I have a BLE peripheral project that is based on NCS 2.5.0 using the typical flags for firmware update:
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
Other relevant flags:
CONFIG_BT_DATA_LEN_UPDATE=y
CONFIG_BT_PERIPHERAL_PREF_MIN_INT=12
CONFIG_BT_PERIPHERAL_PREF_MAX_INT=12
Of the mobile devices on hand, DFU with nRF Connect (latest version) fails only with Samsung S21 and S22 (both Android 14). There is a disconnect basically as soon as DFU is started. Have tried setting the number of buffers to both 2 and 4.
DFU does succeed, however, on other Android devices and iPhones without any issues.
The nRF Connect logs show:
V 16:58:00.033 [McuMgr] Uploading firmware...
W 16:58:05.073 [McuMgr] Error: (0x8): GATT CONN TIMEOUT
D 16:58:05.112 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
D 16:58:05.348 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
Log files are attached for a failure on S21 and a success on a non-Samsung Android tablet.
Do you have any suggestions on things to check? Thank you.
nRF Connect, 2024-04-25 Enso 3 (CF:6D:DD:E8:BB:73) V 17:19:17.162 [McuMgr] Connecting... D 17:19:17.164 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M) D 17:19:17.195 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED) I 17:19:17.198 [McuMgr] Connected to CF:6D:DD:E8:BB:73 D 17:19:17.199 [McuMgr] wait(300) V 17:19:17.501 [McuMgr] Discovering services... D 17:19:17.506 [McuMgr] gatt.discoverServices() I 17:19:17.514 [McuMgr] Services discovered V 17:19:17.516 [McuMgr] Primary service found V 17:19:17.519 [McuMgr] Requesting new MTU... D 17:19:17.521 [McuMgr] gatt.requestMtu(498) I 17:19:17.530 [McuMgr] MTU changed to: 498 D 17:19:17.531 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true) V 17:19:17.534 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48 D 17:19:17.535 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 17:19:17.570 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb V 17:19:17.573 [McuMgr] Waiting for value change... V 17:19:17.575 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 17:19:17.578 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x000000010000FF06A0, WRITE COMMAND) I 17:19:17.585 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 17:19:17.616 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-19-00-00-FF-06-BF-68-62-75-66-5F-73-69-7A-65-19-09-AB-69-62-75-66-5F-63-6F-75-6E-74-04-FF I 17:19:17.618 [McuMgr] Wait for value changed complete A 17:19:17.624 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 25, Group: 0, Seq: 255, Command: 6) CBOR {"buf_size":2475,"buf_count":4} I 17:19:17.630 [McuMgr] SMP reassembly supported with buffer size: 2475 bytes and count: 4 A 17:19:17.635 [McuMgr] Sending (10 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 2, Group: 0, Seq: 0, Command: 8) CBOR {} V 17:19:17.636 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 17:19:17.638 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000200000008BFFF, WRITE COMMAND) I 17:19:17.644 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 17:19:17.675 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-15-00-00-00-08-BF-6A-62-6F-6F-74-6C-6F-61-64-65-72-67-4D-43-55-62-6F-6F-74-FF A 17:19:17.678 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 21, Group: 0, Seq: 0, Command: 8) CBOR {"bootloader":"MCUboot"} A 17:19:17.690 [McuMgr] Sending (21 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 13, Group: 0, Seq: 1, Command: 8) CBOR {"query":"mode"} V 17:19:17.691 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 17:19:17.693 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000D00000108BF657175657279646D6F6465FF, WRITE COMMAND) I 17:19:17.702 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 17:19:17.724 Connection parameters updated (interval: 8.75ms, latency: 0, timeout: 420ms) I 17:19:17.733 [McuMgr] Connection parameters updated (interval: 8.75ms, latency: 0, timeout: 420ms) I 17:19:17.734 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-08-00-00-01-08-BF-64-6D-6F-64-65-03-FF A 