Hi Community!
I am a beginner with NRF and zephyr and currently doing a small project on nrf52832_mdk on zephyr. I want to deep sleep the system (sys_poweroff) when nothing is happening. I followed the poweroff example and its working fine. I have attached a multimeter in paralell to measure current and I can see the current drop when system poweroff smootly.
In my actual project, when I run the sys_poweroff command in main thread after initialization, it gives the expected results. The system shuts down completely and current drops in micro amperes.
printk("initializing the system \n");
int ret;
int errorCode = 0;
struct sensor_value regValue;
/**** Initialize LED****/
ret = led_init();
if (ret != 0) {
printk("could not Initialize LED \n");
/**** Initialize the SC7A20 Sensor ****/
ret = sc7a20_sensor_init();
if (ret != 0) {
printk("sensor Initialization failed \n");
errorCode = ERROR_SC7A20_SENSOR;
ret = sc7a20_interrupt_register();
if (ret != 0) {
printk("Could not Register Interrupt for SC7A20 \n");
errorCode = ERROR_SC7A20_INTERRUPT;
ret = button_init();
if (ret != 0) {
printk("could not Initialize Button \n");
errorCode = ERROR_BUTTON_INIT;
ret = bluetooth_init(&bluetooth_callbacks, &remote_callbacks);
if (ret) {
printk("bt_enable returned %d", ret);
errorCode = ERROR_BLUETOOTH_INIT;
sc7a20_interrupt_controller_thread();
ret = battery_measure_enable(true);
if (ret != 0) {
printk("Failed initialize battery measurement: %d\n", ret);
sys_poweroff();
}However, If I run the sys_poweroff in another thread (or in the same main function after some sleep), it doesn't shut system appropriately. The system freezes there and current also remains same (only a little current drops). Here is a minimal code. The main objective is to poweroff the system from another thread. Its just a minimal example of situation where I get the same strange resuls
int ret;
int errorCode = 0;
ret = led_init();
if (ret != 0) {
if (ret != 0) {
if (ret != 0) {
if (ret != 0) {
if (ret) {
if (ret != 0) {
sys_poweroff();
if (errorCode == 0) {
while (1) {
battery_ble_notifier();
k_msleep(40000);
sys_poweroff();
} else {
led_error_sender(errorCode);
