Hi! I am using cellular GNSS example 6 provided by DEV Academy. I am getting compile time duplicate IRQ error message.
/* * Copyright (c) 2022 Nordic Semiconductor ASA * * SPDX-License-Identifier: LicenseRef-Nordic-5-Clause */ #include <stdio.h> #include <zephyr/kernel.h> #include <zephyr/logging/log.h> #include <modem/lte_lc.h> // #include <dk_buttons_and_leds.h> /* STEP 4 - Include the header file for the GNSS interface */ #include <nrf_modem_gnss.h> /* STEP 5 - Define the PVT data frame variable */ static struct nrf_modem_gnss_pvt_data_frame pvt_data; /* STEP 12.1 - Declare helper variables to find the TTFF */ static int64_t gnss_start_time; static bool first_fix = false; static K_SEM_DEFINE(lte_connected, 0, 1); LOG_MODULE_REGISTER(Lesson6_Exercise1, LOG_LEVEL_INF); static void modem_configure(void) { int err = lte_lc_init(); if (err) { LOG_ERR("Failed to initialize LTE Link Controller, error: %d", err); return; } } /* STEP 6 - Define a function to log fix data in a readable format */ static void print_fix_data(struct nrf_modem_gnss_pvt_data_frame *pvt_data) { LOG_INF("Latitude: %.06f", pvt_data->latitude); LOG_INF("Longitude: %.06f", pvt_data->longitude); LOG_INF("Altitude: %.01f m", pvt_data->altitude); LOG_INF("Time (UTC): %02u:%02u:%02u.%03u", pvt_data->datetime.hour, pvt_data->datetime.minute, pvt_data->datetime.seconds, pvt_data->datetime.ms); } static void gnss_event_handler(int event) { int err; switch (event) { /* STEP 7 - On a PVT event, confirm if PVT data is a valid fix */ case NRF_MODEM_GNSS_EVT_PVT: LOG_INF("Searching..."); /* STEP 15 - Print satellite information */ int num_satellites = 0; for (int i = 0; i < 12 ; i++) { if (pvt_data.sv[i].signal != 0) { LOG_INF("sv: %d, cn0: %d", pvt_data.sv[i].sv, pvt_data.sv[i].cn0); num_satellites++; } } LOG_INF("Number of current satellites: %d", num_satellites); err = nrf_modem_gnss_read(&pvt_data, sizeof(pvt_data), NRF_MODEM_GNSS_DATA_PVT); if (err) { LOG_ERR("nrf_modem_gnss_read failed, err %d", err); return; } if (pvt_data.flags & NRF_MODEM_GNSS_PVT_FLAG_FIX_VALID) { //dk_set_led_on(DK_LED1); print_fix_data(&pvt_data); /* STEP 12.3 - Print the time to first fix */ if (!first_fix) { LOG_INF("Time to first fix: %2.1lld s", (k_uptime_get() - gnss_start_time)/1000); first_fix = true; } return; } break; /* STEP 7.2 - Log when the GNSS sleeps and wakes up */ case NRF_MODEM_GNSS_EVT_PERIODIC_WAKEUP: LOG_INF("GNSS has woken up"); break; case NRF_MODEM_GNSS_EVT_SLEEP_AFTER_FIX: LOG_INF("GNSS enter sleep after fix"); break; default: break; } } void main(void) { // if (dk_leds_init() != 0) { // LOG_ERR("Failed to initialize the LEDs Library"); // } modem_configure(); /* STEP 8 - Activate only the GNSS stack */ if (lte_lc_func_mode_set(LTE_LC_FUNC_MODE_ACTIVATE_GNSS) != 0) { LOG_ERR("Failed to activate GNSS functional mode"); return; } /* STEP 9 - Register the GNSS event handler */ if (nrf_modem_gnss_event_handler_set(gnss_event_handler) != 0) { LOG_ERR("Failed to set GNSS event handler"); return; } /* STEP 10 - Set the GNSS fix interval and GNSS fix retry period */ if (nrf_modem_gnss_fix_interval_set(CONFIG_GNSS_PERIODIC_INTERVAL) != 0) { LOG_ERR("Failed to set GNSS fix interval"); return; } if (nrf_modem_gnss_fix_retry_set(CONFIG_GNSS_PERIODIC_TIMEOUT) != 0) { LOG_ERR("Failed to set GNSS fix retry"); return; } /* STEP 11 - Start the GNSS receiver*/ LOG_INF("Starting GNSS"); if (nrf_modem_gnss_start() != 0) { LOG_ERR("Failed to start GNSS"); return; } /* STEP 12.2 - Log the current system uptime */ gnss_start_time = k_uptime_get(); }
This is output of IRQ ERROR message.
Following is my project config file.
# # Copyright (c) 2019 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # # Logging CONFIG_LOG=y # Button and LED support CONFIG_DK_LIBRARY=y # Newlib CONFIG_NEWLIB_LIBC=y # STEP 2.2 - Enable printing of floating-points CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y CONFIG_FPU=y # Network CONFIG_NETWORKING=y CONFIG_NET_NATIVE=n CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS_POSIX_NAMES=y # Memory CONFIG_HEAP_MEM_POOL_SIZE=4096 CONFIG_MAIN_STACK_SIZE=4096 # Modem library CONFIG_NRF_MODEM_LIB=y # LTE link control CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_AUTO_INIT_AND_CONNECT=n # STEP 2.1 - Enable modem GPS mode CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS=y
