Hi Devzone,
On my nrf52840-based custom board, I am implementing the scanning of devices broadcasting the Heart Rate service while advertising a custom service and connecting to another Central device. In order to do this I based myself off of the Central and Peripheral HRS example:
developer.nordicsemi.com/.../README.html
I can advertise my custom service, connect to it, and send commands to start scanning, however, when I connect to my board (my board acting as a peripheral in that case), I get the following warning:
[00:00:16.727,966] <inf> BLE_MANAGER: Connected 44:1C:A8:E2:B6:96 (public) [00:00:16.729,675] <wrn> bt_hci_core: opcode 0x2039 status 0x0d
Even though it works as expected for now, I would like to get rid of the error message. The status states BT_HCI_ERR_INSUFFICIENT_RESOURCES, and from what I've found, the opcode 0x2039 stands for BT_HCI_OP_LE_SET_EXT_ADV_ENABLE (I do have CONFIG_BT_EXT_ADV enabled in my prj.conf). Do you have an idea where this warning originates from ?
Here is the ble_manager.c file that handles the ble connections:
#include "include/ble_manager.h"
LOG_MODULE_REGISTER(BLE_MANAGER, LOG_LEVEL_DBG);
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_GAP_APPEARANCE,
(CONFIG_BT_DEVICE_APPEARANCE >> 0) & 0xff,
(CONFIG_BT_DEVICE_APPEARANCE >> 8) & 0xff),
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
BT_DATA_BYTES(BT_DATA_UUID16_ALL,
BT_UUID_16_ENCODE(BT_UUID_HRS_VAL),
BT_UUID_16_ENCODE(BT_UUID_BAS_VAL)),
static const struct bt_data sd[] = {
BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_EQS_SERVICE_VAL),
K_MSGQ_DEFINE(hrs_queue, sizeof(struct bt_hrs_client_measurement), HRS_QUEUE_SIZE, 4);
static K_SEM_DEFINE(ble_init_ok, 0, 1);
static struct bt_hrs_client hrs_c;
static struct bt_conn *current_conn_as_peripheral;
static struct bt_conn *current_hrs_conn_as_central;
static struct bt_conn *auth_conn;
static ble_manager_evt_handler_t m_app_evt_handler;
static bool _scan_in_progress = false;
static const char * const sensor_location_str[] = {
"Other",
"Chest",
"Wrist",
"Finger",
"Hand",
"Ear lobe",
"Foot"
static void hrs_sensor_location_read_cb(struct bt_hrs_client *hrs_c,
enum bt_hrs_client_sensor_location location,
int err)
if (err) {
LOG_ERR("HRS Sensor Body Location read error (err %d)", err);
return;
LOG_INF("Heart Rate Sensor body location: %s", sensor_location_str[location]);
static void hrs_measurement_notify_cb(struct bt_hrs_client *hrs_c,
const struct bt_hrs_client_measurement *meas,
int err)
if (err) {
LOG_ERR("Error during receiving Heart Rate Measurement notification, err: %d",
err);
return;
LOG_DBG("Heart Rate Measurement notification received:");
LOG_DBG("Heart Rate Measurement Value Format: %s",
meas->flags.value_format ? "16 - bit" : "8 - bit");
LOG_DBG("Sensor Contact detected: %d", meas->flags.sensor_contact_detected);
LOG_DBG("Sensor Contact supported: %d", meas->flags.sensor_contact_supported);
LOG_DBG("Energy Expended present: %d", meas->flags.energy_expended_present);
LOG_DBG("RR-Intervals present: %d", meas->flags.rr_intervals_present);
LOG_DBG("Heart Rate Measurement Value: %d bpm", meas->hr_value);
if (meas->flags.energy_expended_present) {
LOG_DBG("Energy Expended: %d J", meas->energy_expended);
if (meas->flags.rr_intervals_present) {
LOG_DBG("RR-intervals: ");
for (size_t i = 0; i < meas->rr_intervals_count; i++) {
LOG_DBG("%d ", meas->rr_intervals[i]);
err = k_msgq_put(&hrs_queue, meas, K_NO_WAIT);
if (err) {
LOG_ERR("Notification queue is full. Discarding HRS notification (err %d)", err);