17:19:17.739 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 8, Group: 0, Seq: 1, Command: 8) CBOR {"mode":3} A 17:19:17.746 [McuMgr] Sending (10 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 2, Group: 1, Seq: 2, Command: 0) CBOR {} V 17:19:17.749 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 17:19:17.756 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000200010200BFFF, WRITE COMMAND) I 17:19:17.762 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 17:19:17.784 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-F4-00-01-02-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-32-64-68-61-73-68-58-20-63-11-D4-07-C7-51-D9-51-EC-F8-A6-86-B1-7E-CF-2B-58-CF-67-8C-94-B3-13-DE-AB-D8-29-91-D4-01-81-18-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-BF-64-73-6C-6F-74-01-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-31-64-68-61-73-68-58-20-BC-66-A2-B1-B1-0A-A2-FF-54-2A-96-F5-42-11-67-DD-79-C6-34-02-20-EE-05-6E-70-17-63-22-86-9B-A3-22-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F4-66-61-63-74-69-76-65-F4-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 17:19:17.788 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 244, Group: 1, Seq: 2, Command: 0) CBOR {"images":[{"slot":0,"version":"0.0.2","hash":"YxHUB8dR2VHs+KaGsX7PK1jPZ4yUsxPeq9gpkdQBgRg=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false},{"slot":1,"version":"0.0.1","hash":"vGaisbEKov9UKpb1QhFn3XnGNAIg7gVucBdjIoaboyI=","bootable":true,"pending":false,"confirmed":false,"active":false,"permanent":false}],"splitStatus":0} V 17:19:17.801 [McuMgr] Uploading firmware... A 17:19:17.813 [McuMgr] Sending (10 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 2, Group: 63, Seq: 3, Command: 0) CBOR {} V 17:19:17.815 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 17:19:17.816 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A000002003F0300BFFF, WRITE COMMAND) I 17:19:17.821 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 17:19:17.926 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-02-00-3F-03-00-BF-FF A 17:19:17.930 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 2, Group: 63, Seq: 3, Command: 0) CBOR {} V 17:19:17.939 [McuMgr] New state: TEST A 17:19:17.942 [McuMgr] Sending (58 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 50, Group: 1, Seq: 4, Command: 0) CBOR {"confirm":false,"hash":"vGaisbEKov9UKpb1QhFn3XnGNAIg7gVucBdjIoaboyI="} V 17:19:17.946 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 17:19:17.948 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00003200010400BF67636F6E6669726DF464686173685820BC66A2B1B10AA2FF542A96F5421167DD79C6340220EE056E70176322869BA322FF, WRITE COMMAND) I 17:19:17.955 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 17:19:17.981 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-F4-00-01-04-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-32-64-68-61-73-68-58-20-63-11-D4-07-C7-51-D9-51-EC-F8-A6-86-B1-7E-CF-2B-58-CF-67-8C-94-B3-13-DE-AB-D8-29-91-D4-01-81-18-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-BF-64-73-6C-6F-74-01-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-31-64-68-61-73-68-58-20-BC-66-A2-B1-B1-0A-A2-FF-54-2A-96-F5-42-11-67-DD-79-C6-34-02-20-EE-05-6E-70-17-63-22-86-9B-A3-22-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F5-69-63-6F-6E-66-69-72-6D-65-64-F4-66-61-63-74-69-76-65-F4-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 17:19:17.985 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 244, Group: 1, Seq: 4, Command: 0) CBOR {"images":[{"slot":0,"version":"0.0.2","hash":"YxHUB8dR2VHs+KaGsX7PK1jPZ4yUsxPeq9gpkdQBgRg=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false},{"slot":1,"version":"0.0.1","hash":"vGaisbEKov9UKpb1QhFn3XnGNAIg7gVucBdjIoaboyI=","bootable":true,"pending":true,"confirmed":false,"active":false,"permanent":false}],"splitStatus":0} V 17:19:17.997 [McuMgr] New state: RESET A 17:19:18.011 [McuMgr] Sending (10 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 2, Group: 0, Seq: 5, Command: 5) CBOR {} V 17:19:18.015 