Good morning,
I would like to know if there is a way to use nrf52840-dk to emulate a credit card using NFC.
Is there any example or guide?
Good morning,
What exactly is the use case that you want?
The nRF52 supports NFC tag type,
Here is the info: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/protocols/nfc/index.html#near-field-communication-nfc
And here are all the samples: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/nfc.html#nfc-samples
Jonathan
I would like to try using the following example to try to implement a credit card for exercise. But I don’t know how to do that.
I would like to use the following example:
developer.nordicsemi.com/.../README.html
In your opinion is the correct example to use or should I use another?
How can I modify it to try to implement a credit card?
Gio
That would be the closest sample we have I believe. You can also check out the Zephyr community to see if anyone has done something similar using Zephyr.
Jonathan