static void discovery_completed_cb(struct bt_gatt_dm *dm,
void *context)
int err;
LOG_DBG("The discovery procedure succeeded");
bt_gatt_dm_data_print(dm);
err = bt_hrs_client_handles_assign(dm, &hrs_c);
if (err) {
LOG_ERR("Could not init HRS client object (err %d)", err);
return;
err = bt_hrs_client_sensor_location_read(&hrs_c, hrs_sensor_location_read_cb);
if (err) {
LOG_ERR("Could not read Heart Rate Sensor location (err %d)", err);
err = bt_hrs_client_measurement_subscribe(&hrs_c, hrs_measurement_notify_cb);
if (err) {
LOG_ERR("Could not subscribe to Heart Rate Measurement characteristic (err %d)",
err);
err = bt_gatt_dm_data_release(dm);
if (err) {
LOG_ERR("Could not release the discovery data (err %d)", err);
static void discovery_not_found_cb(struct bt_conn *conn,
void *context)
LOG_WRN("Heart Rate Service could not be found during the discovery");
static void discovery_error_found_cb(struct bt_conn *conn,
int err, void *context)
LOG_ERR("The discovery procedure failed with %d", err);
static const struct bt_gatt_dm_cb discovery_cb = {
.completed = discovery_completed_cb,
.service_not_found = discovery_not_found_cb,
.error_found = discovery_error_found_cb
static void gatt_discover(struct bt_conn *conn)
int err;
err = bt_gatt_dm_start(conn, BT_UUID_HRS, &discovery_cb, NULL);
if (err) {
LOG_ERR("Could not start the discovery procedure, error "
"code: %d", err);
static void mtu_exchange_cb(struct bt_conn *conn, uint8_t err,
struct bt_gatt_exchange_params *params)
LOG_INF("%s: MTU exchange %s (%u)", __func__,
err == 0U ? "successful" : "failed",
bt_gatt_get_mtu(conn));
static struct bt_gatt_exchange_params mtu_exchange_params = {
.func = mtu_exchange_cb
static void connected(struct bt_conn *conn, uint8_t err)
struct bt_conn_info info;
if (err)
LOG_ERR("Connection failed (err %u)", err);
return;
LOG_INF("Connected %s", addr);
app_event_t event;
event.type = EVENT_BLE_CONNECTION;
bt_conn_get_info(conn, &info);
if (info.role == BT_CONN_ROLE_PERIPHERAL) {
event.data = BLE_CONNECTED;
current_conn_as_peripheral = bt_conn_ref(conn);
int ret = bt_gatt_exchange_mtu(conn, &mtu_exchange_params);
if (ret) {
LOG_ERR("%s: MTU exchange failed (err %d)", __func__, err);
} else if (info.role == BT_CONN_ROLE_CENTRAL) {
event.data = BLE_HRS_CONNECTED;
// Don't ref the connection here, it's already done in scan_connecting.
gatt_discover(conn);
app_post_event(event);
LOG_INF("Disconnected: %s (reason %u)", addr, reason);
app_event_t event;
if (conn == auth_conn)
bt_conn_unref(auth_conn);
auth_conn = NULL;
if (conn == current_conn_as_peripheral)
event.data = BLE_DISCONNECTED;
bt_conn_unref(conn);
current_conn_as_peripheral = NULL;
if (conn == current_hrs_conn_as_central){
event.data = BLE_HRS_DISCONNECTED;
current_hrs_conn_as_central = NULL;
#ifdef CONFIG_EQS_SERVICE_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
enum bt_security_err err)
if (!err)
LOG_DBG("Security changed: %s level %u", addr, level);
LOG_ERR("Security failed: %s level %u err %d", addr,
level, err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
.connected = connected,
.disconnected = disconnected,
.security_changed = security_changed,
#if defined(CONFIG_EQS_SERVICE_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
LOG_DBG("Passkey for %s: %06u", addr, passkey);
static void auth_passkey_confirm(struct bt_conn *conn, unsigned int passkey)
auth_conn = bt_conn_ref(conn);
LOG_DBG("Press Button 1 to confirm, Button 2 to reject.");
