I'm facing an issue with Wi-Fi connectivity on my custom board equipped with nRF7002 and nRF52840. When I attempt to connect using net_mgmt(NET_REQUEST_WIFI_CONNECT), I consistently receive an error code of -134. The error appears almost instantaneously, seems like net_mgmt might not even initiate the Wi-Fi scanning process before returning the error.
But everything functions flawlessly when using the shell example for Wi-Fi connection and pinging 100 times.
I have tried searching the error of net_mgmt but it is closed source
I would greatly appreciate any insights or suggestions from the forum.
I've already tried the following:
- Verified the connection between nRF7002 and nRF52840 matched the device tree config.
- Verified my Wi-Fi configuration (SSID, security type, password, not hidden)
- Look up Network Management API documents (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/connectivity/networking/api/net_mgmt.html#c.net_mgmt)
- Verified power for the nRF7002 and nRF52840 (Power Supply 3.1V 1A)
- Increase CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT to 5000
- Set hotspot to 2.4GHz open network and update wifi_connect_req_params to WIFI_SECURITY_TYPE_NONE
Questions:
1. What does net_mgnt error code mean?
2. What is the difference between shell example "wifi connect <ssid> <password>" and
Here is the error message
*** Booting nRF Connect SDK v2.5.1 *** [00:00:01.520,538] <err> Lesson4_Exercise1: Connecting to Wi-Fi failed, err: -134
If I further decrease CONFIG_HEAP_MEM_POOL_SIZE=103600, the code produced same error code but more error message were shown.
*** Booting nRF Connect SDK v2.5.1 *** [00:00:00.528,594] <err> wifi_nrf: hal_rpu_event_get: Unable to alloc HAL msg for event [00:00:01.520,538] <err> Lesson4_Exercise1: Connecting to Wi-Fi failed, err: -134 [00:00:10.524,688] <err> wifi_nrf: hal_rpu_cmd_queue: Unable to alloc buff for frag HAL cmd [00:00:10.524,749] <err> wifi_nrf: nrf_wifi_hal_ctrl_cmd_send: Queueing of command failed [00:00:10.524,780] <err> wifi_nrf: nrf_wifi_wpa_set_supp_port: nrf_wifi_fmac_chg_sta failed
Here is the log for shell example + ping:
SEGGER J-Link V7.90a - Real time terminal output SEGGER J-Link (unknown) V1.0, SN=683375020 Process: JLink.exe rtt:~$ [00:00:00.358,673] <inf> wifi_nrf: SPIM spi@4002f000: freq = 8 MHz rtt:~$ [00:00:00.358,703] <inf> wifi_nrf: SPIM spi@4002f000: latency = 0 rtt:~$ rtt:~$ [00:00:00.592,864] <inf> fs_nvs: 6 Sectors of 4096 bytes rtt:~$ [00:00:00.592,864] <inf> fs_nvs: alloc wra: 0, fd0 rtt:~$ [00:00:00.592,895] <inf> fs_nvs: data wra: 0, 1c rtt:~$ *** Booting nRF Connect SDK v2.5.1 *** rtt:~$ Starting tracker_nrf52840 with CPU frequency: 64 MHz rtt:~$ [00:00:00.593,444] <inf> wpa_supp: Successfully initialized wpa_supplicant net ping 8.8.8.8 -c 100 PING 8.8.8.8 Disconnected Connected [00:06:37.000,671] <inf> wpa_supp: wlan0: CTRL-EVENT-DISCONNECTED bssid=0e:bd:4f:23:7a:0c reason=7 rtt:~$ net[00:06:37.008,117] <inf> wpa_supp: wlan0: SME: Trying to authenticate with 0e:bd:4f:23:7a:0c (SSID='Wireless_FC' freq=2412 MHz) rtt:~$ net[00:06:37.029,785] <inf> wpa_supp: wlan0: Trying to associate with 0e:bd:4f:23:7a:0c (SSID='Wireless_FC' freq=2412 MHz) rtt:~$ net[00:06:37.095,733] <inf> wpa_supp: wlan0: Associated with 0e:bd:4f:23:7a:0c rtt:~$ net[00:06:37.096,313] <inf> wpa_supp: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0 rtt:~$ net[00:06:37.124,847] <inf> wpa_supp: wlan0: WPA: Key negotiation completed with 0e:bd:4f:23:7a:0c [PTK=CCMP GTK=CCMP] rtt:~$ net[00:06:37.125,213] <inf> wpa_supp: wlan0: CTRL-EVENT-CONNECTED - Connection to 0e:bd:4f:23:7a:0c completed [id=0 id_str=] rtt:~$ netrtt:~$ netrtt:~$ net[00:06:38.042,755] <inf> net_dhcpv4: Received: 192.168.227.62 rtt:~$ netrtt:~$ net28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=3 ttl=57 time=57 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=4 ttl=57 time=41 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=5 ttl=57 time=53 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=6 ttl=57 time=41 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=7 ttl=57 time=61 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=8 ttl=57 time=26 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=9 ttl=57 time=50 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=10 ttl=57 time=32 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=11 ttl=57 time=35 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=12 ttl=57 time=48 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=13 ttl=57 time=36 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=14 ttl=57 time=44 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=15 ttl=57 time=40 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=16 ttl=57 time=40 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=17 ttl=57 time=26 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=18 ttl=57 time=35 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=19 ttl=57 time=52 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=20 ttl=57 time=40 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=21 ttl=57 time=32 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=22 ttl=57 time=51 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=23 ttl=57 time=45 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=24 ttl=57 time=37 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=25 ttl=57 time=37 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=26 ttl=57 time=38 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=27 ttl=57 time=45 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=28 ttl=57 time=38 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=29 ttl=57 time=41 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=30 ttl=57 time=37 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=31 ttl=57 time=30 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=32 ttl=57 time=33 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=33 