONFIG_MBEDTLS_BUILTIN=y # CONFIG_MBEDTLS_LIBRARY is not set # end of mbedtls (C:/ncs/v2.3.0/modules/crypto/mbedtls) # # trusted-firmware-m (C:/ncs/v2.3.0/modules/tee/tf-m/trusted-firmware-m) # CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y # end of trusted-firmware-m (C:/ncs/v2.3.0/modules/tee/tf-m/trusted-firmware-m) # # cjson (C:/ncs/v2.3.0/modules/lib/cjson) # CONFIG_ZEPHYR_CJSON_MODULE=y # end of cjson (C:/ncs/v2.3.0/modules/lib/cjson) # # azure-sdk-for-c (C:/ncs/v2.3.0/modules/lib/azure-sdk-for-c) # # CONFIG_AZURE_SDK is not set CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y # end of azure-sdk-for-c (C:/ncs/v2.3.0/modules/lib/azure-sdk-for-c) # # memfault-firmware-sdk (C:/ncs/v2.3.0/modules/lib/memfault-firmware-sdk) # # CONFIG_MEMFAULT is not set CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y # end of memfault-firmware-sdk (C:/ncs/v2.3.0/modules/lib/memfault-firmware-sdk) # # cirrus-logic (C:/ncs/v2.3.0/modules/hal/cirrus-logic) # # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y # end of cirrus-logic (C:/ncs/v2.3.0/modules/hal/cirrus-logic) # # openthread (C:/ncs/v2.3.0/modules/lib/openthread) # # CONFIG_OPENTHREAD is not set CONFIG_ZEPHYR_OPENTHREAD_MODULE=y # end of openthread (C:/ncs/v2.3.0/modules/lib/openthread) # # canopennode (C:/ncs/v2.3.0/modules/lib/canopennode) # CONFIG_ZEPHYR_CANOPENNODE_MODULE=y # end of canopennode (C:/ncs/v2.3.0/modules/lib/canopennode) # # chre (C:/ncs/v2.3.0/modules/lib/chre) # CONFIG_ZEPHYR_CHRE_MODULE=y # CONFIG_CHRE is not set # end of chre (C:/ncs/v2.3.0/modules/lib/chre) # # fatfs (C:/ncs/v2.3.0/modules/fs/fatfs) # CONFIG_ZEPHYR_FATFS_MODULE=y # end of fatfs (C:/ncs/v2.3.0/modules/fs/fatfs) # # hal_nordic (C:/ncs/v2.3.0/modules/hal/nordic) # CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y CONFIG_HAS_NORDIC_DRIVERS=y # # Nordic drivers # # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set # CONFIG_NRF_802154_RADIO_DRIVER is not set # CONFIG_NRF_802154_SER_RADIO is not set # end of Nordic drivers CONFIG_HAS_NRFX=y # # nrfx drivers # # CONFIG_NRFX_CLOCK is not set # CONFIG_NRFX_COMP is not set # CONFIG_NRFX_EGU0 is not set # CONFIG_NRFX_EGU1 is not set # CONFIG_NRFX_EGU2 is not set # CONFIG_NRFX_EGU3 is not set # CONFIG_NRFX_EGU4 is not set # CONFIG_NRFX_EGU5 is not set CONFIG_NRFX_GPIOTE=y # CONFIG_NRFX_I2S is not set # CONFIG_NRFX_NFCT is not set CONFIG_NRFX_NVMC=y # CONFIG_NRFX_PDM is not set # CONFIG_NRFX_POWER is not set CONFIG_NRFX_PPI=y CONFIG_NRFX_PWM=y CONFIG_NRFX_PWM0=y CONFIG_NRFX_PWM1=y # CONFIG_NRFX_PWM2 is not set # CONFIG_NRFX_PWM3 is not set # CONFIG_NRFX_QDEC is not set CONFIG_NRFX_QSPI=y # CONFIG_NRFX_RNG is not set # CONFIG_NRFX_RTC0 is not set # CONFIG_NRFX_RTC1 is not set # CONFIG_NRFX_RTC2 is not set # CONFIG_NRFX_SAADC is not set # CONFIG_NRFX_SPI0 is not set # CONFIG_NRFX_SPI1 is not set # CONFIG_NRFX_SPI2 is not set # CONFIG_NRFX_SPIM3 is not set # CONFIG_NRFX_SYSTICK is not set # CONFIG_NRFX_TEMP is not set # CONFIG_NRFX_TIMER0 is not set # CONFIG_NRFX_TIMER1 is not set # CONFIG_NRFX_TIMER2 is not set # CONFIG_NRFX_TIMER3 is not set # CONFIG_NRFX_TIMER4 is not set # CONFIG_NRFX_TWI1 is not set CONFIG_NRFX_TWIM=y CONFIG_NRFX_TWIM0=y # CONFIG_NRFX_UARTE0 is not set # CONFIG_NRFX_UARTE1 is not set # CONFIG_NRFX_USBD is not set # CONFIG_NRFX_WDT0 is not set # # Peripheral Resource Sharing module # # CONFIG_NRFX_PRS_BOX_0 is not set # CONFIG_NRFX_PRS_BOX_1 is not set # CONFIG_NRFX_PRS_BOX_2 is not set # CONFIG_NRFX_PRS_BOX_3 is not set # CONFIG_NRFX_PRS_BOX_4 is not set # end of Peripheral Resource Sharing module # end of nrfx drivers # end of hal_nordic (C:/ncs/v2.3.0/modules/hal/nordic) # # liblc3 (C:/ncs/v2.3.0/modules/lib/liblc3) # CONFIG_ZEPHYR_LIBLC3_MODULE=y # end of liblc3 (C:/ncs/v2.3.0/modules/lib/liblc3) # # littlefs (C:/ncs/v2.3.0/modules/fs/littlefs) # CONFIG_ZEPHYR_LITTLEFS_MODULE=y # end of littlefs (C:/ncs/v2.3.0/modules/fs/littlefs) # # loramac-node (C:/ncs/v2.3.0/modules/lib/loramac-node) # CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set # end of loramac-node (C:/ncs/v2.3.0/modules/lib/loramac-node) # # lvgl (C:/ncs/v2.3.0/modules/lib/gui/lvgl) # CONFIG_ZEPHYR_LVGL_MODULE=y # end of lvgl (C:/ncs/v2.3.0/modules/lib/gui/lvgl) # # lz4 (C:/ncs/v2.3.0/modules/lib/lz4) # CONFIG_ZEPHYR_LZ4_MODULE=y # CONFIG_LZ4 is not set # end of lz4 (C:/ncs/v2.3.0/modules/lib/lz4) # # nanopb (C:/ncs/v2.3.0/modules/lib/nanopb) # CONFIG_ZEPHYR_NANOPB_MODULE=y # CONFIG_NANOPB is not set # end of nanopb (C:/ncs/v2.3.0/modules/lib/nanopb) # # picolibc (C:/ncs/v2.3.0/modules/lib/picolibc) # # CONFIG_PICOLIBC_MODULE is not set CONFIG_ZEPHYR_PICOLIBC_MODULE=y # end of picolibc (C:/ncs/v2.3.0/modules/lib/picolibc) # # TraceRecorder (C:/ncs/v2.3.0/modules/debug/TraceRecorder) # CONFIG_ZEPHYR_TRACERECORDER_MODULE=y # end of TraceRecorder (C:/ncs/v2.3.0/modules/debug/TraceRecorder) # # uoscore-uedhoc (C:/ncs/v2.3.0/modules/lib/uoscore-uedhoc) # CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y # end of uoscore-uedhoc (C:/ncs/v2.3.0/modules/lib/uoscore-uedhoc) # # zcbor (C:/ncs/v2.3.0/modules/lib/zcbor) # CONFIG_ZEPHYR_ZCBOR_MODULE=y CONFIG_ZCBOR=y # CONFIG_ZCBOR_CANONICAL is not set # CONFIG_ZCBOR_STOP_ON_ERROR is not set # CONFIG_ZCBOR_VERBOSE is not set CONFIG_ZCBOR_ASSERT=y # end of zcbor (C:/ncs/v2.3.0/modules/lib/zcbor) # # zscilib (C:/ncs/v2.3.0/modules/lib/zscilib) # # CONFIG_ZSL is not set CONFIG_ZEPHYR_ZSCILIB_MODULE=y # end of zscilib (C:/ncs/v2.3.0/modules/lib/zscilib) # # nrfxlib (C:/ncs/v2.3.0/nrfxlib) # # # Nordic nrfxlib # CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8 # CONFIG_NFC_T2T_NRFXLIB is not set # CONFIG_NFC_T4T_NRFXLIB is not set CONFIG_MPSL=y CONFIG_MPSL_BUILD_TYPE_LIB=y # # Crypto libraries for nRF5x SOCs. # CONFIG_NRFXLIB_CRYPTO=y CONFIG_CRYPTOCELL_CC310_USABLE=y CONFIG_CRYPTOCELL_USABLE=y CONFIG_NRF_OBERON=y # CONFIG_NRF_CC310_BL is not set CONFIG_NRF_CC3XX_PLATFORM=y # CONFIG_HW_CC3XX_INTERRUPT is not set CONFIG_CC3XX_MUTEX_LOCK=y # CONFIG_CC3XX_ATOMIC_LOCK is not set # end of Crypto libraries for nRF5x SOCs. # # nrf_security module # # CONFIG_NORDIC_SECURITY_BACKEND is not set # CONFIG_NRF_SECURITY is not set # end of nrf_security module # CONFIG_NRF_RPC is not set CONFIG_NRF_802154_SOURCE_NRFXLIB=y # CONFIG_GZLL is not set # CONFIG_NRF_DM is not set # CONFIG_LC3_PLC_DISABLED is not set CONFIG_LC3_ENC_CHAN_MAX=1 CONFIG_LC3_DEC_CHAN_MAX=1 # # Encoder sample rates # CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y # end of Encoder sample rates # # Decoder sample rates # CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y # end of Decoder sample rates # end of Nordic nrfxlib CONFIG_ZEPHYR_NRFXLIB_MODULE=y # end of nrfxlib (C:/ncs/v2.3.0/nrfxlib) # # connectedhomeip (C:/ncs/v2.3.0/modules/lib/matter) # # CONFIG_CHIP is not set # CONFIG_CHIP_LOG_SIZE_OPTIMIZATION is not set CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y # end of connectedhomeip (C:/ncs/v2.3.0/modules/lib/matter) # # Optional modules. Make sure they're installed, via the project manifest. # CONFIG_HAS_CMSIS_CORE=y CONFIG_HAS_CMSIS_CORE_M=y # CONFIG_CMSIS_NN is not set # CONFIG_LIBMETAL is not set # CONFIG_LVGL is not set # CONFIG_HAS_MEC_HAL is not set # CONFIG_HAS_MPFS_HAL is not set # CONFIG_OPENAMP is not set # CONFIG_SOF is not set # CONFIG_MIPI_SYST_LIB is not set # CONFIG_HAS_TELINK_DRIVERS is not set # CONFIG_TINYCBOR is not set # CONFIG_TINYCRYPT_CTR_PRNG is not set # CONFIG_TINYCRYPT_SHA256 is not set # CONFIG_TINYCRYPT_ECC_DH is not set # CONFIG_TINYCRYPT_ECC_DSA is not set CONFIG_TINYCRYPT_AES=y # CONFIG_TINYCRYPT_AES_CBC is not set # CONFIG_TINYCRYPT_AES_CTR is not set # CONFIG_TINYCRYPT_AES_CCM is not set CONFIG_TINYCRYPT_AES_CMAC=y CONFIG_MCUBOOT_BOOTUTIL_LIB=y CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF=y # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3 # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set # # Unavailable modules, please install those via the project manifest. # # # hal_gigadevice module not available. # # # Trusted-firmware-a