static void auth_cancel(struct bt_conn *conn)
LOG_DBG("Pairing cancelled: %s", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
LOG_DBG("Pairing completed: %s, bonded: %d", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
LOG_DBG("Pairing failed conn: %s, reason %d", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
.passkey_display = auth_passkey_display,
.passkey_confirm = auth_passkey_confirm,
.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
.pairing_complete = pairing_complete,
.pairing_failed = pairing_failed};
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static struct bt_conn_auth_info_cb conn_auth_info_callbacks;
struct bt_le_scan_param scan_param = {
.type = BT_HCI_LE_SCAN_PASSIVE,
.options = BT_LE_SCAN_OPT_NONE,
.interval = 0x0010,
.window = 0x0010,
.timeout = 1000, // N*10ms => timeout = 10s
static int scan_start(void)
LOG_DBG("Starting scanning for HRS devices");
int err = bt_le_scan_start(&scan_param, NULL);
if (err) {
LOG_ERR("Scanning failed to start (err %d)", err);
return err;
_scan_in_progress = true;
return err;
static void scan_filter_match(struct bt_scan_device_info *device_info,
struct bt_scan_filter_match *filter_match,
bool connectable)
bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
LOG_INF("Filters matched. Address: %s connectable: %d",
addr, connectable);
static void scan_connecting_error(struct bt_scan_device_info *device_info)
LOG_WRN("Connecting failed");
static void scan_connecting(struct bt_scan_device_info *device_info,
current_hrs_conn_as_central = bt_conn_ref(conn);
BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL,
scan_connecting_error, scan_connecting);
static void scan_recv(const struct bt_le_scan_recv_info *info, struct net_buf_simple *buf){
if (info){
bt_addr_le_to_str(info->addr, addr, sizeof(addr));
LOG_INF("Received advertising data from %s", addr);
static void scan_timeout(void){
LOG_WRN("Scan timeout");
struct bt_le_scan_cb scan_callback = {
.recv = scan_recv,
.timeout = scan_timeout,
static void scan_init(void)
int err;
struct bt_scan_init_param param = {
.scan_param = NULL,
.conn_param = BT_LE_CONN_PARAM_DEFAULT,
.connect_if_match = 1
bt_scan_init(¶m);
bt_scan_cb_register(&scan_cb);
bt_le_scan_cb_register(&scan_callback);
err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_HRS);
if (err) {
LOG_ERR("Scanning filters cannot be set (err %d)", err);
err = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
if (err) {
LOG_ERR("Filters cannot be turned on (err %d)", err);
static void bt_receive_cb(struct bt_conn *conn, const uint8_t *const data,
uint16_t len)
char addr[BT_ADDR_LE_STR_LEN] = {0};
bt_addr_le_to_str(bt_conn_get_dst(conn), addr, ARRAY_SIZE(addr));
ble_eqss_control_process(data, len);
static void bt_subscribe_cb(enum eqs_service_send_status status)
return;
static void bt_subscribe_cb_processed(enum eqs_service_send_status status)
sync_mgr_char_ind(AREA_PROCESSED, status == EQS_SERVICE_SEND_STATUS_ENABLED ? true : false);
static void bt_subscribe_cb_raw_imu(enum eqs_service_send_status status)
sync_mgr_char_ind(AREA_RAW_IMU, status == EQS_SERVICE_SEND_STATUS_ENABLED ? true : false);
static void bt_subscribe_cb_raw_ecg(enum eqs_service_send_status status)
sync_mgr_char_ind(AREA_RAW_ECG, status == EQS_SERVICE_SEND_STATUS_ENABLED ? true : false);
static void bt_subscribe_cb_storage(enum eqs_service_send_status status)
sync_mgr_char_ind(AREA_STORAGE, status == EQS_SERVICE_SEND_STATUS_ENABLED ? true : false);
static struct eqs_service_cb eqs_cb = {