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 17:19:18.016 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00000200000505BFFF, WRITE COMMAND) I 17:19:18.025 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 17:19:18.044 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-02-00-00-05-05-BF-FF A 17:19:18.047 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 2, Group: 0, Seq: 5, Command: 5) CBOR {} D 17:19:18.698 [Server callback] Connection state changed with status: 0 and new state: DISCONNECTED (0) I 17:19:18.698 [Server] Device disconnected D 17:19:18.708 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0) E 17:19:18.708 Error 8 (0x8): GATT CONN TIMEOUT I 17:19:18.708 Disconnected D 17:19:18.713 [McuMgr] [Callback] Connection state changed with status: 8 and new state: 0 (DISCONNECTED) W 17:19:18.716 [McuMgr] Error: (0x8): GATT CONN TIMEOUT I 17:19:18.720 [McuMgr] Disconnected D 17:19:18.735 [McuMgr] gatt.close() D 17:19:18.753 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED V 17:19:28.062 [McuMgr] Connecting... D 17:19:28.065 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M) V 17:19:28.071 [McuMgr] New state: CONFIRM D 17:19:38.088 [Server callback] Connection state changed with status: 0 and new state: DISCONNECTED (0) I 17:19:38.088 [Server] Device disconnected D 17:19:38.106 [McuMgr] [Callback] Connection state changed with status: 133 and new state: 0 (DISCONNECTED) W 17:19:38.109 [McuMgr] Error: (0x85): GATT ERROR D 17:19:38.111 [McuMgr] wait(500) D 17:19:38.614 [McuMgr] gatt.close() D 17:19:38.629 [McuMgr] wait(200) V 17:19:38.831 [McuMgr] Retrying... D 17:19:38.839 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M) D 17:19:39.055 [Server callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 17:19:39.055 [Server] Device with address CF:6D:DD:E8:BB:73 connected I 17:19:39.060 [Server] MTU changed to 498 D 17:19:39.111 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED) I 17:19:39.116 [McuMgr] Connected to CF:6D:DD:E8:BB:73 D 17:19:39.118 [McuMgr] wait(300) D 17:19:39.124 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED V 17:19:39.424 [McuMgr] Discovering services... D 17:19:39.428 [McuMgr] gatt.discoverServices() I 17:19:39.575 [McuMgr] Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms) I 17:19:40.049 [McuMgr] Services discovered V 17:19:40.056 [McuMgr] Primary service found V 17:19:40.059 [McuMgr] Requesting new MTU... D 17:19:40.060 [McuMgr] gatt.requestMtu(498) I 17:19:40.064 [McuMgr] MTU changed to: 498 D 17:19:40.072 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true) V 17:19:40.075 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48 D 17:19:40.076 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 17:19:40.110 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb V 17:19:40.112 [McuMgr] Waiting for value change... V 17:19:40.114 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 17:19:40.115 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x000000010000FF06A0, WRITE COMMAND) I 17:19:40.123 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 17:19:40.143 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-19-00-00-FF-06-BF-68-62-75-66-5F-73-69-7A-65-19-09-AB-69-62-75-66-5F-63-6F-75-6E-74-04-FF I 17:19:40.146 [McuMgr] Wait for value changed complete I 17:19:40.148 [McuMgr] Connection parameters updated (interval: 47.5ms, latency: 0, timeout: 5000ms) A 17:19:40.150 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 25, Group: 0, Seq: 255, Command: 6) CBOR {"buf_size":2475,"buf_count":4} I 17:19:40.158 [McuMgr] SMP reassembly supported with buffer size: 2475 bytes and count: 4 A 17:19:40.163 [McuMgr] Sending (58 bytes) Header (Version: 1, Op: 2, Flags: 0, Len: 50, Group: 1, Seq: 0, Command: 0) CBOR {"confirm":true,"hash":"vGaisbEKov9UKpb1QhFn3XnGNAIg7gVucBdjIoaboyI="} V 17:19:40.165 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 17:19:40.170 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0A00003200010000BF67636F6E6669726DF564686173685820BC66A2B1B10AA2FF542A96F5421167DD79C6340220EE056E70176322869BA322FF, WRITE