Hi there,
Please check logs and below data on ZEPHYR FATAL ERROR. Please let me know if you need any other info.
* Sample: Matter Light Bulb
* nRF Connect SDK version: 2.6.0
* HW: nRF21540-DK
* Behaviour: Device will crash on establishing a connection when CONFIG_SERIAL=y flag is enabled.
* Logs: Attached
[00:00:00.001,831] <err> qspi_nor: JEDEC id [00 00 00] expect [c2 28 17] *** Booting nRF Connect SDK v3.5.99-ncs1 *** [00:00:00.022,338] <inf> chip: [DL]BLE address: F8:AC:68:19:31:DB [00:00:00.035,827] <inf> chip: [DL]CHIP task running [00:00:00.042,358] <inf> app: Init CHIP stack [00:00:00.049,530] <inf> chip: [DL]OpenThread started: OK [00:00:00.056,396] <inf> chip: [DL]Setting OpenThread device type to ROUTER [00:00:00.064,910] <inf> chip: [SVR]Subscription persistence not supported [00:00:00.073,303] <inf> chip: [SVR]Server initializing... [00:[00:00:00.001,831] <err> qspi_nor: JEDEC id [00 00 00] expect [c2 28 17] *** Booting nRF Connect SDK v3.5.99-ncs1 *** [00:00:00.022,308] <inf> chip: [DL]BLE address: E8:5C:DE:B3:4E:91 [00:00:00.035,797] <inf> chip: [DL]CHIP task running [00:00:00.042,327] <inf> app: Init CHIP stack [00:00:00.049,499] <inf> chip: [DL]OpenThread started: OK [00:00:00.056,365] <inf> chip: [DL]Setting OpenThread device type to ROUTER [00:00:00.064,880] <inf> chip: [SVR]Subscription persistence not supported [00:00:00.073,272] <inf> chip: [SVR]Server initializing... [00:00:00.080,596] <inf> chip: [TS]Last Known Good Time: 2023-10-14T01:16:48 [00:00:00.089,752] <inf> chip: [DMG]AccessControl: initializing [00:00:00.097,167] <inf> chip: [DMG]Examples::AccessControlDelegate::Init [00:00:00.105,560] <inf> chip: [DMG]AccessControl: setting [00:00:00.112,518] <inf> chip: [DMG]DefaultAclStorage: initializing [00:00:00.120,300] <inf> chip: [DMG]DefaultAclStorage: 0 entries loaded [00:00:00.128,479] <dbg> chip: LogV: [IN]UDP::Init bind&listen port=5540 [00:00:00.136,901] <dbg> chip: LogV: [IN]UDP::Init bound to port=5540 [00:00:00.144,866] <dbg> chip: LogV: [IN]BLEBase::Init - setting/overriding transport [00:00:00.154,266] <dbg> chip: LogV: [IN]TransportMgr initialized [00:00:00.165,069] <dbg> chip: LogV: [DL]Using Thread extended MAC for hostname. [00:00:00.175,659] <inf> chip: [ZCL]Using ZAP configuration... [00:00:00.185,333] <inf> chip: [DMG]AccessControlCluster: initializing [00:00:00.193,450] <dbg> chip: LogV: [DL]Boot reason: 1 [00:00:00.200,347] <inf> chip: [ZCL]Initiating Admin Commissioning cluster. [00:00:00.209,106] <inf> chip: [ZCL]Endpoint 1 On/off already set to new value [00:00:00.218,170] <inf> chip: [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254 [00:00:00.229,858] <dbg> chip: LogV: [IN]SecureSession[0x20002fe8]: Allocated Type:1 LSID:49973 [00:00:00.240,203] <dbg> chip: LogV: [DL]CHIPoBLE advertising set to on [00:00:00.248,413] <inf> chip: [DIS]Updating services using commissioning mode 1 [00:00:00.257,415] <err> chip: [DIS]Failed to remove advertised services: 3 [00:00:00.265,960] <dbg> chip: LogV: [DL]Using Thread extended MAC for hostname. [00:00:00.275,360] <inf> chip: [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 [00:00:00.288,299] <err> chip: [DIS]Failed to advertise commissionable node: 3 [00:00:00.297,058] <err> chip: [DIS]Failed to finalize service update: 3 [00:00:00.305,328] <inf> chip: [DIS]Updating services using commissioning mode 1 [00:00:00.314,270] <err> chip: [DIS]Failed to remove