.control_received = bt_receive_cb,
.control_send_enabled = bt_subscribe_cb,
.processed_send_enabled = bt_subscribe_cb_processed,
.raw_imu_send_enabled = bt_subscribe_cb_raw_imu,
.raw_ecg_send_enabled = bt_subscribe_cb_raw_ecg,
.storage_send_enabled = bt_subscribe_cb_storage,
static void num_comp_reply(bool accept)
if (accept)
bt_conn_auth_passkey_confirm(auth_conn);
LOG_DBG("Numeric Match, conn %p", (void *)auth_conn);
bt_conn_auth_cancel(auth_conn);
LOG_DBG("Numeric Reject, conn %p", (void *)auth_conn);
auth_conn = NULL;
void button_changed(uint32_t button_state, uint32_t has_changed)
uint32_t buttons = button_state & has_changed;
if (auth_conn)
if (buttons & KEY_PASSKEY_ACCEPT)
num_comp_reply(true);
if (buttons & KEY_PASSKEY_REJECT)
num_comp_reply(false);
#endif /* CONFIG_EQS_SERVICE_SECURITY_ENABLED */
bool ble_manager_is_connected()
return current_conn_as_peripheral != NULL;
bool ble_manager_control_is_subscribed(){
return bt_gatt_is_subscribed(current_conn_as_peripheral, bt_gatt_find_by_uuid(NULL, 1, BT_UUID_CONTROL), BT_GATT_CCC_INDICATE);
uint32_t ble_mgr_eqss_processed_data(app_pkt_data_t* pkt, uint16_t len){
return processed_send(NULL, pkt->bytes, len);
uint32_t ble_mgr_eqss_raw_imu(app_pkt_data_t* pkt, uint16_t len){
return raw_imu_send(NULL, pkt->bytes, len);
uint32_t ble_mgr_eqss_raw_ecg(app_pkt_data_t* pkt, uint16_t len){
return raw_ecg_send(NULL, pkt->bytes, len);
uint32_t ble_mgr_eqss_storage(app_pkt_data_t* pkt, uint16_t len){
return storage_send(NULL, pkt->bytes, len);
uint32_t ble_manager_start_hrs_scan()
int err = 0;
err = scan_start();
if (err)
LOG_ERR("Error launching scan");
return 0;
return 1;
uint32_t ble_manager_stop_hrs_scan()
int err = 0;
if (_scan_in_progress) {
LOG_DBG("Stopping scanning for HRS devices");
err = bt_le_scan_stop();
if (err)
LOG_ERR("Error stopping scan");
return 0;
else {
// No scan in progress
if (current_hrs_conn_as_central){
// There is an active connection with a HR device.
bt_conn_disconnect(current_hrs_conn_as_central, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
return 1;
uint32_t ble_manager_start_advertising()
int err = 0;
err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd,
ARRAY_SIZE(sd));
if (err)
if (err == -EALREADY)
LOG_DBG("Advertising already started.");
LOG_ERR("Advertising failed to start (err %d)", err);
return 0;
return 1;
uint32_t ble_manager_stop_advertising()
int err = 0;
err = bt_le_adv_stop();
if (err)
LOG_DBG("Advertising already stopped.");
LOG_ERR("Advertising failed to stop (err %d)", err);
return 0;
return 1;
uint32_t ble_manager_disconnect()
int err = 0;
if (current_conn_as_peripheral)
err = bt_conn_disconnect(current_conn_as_peripheral, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
if (err)
LOG_ERR("Failed to disconnect (err %d)", err);
return 0;
return 1;
uint8_t ble_manager_init()
int err = 0;
if (IS_ENABLED(CONFIG_EQS_SERVICE_SECURITY_ENABLED))
err = bt_conn_auth_cb_register(&conn_auth_callbacks);
if (err)
LOG_ERR("Failed to register authorization callbacks.");
return 0;
err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
if (err)
LOG_ERR("Failed to register authorization info callbacks.");
return 0;
err = bt_enable(NULL);
if (err)
LOG_ERR("Error enabling the Bluetooth stack...");
LOG_INF("Bluetooth initialized");
k_sem_give(&ble_init_ok);
if (IS_ENABLED(CONFIG_SETTINGS))
settings_load();
err = eqs_service_init(&eqs_cb);
if (err)
LOG_ERR("Failed to initialize EQS service (err: %d)", err);
return 0;