COMMAND) I 17:19:40.176 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 17:19:40.289 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 0B-00-00-F4-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-31-64-68-61-73-68-58-20-BC-66-A2-B1-B1-0A-A2-FF-54-2A-96-F5-42-11-67-DD-79-C6-34-02-20-EE-05-6E-70-17-63-22-86-9B-A3-22-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-BF-64-73-6C-6F-74-01-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-32-64-68-61-73-68-58-20-63-11-D4-07-C7-51-D9-51-EC-F8-A6-86-B1-7E-CF-2B-58-CF-67-8C-94-B3-13-DE-AB-D8-29-91-D4-01-81-18-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F4-66-61-63-74-69-76-65-F4-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 17:19:40.294 [McuMgr] Received Header (Version: 1, Op: 3, Flags: 0, Len: 244, Group: 1, Seq: 0, Command: 0) CBOR {"images":[{"slot":0,"version":"0.0.1","hash":"vGaisbEKov9UKpb1QhFn3XnGNAIg7gVucBdjIoaboyI=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false},{"slot":1,"version":"0.0.2","hash":"YxHUB8dR2VHs+KaGsX7PK1jPZ4yUsxPeq9gpkdQBgRg=","bootable":true,"pending":false,"confirmed":false,"active":false,"permanent":false}],"splitStatus":0} V 17:19:40.303 [McuMgr] Disconnecting... D 17:19:40.304 [McuMgr] gatt.disconnect() D 17:19:40.314 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 0 (DISCONNECTED) I 17:19:40.315 [McuMgr] Disconnected D 17:19:40.316 [McuMgr] gatt.close() D 17:19:40.328 gatt.close() D 17:19:40.330 wait(200) V 17:19:40.531 Connecting to CF:6D:DD:E8:BB:73... D 17:19:40.531 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 17:19:40.556 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 17:19:40.556 Connected to CF:6D:DD:E8:BB:73 V 17:19:40.569 Discovering services... D 17:19:40.569 gatt.discoverServices() I 17:19:41.284 Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms) D 17:19:41.692 [Callback] Services discovered with status: 0 I 17:19:41.692 Services discovered V 17:19:41.704 Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) Generic Access (0x1800) - Device Name [R] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) Battery Service (0x180F) - Battery Level [N R] (0x2A19) Client Characteristic Configuration (0x2902) Device Information (0x180A) - Model Number String [R] (0x2A24) - Manufacturer Name String [R] (0x2A29) - Serial Number String [R] (0x2A25) - Firmware Revision String [R] (0x2A26) - Hardware Revision String [R] (0x2A27) - Software Revision String [R] (0x2A28) Unknown Service (e5030001-4e19-428e-a331-f90d5abba18c) - Unknown Characteristic [W WNR] (e5030002-4e19-428e-a331-f90d5abba18c) - Unknown Characteristic [N] (e5030003-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N] (e5030004-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W WNR] (e5030005-4e19-428e-a331-f90d5abba18c) - Unknown Characteristic [N R] (e5030006-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R] (e5030007-4e19-428e-a331-f90d5abba18c) - Unknown Characteristic [N R] (e5030008-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R] (e5030009-4e19-428e-a331-f90d5abba18c) - Unknown Characteristic [N R] (e503000a-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N R] (e503000b-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N R] (e503000c-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N] (e503000d-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N R] (e503000e-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R] (e503000f-4e19-428e-a331-f90d5abba18c) - Unknown Characteristic [R] (e5030010-4e19-428e-a331-f90d5abba18c) SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84) - SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48) Client Characteristic Configuration (0x2902) D 17:19:41.704 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) D 17:19:41.707 gatt.setCharacteristicNotification(00002a19-0000-1000-8000-00805f9b34fb, true) D 17:19:41.709 gatt.setCharacteristicNotification(e5030003-4e19-428e-a331-f90d5abba18c, true) D 17:19:41.713 