Build Issue Integrating central NFC poller sample code into nRF5340 ADK headset app
Hi.
I have integrated the NFC samples (nRF5340 DK) into the audio headset app (nRF5340 ADK), using SDK 2.5.2.
For simplicity I've created two builds, a central version and a peripheral version.
The peripheral version was fairly straight forward to get to build. The central version has been giving some build issues.
I am getting 'undefined references' where the object files are being brought together, although seems to build into the objects ok.
The main items in question are nfc_poller_init/nfc_poller_process and log_set_tag.
The nfc_ functions are included in nfc_poller.h and nfc_poller.c, and these have been copied from the central_nfc_pairing sample with these two source files added to the source directory of the modified headset app in the same way they were for the central_nfc_pairing sample.  #include "nfc_poller.h" was added to the top of main.c and VS code picks up this link within the IDE and there are no squiggles or obvious issues.
log_set_tag is included in log_core.h, and is referenced in fw_app_info.c.  There is no #include for log_core.h at the top of fw_app_info.c, although this .c file is build generated, so it does not seem obvious that I can add the #include where I would expect to.
What can be causing these?
Thanks, Larry.
  • I am also having difficulty inserting the VS code terminal output into this ticketing system.  The OK button has no effect, if I paste this into the comment box I get an orange error box pop up.
  • Hi Laurence
    'undefined reference' errors are usually caused by some missing Kconfig configurations.
    Did you make sure to copy the following configuration from the central_nfc_pairing sample into your own project configuration?
    #Condif NFC modules
    CONFIG_NFC_NDEF=y
    CONFIG_NFC_NDEF_RECORD=y
    CONFIG_NFC_NDEF_TEXT_RECORD=y
    CONFIG_NFC_NDEF_MSG=y
    CONFIG_NFC_NDEF_PARSER=y
    CONFIG_NFC_T2T_PARSER=y
    CONFIG_NFC_T4T_HL_PROCEDURE=y
    CONFIG_NFC_TNEP_POLLER=y
    CONFIG_NFC_NDEF_LE_OOB_REC=y
    CONFIG_NFC_NDEF_LE_OOB_REC_PARSER=y
    CONFIG_NFC_NDEF_CH_MSG=y
    CONFIG_NFC_TNEP_CH=y
    CONFIG_POLL=y
    Could you try the Insert -> Code feature?
    This is generally the best way to include logs, source code etc into a ticket.
    Best regards
    Torbjørn
