I am trying to format an external flash chip with littlefs, but keep getting an MPU fault. I can erase the chip, but not mount or format. I have tried writing and reading to the chip using flash_area_read/write at different areas in the chip and it goes well. I've read several posts here and tried them, but didn't work.
I'm using a small board from HolyIOT with the nrf52832 chip and a W25Q32JV Winbond chip using SPI.
nRF Connect SDK v2.6.1
Zephyr version: 3.5.99 (C:/ncs/v2.6.1/zephyr), build: v3.5.99-ncs1-1
VSCode v1.88.1
nRF Connect for VSCode v2024.3.25
// Copyright (c) 2024 Nordic Semiconductor ASA // SPDX-License-Identifier: Apache-2.0 /dts-v1/; //#include <nordic/nrf52832_ciaa.dtsi> #include <nordic/nrf52832_qfaa.dtsi> / { model = "ArrowOne_V3"; compatible = "denis,arrowone-v3"; chosen { zephyr,sram = &sram0; zephyr,flash = &flash0; }; cspins { compatible = "gpio-leds"; csflash: csflash { label = "CS_FLASH"; gpios = <&gpio0 12 0>; }; }; }; &gpiote { status = "okay"; }; &gpio0 { status = "okay"; }; &pinctrl { spi2_default: spi2_default { group1 { psels = <NRF_PSEL(SPIM_SCK, 0, 21)>, <NRF_PSEL(SPIM_MOSI, 0, 18)>, <NRF_PSEL(SPIM_MISO, 0, 15)>; }; }; spi2_sleep: spi2_sleep { group1 { psels = <NRF_PSEL(SPIM_SCK, 0, 21)>, <NRF_PSEL(SPIM_MOSI, 0, 18)>, <NRF_PSEL(SPIM_MISO, 0, 15)>; }; }; }; &spi2 { compatible = "nordic,nrf-spi"; status = "okay"; pinctrl-0 = <&spi2_default>; pinctrl-1 = <&spi2_sleep>; pinctrl-names = "default", "sleep"; cs-gpios = <&gpio0 12 GPIO_ACTIVE_LOW>; spiflash: spiflash@0 { compatible = "jedec,spi-nor"; status = "okay"; reg = <0>; spi-max-frequency = <1000000U>; jedec-id = [ef 40 16]; t-enter-dpd=<3000>; t-exit-dpd=<3000>; size = <0x2000000>; //bits, not bytes! partitions { compatible="fixed-partitions"; #address-cells = <1>; #size-cells = <1>; lfs1_part: partition@0 { label = "littlefs_storage"; reg = <0x00000000 0x00400000>; //bytes }; }; }; }; /* These aliases are provided for compatibility with samples */ / { aliases { csflash = &csflash; spiflash = &spiflash; }; }; &flash0 { partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; boot_partition: partition@0 { label = "mcuboot"; reg = <0x0 0xc000>; }; slot0_partition: partition@c000 { label = "image-0"; reg = <0xc000 0x32000>; }; slot1_partition: partition@3e000 { label = "image-1"; reg = <0x3e000 0x32000>; }; scratch_partition: partition@70000 { label = "image-scratch"; reg = <0x70000 0xa000>; }; storage_partition: partition@7a000 { label = "storage"; reg = <0x7a000 0x6000>; }; }; }; &ficr { status = "okay"; };
#math library? CONFIG_NEWLIB_LIBC=y #No external low frequency crystal CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n CONFIG_GPIO_AS_PINRESET=n CONFIG_GPIO=y CONFIG_GPIO_AS_PINRESET=n # Make sure printk is printing to the UART console CONFIG_CONSOLE=y CONFIG_HEAP_MEM_POOL_SIZE=2048 CONFIG_FPU=y CONFIG_CBPRINTF_FP_SUPPORT=y # Config logger CONFIG_LOG=y CONFIG_USE_SEGGER_RTT=y CONFIG_LOG_BACKEND_RTT=y CONFIG_LOG_PRINTK=y CONFIG_RTT_CONSOLE=y CONFIG_UART_CONSOLE=n #Flash NOR CONFIG_SPI=y CONFIG_SPI_NOR=y CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_FLASH_JESD216_API=y CONFIG_FLASH=y CONFIG_FLASH_MAP=y CONFIG_FLASH_PAGE_LAYOUT=y #CONFIG_NVS=y #littlefs file system CONFIG_FILE_SYSTEM=y CONFIG_FILE_SYSTEM_MKFS=y CONFIG_FILE_SYSTEM_LITTLEFS=y #partition manager settings CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n