gatt.setCharacteristicNotification(e5030004-4e19-428e-a331-f90d5abba18c, true) D 17:19:41.715 gatt.setCharacteristicNotification(e5030006-4e19-428e-a331-f90d5abba18c, true) D 17:19:41.716 gatt.setCharacteristicNotification(e5030008-4e19-428e-a331-f90d5abba18c, true) D 17:19:41.724 gatt.setCharacteristicNotification(e503000a-4e19-428e-a331-f90d5abba18c, true) D 17:19:41.726 gatt.setCharacteristicNotification(e503000b-4e19-428e-a331-f90d5abba18c, true) D 17:19:41.728 gatt.setCharacteristicNotification(e503000c-4e19-428e-a331-f90d5abba18c, true) D 17:19:41.730 gatt.setCharacteristicNotification(e503000d-4e19-428e-a331-f90d5abba18c, true) D 17:19:41.733 gatt.setCharacteristicNotification(e503000e-4e19-428e-a331-f90d5abba18c, true) I 17:19:41.805 Connection parameters updated (interval: 47.5ms, latency: 0, timeout: 5000ms) I 17:19:44.422 Connection parameters updated (interval: 8.75ms, latency: 0, timeout: 420ms) I 17:19:45.335 Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 420ms)
nRF Connect, 2024-04-25 Enso 3 (E8:04:E0:A1:93:8F) V 16:57:54.925 [McuMgr] Connecting... D 16:57:54.927 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M) D 16:57:54.953 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED) I 16:57:54.956 [McuMgr] Connected to E8:04:E0:A1:93:8F D 16:57:54.957 [McuMgr] wait(1600) V 16:57:56.559 [McuMgr] Discovering services... D 16:57:56.567 [McuMgr] gatt.discoverServices() I 16:57:56.584 [McuMgr] Services discovered V 16:57:56.586 [McuMgr] Primary service found V 16:57:56.589 [McuMgr] Requesting new MTU... D 16:57:56.592 [McuMgr] gatt.requestMtu(498) I 16:57:56.601 [McuMgr] MTU changed to: 498 D 16:57:56.603 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true) V 16:57:56.607 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48 D 16:57:56.608 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 16:57:56.652 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb V 16:57:56.656 [McuMgr] Waiting for value change... V 16:57:56.659 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 16:57:56.662 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x000000010000FF06A0, WRITE COMMAND) I 16:57:56.668 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 16:57:56.698 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-19-00-00-FF-06-BF-68-62-75-66-5F-73-69-7A-65-19-09-AB-69-62-75-66-5F-63-6F-75-6E-74-04-FF I 16:57:56.701 [McuMgr] Wait for value changed complete A 16:57:56.704 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 25, Group: 0, Seq: 255, Command: 6) CBOR {"buf_size":2475,"buf_count":4} I 16:57:56.710 [McuMgr] SMP reassembly supported with buffer size: 2475 bytes and count: 4 A 16:57:56.715 [McuMgr] Sending (10 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 2, Group: 0, Seq: 0, Command: 8) CBOR {} V 16:57:56.716 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 16:57:56.718 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000200000008BFFF, WRITE COMMAND) I 16:57:56.723 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 16:57:56.757 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-15-00-00-00-08-BF-6A-62-6F-6F-74-6C-6F-61-64-65-72-67-4D-43-55-62-6F-6F-74-FF A 16:57:56.762 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 21, Group: 0, Seq: 0, Command: 8) CBOR {"bootloader":"MCUboot"} A 16:57:56.771 [McuMgr] Sending (21 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 13, Group: 0, Seq: 1, Command: 8) CBOR {"query":"mode"} V 16:57:56.773 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 16:57:56.774 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000D00000108BF657175657279646D6F6465FF, WRITE COMMAND) I 16:57:56.780 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 16:57:56.820 Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms) I 16:57:56.825 [McuMgr] Connection parameters updated (interval: 11.25ms, latency: 0, timeout: 420ms) D 16:57:57.530 [McuMgr] [Callback] Connection state changed with status: 8 and new state: 0 (DISCONNECTED) D 16:57:57.531 [Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0) E 