ttl=57 time=40 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=34 ttl=57 time=70 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=35 ttl=57 time=31 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=36 ttl=57 time=33 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=37 ttl=57 time=40 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=38 ttl=57 time=42 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=39 ttl=57 time=34 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=40 ttl=57 time=41 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=41 ttl=57 time=45 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=42 ttl=57 time=42 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=43 ttl=57 time=37 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=44 ttl=57 time=33 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=46 ttl=57 time=1019 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=47 ttl=57 time=46 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=48 ttl=57 time=34 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=49 ttl=57 time=49 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=51 ttl=57 time=1020 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=52 ttl=57 time=48 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=53 ttl=57 time=44 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=54 ttl=57 time=40 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=55 ttl=57 time=43 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=56 ttl=57 time=45 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=57 ttl=57 time=42 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=58 ttl=57 time=45 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=59 ttl=57 time=36 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=60 ttl=57 time=32 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=61 ttl=57 time=31 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=62 ttl=57 time=39 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=63 ttl=57 time=41 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=64 ttl=57 time=36 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=65 ttl=57 time=45 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=66 ttl=57 time=36 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=67 ttl=57 time=43 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=68 ttl=57 time=44 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=69 ttl=57 time=42 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=70 ttl=57 time=38 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=71 ttl=57 time=46 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=72 ttl=57 time=37 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=73 ttl=57 time=38 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=74 ttl=57 time=32 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=75 ttl=57 time=40 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=76 ttl=57 time=44 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=77 ttl=57 time=30 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=78 ttl=57 time=30 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=79 ttl=57 time=44 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=80 ttl=57 time=43 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=81 ttl=57 time=38 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=82 ttl=57 time=43 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=83 ttl=57 time=40 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=84 ttl=57 time=39 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=85 ttl=57 time=41 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=86 ttl=57 time=34 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=87 ttl=57 time=31 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=88 ttl=57 time=33 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=89 ttl=57 time=33 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=90 ttl=57 time=44 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=91 ttl=57 time=34 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=92 ttl=57 time=37 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=93 ttl=57 time=40 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=95 ttl=57 time=1021 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=96 ttl=57 time=45 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=97 ttl=57 time=50 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=98 ttl=57 time=48 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=99 ttl=57 time=40 ms 28 bytes from 8.8.8.8 to 192.168.227.62: icmp_seq=100 ttl=57 time=36 ms
wifi status
rtt:~$ wifi status Status: successful ================== State: COMPLETED Interface Mode: STATION Link Mode: WIFI 4 (802.11n/HT) SSID: HUAWEI_E5576_4E56 BSSID: E2:C5:FE:56:4E:75 Band: 2.4GHz Channel: 6 Security: WPA2-PSK MFP: Optional RSSI: -29 Beacon Interval: 100 DTIM: 1 TWT: Not supported rtt:~$ net stats Interface 0x20001840 (Ethernet) [1] =================================== IPv6 recv 121 sent 9 drop 115 forwarded 0 IPv6 ND recv 6 sent 7 drop 0 IPv6 MLD recv 0 sent 2 drop 0 IPv4 recv 154 sent 13 drop 142 forwarded 0 IP vhlerr 2 hblener 0 lblener 0 IP fragerr 0 chkerr 0 protoer 2 ICMP recv 16 sent 19 drop 0 ICMP typeer 0 chkerr 0 UDP recv 2 sent 3 drop 142 UDP chkerr 0 TCP bytes recv 0 sent 0 resent 0 TCP seg recv 0 sent 0 drop 0 TCP seg resent 0 chkerr 0 ackerr 0 TCP seg rsterr 0 rst 0 TCP conn drop 0 connrst 0 TCP pkt drop 0 Bytes received 24779 Bytes sent 2172 Processing err 0 Statistics for Ethernet interface 0x20001840 [1] Bytes received : 24779 Bytes sent : 2172 Packets received : 280 Packets sent : 24 Bcast received : 9 Bcast sent : 3 Mcast received : 23 Mcast sent : 3 Send errors : 4 Receive errors : 0 Collisions : 0 Send Drops : 0 Send timeouts : 0 Send restarts : 0 Unknown protocol : 0
Platform:
-nRF7002+nRF52840 custom board
-ncs 2.5.1
-Windows 10, VS code