module not available. # # end of Modules CONFIG_BOARD_REVISION="$BOARD_REVISION" # CONFIG_NET_DRIVERS is not set CONFIG_BOARD_NRF52840DK_NRF52840=y # # Board Options # CONFIG_BOARD_ENABLE_DCDC=y CONFIG_BOARD_ENABLE_DCDC_HV=y # end of Board Options # CONFIG_SOC_SERIES_BEETLE is not set # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set # CONFIG_SOC_SERIES_MPS2 is not set # CONFIG_SOC_SERIES_MPS3 is not set # CONFIG_SOC_SERIES_MUSCA_B1 is not set # CONFIG_SOC_SERIES_MUSCA_S1 is not set # CONFIG_SOC_SERIES_AST10X0 is not set # CONFIG_SOC_SERIES_SAMC20 is not set # CONFIG_SOC_SERIES_SAMC21 is not set # CONFIG_SOC_SERIES_SAMD20 is not set # CONFIG_SOC_SERIES_SAMD21 is not set # CONFIG_SOC_SERIES_SAMD51 is not set # CONFIG_SOC_SERIES_SAME51 is not set # CONFIG_SOC_SERIES_SAME53 is not set # CONFIG_SOC_SERIES_SAME54 is not set # CONFIG_SOC_SERIES_SAML21 is not set # CONFIG_SOC_SERIES_SAMR21 is not set # CONFIG_SOC_SERIES_SAMR34 is not set # CONFIG_SOC_SERIES_SAMR35 is not set # CONFIG_SOC_SERIES_SAM3X is not set # CONFIG_SOC_SERIES_SAM4E is not set # CONFIG_SOC_SERIES_SAM4L is not set # CONFIG_SOC_SERIES_SAM4S is not set # CONFIG_SOC_SERIES_SAME70 is not set # CONFIG_SOC_SERIES_SAMV71 is not set # CONFIG_SOC_SERIES_VALKYRIE is not set # CONFIG_SOC_SERIES_VIPER is not set # CONFIG_SOC_SERIES_PSOC62 is not set # CONFIG_SOC_SERIES_PSOC63 is not set # CONFIG_SOC_SERIES_GD32E10X is not set # CONFIG_SOC_SERIES_GD32E50X is not set # CONFIG_SOC_SERIES_GD32F3X0 is not set # CONFIG_SOC_SERIES_GD32F403 is not set # CONFIG_SOC_SERIES_GD32F4XX is not set # CONFIG_SOC_SERIES_XMC_4XXX is not set # CONFIG_SOC_SERIES_CYCLONE5 is not set # CONFIG_SOC_SERIES_MEC1501X is not set # CONFIG_SOC_SERIES_MEC1701X is not set # CONFIG_SOC_SERIES_MEC172X is not set # CONFIG_SOC_SERIES_NRF51X is not set CONFIG_SOC_SERIES_NRF52X=y # CONFIG_SOC_SERIES_NRF53X is not set # CONFIG_SOC_SERIES_NRF91X is not set # CONFIG_SOC_SERIES_NPCX7 is not set # CONFIG_SOC_SERIES_NPCX9 is not set # CONFIG_SOC_SERIES_M48X is not set # CONFIG_SOC_SERIES_IMX_6X_M4 is not set # CONFIG_SOC_SERIES_IMX7_M4 is not set # CONFIG_SOC_SERIES_IMX8ML_M7 is not set # CONFIG_SOC_SERIES_IMX8MM_M4 is not set # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set # CONFIG_SOC_SERIES_IMX_RT5XX is not set # CONFIG_SOC_SERIES_IMX_RT6XX is not set # CONFIG_SOC_SERIES_IMX_RT is not set # CONFIG_SOC_SERIES_KINETIS_K2X is not set # CONFIG_SOC_SERIES_KINETIS_K6X is not set # CONFIG_SOC_SERIES_KINETIS_K8X is not set # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set # CONFIG_SOC_SERIES_KINETIS_KL2X is not set # CONFIG_SOC_SERIES_KINETIS_KV5X is not set # CONFIG_SOC_SERIES_KINETIS_KWX is not set # CONFIG_SOC_SERIES_LPC11U6X is not set # CONFIG_SOC_SERIES_LPC51U68 is not set # CONFIG_SOC_SERIES_LPC54XXX is not set # CONFIG_SOC_SERIES_LPC55XXX is not set # CONFIG_SOC_SERIES_S32ZE_R52 is not set # CONFIG_SOC_EOS_S3 is not set # CONFIG_SOC_SERIES_RCAR_GEN3 is not set # CONFIG_SOC_SERIES_DA1469X is not set # CONFIG_SOC_SERIES_RP2XXX is not set # CONFIG_SOC_SERIES_EFM32GG11B is not set # CONFIG_SOC_SERIES_EFM32HG is not set # CONFIG_SOC_SERIES_EFM32JG12B is not set # CONFIG_SOC_SERIES_EFM32PG12B is not set # CONFIG_SOC_SERIES_EFM32PG1B is not set # CONFIG_SOC_SERIES_EFM32WG is not set # CONFIG_SOC_SERIES_EFR32BG13P is not set # CONFIG_SOC_SERIES_EFR32FG13P is not set # CONFIG_SOC_SERIES_EFR32FG1P is not set # CONFIG_SOC_SERIES_EFR32MG12P is not set # CONFIG_SOC_SERIES_EFR32MG21 is not set # CONFIG_SOC_SERIES_STM32F0X is not set # CONFIG_SOC_SERIES_STM32F1X is not set # CONFIG_SOC_SERIES_STM32F2X is not set # CONFIG_SOC_SERIES_STM32F3X is not set # CONFIG_SOC_SERIES_STM32F4X is not set # CONFIG_SOC_SERIES_STM32F7X is not set # CONFIG_SOC_SERIES_STM32G0X is not set # CONFIG_SOC_SERIES_STM32G4X is not set # CONFIG_SOC_SERIES_STM32H7X is not set # CONFIG_SOC_SERIES_STM32L0X is not set # CONFIG_SOC_SERIES_STM32L1X is not set # CONFIG_SOC_SERIES_STM32L4X is not set # CONFIG_SOC_SERIES_STM32L5X is not set # CONFIG_SOC_SERIES_STM32MP1X is not set # CONFIG_SOC_SERIES_STM32U5X is not set # CONFIG_SOC_SERIES_STM32WBX is not set # CONFIG_SOC_SERIES_STM32WLX is not set # CONFIG_SOC_TI_LM3S6965 is not set # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set # CONFIG_SOC_SERIES_CC32XX is not set # CONFIG_SOC_SERIES_MSP432P4XX is not set # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set # # Hardware Configuration # CONFIG_CPU_HAS_ARM_MPU=y CONFIG_HAS_SWO=y CONFIG_SOC_FAMILY="nordic_nrf" CONFIG_SOC_FAMILY_NRF=y CONFIG_HAS_HW_NRF_ACL=y CONFIG_HAS_HW_NRF_CC310=y CONFIG_HAS_HW_NRF_CCM=y CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y CONFIG_HAS_HW_NRF_CLOCK=y CONFIG_HAS_HW_NRF_ECB=y CONFIG_HAS_HW_NRF_EGU0=y CONFIG_HAS_HW_NRF_EGU1=y CONFIG_HAS_HW_NRF_EGU2=y CONFIG_HAS_HW_NRF_EGU3=y CONFIG_HAS_HW_NRF_EGU4=y CONFIG_HAS_HW_NRF_EGU5=y CONFIG_HAS_HW_NRF_GPIO0=y CONFIG_HAS_HW_NRF_GPIO1=y CONFIG_HAS_HW_NRF_GPIOTE=y CONFIG_HAS_HW_NRF_MWU=y CONFIG_HAS_HW_NRF_NVMC_PE=y CONFIG_HAS_HW_NRF_POWER=y CONFIG_HAS_HW_NRF_PPI=y CONFIG_HAS_HW_NRF_PWM0=y CONFIG_HAS_HW_NRF_PWM1=y CONFIG_HAS_HW_NRF_QSPI=y CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y CONFIG_HAS_HW_NRF_RNG=y CONFIG_HAS_HW_NRF_RTC0=y CONFIG_HAS_HW_NRF_RTC1=y CONFIG_HAS_HW_NRF_RTC2=y CONFIG_HAS_HW_NRF_SAADC=y CONFIG_HAS_HW_NRF_SPI1=y CONFIG_HAS_HW_NRF_SPIM3=y CONFIG_HAS_HW_NRF_SWI0=y CONFIG_HAS_HW_NRF_SWI1=y CONFIG_HAS_HW_NRF_SWI2=y CONFIG_HAS_HW_NRF_SWI3=y CONFIG_HAS_HW_NRF_SWI4=y CONFIG_HAS_HW_NRF_SWI5=y CONFIG_HAS_HW_NRF_TEMP=y CONFIG_HAS_HW_NRF_TIMER0=y CONFIG_HAS_HW_NRF_TIMER1=y CONFIG_HAS_HW_NRF_TIMER2=y CONFIG_HAS_HW_NRF_TIMER3=y CONFIG_HAS_HW_NRF_TIMER4=y CONFIG_HAS_HW_NRF_TWIM0=y CONFIG_HAS_HW_NRF_UARTE0=y CONFIG_HAS_HW_NRF_UARTE1=y CONFIG_HAS_HW_NRF_USBD=y CONFIG_HAS_HW_NRF_WDT0=y CONFIG_NRF_HW_RTC1_RESERVED=y CONFIG_SOC_NRF52840=y # CONFIG_SOC_NRF52805_CAAA is not set # CONFIG_SOC_NRF52810_QFAA is not set # CONFIG_SOC_NRF52811_QFAA is not set # CONFIG_SOC_NRF52820_QDAA is not set # CONFIG_SOC_NRF52832_CIAA is not set # CONFIG_SOC_NRF52832_QFAA is not set # CONFIG_SOC_NRF52832_QFAB is not set # CONFIG_SOC_NRF52833_QIAA is not set CONFIG_SOC_NRF52840_QIAA=y CONFIG_SOC_DCDC_NRF52X=y CONFIG_SOC_DCDC_NRF52X_HV=y CONFIG_GPIO_AS_PINRESET=y CONFIG_NRF_ENABLE_ICACHE=y CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0 CONFIG_NRF_SOC_SECURE_SUPPORTED=y # CONFIG_NFCT_PINS_AS_GPIOS is not set CONFIG_NRF_APPROTECT_USE_UICR=y # CONFIG_NRF_APPROTECT_LOCK is not set # CONFIG_NRF_TRACE_PORT is not set # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set # CONFIG_SOC_LOG_LEVEL_OFF is not set # CONFIG_SOC_LOG_LEVEL_ERR is not set # CONFIG_SOC_LOG_LEVEL_WRN is not set CONFIG_SOC_LOG_LEVEL_INF=y # CONFIG_SOC_LOG_LEVEL_DBG is not set CONFIG_SOC_LOG_LEVEL=3 # end of Hardware Configuration CONFIG_SOC_COMPATIBLE_NRF=y CONFIG_SOC_COMPATIBLE_NRF52X=y # # ARM Options # CONFIG_ARCH="arm" CONFIG_CPU_CORTEX=y # CONFIG_CODE_DATA_RELOCATION_SRAM is not set CONFIG_CPU_CORTEX_M=y CONFIG_ISA_THUMB2=y CONFIG_ASSEMBLER_ISA_THUMB2=y CONFIG_COMPILER_ISA_THUMB2=y CONFIG_STACK_ALIGN_DOUBLE_WORD=y # CONFIG_RUNTIME_NMI is not set CONFIG_FAULT_DUMP=2 CONFIG_ARM_STACK_PROTECTION=y CONFIG_FP16=y CONFIG_FP16_IEEE=y # CONFIG_FP16_ALT is not set CONFIG_CPU_CORTEX_M4=y CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y CONFIG_CPU_CORTEX_M_HAS_DWT=y CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y CONFIG_CPU_CORTEX_M_HAS_VTOR=y CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y CONFIG_ARMV7_M_ARMV8_M_FP=y # # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options # CONFIG_GEN_ISR_TABLES=y CONFIG_ZERO_LATENCY_IRQS=y CONFIG_ZERO_LATENCY_LEVELS=1 # CONFIG_SW_VECTOR_RELAY is not set # CONFIG_CORTEX_M_DWT is not set # CONFIG_TRAP_UNALIGNED_ACCESS is not set # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set CONFIG_GEN_IRQ_VECTOR_TABLE=y CONFIG_ARM_MPU=y CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32 CONFIG_MPU_STACK_GUARD=y CONFIG_MPU_ALLOW_FLASH_WRITE=y # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set # CONFIG_CUSTOM_SECTION_ALIGN is not set CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32 # end of ARM Options CONFIG_ARM=y CONFIG_ARCH_IS_SET=y # # General Architecture Options # # CONFIG_SEMIHOST is not set # CONFIG_ARCH_LOG_LEVEL_OFF is not set # CONFIG_ARCH_LOG_LEVEL_ERR is not set # CONFIG_ARCH_LOG_LEVEL_WRN is not set CONFIG_ARCH_LOG_LEVEL_INF=y # CONFIG_ARCH_LOG_LEVEL_DBG is not set CONFIG_ARCH_LOG_LEVEL=3 CONFIG_LITTLE_ENDIAN=y CONFIG_HW_STACK_PROTECTION=y # CONFIG_USERSPACE is not set CONFIG_KOBJECT_TEXT_AREA=256 CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100 CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16 CONFIG_GEN_PRIV_STACKS=y # CONFIG_STACK_GROWS_UP is not set # # Interrupt Configuration # # CONFIG_DYNAMIC_INTERRUPTS is not set CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4 CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set CONFIG_GEN_SW_ISR_TABLE=y CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4 CONFIG_GEN_IRQ_START_VECTOR=0 # CONFIG_EXTRA_EXCEPTION_INFO is not set # end of Interrupt Configuration # end of General Architecture Options CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y CONFIG_ARCH_HAS_STACK_PROTECTION=y CONFIG_ARCH_HAS_USERSPACE=y CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y CONFIG_ARCH_SUPPORTS_COREDUMP=y CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y CONFIG_ARCH_HAS_THREAD_ABORT=y CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y CONFIG_CPU_HAS_FPU=y CONFIG_CPU_HAS_MPU=y CONFIG_MPU=y # CONFIG_MPU_LOG_LEVEL_OFF is not set # CONFIG_MPU_LOG_LEVEL_ERR is not set # CONFIG_MPU_LOG_LEVEL_WRN is not set CONFIG_MPU_LOG_LEVEL_INF=y # CONFIG_MPU_LOG_LEVEL_DBG is not set CONFIG_MPU_LOG_LEVEL=3 CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y CONFIG_SRAM_REGION_PERMISSIONS=y # # Floating Point Options # # end of Floating Point Options # # Cache Options # # end of Cache Options CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y # # General Kernel Options # # CONFIG_KERNEL_LOG_LEVEL_OFF is not set # CONFIG_KERNEL_LOG_LEVEL_ERR is not set # CONFIG_KERNEL_LOG_LEVEL_WRN is not set CONFIG_KERNEL_LOG_LEVEL_INF=y # CONFIG_KERNEL_LOG_LEVEL_DBG is not set CONFIG_KERNEL_LOG_LEVEL=3 CONFIG_MULTITHREADING=y CONFIG_NUM_COOP_PRIORITIES=16 CONFIG_NUM_PREEMPT_PRIORITIES=15 CONFIG_MAIN_THREAD_PRIORITY=0 CONFIG_COOP_ENABLED=y CONFIG_PREEMPT_ENABLED=y CONFIG_PRIORITY_CEILING=-127 # CONFIG_SCHED_DEADLINE is not set # CONFIG_SCHED_CPU_MASK is not set CONFIG_IDLE_STACK_SIZE=320 CONFIG_ISR_STACK_SIZE=2048 CONFIG_THREAD_STACK_INFO=y # CONFIG_THREAD_CUSTOM_DATA is not set CONFIG_ERRNO=y CONFIG_SCHED_DUMB=y # CONFIG_SCHED_SCALABLE is not set # CONFIG_SCHED_MULTIQ is not set # CONFIG_WAITQ_SCALABLE is not set CONFIG_WAITQ_DUMB=y # # Kernel Debugging and Metrics # CONFIG_BOOT_BANNER=y CONFIG_BOOT_DELAY=0 # CONFIG_THREAD_MONITOR is not set # CONFIG_THREAD_NAME is not set # CONFIG_THREAD_RUNTIME_STATS is not set # end of Kernel Debugging and Metrics # # Work Queue Options # CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1 # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set # end of Work Queue Options # # Atomic Operations # CONFIG_ATOMIC_OPERATIONS_BUILTIN=y # end of Atomic Operations # # Timer API Options # CONFIG_TIMESLICING=y CONFIG_TIMESLICE_SIZE=0 CONFIG_TIMESLICE_PRIORITY=0 # CONFIG_TIMESLICE_PER_THREAD is not set CONFIG_POLL=y # end of Timer API Options # # Other Kernel Object Options # # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set CONFIG_NUM_MBOX_ASYNC_MSGS=10 # CONFIG_EVENTS is not set # CONFIG_PIPES is not set CONFIG_KERNEL_MEM_POOL=y # end of Other Kernel Object Options CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y CONFIG_SWAP_NONATOMIC=y CONFIG_SYS_CLOCK_EXISTS=y CONFIG_TIMEOUT_64BIT=y CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365 CONFIG_XIP=y # # Initialization Priorities # CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30 CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40 CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50 CONFIG_APPLICATION_INIT_PRIORITY=90 # end of Initialization Priorities # # Security Options # # CONFIG_STACK_CANARIES is not set CONFIG_STACK_POINTER_RANDOM=0 # end of Security Options # # SMP Options # CONFIG_MP_NUM_CPUS=1 # end of SMP Options CONFIG_TICKLESS_KERNEL=y CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y # CONFIG_THREAD_LOCAL_STORAGE is not set # end of General Kernel Options # # Device Options # # end of Device Options # # Virtual Memory Support # # end of Virtual Memory Support # # Device Drivers # # CONFIG_LORA is not set CONFIG_CONSOLE=y CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128 CONFIG_CONSOLE_HAS_DRIVER=y # CONFIG_CONSOLE_HANDLER is not set CONFIG_CONSOLE_INIT_PRIORITY=60 CONFIG_UART_CONSOLE=y # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set # CONFIG_UART_CONSOLE_MCUMGR is not set CONFIG_UART_CONSOLE_INPUT_EXPIRED=y CONFIG_UART_CONSOLE_INPUT_EXPIRED_TIMEOUT=15000 # CONFIG_RAM_CONSOLE is not set # CONFIG_RTT_CONSOLE is not set # CONFIG_IPM_CONSOLE_SENDER is not set # CONFIG_IPM_CONSOLE_RECEIVER is not set # CONFIG_UART_MCUMGR is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set CONFIG_UART_CONSOLE_LOG_LEVEL_INF=y # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set CONFIG_UART_CONSOLE_LOG_LEVEL=3 # CONFIG_GSM_MUX is not set # CONFIG_EFI_CONSOLE is not set CONFIG_HAS_SEGGER_RTT=y CONFIG_USE_SEGGER_RTT=y CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3 CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3 CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024 CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16 CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64 CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set CONFIG_SEGGER_RTT_MODE=0 # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set CONFIG_SEGGER_RTT_SECTION_NONE=y # CONFIG_SEGGER_RTT_SECTION_DTCM is not set CONFIG_ETH_INIT_PRIORITY=80 # CONFIG_MDIO is not set # # Capabilities # CONFIG_SERIAL_HAS_DRIVER=y CONFIG_SERIAL_SUPPORT_ASYNC=y CONFIG_SERIAL_SUPPORT_INTERRUPT=y # CONFIG_UART_LOG_LEVEL_OFF is not set # CONFIG_UART_LOG_LEVEL_ERR is not set # CONFIG_UART_LOG_LEVEL_WRN is not set CONFIG_UART_LOG_LEVEL_INF=y # CONFIG_UART_LOG_LEVEL_DBG is not set CONFIG_UART_LOG_LEVEL=3 CONFIG_UART_USE_RUNTIME_CONFIGURE=y # CONFIG_UART_ASYNC_API is not set # CONFIG_UART_LINE_CTRL is not set # CONFIG_UART_DRV_CMD is not set # CONFIG_UART_WIDE_DATA is not set # CONFIG_UART_PIPE is not set # # Serial Drivers # CONFIG_UART_NRFX=y CONFIG_UART_0_NRF_UARTE=y CONFIG_UART_0_ENHANCED_POLL_OUT=y # CONFIG_UART_0_NRF_PARITY_BIT is not set CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32 CONFIG_UART_1_NRF_UARTE=y CONFIG_UART_1_ENHANCED_POLL_OUT=y # CONFIG_UART_1_NRF_PARITY_BIT is not set CONFIG_UART_ENHANCED_POLL_OUT=y CONFIG_NRF_UARTE_PERIPHERAL=y # # Interrupt Controllers # CONFIG_INTC_INIT_PRIORITY=40 # CONFIG_INTC_LOG_LEVEL_OFF is not set # CONFIG_INTC_LOG_LEVEL_ERR is not set # CONFIG_INTC_LOG_LEVEL_WRN is not set CONFIG_INTC_LOG_LEVEL_INF=y # CONFIG_INTC_LOG_LEVEL_DBG is not set CONFIG_INTC_LOG_LEVEL=3 # CONFIG_MULTI_LEVEL_INTERRUPTS is not set # CONFIG_INTC_ESP32 is not set # end of Interrupt Controllers # # Timer Drivers # # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0 CONFIG_TICKLESS_CAPABLE=y CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y # end of Timer Drivers # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set CONFIG_ENTROPY_LOG_LEVEL_INF=y # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set CONFIG_ENTROPY_LOG_LEVEL=3 CONFIG_ENTROPY_INIT_PRIORITY=50 CONFIG_ENTROPY_NRF5_RNG=y # CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8 CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4 CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16 CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12 CONFIG_ENTROPY_BT_HCI=y CONFIG_ENTROPY_HAS_DRIVER=y # CONFIG_PCIE is not set # CONFIG_PCIE_ENDPOINT is not set # CONFIG_GPIO_LOG_LEVEL_OFF is not set # CONFIG_GPIO_LOG_LEVEL_ERR is not set # CONFIG_GPIO_LOG_LEVEL_WRN is not set CONFIG_GPIO_LOG_LEVEL_INF=y # CONFIG_GPIO_LOG_LEVEL_DBG is not set CONFIG_GPIO_LOG_LEVEL=3 # CONFIG_GPIO_GET_DIRECTION is not set # CONFIG_GPIO_GET_CONFIG is not set CONFIG_GPIO_NRFX=y # CONFIG_FXL6408_LOG_LEVEL_OFF is not set # CONFIG_FXL6408_LOG_LEVEL_ERR is not set # CONFIG_FXL6408_LOG_LEVEL_WRN is not set CONFIG_FXL6408_LOG_LEVEL_INF=y # CONFIG_FXL6408_LOG_LEVEL_DBG is not set CONFIG_FXL6408_LOG_LEVEL=3 # CONFIG_SDHC is not set # CONFIG_I2C_CALLBACK is not set # CONFIG_I2C_TARGET is not set CONFIG_I2C_NRFX=y CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500 CONFIG_I2C_0_NRF_TWIM=y CONFIG_I2C_INIT_PRIORITY=50 # CONFIG_I2C_LOG_LEVEL_OFF is not set # CONFIG_I2C_LOG_LEVEL_ERR is not set # CONFIG_I2C_LOG_LEVEL_WRN is not set CONFIG_I2C_LOG_LEVEL_INF=y # CONFIG_I2C_LOG_LEVEL_DBG is not set CONFIG_I2C_LOG_LEVEL=3 # CONFIG_I3C is not set # CONFIG_I2S is not set # CONFIG_DAI is not set CONFIG_PWM=y # CONFIG_PWM_LOG_LEVEL_OFF is not set # CONFIG_PWM_LOG_LEVEL_ERR is not set # CONFIG_PWM_LOG_LEVEL_WRN is not set # CONFIG_PWM_LOG_LEVEL_INF is not set CONFIG_PWM_LOG_LEVEL_DBG=y CONFIG_PWM_LOG_LEVEL=4 CONFIG_PWM_INIT_PRIORITY=50 # CONFIG_PWM_CAPTURE is not set CONFIG_PWM_NRFX=y # CONFIG_PINMUX is not set # CONFIG_ADC is not set # CONFIG_DAC is not set # CONFIG_W1 is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF=y # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set CONFIG_CLOCK_CONTROL_LOG_LEVEL=3 CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y CONFIG_CLOCK_CONTROL_NRF=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50 # CONFIG_PTP_CLOCK is not set # CONFIG_IPM is not set CONFIG_FLASH_HAS_DRIVER_ENABLED=y CONFIG_FLASH_HAS_PAGE_LAYOUT=y CONFIG_FLASH_JESD216=y CONFIG_FLASH=y # CONFIG_FLASH_LOG_LEVEL_OFF is not set # CONFIG_FLASH_LOG_LEVEL_ERR is not set # CONFIG_FLASH_LOG_LEVEL_WRN is not set CONFIG_FLASH_LOG_LEVEL_INF=y # CONFIG_FLASH_LOG_LEVEL_DBG is not set CONFIG_FLASH_LOG_LEVEL=3 # CONFIG_FLASH_JESD216_API is not set CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_INIT_PRIORITY=50 CONFIG_SOC_FLASH_NRF=y # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE is not set CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE=y CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE_MS=3 CONFIG_SOC_FLASH_NRF_TIMEOUT_MULTIPLIER=10 # CONFIG_SOC_FLASH_NRF_UICR is not set # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set CONFIG_NORDIC_QSPI_NOR_INIT_PRIORITY=80 # CONFIG_SENSOR_LOG_LEVEL_OFF is not set # CONFIG_SENSOR_LOG_LEVEL_ERR is not set # CONFIG_SENSOR_LOG_LEVEL_WRN is not set CONFIG_SENSOR_LOG_LEVEL_INF=y # CONFIG_SENSOR_LOG_LEVEL_DBG is not set CONFIG_SENSOR_LOG_LEVEL=3 CONFIG_SENSOR_INIT_PRIORITY=90 # CONFIG_SENSOR_INFO is not set # # Device Drivers # CONFIG_TEMP_NRF5_FORCE_ALT=y CONFIG_TEMP_NRF5=y CONFIG_TMP112_FULL_SCALE_RUNTIME=y CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME=y # CONFIG_COUNTER is not set # CONFIG_DMA is not set # CONFIG_UDC_DRIVER is not set # CONFIG_USB_DEVICE_DRIVER is not set # CONFIG_CRYPTO is not set # CONFIG_DISPLAY is not set # CONFIG_LED_STRIP is not set CONFIG_LED=y # CONFIG_LED_LOG_LEVEL_OFF is not set # CONFIG_LED_LOG_LEVEL_ERR is not set # CONFIG_LED_LOG_LEVEL_WRN is not set CONFIG_LED_LOG_LEVEL_INF=y # CONFIG_LED_LOG_LEVEL_DBG is not set CONFIG_LED_LOG_LEVEL=3 CONFIG_LED_INIT_PRIORITY=90 CONFIG_LED_GPIO=y CONFIG_LED_PWM=y # CONFIG_CAN is not set # CONFIG_AUDIO is not set # CONFIG_NEURAL_NET_ACCEL is not set CONFIG_HWINFO=y # CONFIG_HWINFO_LOG_LEVEL_OFF is not set # CONFIG_HWINFO_LOG_LEVEL_ERR is not set # CONFIG_HWINFO_LOG_LEVEL_WRN is not set CONFIG_HWINFO_LOG_LEVEL_INF=y # CONFIG_HWINFO_LOG_LEVEL_DBG is not set CONFIG_HWINFO_LOG_LEVEL=3 CONFIG_HWINFO_NRF=y # CONFIG_ESPI is not set # CONFIG_PS2 is not set # CONFIG_VIDEO is not set # CONFIG_EEPROM is not set # CONFIG_PECI is not set # CONFIG_PECI_INTERRUPT_DRIVEN is not set # CONFIG_REGULATOR is not set # CONFIG_MEMC is not set # CONFIG_VIRTUALIZATION is not set # CONFIG_EDAC is not set # CONFIG_PM_CPU_OPS is not set # # Miscellaneous Drivers # # CONFIG_GROVE_LCD_RGB is not set # end of Miscellaneous Drivers # CONFIG_DISK_DRIVERS is not set # CONFIG_CACHE is not set # CONFIG_SYSCON is not set # CONFIG_BBRAM is not set # CONFIG_FPGA is not set # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set CONFIG_PINCTRL_LOG_LEVEL_INF=y # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set CONFIG_PINCTRL_LOG_LEVEL=3 CONFIG_PINCTRL_STORE_REG=y # CONFIG_PINCTRL_DYNAMIC is not set CONFIG_PINCTRL_NRF=y # CONFIG_MBOX is not set # CONFIG_MM_DRV is not set # CONFIG_POWER_DOMAIN is not set # CONFIG_USBC_TCPC_DRIVER is not set # CONFIG_USBC_LOG_LEVEL_OFF is not set # CONFIG_USBC_LOG_LEVEL_ERR is not set # CONFIG_USBC_LOG_LEVEL_WRN is not set CONFIG_USBC_LOG_LEVEL_INF=y # CONFIG_USBC_LOG_LEVEL_DBG is not set CONFIG_USBC_LOG_LEVEL=3 # CONFIG_USBC_VBUS_DRIVER is not set # CONFIG_MIPI_DSI is not set # CONFIG_COREDUMP_DEVICE is not set # CONFIG_FUEL_GAUGE is not set # end of Device Drivers # # C Library # CONFIG_SUPPORT_MINIMAL_LIBC=y CONFIG_PICOLIBC_SUPPORTED=y CONFIG_MINIMAL_LIBC=y # CONFIG_PICOLIBC is not set # CONFIG_NEWLIB_LIBC is not set # CONFIG_EXTERNAL_LIBC is not set CONFIG_HAS_NEWLIB_LIBC_NANO=y CONFIG_MINIMAL_LIBC_NON_REENTRANT_FUNCTIONS=y CONFIG_MINIMAL_LIBC_MALLOC=y CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=0 CONFIG_MINIMAL_LIBC_CALLOC=y CONFIG_MINIMAL_LIBC_REALLOCARRAY=y # CONFIG_MINIMAL_LIBC_LL_PRINTF is not set CONFIG_MINIMAL_LIBC_OPTIMIZE_STRING_FOR_SIZE=y # CONFIG_MINIMAL_LIBC_RAND is not set CONFIG_MINIMAL_LIBC_TIME=y # CONFIG_MINIMAL_LIBC_STRING_ERROR_TABLE is not set CONFIG_STDOUT_CONSOLE=y CONFIG_NEED_LIBC_MEM_PARTITION=y # end of C Library # # Additional libraries # # # OS Support Library # # CONFIG_JSON_LIBRARY is not set # CONFIG_RING_BUFFER is not set CONFIG_NOTIFY=y # CONFIG_BASE64 is not set CONFIG_CRC=y # CONFIG_PRINTK_SYNC is not set CONFIG_MPSC_PBUF=y CONFIG_ONOFF=y # CONFIG_SPSC_PBUF is not set # CONFIG_SHARED_MULTI_HEAP is not set # CONFIG_WINSTREAM is not set # CONFIG_MPSC_CLEAR_ALLOCATED is not set CONFIG_REBOOT=y # CONFIG_UTF8 is not set CONFIG_CBPRINTF_COMPLETE=y # CONFIG_CBPRINTF_NANO is not set CONFIG_CBPRINTF_FULL_INTEGRAL=y # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set # CONFIG_CBPRINTF_FP_SUPPORT is not set # CONFIG_CBPRINTF_FP_A_SUPPORT is not set # CONFIG_CBPRINTF_FP_ALWAYS_A is not set CONFIG_CBPRINTF_N_SPECIFIER=y # CONFIG_CBPRINTF_LIBC_SUBSTS is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF=y # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3 # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set # # Heap and Memory Allocation # # CONFIG_SYS_HEAP_VALIDATE is not set CONFIG_SYS_HEAP_ALLOC_LOOPS=3 # CONFIG_SYS_HEAP_RUNTIME_STATS is not set # CONFIG_SYS_HEAP_LISTENER is not set CONFIG_SYS_HEAP_SMALL_ONLY=y # CONFIG_SYS_HEAP_BIG_ONLY is not set # CONFIG_SYS_HEAP_AUTO is not set # CONFIG_SYS_MEM_BLOCKS is not set # end of Heap and Memory Allocation # end of OS Support Library # CONFIG_GETOPT is not set # CONFIG_POSIX_API is not set # CONFIG_POSIX_CLOCK is not set CONFIG_MAX_TIMER_COUNT=5 # CONFIG_POSIX_MQUEUE is not set # CONFIG_EVENTFD is not set # CONFIG_OPENAMP_RSC_TABLE is not set # # Util libraries # # CONFIG_FNMATCH is not set # end of Util libraries # CONFIG_SMF is not set # end of Additional libraries # # Sub Systems and OS Services # CONFIG_BT=y # CONFIG_BT_LOG_LEVEL_OFF is not set # CONFIG_BT_LOG_LEVEL_ERR is not set # CONFIG_BT_LOG_LEVEL_WRN is not set CONFIG_BT_LOG_LEVEL_INF=y # CONFIG_BT_LOG_LEVEL_DBG is not set CONFIG_BT_LOG_LEVEL=3 CONFIG_BT_HCI=y # CONFIG_BT_CUSTOM is not set # CONFIG_BT_HCI_RAW is not set # CONFIG_BT_HCI_RAW_H4 is not set # CONFIG_BT_HCI_RAW_CMD_EXT is not set CONFIG_BT_CONN_TX=y # CONFIG_BT_PER_ADV_SYNC_TRANSFER_RECEIVER is not set # CONFIG_BT_PER_ADV_SYNC_TRANSFER_SENDER is not set # CONFIG_BT_SCA_UPDATE is not set # # Bluetooth buffer configuration # # end of Bluetooth buffer configuration # # Bluetooth Host # # # L2CAP Options # # end of L2CAP Options # # ATT and GATT Options # # end of ATT and GATT Options # # GATT Services # # end of GATT Services # end of Bluetooth Host CONFIG_BT_CTLR_LE_ENC_SUPPORT=y CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y CONFIG_BT_CTLR_PRIVACY_SUPPORT=y CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y CONFIG_BT_CTLR_PHY_2M_SUPPORT=y CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y CONFIG_BT_CTLR_ECDH_SUPPORT=y # CONFIG_BT_LL_SW_SPLIT is not set # # BLE Controller configuration # CONFIG_BT_CTLR_CRYPTO=y CONFIG_BT_CTLR_HCI_VS_BUILD_INFO="" CONFIG_BT_CTLR_AD_DATA_BACKUP=y # CONFIG_BT_CTLR_HCI_ADV_HANDLE_MAPPING is not set CONFIG_BT_CTLR_DUP_FILTER_LEN=0 CONFIG_BT_CTLR_RX_BUFFERS=1 # CONFIG_BT_CTLR_TX_PWR_PLUS_8 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_7 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_6 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_5 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_4 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set # CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set CONFIG_BT_CTLR_TX_PWR_0=y # CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set # CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set CONFIG_BT_CTLR_TX_PWR_ANTENNA=0 # CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set # # BLE Controller features # # CONFIG_BT_CTLR_LE_ENC is not set CONFIG_BT_CTLR_ECDH=y CONFIG_BT_CTLR_EXT_REJ_IND=y CONFIG_BT_CTLR_DATA_LENGTH=y # CONFIG_BT_CTLR_CONN_RSSI is not set CONFIG_BT_CTLR_CHECK_SAME_PEER_CONN=y # CONFIG_BT_CTLR_FILTER_ACCEPT_LIST is not set # CONFIG_BT_CTLR_PRIVACY is not set CONFIG_BT_CTLR_EXT_SCAN_FP=y CONFIG_BT_CTLR_PHY_2M=y # CONFIG_BT_CTLR_PHY_CODED is not set # CONFIG_BT_CTLR_CHAN_SEL_2 is not set CONFIG_BT_CTLR_ADV_EXT=y CONFIG_BT_CTLR_ADV_SET=4 CONFIG_BT_CTLR_ADV_INTERVAL_MAX=0xFFFFFF CONFIG_BT_CTLR_ADV_DATA_LEN_MAX=31 CONFIG_BT_CTLR_ADV_EXT_RX_PDU_LEN_MAX=255 CONFIG_BT_CTLR_SCAN_DATA_LEN_MAX=31 # CONFIG_BT_CTLR_ADV_PERIODIC is not set # CONFIG_BT_CTLR_SYNC_PERIODIC is not set # CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER is not set # CONFIG_BT_CTLR_SET_HOST_FEATURE is not set # CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set # CONFIG_BT_CTLR_ASSERT_HANDLER is not set # CONFIG_BT_CTLR_TEST is not set # CONFIG_BT_SHELL is not set CONFIG_BT_COMPANY_ID=0x0B18 # # Controller Area Network (CAN) bus subsystem # # CONFIG_ISOTP is not set # end of Controller Area Network (CAN) bus subsystem # CONFIG_CONSOLE_SUBSYS is not set # CONFIG_CPLUSPLUS is not set # # System Monitoring Options # # CONFIG_THREAD_ANALYZER is not set # end of System Monitoring Options # # Debugging Options # # CONFIG_DEBUG is not set # CONFIG_STACK_USAGE is not set # CONFIG_STACK_SENTINEL is not set CONFIG_PRINTK=y CONFIG_EARLY_CONSOLE=y CONFIG_ASSERT=y CONFIG_ASSERT_LEVEL=2 CONFIG_SPIN_VALIDATE=y # CONFIG_FORCE_NO_ASSERT is not set CONFIG_ASSERT_VERBOSE=y # CONFIG_ASSERT_NO_FILE_INFO is not set CONFIG_ASSERT_NO_COND_INFO=y CONFIG_ASSERT_NO_MSG_INFO=y # CONFIG_ASSERT_TEST is not set # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set # CONFIG_DEBUG_INFO is not set # CONFIG_DEBUG_THREAD_INFO is not set # CONFIG_DEBUG_COREDUMP is not set # end of Debugging Options # CONFIG_DISK_ACCESS is not set # CONFIG_EMUL is not set # CONFIG_CHARACTER_FRAMEBUFFER is not set # # File Systems # # CONFIG_FILE_SYSTEM is not set # CONFIG_FCB is not set CONFIG_NVS=y # CONFIG_NVS_LOOKUP_CACHE is not set # CONFIG_NVS_LOG_LEVEL_OFF is not set # CONFIG_NVS_LOG_LEVEL_ERR is not set # CONFIG_NVS_LOG_LEVEL_WRN is not set CONFIG_NVS_LOG_LEVEL_INF=y # CONFIG_NVS_LOG_LEVEL_DBG is not set CONFIG_NVS_LOG_LEVEL=3 # end of File Systems # # Inter Processor Communication # # CONFIG_RPMSG_SERVICE is not set # CONFIG_IPC_SERVICE is not set # end of Inter Processor Communication # CONFIG_JWT is not set # # Logging # CONFIG_LOG=y CONFIG_LOG_MODE_DEFERRED=y # CONFIG_LOG_MODE_IMMEDIATE is not set # CONFIG_LOG_MODE_MINIMAL is not set # CONFIG_LOG_FRONTEND is not set CONFIG_LOG_DEFAULT_MINIMAL=y # CONFIG_LOG_MULTIDOMAIN is not set # # Logging levels filtering # # CONFIG_LOG_RUNTIME_FILTERING is not set CONFIG_LOG_OVERRIDE_LEVEL=0 CONFIG_LOG_MAX_LEVEL=4 # end of Logging levels filtering # # Processing # CONFIG_LOG_PRINTK=y CONFIG_LOG_MODE_OVERFLOW=y # CONFIG_LOG_BLOCK_IN_THREAD is not set CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10 CONFIG_LOG_PROCESS_THREAD=y CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0 CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000 CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048 # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y # CONFIG_LOG_TIMESTAMP_64BIT is not set # CONFIG_LOG_SPEED is not set # end of Processing # # Output Formatting # # # Prepend non-hexdump log message with function name # # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y # end of Prepend non-hexdump log message with function name # CONFIG_LOG_MIPI_SYST_ENABLE is not set # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set CONFIG_LOG_BACKEND_SHOW_COLOR=y # CONFIG_LOG_INFO_COLOR_GREEN is not set CONFIG_LOG_TAG_MAX_LEN=0 CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set # end of Output Formatting # # Backends # CONFIG_LOG_BACKEND_RTT=y # CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y # CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y # CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set # CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0 CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16 CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4 CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5 CONFIG_LOG_BACKEND_RTT_BUFFER=0 # CONFIG_LOG_BACKEND_SWO is not set CONFIG_LOG_BACKEND_UART=y CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1 CONFIG_LOG_BACKEND_UART_AUTOSTART=y CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y # CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set # CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0 # CONFIG_LOG_BACKEND_IPC_SERVICE is not set # end of Backends # # Misc # CONFIG_LOG_DOMAIN_ID=0 CONFIG_LOG_USE_VLA=y # CONFIG_LOG_ALWAYS_RUNTIME is not set # CONFIG_LOG_FMT_SECTION is not set # CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set # CONFIG_LOG_MEM_UTILIZATION is not set CONFIG_LOG_FAILURE_REPORT_PERIOD=1000 # end of Misc CONFIG_LOG_OUTPUT=y # end of Logging # CONFIG_DSP is not set # # Device Management # # # Host command handler subsystem # # CONFIG_EC_HOST_CMD is not set # end of Host command handler subsystem CONFIG_MCUMGR=y # CONFIG_MCUMGR_LOG_LEVEL_OFF is not set # CONFIG_MCUMGR_LOG_LEVEL_ERR is not set # CONFIG_MCUMGR_LOG_LEVEL_WRN is not set CONFIG_MCUMGR_LOG_LEVEL_INF=y # CONFIG_MCUMGR_LOG_LEVEL_DBG is not set CONFIG_MCUMGR_LOG_LEVEL=3 CONFIG_MCUMGR_SMP_WORKQUEUE_STACK_SIZE=2048 CONFIG_MCUMGR_SMP_WORKQUEUE_THREAD_PRIO=3 # CONFIG_MGMT_VERBOSE_ERR_RESPONSE is not set CONFIG_MGMT_MAX_MAIN_MAP_ENTRIES=15 CONFIG_MGMT_MIN_DECODING_LEVELS=2 CONFIG_MGMT_MIN_DECODING_LEVEL_2=y CONFIG_MGMT_MAX_DECODING_LEVELS=2 # CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS is not set # # Command Handlers # CONFIG_MCUMGR_CMD_IMG_MGMT=y CONFIG_IMG_MGMT_UPDATABLE_IMAGE_NUMBER=1 # CONFIG_IMG_MGMT_VERBOSE_ERR is not set # CONFIG_IMG_MGMT_DUMMY_HDR is not set # CONFIG_IMG_MGMT_DIRECT_IMAGE_UPLOAD is not set # CONFIG_IMG_MGMT_REJECT_DIRECT_XIP_MISMATCHED_SLOT is not set # CONFIG_IMG_MGMT_FRUGAL_LIST is not set # CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_OFF is not set # CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_ERR is not set # CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_WRN is not set CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_INF=y # CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL_DBG is not set CONFIG_MCUMGR_IMG_MGMT_LOG_LEVEL=3 CONFIG_MCUMGR_CMD_OS_MGMT=y CONFIG_OS_MGMT_RESET_MS=250 CONFIG_OS_MGMT_ECHO=y # CONFIG_MCUMGR_GRP_OS_INFO is not set # end of Command Handlers # # Transports