err = bt_hrs_client_init(&hrs_c);
if (err) {
LOG_ERR("Heart Rate Service client failed to init (err %d)", err);
return 0;
scan_init();
return 1;
static void hrs_notify_thread(void)
struct bt_hrs_client_measurement meas;
uint16_t heart_rate;
k_sem_take(&ble_init_ok, K_FOREVER);
while (1) {
k_msgq_get(&hrs_queue, &meas, K_FOREVER);
if (meas.flags.value_format) {
heart_rate = (uint8_t)(meas.hr_value >> 0x08);
} else {
heart_rate = meas.hr_value;
bt_hrs_notify(heart_rate);
void ble_mgr_start(ble_manager_evt_handler_t app_handler)
m_app_evt_handler = app_handler;
K_THREAD_DEFINE(hrs_notify_thread_id, 1024, hrs_notify_thread,
NULL, NULL, NULL, 7, 0, 0);
And the proj.conf file if that's relevant:
# Copyright (c) 2021 Nordic Semiconductor ASA # SPDX-License-Identifier: Apache-2.0 # # This file contains selected Kconfig options for the application. CONFIG_SENSOR=y # Config for Immutable Secure Bootloader CONFIG_SECURE_BOOT=n CONFIG_B0_MIN_PARTITION_SIZE=n # Config for Upgradable Bootloader CONFIG_BOOTLOADER_MCUBOOT=n CONFIG_BUILD_S1_VARIANT=n # enable logging CONFIG_LOG=y CONFIG_LOG_INFO_COLOR_GREEN=y CONFIG_LOG_MODE_IMMEDIATE=y # enable Hardware info CONFIG_HWINFO=y CONFIG_HWINFO_NRF=y # enable ADC CONFIG_ADC=y CONFIG_ADC_NRFX_SAADC=y # enable SPI CONFIG_SPI=y CONFIG_SPI_NOR=y # enabling State Machine Framework and events CONFIG_SMF=y CONFIG_EVENTS=y CONFIG_SMF_ANCESTOR_SUPPORT=y # enabling Bluetooth: both central an peripheral mode. CONFIG_BT=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_CENTRAL=y CONFIG_BT_DEVICE_NAME="Zephyr" CONFIG_BT_DEVICE_APPEARANCE=5184 # 5184 means Generic Outdoor Sports Activity. Complete list of appearance values can be found on the Bluetooth website under "assigned values" : https://www.bluetooth.com/specifications/assigned-numbers/ CONFIG_BT_MAX_CONN=2 CONFIG_BT_MAX_PAIRED=2 CONFIG_BT_GATT_CLIENT=y CONFIG_BT_L2CAP_TX_MTU=247 CONFIG_BT_BUF_ACL_RX_SIZE=251 CONFIG_BT_EXT_ADV=y CONFIG_BT_SMP=y CONFIG_BT_SCAN=y CONFIG_BT_SCAN_FILTER_ENABLE=y CONFIG_BT_SCAN_UUID_CNT=1 CONFIG_BT_GATT_DM=y CONFIG_HEAP_MEM_POOL_SIZE=512 # enabling bonding CONFIG_BT_SETTINGS=y CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_NVS=y CONFIG_SETTINGS=y # enabling BAS service and HRS service CONFIG_BT_BAS=y CONFIG_BT_HRS=y CONFIG_BT_HRS_CLIENT=y # This example requires more workqueue stack CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 CONFIG_ASSERT=y # Enable the UART driver (for the BG77 UART?) CONFIG_UART_ASYNC_API=n CONFIG_SERIAL=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_NRFX_UARTE0=y # Enbale Ring Buffer CONFIG_RING_BUFFER=y # Config for enabling newlib C CONFIG_NEWLIB_LIBC=y CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y # Enabling FPU CONFIG_FPU=y CONFIG_MAIN_STACK_SIZE=4096 CONFIG_BT_RX_STACK_SIZE=4096 CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT=y CONFIG_BT_HCI_TX_STACK_SIZE=4096 #CONFIG_THREAD_ANALYZER=y #CONFIG_THREAD_ANALYZER_AUTO=y #CONFIG_THREAD_ANALYZER_USE_LOG=y #CONFIG_THREAD_NAME=y #Enable Power Off of the device CONFIG_POWEROFF=y CONFIG_PM_DEVICE=y # USB CONFIG_STDOUT_CONSOLE=y CONFIG_USB_DEVICE_STACK=y CONFIG_USB_DEVICE_PRODUCT="test" CONFIG_USB_DEVICE_PID=0x0001 CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y CONFIG_UART_LINE_CTRL=y # Enable MBED TFM PSA for hash and crypto CONFIG_MBEDTLS=y CONFIG_MBEDTLS_BUILTIN=y CONFIG_MBEDTLS_CFG_FILE="config-tls-generic.h" CONFIG_MBEDTLS_ENTROPY_ENABLED=y CONFIG_MBEDTLS_PSA_CRYPTO_C=y CONFIG_MBEDTLS_ZEPHYR_ENTROPY=y