advertised services: 3 [00:00:00.322,845] <dbg> chip: LogV: [DL]Using Thread extended MAC for hostname. [00:00:00.332,214] <inf> chip: [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 [00:00:00.345,153] <err> chip: [DIS]Failed to advertise commissionable node: 3 [00:00:00.353,942] <err> chip: [DIS]Failed to finalize service update: 3 [00:00:00.362,182] <inf> chip: [IN]CASE Server enabling CASE session setups [00:00:00.371,063] <dbg> chip: LogV: [IN]SecureSession[0x200030a8]: Allocated Type:2 LSID:49974 [00:00:00.381,378] <inf> chip: [SVR]Joining Multicast groups [00:00:00.388,671] <inf> chip: [SVR]Server Listening... [00:00:00.395,355] <inf> chip: [DL]Device Configuration: [00:00:00.402,404] <inf> chip: [DL] Serial Number: 11223344556677889900 [00:00:00.410,644] <inf> chip: [DL] Vendor Id: 65521 (0xFFF1) [00:00:00.417,999] <inf> chip: [DL] Product Id: 32773 (0x8005) [00:00:00.425,415] <inf> chip: [DL] Product Name: not-specified [00:00:00.433,166] <inf> chip: [DL] Hardware Version: 0 [00:00:00.440,246] <inf> chip: [DL] Setup Pin Code (0 for UNKNOWN/ERROR): 20202021 [00:00:00.449,798] <inf> chip: [DL] Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00) [00:00:00.460,540] <inf> chip: [DL] Manufacturing Date: (not set) [00:00:00.468,231] <inf> chip: [DL] Device Type: 65535 (0xFFFF) [00:00:00.476,348] <inf> chip: [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00] [00:00:00.484,741] <inf> chip: [SVR]Copy/paste the below URL in a browser to see the QR Code: [00:00:00.494,873] <inf> chip: [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A6FCJ142C00KA0648G00 [00:00:00.507,904] <inf> chip: [SVR]Manual pairing code: [34970112332] [00:00:00.516,113] <err> chip: [DL]Long dispatch time: 474 ms, for event type 2 [00:00:00.525,146] <inf> chip: [ZCL]Cluster OnOff: attribute OnOff set to 0 [00:00:00.533,782] <inf> chip: [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254 [00:00:00.545,532] <inf> chip: [DL]CHIPoBLE advertising started [00:00:00.553,619] <inf> chip: [DL]NFC Tag emulation started [00:00:26.787,414] <err> os: ***** MPU FAULT ***** [00:00:26.793,579] <err> os: Stacking error (context area might be not valid) [00:00:26.802,307] <err> os: Data Access Violation [00:00:26.808,624] <err> os: MMFAR Address: 0x200231b8 [00:00:26.815,368] <err> os: r0/a1: 0x865cee3c r1/a2: 0x5a65e243 r2/a3: 0x23f7755f [00:00:26.824,920] <err> os: r3/a4: 0x21200ac1 r12/ip: 0xaaaaaaaa r14/lr: 0xaaaaaaaa [00:00:26.834,472] <err> os: xpsr: 0x21000000 [00:00:26.840,423] <err> os: s[ 0]: 0x0000005b s[ 1]: 0x5b0ab320 s[ 2]: 0x000b0f55 s[ 3]: 0x00011187 [00:00:26.851,867] <err> os: s[ 4]: 0xaaaaaaaa s[ 5]: 0xaaaaaaaa s[ 6]: 0xaaaaaaaa s[ 7]: 0x000ab320 [00:00:26.863,311] <err> os: s[ 8]: 0xaaaaaaaa s[ 9]: 0xaaaaaaaa s[10]: 0x000b0f56 s[11]: 0xaaaaaaaa [00:00:26.874,786] <err> os: s[12]: 0xaaaaaaaa s[13]: 0xaaaaaaaa s[14]: 0xaaaaaaaa s[15]: 0xaaaaaaaa [00:00:26.886,230] <err> os: fpscr: 0xaaaaaaaa [00:00:26.892,150] <err> os: Faulting instruction address (r15/pc): 0x00021740 [00:00:26.900,848] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0 [00:00:26.909,545] <err> os: Current thread: 0x20006178 (BT RX) [00:00:26.916,870] [1;31m<err> os: Halting system[0m
* Changes:
- Added below lines to prj_no_dfu.con
# Reduce application size
#CONFIG_USE_SEGGER_RTT=n
# Config logger
CONFIG_LOG=y
CONFIG_MATTER_LOG_LEVEL_DBG=y
CONFIG_LOG_MODE_IMMEDIATE=y
# Config UART
CONFIG_SERIAL=y