16:57:57.531 Error 8 (0x8): GATT CONN TIMEOUT I 16:57:57.531 Disconnected W 16:57:57.536 [McuMgr] Error: (0x8): GATT CONN TIMEOUT I 16:57:57.538 [McuMgr] Disconnected D 16:57:57.564 [McuMgr] gatt.close() D 16:57:57.573 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED V 16:57:57.583 [McuMgr] Connecting... D 16:57:57.584 [McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M) D 16:57:58.014 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED D 16:57:58.017 [McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED) I 16:57:58.018 [McuMgr] Connected to E8:04:E0:A1:93:8F D 16:57:58.023 [McuMgr] wait(1600) V 16:57:59.625 [McuMgr] Discovering services... D 16:57:59.628 [McuMgr] gatt.discoverServices() I 16:57:59.656 [McuMgr] Services discovered V 16:57:59.657 [McuMgr] Primary service found V 16:57:59.659 [McuMgr] Requesting new MTU... D 16:57:59.660 [McuMgr] gatt.requestMtu(498) I 16:57:59.664 [McuMgr] MTU changed to: 498 D 16:57:59.665 [McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true) V 16:57:59.668 [McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48 D 16:57:59.668 [McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00) I 16:57:59.831 [McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb V 16:57:59.833 [McuMgr] Waiting for value change... V 16:57:59.835 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 16:57:59.836 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x000000010000FF06A0, WRITE COMMAND) I 16:57:59.840 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 16:57:59.923 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-19-00-00-FF-06-BF-68-62-75-66-5F-73-69-7A-65-19-09-AB-69-62-75-66-5F-63-6F-75-6E-74-04-FF I 16:57:59.924 [McuMgr] Wait for value changed complete A 16:57:59.928 [McuMgr] Received Header (Version: 0, Op: 1, Flags: 0, Len: 25, Group: 0, Seq: 255, Command: 6) CBOR {"buf_size":2475,"buf_count":4} I 16:57:59.933 [McuMgr] SMP reassembly supported with buffer size: 2475 bytes and count: 4 A 16:57:59.937 [McuMgr] Sending (10 bytes) Header (Version: 1, Op: 0, Flags: 0, Len: 2, Group: 1, Seq: 0, Command: 0) CBOR {} V 16:57:59.939 [McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND) D 16:57:59.940 [McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48, value=0x0800000200010000BFFF, WRITE COMMAND) I 16:57:59.943 [McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48 I 16:58:00.017 [McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 09-00-00-F4-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-31-2E-31-2E-32-64-68-61-73-68-58-20-0D-77-65-EB-A3-4A-E3-10-78-42-EC-2B-E7-DB-7A-49-1F-0C-53-F7-CF-72-4F-D3-FB-D1-9A-7A-EF-A6-2A-62-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-BF-64-73-6C-6F-74-01-67-76-65-72-73-69-6F-6E-65-31-2E-31-2E-31-64-68-61-73-68-58-20-BE-D6-EC-98-B0-7F-C9-5B-D1-67-FD-48-E6-30-9A-1C-7C-1F-5A-15-02-2E-20-64-F3-7C-FA-1E-AB-FE-DF-AC-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F4-66-61-63-74-69-76-65-F4-69-70-65-72-6D-61-6E-65-6E-74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF A 16:58:00.021 [McuMgr] Received Header (Version: 1, Op: 1, Flags: 0, Len: 244, Group: 1, Seq: 0, Command: 0) CBOR {"images":[{"slot":0,"version":"1.1.2","hash":"DXdl66NK4xB4Quwr59t6SR8MU/fPck/T+9Gaeu+mKmI=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false},{"slot":1,"version":"1.1.1","hash":"vtbsmLB/yVvRZ/1I5jCaHHwfWhUCLiBk83z6Hqv+36w=","bootable":true,"pending":false,"confirmed":false,"active":false,"permanent":false}],"splitStatus":0} V 16:58:00.033 [McuMgr] Uploading firmware... W 16:58:05.073 [McuMgr] Error: (0x8): GATT CONN TIMEOUT D 16:58:05.112 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED D 16:58:05.348 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED W 16:58:12.236 [McuMgr] Error: (0x8): GATT CONN TIMEOUT D 16:58:12.253 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED D 16:58:12.490 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED W 16:58:19.437 [McuMgr] Error: (0x8): GATT CONN TIMEOUT D 16:58:19.454 