Reduce the number of retries for an unavailable device
We are currently working with Zigbee coordinator sample SDK version 2.1.0.
When attempting to write data to a unavailable device, the stack sends an unimplemented signal four times, with a gap of 10 seconds between each attempt. After this (about 40 seconds) later we have the callback. But we would like to reduce this time even if it means reducing the no of retries.
To reduce the number of retries, we adjusted the value of ZB_MAC_MAX_FRAME_RETRIES from 3U to 1U. However, even after this modification, the stack still sends the unimplemented signal four times with a 10-second gap. If we need to reduce the number of retries and also the time duration between attempts, how should we adjust the settings? Our aim is to bring down this 40 seconds to 15 seconds as we don't want the user to wait that long for callback.
Please note, that in the zb_zcl_send_write_attribute command function, we have used ZB_ZCL_DISABLE_DEFAULT_RESPONSE.
Thanks, and regards,
Kavitha
    I've picked up your case and will be looking into it. I will return with an update regarding the status next week.
    Andreas
    Just an update: We've done some testing regarding the following
    apscMaxFrameRetries is set to 3 according to the spec, but macMaxFrameRetries in the 802.15.4 spec is 3 by default but can be 0-7. The question is if it is possible to change this value.
    ZB_MAC_MAX_FRAME_RETRIES, which the customer changed, does not seem to affect the number of MAC frame retries.
    We've created an internal inquiry with the Zigbee team and I'll get back to you when I have some more information
    Andreas
    The answer is as follows:
    • `ZB_N_APS_MAX_FRAME_RETRIES` defaults to 3, but the Zigbee spec defines `apscMaxFrameRetries` as `The maximum number of retries allowed after a transmission failure`, so I would say it leaves the door open to set a lower value.
    • `ZB_MAC_MAX_FRAME_RETRIES` defaults to 3, and as mentioned the IEEE 802.15.4 spec defines `macMaxFrameRetries` also as `The maximum number of retries allowed after a transmission failure` and allows the values 0-7.
    However, both are defined in `modules/lib/zboss/include/zb_config_common.h`, which means that those are hard coded in the stack provided with the precompiled libraries and modifying them has no effect (as you observed).
    So, those are the values that were used to asses the Zigbee certification conformance and Nordic in-house testing. Changing them could  lead to unexpected behavior and potentially non-conformance with the Zigbee certification.
    You can see more in 2.2.7.1 in the Zigbee spec.
    Andreas