and Transport Related Configuration Options # CONFIG_MCUMGR_BUF_COUNT=4 CONFIG_MCUMGR_BUF_USER_DATA_SIZE=8 # CONFIG_MCUMGR_SMP_DUMMY is not set CONFIG_MCUMGR_SMP_BT=y # CONFIG_MCUMGR_SMP_REASSEMBLY_BT is not set # CONFIG_MCUMGR_SMP_BT_CONN_PARAM_CONTROL is not set # CONFIG_MCUMGR_SMP_UART is not set # end of Transports and Transport Related Configuration Options # CONFIG_MCUMGR_SMP_LOG_LEVEL_OFF is not set # CONFIG_MCUMGR_SMP_LOG_LEVEL_ERR is not set # CONFIG_MCUMGR_SMP_LOG_LEVEL_WRN is not set CONFIG_MCUMGR_SMP_LOG_LEVEL_INF=y # CONFIG_MCUMGR_SMP_LOG_LEVEL_DBG is not set CONFIG_MCUMGR_SMP_LOG_LEVEL=3 # CONFIG_HAWKBIT is not set # CONFIG_UPDATEHUB is not set # CONFIG_OSDP is not set # end of Device Management # CONFIG_MODBUS is not set # # Networking # CONFIG_NET_BUF=y # CONFIG_NET_BUF_LOG is not set # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set CONFIG_NET_BUF_LOG_LEVEL_INF=y # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set CONFIG_NET_BUF_LOG_LEVEL=3 # CONFIG_NET_BUF_POOL_USAGE is not set # CONFIG_NETWORKING is not set # end of Networking # # Portability # # end of Portability # # Power Management # # CONFIG_PM_LOG_LEVEL_OFF is not set # CONFIG_PM_LOG_LEVEL_ERR is not set # CONFIG_PM_LOG_LEVEL_WRN is not set CONFIG_PM_LOG_LEVEL_INF=y # CONFIG_PM_LOG_LEVEL_DBG is not set CONFIG_PM_LOG_LEVEL=3 # CONFIG_PM_S2RAM is not set CONFIG_PM_POLICY_DEFAULT=y # CONFIG_PM_POLICY_CUSTOM is not set # end of Power Management # CONFIG_SHELL is not set # CONFIG_STATS is not set # CONFIG_USB_DEVICE_STACK is not set # CONFIG_USBC_STACK is not set # CONFIG_SD_STACK is not set # CONFIG_USB_DEVICE_STACK_NEXT is not set CONFIG_IMG_MANAGER=y CONFIG_MCUBOOT_IMG_MANAGER=y CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y CONFIG_IMG_BLOCK_BUF_SIZE=512 # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set CONFIG_IMG_MANAGER_LOG_LEVEL_INF=y # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set CONFIG_IMG_MANAGER_LOG_LEVEL=3 # # Random Number Generators # # CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set # CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set CONFIG_XOSHIRO_RANDOM_GENERATOR=y CONFIG_CSPRING_ENABLED=y CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set # end of Random Number Generators # # Storage # CONFIG_FLASH_MAP=y # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set CONFIG_STREAM_FLASH=y # CONFIG_STREAM_FLASH_ERASE is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set CONFIG_STREAM_FLASH_LOG_LEVEL_INF=y # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set CONFIG_STREAM_FLASH_LOG_LEVEL=3 # end of Storage # CONFIG_SETTINGS is not set # CONFIG_TASK_WDT is not set # # Testing # # CONFIG_ZTEST is not set # CONFIG_ZTEST_MOCKING is not set # CONFIG_ZTRESS is not set # CONFIG_TEST is not set CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384 # CONFIG_TEST_USERSPACE is not set # end of Testing # CONFIG_TIMING_FUNCTIONS is not set # CONFIG_TRACING is not set # CONFIG_RTIO is not set # CONFIG_ZBUS is not set # end of Sub Systems and OS Services CONFIG_TOOLCHAIN_ZEPHYR_0_15=y CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y # # Build and Link Features # # # Linker Options # # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set CONFIG_LINKER_ORPHAN_SECTION_WARN=y # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set CONFIG_HAS_FLASH_LOAD_OFFSET=y CONFIG_USE_DT_CODE_PARTITION=y CONFIG_FLASH_LOAD_OFFSET=0xc000 CONFIG_FLASH_LOAD_SIZE=0x67000 CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y CONFIG_LD_LINKER_TEMPLATE=y # CONFIG_CMAKE_LINKER_GENERATOR is not set # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set CONFIG_KERNEL_ENTRY="__start" CONFIG_LINKER_SORT_BY_ALIGNMENT=y CONFIG_SRAM_OFFSET=0 # # Linker Sections # # CONFIG_LINKER_USE_BOOT_SECTION is not set # CONFIG_LINKER_USE_PINNED_SECTION is not set CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y CONFIG_LINKER_LAST_SECTION_ID=y CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015 # end of Linker Sections # end of Linker Options # # Compiler Options # # CONFIG_CODING_GUIDELINE_CHECK is not set # CONFIG_NATIVE_APPLICATION is not set CONFIG_SIZE_OPTIMIZATIONS=y # CONFIG_SPEED_OPTIMIZATIONS is not set # CONFIG_DEBUG_OPTIMIZATIONS is not set # CONFIG_NO_OPTIMIZATIONS is not set CONFIG_COMPILER_COLOR_DIAGNOSTICS=y CONFIG_FORTIFY_SOURCE_NONE=y # CONFIG_FORTIFY_SOURCE_COMPILE_TIME is not set # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set CONFIG_COMPILER_OPT="" # CONFIG_MISRA_SANE is not set # end of Compiler Options # CONFIG_ASSERT_ON_ERRORS is not set # CONFIG_NO_RUNTIME_CHECKS is not set CONFIG_RUNTIME_ERROR_CHECKS=y # # Build Options # CONFIG_KERNEL_BIN_NAME="zephyr" CONFIG_OUTPUT_STAT=y # CONFIG_OUTPUT_SYMBOLS is not set CONFIG_OUTPUT_DISASSEMBLY=y # CONFIG_OUTPUT_DISASSEMBLE_ALL is not set CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set # CONFIG_BUILD_NO_GAP_FILL is not set CONFIG_BUILD_OUTPUT_BIN=y # CONFIG_BUILD_OUTPUT_EXE is not set # CONFIG_BUILD_OUTPUT_S19 is not set # CONFIG_BUILD_OUTPUT_UF2 is not set # CONFIG_BUILD_OUTPUT_STRIPPED is not set # CONFIG_APPLICATION_DEFINED_SYSCALL is not set # CONFIG_MAKEFILE_EXPORTS is not set CONFIG_BUILD_OUTPUT_META=y # CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set # end of Build Options CONFIG_WARN_DEPRECATED=y CONFIG_ENFORCE_ZEPHYR_STDINT=y # end of Build and Link Features # # Boot Options # # CONFIG_IS_BOOTLOADER is not set CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="" CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS="" # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set # CONFIG_BOOTLOADER_BOSSA is not set # end of Boot Options # # Compatibility # CONFIG_COMPAT_INCLUDES=y # end of Compatibility # CONFIG_LEGACY_INCLUDE_PATH is not set
And the generated zephyr.dts where the devicetree is well apply
/dts-v1/; / { #address-cells = < 0x1 >; #size-cells = < 0x1 >; model = "Nordic nRF52840 DK NRF52840"; compatible = "nordic,nrf52840-dk-nrf52840"; chosen { zephyr,entropy = &cryptocell; zephyr,flash-controller = &flash_controller; zephyr,console = &uart0; zephyr,shell-uart = &uart0; zephyr,uart-mcumgr = &uart0; zephyr,bt-mon-uart = &uart0; zephyr,bt-c2h-uart = &uart0; zephyr,sram = &sram0; zephyr,flash = &flash0; zephyr,code-partition = &slot0_partition; zephyr,ieee802154 = &ieee802154; }; aliases { led0 = &led0; led1 = &led1; led2 = &led2; led3 = &led3; pwm-led0 = &pwm_led0; sw0 = &button0; sw1 = &button1; sw2 = &button2; sw3 = &button3; bootloader-led0 = &led0; mcuboot-button0 = &button0; mcuboot-led0 = &led0; watchdog0 = &wdt0; spi-flash0 = &mx25r64; pwm-ledr0 = &pwm0_CH0; pwm-ledg0 = &pwm0_CH1; pwm-ledb0 = &pwm0_CH2; pwm-buzzer = &pwm1_CH0; accel0 = &lis2dh; }; soc { #address-cells = < 0x1 >; #size-cells = < 0x1 >; compatible = "nordic,nRF52840-QIAA", "nordic,nRF52840", "nordic,nRF52", "simple-bus"; interrupt-parent = < &nvic >; ranges; nvic: interrupt-controller@e000e100 { #address-cells = < 0x1 >; compatible = "arm,v7m-nvic"; reg = < 0xe000e100 0xc00 >; interrupt-controller; #interrupt-cells = < 0x2 >; arm,num-irq-priority-bits = < 0x3 >; phandle = < 0x1 >; }; systick: timer@e000e010 { compatible = "arm,armv7m-systick"; reg = < 0xe000e010 0x10 >; status = "disabled"; }; ficr: ficr@10000000 { compatible = "nordic,nrf-ficr"; reg = < 0x10000000 0x1000 >; status = "okay"; }; uicr: uicr@10001000 { compatible = "nordic,nrf-uicr"; reg = < 0x10001000 0x1000 >; status = "okay"; }; sram0: memory@20000000 { compatible = "mmio-sram"; reg = < 0x20000000 0x40000 >; }; clock: clock@40000000 { compatible = "nordic,nrf-clock"; reg = < 0x40000000 0x1000 >; interrupts = < 0x0 0x1 >; status = "okay"; }; power: power@40000000 { compatible = "nordic,nrf-power"; reg = < 0x40000000 0x1000 >; interrupts = < 0x0 0x1 >; status = "okay"; }; radio: radio@40001000 { compatible = "nordic,nrf-radio"; reg = < 0x40001000 0x1000 >; interrupts = < 0x1 0x1 >; status = "okay"; ieee802154-supported; ble-2mbps-supported; ble-coded-phy-supported; tx-high-power-supported; ieee802154: ieee802154 { compatible = "nordic,nrf-ieee802154"; status = "okay"; }; }; uart0: uart@40002000 { compatible = "nordic,nrf-uarte"; reg = < 0x40002000 0x1000 >; interrupts = < 0x2 0x1 >; status = "okay"; current-speed = < 0x1c200 >; pinctrl-0 = < &uart0_default >; pinctrl-1 = < &uart0_sleep >; pinctrl-names = "default", "sleep"; }; i2c0: arduino_i2c: i2c@40003000 { compatible = "nordic,nrf-twim"; #address-cells = < 0x1 >; #size-cells = < 0x0 >; reg = < 0x40003000 0x1000 >; clock-frequency = < 0x186a0 >; interrupts = < 0x3 0x1 >; status = "okay"; pinctrl-0 = < &i2c0_default >; pinctrl-1 = < &i2c0_sleep >; pinctrl-names = "default", "sleep"; lis2dh: lis2dh@18 { compatible = "st,lis2dh12"; status = "okay"; reg = < 0x18 >; irq-gpios = < &gpio0 0x2 0x0 >, < &gpio1 0xf 0x0 >; disconnect-sdo-sa0-pull-up; }; }; spi0: spi@40003000 { compatible = "nordic,nrf-spi"; #address-cells = < 0x1 >; #size-cells = < 0x0 >; reg = < 0x40003000 0x1000 >; interrupts = < 0x3 0x1 >; max-frequency = < 0x7a1200 >; status = "disabled"; pinctrl-0 = < &spi0_default >; pinctrl-1 = < &spi0_sleep >; pinctrl-names = "default", "sleep"; }; i2c1: i2c@40004000 { compatible = "nordic,nrf-twi"; #address-cells = < 0x1 >; #size-cells = < 0x0 >; reg = < 0x40004000 0x1000 >; clock-frequency = < 0x186a0 >; interrupts = < 0x4 0x1 >; status = "disabled"; pinctrl-0 = < &i2c1_default >; pinctrl-1 = < &i2c1_sleep >; pinctrl-names = "default", "sleep"; }; spi1: spi@40004000 { compatible = "nordic,nrf-spi"; #address-cells = < 0x1 >; #size-cells = < 0x0 >; reg = < 0x40004000 0x1000 >; interrupts = < 0x4 0x1 >; max-frequency = < 0x7a1200 >; status = "okay"; pinctrl-0 = < &spi1_default >; pinctrl-1 = < &spi1_sleep >; pinctrl-names = "default", "sleep"; }; nfct: nfct@40005000 { compatible = "nordic,nrf-nfct"; reg = < 0x40005000 0x1000 >; interrupts = < 0x5 0x1 >; status = "disabled"; }; gpiote: gpiote@40006000 { compatible = "nordic,nrf-gpiote"; reg = < 0x40006000 0x1000 >; interrupts = < 0x6 0x5 >; status = "okay"; }; adc: adc@40007000 { compatible = "nordic,nrf-saadc"; reg = < 0x40007000 0x1000 >; interrupts = < 0x7 0x1 >; status = "okay"; #io-channel-cells = < 0x1 >; phandle = < 0x1d >; }; timer0: timer@40008000 { compatible = "nordic,nrf-timer"; status = "okay"; reg = < 0x40008000 0x1000 >; cc-num = < 0x4 >; interrupts = < 0x8 0x1 >; prescaler = < 0x0 >; }; timer1: timer@40009000 { compatible = "nordic,nrf-timer"; status = "okay"; reg = < 0x40009000 0x1000 >; cc-num = < 0x4 >; interrupts = < 0x9 0x1 >; prescaler = < 0x0 >; }; timer2: timer@4000a000 { compatible = "nordic,nrf-timer"; status = "okay"; reg = < 0x4000a000 0x1000 >; cc-num = < 0x4 >; interrupts = < 0xa 0x1 >; prescaler = < 0x0 >; phandle = < 0x1b >; }; rtc0: rtc@4000b000 { compatible = "nordic,nrf-rtc"; reg = < 0x4000b000 0x1000 >; cc-num = < 0x3 >; interrupts = < 0xb 0x1 >; status = "okay"; clock-frequency = < 0x8000 >; prescaler = < 0x1 >; }; temp: temp@4000c000 { compatible = "nordic,nrf-temp"; reg = < 0x4000c000 0x1000 >; interrupts = < 0xc 0x1 >; status = "okay"; }; rng: random@4000d000 { compatible = "nordic,nrf-rng"; reg = < 0x4000d000 0x1000 >; interrupts = < 0xd 0x1 >; status = "okay"; }; ecb: ecb@4000e000 { compatible = "nordic,nrf-ecb"; reg = < 0x4000e000 0x1000 >; interrupts = < 0xe 0x1 >; status = "okay"; }; ccm: ccm@4000f000 { compatible = "nordic,nrf-ccm"; reg = < 0x4000f000 0x1000 >; interrupts = < 0xf 0x1 >; length-field-length-8-bits; status = "okay"; }; wdt: wdt0: watchdog@40010000 { compatible = "nordic,nrf-wdt"; reg = < 0x40010000 0x1000 >; interrupts = < 0x10 0x1 >; status = "okay"; }; rtc1: rtc@40011000 { compatible = "nordic,nrf-rtc"; reg = < 0x40011000 0x1000 >; cc-num = < 0x4 >; interrupts = < 0x11 0x1 >; status = "okay"; clock-frequency = < 0x8000 >; prescaler = < 0x1 >; }; qdec: qdec0: qdec@40012000 { compatible = "nordic,nrf-qdec"; reg = < 0x40012000 0x1000 >; interrupts = < 0x12 0x1 >; status = "disabled"; }; comp: comparator@40013000 { compatible = "nordic,nrf-comp"; reg = < 0x40013000 0x1000 >; interrupts = < 0x13 0x1 >; status = "disabled"; #io-channel-cells = < 0x1 >; }; egu0: swi0: egu@40014000 { compatible = "nordic,nrf-egu", "nordic,nrf-swi"; reg = < 0x40014000 0x1000 >; interrupts = < 0x14 0x1 >; status = "okay"; }; egu1: swi1: egu@40015000 { compatible = "nordic,nrf-egu", "nordic,nrf-swi"; reg = < 0x40015000 0x1000 >; interrupts = < 0x15 0x1 >; status = "okay"; }; egu2: swi2: egu@40016000 { compatible = "nordic,nrf-egu", "nordic,nrf-swi"; reg = < 0x40016000 0x1000 >; interrupts = < 0x16 0x1 >; status = "okay"; }; egu3: swi3: egu@40017000 { compatible = "nordic,nrf-egu", "nordic,nrf-swi"; reg = < 0x40017000 0x1000 >; interrupts = < 0x17 0x1 >; status = "okay"; }; egu4: swi4: egu@40018000 { compatible = "nordic,nrf-egu", "nordic,nrf-swi"; reg = < 0x40018000 0x1000 >; interrupts = < 0x18 0x1 >; status = "okay"; }; egu5: swi5: egu@40019000 { compatible = "nordic,nrf-egu", "nordic,nrf-swi"; reg = < 0x40019000 0x1000 >; interrupts = < 0x19 0x1 >; status = "okay"; }; timer3: timer@4001a000 { compatible = "nordic,nrf-timer"; status = "okay"; reg = < 0x4001a000 0x1000 >; cc-num = < 0x6 >; interrupts = < 0x1a 0x1 >; prescaler = < 0x0 >; }; timer4: timer@4001b000 { compatible = "nordic,nrf-timer"; status = "okay"; reg = < 0x4001b000 0x1000 >; cc-num = < 0x6 >; interrupts = < 0x1b 0x1 >; prescaler = < 0x0 >; }; pwm0: pwm@4001c000 { compatible = "nordic,nrf-pwm"; reg = < 0x4001c000 0x1000 >; interrupts = < 0x1c 0x1 >; status = "okay"; #pwm-cells = < 0x3 >; pinctrl-0 = < &pwm0_default >; pinctrl-1 = < &pwm0_sleep >; pinctrl-names = "default", "sleep"; phandle = < 0x1c >; }; pdm0: pdm@4001d000 { compatible = "nordic,nrf-pdm"; reg = < 0x4001d000 0x1000 >; interrupts = < 0x1d 0x1 >; status = "disabled"; }; acl: acl@4001e000 { compatible = "nordic,nrf-acl"; reg = < 0x4001e000 0x1000 >; status = "okay"; }; flash_controller: flash-controller@4001e000 { compatible = "nordic,nrf52-flash-controller"; reg = < 0x4001e000 0x1000 >; partial-erase; #address-cells = < 0x1 >; #size-cells = < 0x1 >; flash0: flash@0 { compatible = "soc-nv-flash"; erase-block-size = < 0x1000 >; write-block-size = < 0x4 >; reg = < 0x0 0x100000 >; partitions { compatible = "fixed-partitions"; #address-cells = < 0x1 >; #size-cells = < 0x1 >; boot_partition: partition@0 { label = "mcuboot"; reg = < 0x0 0xc000 >; }; slot0_partition: partition@c000 { label = "image-0"; reg = < 0xc000 0x67000 >; }; slot1_partition: partition@73000 { label = "image-1"; reg = < 0x73000 0x67000 >; }; scratch_partition: partition@da000 { label = "image-scratch"; reg = < 0xda000 0x1e000 >; }; storage_partition: partition@f8000 { label = "storage"; reg = < 0xf8000 0x8000 >; }; }; }; }; ppi: ppi@4001f000 { compatible = "nordic,nrf-ppi"; reg = < 0x4001f000 0x1000 >; status = "okay"; }; mwu: mwu@40020000 { compatible = "nordic,nrf-mwu"; reg = < 0x40020000 0x1000 >; status = "okay"; }; pwm1: pwm@40021000 { compatible = "nordic,nrf-pwm"; reg = < 0x40021000 0x1000 >; interrupts = < 0x21 0x1 >; status = "okay"; #pwm-cells = < 0x3 >; pinctrl-0 = < &pwm1_default >; pinctrl-1 = < &pwm1_sleep >; pinctrl-names = "default", "sleep"; phandle = < 0x1e >; }; pwm2: pwm@40022000 { compatible = "nordic,nrf-pwm"; reg = < 0x40022000 0x1000 >; interrupts = < 0x22 0x1 >; status = "disabled"; #pwm-cells = < 0x3 >; }; spi2: spi@40023000 { compatible = "nordic,nrf-spi"; #address-cells = < 0x1 >; #size-cells = < 0x0 >; reg = < 0x40023000 0x1000 >; interrupts = < 0x23 0x1 >; max-frequency = < 0x7a1200 >; status = "disabled"; pinctrl-0 = < &spi2_default >; pinctrl-1 = < &spi2_sleep >; pinctrl-names = "default", "sleep"; }; rtc2: rtc@40024000 { compatible = "nordic,nrf-rtc"; reg = < 0x40024000 0x1000 >; cc-num = < 0x4 >; interrupts = < 0x24 0x1 >; status = "okay"; clock-frequency = < 0x8000 >; prescaler = < 0x1 >; }; i2s0: i2s@40025000 { compatible = "nordic,nrf-i2s"; #address-cells = < 0x1 >; #size-cells = < 0x0 >; reg = < 0x40025000 0x1000 >; interrupts = < 0x25 0x1 >; status = "disabled"; }; usbd: zephyr_udc0: usbd@40027000 { compatible = "nordic,nrf-usbd"; reg = < 0x40027000 