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED D 16:58:19.695 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED W 16:58:26.614 [McuMgr] Error: (0x8): GATT CONN TIMEOUT D 16:58:26.660 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED D 16:58:26.862 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED W 16:58:33.769 [McuMgr] Error: (0x8): GATT CONN TIMEOUT D 16:58:33.794 gatt.close() D 16:58:33.797 wait(200) V 16:58:33.999 Connecting to E8:04:E0:A1:93:8F... D 16:58:33.999 gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M) D 16:58:34.012 [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED I 16:58:34.097 Disconnected D 16:58:34.336 [Callback] Connection state changed with status: 0 and new state: CONNECTED (2) I 16:58:34.336 Connected to E8:04:E0:A1:93:8F D 16:58:34.336 wait(1600ms) D 16:58:34.355 [Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED V 16:58:35.938 Discovering services... D 16:58:35.938 gatt.discoverServices() D 16:58:35.949 [Callback] Services discovered with status: 0 I 16:58:35.949 Services discovered V 16:58:35.964 Generic Attribute (0x1801) - Service Changed [I] (0x2A05) Client Characteristic Configuration (0x2902) Generic Access (0x1800) - Device Name [R] (0x2A00) - Appearance [R] (0x2A01) - Peripheral Preferred Connection Parameters [R] (0x2A04) Battery Service (0x180F) - Battery Level [N R] (0x2A19) Client Characteristic Configuration (0x2902) Device Information (0x180A) - Model Number String [R] (0x2A24) - Manufacturer Name String [R] (0x2A29) - Serial Number String [R] (0x2A25) - Firmware Revision String [R] (0x2A26) - Hardware Revision String [R] (0x2A27) - Software Revision String [R] (0x2A28) Unknown Service (e5030001-4e19-428e-a331-f90d5abba18c) - Unknown Characteristic [W WNR] (e5030002-4e19-428e-a331-f90d5abba18c) - Unknown Characteristic [N] (e5030003-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N] (e5030004-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R W WNR] (e5030005-4e19-428e-a331-f90d5abba18c) - Unknown Characteristic [N R] (e5030006-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R] (e5030007-4e19-428e-a331-f90d5abba18c) - Unknown Characteristic [N R] (e5030008-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R] (e5030009-4e19-428e-a331-f90d5abba18c) - Unknown Characteristic [N R] (e503000a-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N R] (e503000b-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N R] (e503000c-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N] (e503000d-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [N R] (e503000e-4e19-428e-a331-f90d5abba18c) Client Characteristic Configuration (0x2902) - Unknown Characteristic [R] (e503000f-4e19-428e-a331-f90d5abba18c) - Unknown Characteristic [R] (e5030010-4e19-428e-a331-f90d5abba18c) SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84) - SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48) Client Characteristic Configuration (0x2902) D 16:58:35.964 gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true) D 16:58:35.968 gatt.setCharacteristicNotification(00002a19-0000-1000-8000-00805f9b34fb, true) D 16:58:35.971 gatt.setCharacteristicNotification(e5030003-4e19-428e-a331-f90d5abba18c, true) D 16:58:35.973 gatt.setCharacteristicNotification(e5030004-4e19-428e-a331-f90d5abba18c, true) D 16:58:35.975 gatt.setCharacteristicNotification(e5030006-4e19-428e-a331-f90d5abba18c, true) D 16:58:35.976 gatt.setCharacteristicNotification(e5030008-4e19-428e-a331-f90d5abba18c, true) D 16:58:35.978 gatt.setCharacteristicNotification(e503000a-4e19-428e-a331-f90d5abba18c, true) D 16:58:35.980 gatt.setCharacteristicNotification(e503000b-4e19-428e-a331-f90d5abba18c, true) D 16:58:35.981 gatt.setCharacteristicNotification(e503000c-4e19-428e-a331-f90d5abba18c, true) D 16:58:35.983 gatt.setCharacteristicNotification(e503000d-4e19-428e-a331-f90d5abba18c, true) D 16:58:35.987 gatt.setCharacteristicNotification(e503000e-4e19-428e-a331-f90d5abba18c, true) I 16:58:39.629 Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 420ms)