#include <zephyr/kernel.h> #include <zephyr/device.h> #include <zephyr/devicetree.h> #include <soc.h> #include <zephyr/fs/fs.h> #include <zephyr/fs/littlefs.h> #include <zephyr/storage/flash_map.h> #include <zephyr/settings/settings.h> #include <zephyr/logging/log.h> FS_LITTLEFS_DECLARE_DEFAULT_CONFIG(flash_storage); static struct fs_mount_t lfs_storage_mnt = { .type = FS_LITTLEFS, .fs_data = &flash_storage, .storage_dev = (void *)FIXED_PARTITION_ID(lfs1_part), .mnt_point = "/lfs", }; #define MKFS_FS_TYPE FS_LITTLEFS #define MKFS_DEV_ID FIXED_PARTITION_ID(lfs1_part) #define MKFS_FLAGS 0 LOG_MODULE_REGISTER(main, LOG_LEVEL_DBG); int formatFS(void) { int rc; rc = fs_mkfs(MKFS_FS_TYPE, (uintptr_t)MKFS_DEV_ID, NULL, MKFS_FLAGS); if (rc < 0) { LOG_ERR("Format failed"); return 0; } LOG_INF("Format successful"); return 0; } int eraseFlash() { int rc; struct fs_mount_t *mp = &lfs_storage_mnt; unsigned int id = (uintptr_t)mp->storage_dev; const struct flash_area *pfa; rc = flash_area_open(id, &pfa); if (rc < 0) { printk("FAIL: unable to find flash area %u: %d\n", id, rc); return 1; } printk("Area %u at 0x%x for %u bytes\n", id, (unsigned int)pfa->fa_off, (unsigned int)pfa->fa_size); rc = flash_area_erase(pfa, 0, pfa->fa_size); printk("flash erase: %d\n", rc); flash_area_close(pfa); return 0; } int main(void) { printk("\nerasing flash\n"); eraseFlash(); printk("Done.\n\n"); printk("formating flash\n"); formatFS(); printk("Done.\n\n"); printk("Starting main routine\n\n"); while(1) { k_sleep(K_MSEC(50)); } return 0; }
SEGGER J-Link V7.80c - Real time terminal output J-Link EDU Mini V1 compiled Sep 22 2022 14:55:40 V1.0, SN=801020502 Process: JLink.exe [00:00:00.000,030] <wrn> spi_nor: Waiting until flash is ready *** Booting nRF Connect SDK v3.5.99-ncs1-1 *** erasing flash Area 5 at 0x0 for 4194304 bytes flash erase: 0 Done. formating flash [00:00:25.720,336] <inf> littlefs: LittleFS version 2.5, disk version 2.0 [00:00:25.721,282] <inf> littlefs: FS at spiflash@0:0x0 is 1024 0x1000-byte blocks with 512 cycle [00:00:25.721,282] <inf> littlefs: sizes: rd 16 ; pr 16 ; ca 64 ; la 32 [00:00:25.721,588] <err> os: ***** MPU FAULT ***** [00:00:25.721,588] <err> os: Stacking error (context area might be not valid) [00:00:25.721,588] <err> os: Data Access Violation [00:00:25.721,618] <err> os: MMFAR Address: 0x2000216c [00:00:25.721,649] <err> os: r0/a1: 0xffdc5036 r1/a2: 0x90234921 r2/a3: 0xf7a0bb89 [00:00:25.721,649] <err> os: r3/a4: 0x8c2f424f r12/ip: 0xcbb6f52a r14/lr: 0xdce5aef8 [00:00:25.721,679] <err> os: xpsr: 0xc92d0000 [00:00:25.721,679] <err> os: s[ 0]: 0x651fdac5 s[ 1]: 0x4bcb40c8 s[ 2]: 0x6cb4902d s[ 3]: 0xea9b53c3 [00:00:25.721,710] <err> os: s[ 4]: 0xd7d6866c s[ 5]: 0xc82cc575 s[ 6]: 0x774b11ad s[ 7]: 0x116042b5 [00:00:25.721,710] <err> os: s[ 8]: 0xcb352f2f s[ 9]: 0x8c9f08e0 s[10]: 0x6644993f s[11]: 0xb07a1cd8 [00:00:25.721,740] <err> os: s[12]: 0xc77a3048 s[13]: 0xa48f49fa s[14]: 0xf346350e s[15]: 0x65346337 [00:00:25.721,740] <err> os: fpscr: 0xfc9fc82a [00:00:25.721,740] <err> os: Faulting instruction address (r15/pc): 0x40f822a2 [00:00:25.721,801] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0 [00:00:25.721,832] <err> os: Current thread: 0x200009c0 (main) [00:00:26.292,327] <err> fatal_error: Resetting system *** Booting nRF Connect SDK v3.5.99-ncs1-1 *** erasing flash Area 5 at 0x0 for 4194304 bytes