0x1000 >; interrupts = < 0x27 0x1 >; num-bidir-endpoints = < 0x1 >; num-in-endpoints = < 0x7 >; num-out-endpoints = < 0x7 >; num-isoin-endpoints = < 0x1 >; num-isoout-endpoints = < 0x1 >; status = "okay"; }; uart1: arduino_serial: uart@40028000 { compatible = "nordic,nrf-uarte"; reg = < 0x40028000 0x1000 >; interrupts = < 0x28 0x1 >; status = "okay"; current-speed = < 0x1c200 >; pinctrl-0 = < &uart1_default >; pinctrl-1 = < &uart1_sleep >; pinctrl-names = "default", "sleep"; }; qspi: qspi@40029000 { compatible = "nordic,nrf-qspi"; #address-cells = < 0x1 >; #size-cells = < 0x0 >; reg = < 0x40029000 0x1000 >, < 0x12000000 0x8000000 >; reg-names = "qspi", "qspi_mm"; interrupts = < 0x29 0x1 >; status = "okay"; pinctrl-0 = < &qspi_default >; pinctrl-1 = < &qspi_sleep >; pinctrl-names = "default", "sleep"; mx25r64: mx25r6435f@0 { compatible = "nordic,qspi-nor"; reg = < 0x0 >; writeoc = "pp4io"; readoc = "read4io"; sck-frequency = < 0x7a1200 >; jedec-id = [ C2 28 17 ]; sfdp-bfp = [ E5 20 F1 FF FF FF FF 03 44 EB 08 6B 08 3B 04 BB EE FF FF FF FF FF 00 FF FF FF 00 FF 0C 20 0F 52 10 D8 00 FF 23 72 F5 00 82 ED 04 CC 44 83 68 44 30 B0 30 B0 F7 C4 D5 5C 00 BE 29 FF F0 D0 FF FF ]; size = < 0x4000000 >; has-dpd; t-enter-dpd = < 0x2710 >; t-exit-dpd = < 0x88b8 >; }; }; pwm3: pwm@4002d000 { compatible = "nordic,nrf-pwm"; reg = < 0x4002d000 0x1000 >; interrupts = < 0x2d 0x1 >; status = "disabled"; #pwm-cells = < 0x3 >; }; spi3: arduino_spi: spi@4002f000 { compatible = "nordic,nrf-spim"; #address-cells = < 0x1 >; #size-cells = < 0x0 >; reg = < 0x4002f000 0x1000 >; interrupts = < 0x2f 0x1 >; max-frequency = < 0x1e84800 >; rx-delay-supported; rx-delay = < 0x2 >; status = "okay"; cs-gpios = < &arduino_header 0x10 0x1 >; pinctrl-0 = < &spi3_default >; pinctrl-1 = < &spi3_sleep >; pinctrl-names = "default", "sleep"; }; gpio0: gpio@50000000 { compatible = "nordic,nrf-gpio"; gpio-controller; reg = < 0x50000000 0x200 0x50000500 0x300 >; #gpio-cells = < 0x2 >; status = "okay"; port = < 0x0 >; phandle = < 0x6 >; }; gpio1: gpio@50000300 { compatible = "nordic,nrf-gpio"; gpio-controller; reg = < 0x50000300 0x200 0x50000800 0x300 >; #gpio-cells = < 0x2 >; ngpios = < 0x10 >; status = "okay"; port = < 0x1 >; phandle = < 0x7 >; }; cryptocell: crypto@5002a000 { compatible = "nordic,nrf-cc310"; reg = < 0x5002a000 0x1000 >; status = "okay"; #address-cells = < 0x1 >; #size-cells = < 0x1 >; cryptocell310: crypto@5002b000 { compatible = "arm,cryptocell-310"; reg = < 0x5002b000 0x1000 >; interrupts = < 0x2a 0x1 >; }; }; }; pinctrl: pin-controller { compatible = "nordic,nrf-pinctrl"; uart0_default: uart0_default { phandle = < 0x2 >; group1 { psels = < 0x6 >, < 0x20005 >; }; group2 { psels = < 0x10008 >, < 0x30007 >; bias-pull-up; }; }; uart0_sleep: uart0_sleep { phandle = < 0x3 >; group1 { psels = < 0x6 >, < 0x10008 >, < 0x20005 >, < 0x30007 >; low-power-enable; }; }; uart1_default: uart1_default { phandle = < 0x14 >; group1 { psels = < 0x10021 >; bias-pull-up; }; group2 { psels = < 0x22 >; }; }; uart1_sleep: uart1_sleep { phandle = < 0x15 >; group1 { psels = < 0x10021 >, < 0x22 >; low-power-enable; }; }; i2c0_default: i2c0_default { phandle = < 0x4 >; group1 { psels = < 0xc001a >, < 0xb001b >; }; }; i2c0_sleep: i2c0_sleep { phandle = < 0x5 >; group1 { psels = < 0xc001a >, < 0xb001b >; low-power-enable; }; }; i2c1_default: i2c1_default { phandle = < 0xa >; group1 { psels = < 0xc001e >, < 0xb001f >; }; }; i2c1_sleep: i2c1_sleep { phandle = < 0xb >; group1 { psels = < 0xc001e >, < 0xb001f >; low-power-enable; }; }; pwm0_default: pwm0_default { phandle = < 0xe >; group1 { psels = < 0x16000d >, < 0x17000e >, < 0x18000f >; nordic,invert; }; }; pwm0_sleep: pwm0_sleep { phandle = < 0xf >; group1 { psels = < 0x16000d >, < 0x17000e >, < 0x18000f >; low-power-enable; }; }; spi0_default: spi0_default { phandle = < 0x8 >; group1 { psels = < 0x4001b >, < 0x5001a >, < 0x6001d >; }; }; spi0_sleep: spi0_sleep { phandle = < 0x9 >; group1 { psels = < 0x4001b >, < 0x5001a >, < 0x6001d >; low-power-enable; }; }; spi1_default: spi1_default { phandle = < 0xc >; group1 { psels = < 0x4001f >, < 0x5001e >, < 0x60028 >; }; }; spi1_sleep: spi1_sleep { phandle = < 0xd >; group1 { psels = < 0x4001f >, < 0x5001e >, < 0x60028 >; low-power-enable; }; }; spi2_default: spi2_default { phandle = < 0x12 >; group1 { psels = < 0x40013 >, < 0x50014 >, < 0x60015 >; }; }; spi2_sleep: spi2_sleep { phandle = < 0x13 >; group1 { psels = < 0x40013 >, < 0x50014 >, < 0x60015 >; low-power-enable; }; }; qspi_default: qspi_default { phandle = < 0x16 >; group1 { psels = < 0x1d0013 >, < 0x1f0014 >, < 0x200015 >, < 0x210016 >, < 0x220017 >, < 0x1e0011 >; }; }; qspi_sleep: qspi_sleep { phandle = < 0x17 >; group1 { psels = < 0x1d0013 >, < 0x1f0014 >, < 0x200015 >, < 0x210016 >, < 0x220017 >; low-power-enable; }; group2 { psels = < 0x1e0011 >; low-power-enable; bias-pull-up; }; }; spi3_default: spi3_default { phandle = < 0x19 >; group1 { psels = < 0x4002f >, < 0x6002e >, < 0x5002d >; }; }; spi3_sleep: spi3_sleep { phandle = < 0x1a >; group1 { psels = < 0x4002f >, < 0x6002e >, < 0x5002d >; low-power-enable; }; }; pwm1_default: pwm1_default { phandle = < 0x10 >; group1 { psels = < 0x160003 >; nordic,invert; }; }; pwm1_sleep: pwm1_sleep { phandle = < 0x11 >; group1 { psels = < 0x160003 >; low-power-enable; }; }; }; rng_hci: entropy_bt_hci { compatible = "zephyr,bt-hci-entropy"; status = "okay"; }; cpus { #address-cells = < 0x1 >; #size-cells = < 0x0 >; cpu@0 { device_type = "cpu"; compatible = "arm,cortex-m4f"; reg = < 0x0 >; #address-cells = < 0x1 >; #size-cells = < 0x1 >; itm: itm@e0000000 { compatible = "arm,armv7m-itm"; reg = < 0xe0000000 0x1000 >; swo-ref-frequency = < 0x1e84800 >; }; }; }; sw_pwm: sw-pwm { compatible = "nordic,nrf-sw-pwm"; status = "disabled"; generator = < &timer2 >; clock-prescaler = < 0x0 >; #pwm-cells = < 0x3 >; }; leds { compatible = "gpio-leds"; led0: led_0 { gpios = < &gpio0 0xd 0x1 >; label = "Green LED 0"; }; led1: led_1 { gpios = < &gpio0 0xe 0x1 >; label = "Green LED 1"; }; led2: led_2 { gpios = < &gpio0 0xf 0x1 >; label = "Green LED 2"; }; led3: led_3 { gpios = < &gpio0 0x10 0x1 >; label = "Green LED 3"; }; }; pwmleds { compatible = "pwm-leds"; pwm_led0: pwm_led_0 { pwms = < &pwm0 0x0 0x1312d00 0x1 >; }; pwm0_CH0: pwm_0_channel_0 { pwms = < &pwm0 0x0 0xf4240 0x1 >; }; pwm0_CH1: pwm_0_channel_1 { pwms = < &pwm0 0x1 0xf4240 0x1 >; }; pwm0_CH2: pwm_0_channel_2 { pwms = < &pwm0 0x2 0xf4240 0x1 >; }; }; buttons { compatible = "gpio-keys"; button0: button_0 { gpios = < &gpio0 0xb 0x11 >; label = "Push button switch 0"; }; button1: button_1 { gpios = < &gpio0 0xc 0x11 >; label = "Push button switch 1"; }; button2: button_2 { gpios = < &gpio0 0x18 0x11 >; label = "Push button switch 2"; }; button3: button_3 { gpios = < &gpio0 0x19 0x11 >; label = "Push button switch 3"; }; }; arduino_header: connector { compatible = "arduino-header-r3"; #gpio-cells = < 0x2 >; gpio-map-mask = < 0xffffffff 0xffffffc0 >; gpio-map-pass-thru = < 0x0 0x3f >; gpio-map = < 0x0 0x0 &gpio0 0x3 0x0 >, < 0x1 0x0 &gpio0 0x4 0x0 >, < 0x2 0x0 &gpio0 0x1c 0x0 >, < 0x3 0x0 &gpio0 0x1d 0x0 >, < 0x4 0x0 &gpio0 0x1e 0x0 >, < 0x5 0x0 &gpio0 0x1f 0x0 >, < 0x6 0x0 &gpio1 0x1 0x0 >, < 0x7 0x0 &gpio1 0x2 0x0 >, < 0x8 0x0 &gpio1 0x3 0x0 >, < 0x9 0x0 &gpio1 0x4 0x0 >, < 0xa 0x0 &gpio1 0x5 0x0 >, < 0xb 0x0 &gpio1 0x6 0x0 >, < 0xc 0x0 &gpio1 0x7 0x0 >, < 0xd 0x0 &gpio1 0x8 0x0 >, < 0xe 0x0 &gpio1 0xa 0x0 >, < 0xf 0x0 &gpio1 0xb 0x0 >, < 0x10 0x0 &gpio1 0xc 0x0 >, < 0x11 0x0 &gpio1 0xd 0x0 >, < 0x12 0x0 &gpio1 0xe 0x0 >, < 0x13 0x0 &gpio1 0xf 0x0 >, < 0x14 0x0 &gpio0 0x1a 0x0 >, < 0x15 0x0 &gpio0 0x1b 0x0 >; phandle = < 0x18 >; }; arduino_adc: analog-connector { compatible = "arduino,uno-adc"; #io-channel-cells = < 0x1 >; io-channel-map = < 0x0 &adc 0x1 >, < 0x1 &adc 0x2 >, < 0x2 &adc 0x4 >, < 0x3 &adc 0x5 >, < 0x4 &adc 0x6 >, < 0x5 &adc 0x7 >; }; buzzer { compatible = "pwm-leds"; pwm1_CH0: pwm_1_channel_0 { pwms = < &pwm1 0x0 0x30d40 0x1 >; }; }; };
Well I don't know what can I do more ..
Thanks for your help !
Florent
