In nrf5340 pin assignment for SPIM2 is given,
How to select which pin to use if we need to use SPIM1/3?
How to know Pin function and all its alternate functions for particular pin?
I think you're looking at an outdated product specification that contained an error, if you look at the current product specification, you can see that it mentions SPIM4 instead.
Thus, this restriction is not relevant for SPIM1-3,
regards
Jared
Thanks Jared.
What if I want to use 2 SPIM ? How to select the pins? In pin assignments only SPIM4 is given?
Im also using the QSPI.
You can use any GPIOs for SPIM except for SPIM4 where we recommend using the dedicated SPIM pins.
regards
Jared
Hi Jared,
Kindly give your comments on this
1) SPIM4 (High speed - 32Mbps)
P0.08 - SCK
P0.09 -MOSI
P0.10 - MISO
PO.11 - CSB
2) SPIM2(8 Mbps)
P1.00 - SCK
P0.19 - MOSI
P1.05 - MISO
P1.04 - CS
3) I2C1 (High speed)
P1.02 - SDA
P1.03 - SCL
4)I2C2
P0.07 - SCL
P0.06 - SDA
Is this pin allocations go to go?? Please give your comments on this.
That looks fine,
regards
Jared
