Can you fix NRF_LOG* in SDK 11?
Not sure if forums or MyPage support requests are better for this.
It seems NRF_LOG has taken a step backward from what was used in the previous nRF52 0.9.2 SDK. What I've discovered is that there is no buffering at all taking place. If the remote terminal emulator is not pulling the characters off as fast as the hardware (nRF52 board) is writing them, the message that is being logged gets truncated. For me at the hard-coded 38400baud rate, this means one character gets logged and the rest of the message is lost.
If you look at app_uart_init, you'll see app_uart_buffers_t being passed in. This is never used in that function. So whatever you set TX_BUFFER_SIZE to is ignored. Calling NRF_LOG or one of its variants boils down to this:
A loop calls app_uart_put/nrf_drv_uart_tx with one character.
As fast as that loop runs, it will call those functions. As soon as nrf_drv_uart_tx gets called and the TX buffer isn't empty, it quits.
By fix, I mean set this up so that a transmit buffer greater than 1 is used. It used to be that TX_BUFFER_SIZE was the size of the transmit buffer.
