I am using nrf5340 audio dk for development. I had no trouble with gpio_pin_get_dt() function when reading from sw2. However, once I switched to interrupt. I had to physically press sw3 to start the ISR I set up for sw2.
My code is as following:
struct gpio_callback button_cb_data;
const struct gpio_dt_spec button;
#define BUTTON_NODE DT_ALIAS(sw2)
const struct gpio_dt_spec button = GPIO_DT_SPEC_GET(BUTTON_NODE, gpios);
static void button_pressed_cb(const struct device *dev, struct gpio_callback *cb, uint32_t pins) {
if (!recording_toggle_locked) {
recording_toggle_locked = true;
recording = !recording; // Toggle recording state
printk("Recording toggled: %s\n", recording ? "ON" : "OFF");
gpio_pin_set_dt(&led, recording);
k_work_schedule(&unlock_work, K_SECONDS(1));
printk("GPIO Pin: %u triggered callback.\n", pins);
int button_init(void) {
if (!gpio_is_ready_dt(&button)) {
LOG_ERR("Button device not ready");
return -1;
LOG_INF("Button device ready");
k_work_init_delayable(&unlock_work, unlock_recording_toggle_locked);
int ret = gpio_pin_interrupt_configure_dt(&button, GPIO_INT_EDGE_TO_ACTIVE);
if (ret < 0) {
LOG_ERR("Failed to configure button GPIO: %d", ret);
return ret;
gpio_init_callback(&button_cb_data, button_pressed_cb, BIT(button.pin));
gpio_add_callback(button.port, &button_cb_data);
LOG_INF("Button configured");
LOG_INF("button pin: %d", button.pin);
LOG_INF("button port: %p", button.port);
return 0;
The console shows the following:
-- [00:00:00.385,803] <inf> button: Button device ready
-- [00:00:00.385,864] <inf> button: Button configured
-- [00:00:00.385,894] <inf> button: button pin: 4
-- [00:00:00.385,894] <inf> button: button port: 0x2bb5c
GPIO Pin: 16 triggered callback.
I did not change the device tree for the board and checked the zephyr.dts file from the build output folder. The relevant part is as following:
buttons {
compatible = "gpio-keys";
button_1_vol_dn: button_1_vol_dn {
gpios = < &gpio0 0x2 0x11 >;
label = "Push button 1";
zephyr,code = < 0x72 >;
button_2_vol_up: button_2_vol_up {
gpios = < &gpio0 0x3 0x11 >;
label = "Push button 2";
zephyr,code = < 0x73 >;
button3: button_3 {
gpios = < &gpio0 0x4 0x11 >;
label = "Push button 3";
zephyr,code = < 0x4 >;
button4: button_4 {
gpios = < &gpio0 0x6 0x11 >;
label = "Push button 4";
zephyr,code = < 0x5 >;
button5: button_5 {
gpios = < &gpio0 0x5 0x11 >;
label = "Push button 5";
zephyr,code = < 0x6 >;
aliases {
pwm-led0 = &rgb1_red_pwm_led;
pwm-led1 = &rgb1_green_pwm_led;
pwm-led2 = &rgb1_blue_pwm_led;
red-pwm-led = &rgb1_red_pwm_led;
green-pwm-led = &rgb1_green_pwm_led;
blue-pwm-led = &rgb1_blue_pwm_led;
led0 = &rgb1_red;
led1 = &rgb1_green;
led2 = &rgb1_blue;
led3 = &rgb2_red;
led4 = &rgb2_green;
led5 = &rgb2_blue;
led6 = &led1_blue;
led7 = &led2_green;
led8 = &led3_green;
sw0 = &button_1_vol_dn;
sw1 = &button_2_vol_up;
sw2 = &button3;
sw3 = &button4;
sw4 = &button5;
mcuboot-led0 = &led1_blue;
mcuboot-button0 = &button3;
watchdog0 = &wdt0;
Could anyone help me with this issue? Thank you very much!
