"ERROR: Failed when selecting coprocessor APPLICATION" when attempting to flash blinky sample app on NRF5340
I created a new application using the "Create a new application" > "Copy a sample" > "zephyr/samples/basic/blinky" option in vscode. And I added a new build configuration using the default settings except for changing the board to "nrf5340dk_nrf5340_cpuapp". After building, I pressed the flash button in the actions panel to flash it to my NRF5340 DK. It executes the following command (without --log), which I also tried running manually:
➜ Desktop nrfjprog --program /opt/nordic/ncs/v2.6.1/nrf/applications/nrf5340dk_nrf5340_cpuapp/blinky/build/zephyr/zephyr.hex --chiperase --verify -f NRF53 --coprocessor CP_APPLICATION --snr 1050303214 --log
[error] [ Client] - Encountered error -5: Command select_coprocessor executed for 6 milliseconds with result -5
[error] [ Worker] - Encountered unexpected debug port ID 2, expected 6
ERROR: The --family option given with the command (or the default from
ERROR: nrfjprog.ini) does not match the device connected.
Why isn't it able to recognize the coprocessor when flashing? The computer (and jlink) is able to recognize my development kit just fine. I have tried everything from selecting all the other nrf5340dk boards in the board configuration settings and rebuilding/reflashing, to running "nrfjprog --recover" and "nrfjprog --eraseall" to reset everything. Why is it so hard to get a blinky app to work? Seems so basic, yet I've been trying for 2 days and still haven't gotten anywhere. I have two NRF 5340 DK boards and they both do the same thing. I attached the logs that I generated from running the command to flash.
[2024-May-04 16:51:44] [debug] --------------------------------------------------------------------------------
[2024-May-04 16:51:44] [debug] nrfjprog --program /opt/nordic/ncs/v2.6.1/nrf/applications/nrf5340dk_nrf5340_cpuapp/blinky/build/zephyr/zephyr.hex --chiperase --verify -f NRF53 --coprocessor CP_APPLICATION --snr 1050303214 --log
[2024-May-04 16:51:44] [debug] nrfjprog version 10.24.2 external
[2024-May-04 16:51:44] [ info] Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib.
[2024-May-04 16:51:44] [ info] Library loaded, loading member functions.
[2024-May-04 16:51:44] [ info] Member functions succesfully loaded.
[2024-May-04 16:51:44] [debug] [ Client] - open
[2024-May-04 16:51:44] [debug] [ Client] - start
[2024-May-04 16:51:44] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence ae2c3880-cbd9-4ec7-8f44-4343bef59c0a.
[2024-May-04 16:51:44] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2024-May-04 16:51:44] [debug] [  JLink] - Logger sink registered in JLink logger
[2024-May-04 16:51:44] [debug] [  nRF53] - open
[2024-May-04 16:51:44] [debug] [  nRF53] - just_check_family
[2024-May-04 16:51:44] [debug] [SeggerBackend] - open_dll
[2024-May-04 16:51:44] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2024-May-04 16:51:44] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.dylib.
[2024-May-04 16:51:44] [trace] [ Client] - Command open executed for 49 milliseconds with result 0
[2024-May-04 16:51:44] [debug] [ Client] - config
[2024-May-04 16:51:44] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2024-May-04 16:51:44] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2024-May-04 16:51:44] [debug] [SeggerBackend] - Set batch mode
[2024-May-04 16:51:44] [debug] [SeggerBackend] - dll_version
[2024-May-04 16:51:44] [ info] [SeggerBackend] - Segger dll version 7.94.e loaded.
[2024-May-04 16:51:44] [trace] [ Worker] - Command open executed for 29 milliseconds with result 0
[2024-May-04 16:51:44] [debug] [  nRF53] - config
[2024-May-04 16:51:44] [trace] [ Client] - Command config executed for 12 milliseconds with result 0
[2024-May-04 16:51:44] [debug] [ Client] - enum_emu_snr
[2024-May-04 16:51:44] [trace] [ Client] - Command enum_emu_con_info executed for 6 milliseconds with result 0
[2024-May-04 16:51:44] [debug] [ Client] - connect_to_emu_with_snr
[2024-May-04 16:51:44] [debug] [SeggerBackend] - enum_emu_snr
[2024-May-04 16:51:44] [trace] [ Worker] - Command config executed for 4 milliseconds with result 0
[2024-May-04 16:51:44] [debug] [  nRF53] - enum_emu_con_info
[2024-May-04 16:51:44] [debug] [SeggerBackend] - is_connected_to_emu
[2024-May-04 16:51:44] [debug] [SeggerBackend] - enum_emu_con_info
[2024-May-04 16:51:44] [trace] [ Worker] - Command enum_emu_con_info executed for 0 milliseconds with result 0
[2024-May-04 16:51:44] [debug] [  nRF53] - connect_to_emu_with_snr
[2024-May-04 16:51:44] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2024-May-04 16:51:44] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2024-May-04 16:51:44] [debug] [SeggerBackend] - ---just_get_num_emus
[2024-May-04 16:51:44] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2024-May-04 16:51:44] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2024-May-04 16:51:44] [debug] [SeggerBackend] - Segger logging enabled.
[2024-May-04 16:51:44] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Oct 30 2023 12:13:06
[2024-May-04 16:51:44] [trace] [  JLink] - Hardware: V1.00
[2024-May-04 16:51:44] [trace] [  JLink] - S/N: 1050303214
[2024-May-04 16:51:44] [trace] [  JLink] - OEM: SEGGER
[2024-May-04 16:51:44] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2024-May-04 16:51:44] [trace] [  JLink] - Bootloader: 2021 May 18
[2024-May-04 16:51:44] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
[2024-May-04 16:51:44] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2024-May-04 16:51:44] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2024-May-04 16:51:44] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
[2024-May-04 16:51:44] [trace] [  JLink] - Looking for J-Link GUI Server exe at: /Applications/SEGGER/JLink_V794e/JLinkGUIServerExe
[2024-May-04 16:51:44] [trace] [  JLink] - Forking J-Link GUI Server: /Applications/SEGGER/JLink_V794e/JLinkGUIServerExe
[2024-May-04 16:51:44] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V7.94e "
[2024-May-04 16:51:44] [trace] [ Client] - Command connect_to_emu_with_snr executed for 402 milliseconds with result 0
[2024-May-04 16:51:44] [debug] [ Client] - read_connected_emu_snr
[2024-May-04 16:51:44] [trace] [ Client] - Command read_connected_emu_snr executed for 6 milliseconds with result 0
[2024-May-04 16:51:44] [debug] [ Client] - enable_coprocessor
[2024-May-04 16:51:44] [trace] [  JLink] - - 366.159ms returns "O.K."
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_HasError()
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_Lock()
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.133ms returns 0x01
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.001ms returns 0x00
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.116ms returns 0x00
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.003ms returns 0
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2024-May-04 16:51:44] [trace] [  JLink] - - 1.623ms returns 0x00
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_GetSpeedInfo()
[2024-May-04 16:51:44] [trace] [  JLink] - 128000000 Hz / n, n >= 64
[2024-May-04 16:51:44] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.284ms
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_GetSpeed()
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.001ms returns 2000
[2024-May-04 16:51:44] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_GetSN()
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.001ms returns 1050303214
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.002ms
[2024-May-04 16:51:44] [debug] [  nRF53] - read_device_family
[2024-May-04 16:51:44] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 395 milliseconds with result 0
[2024-May-04 16:51:44] [debug] [  nRF53] - read_connected_emu_snr
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_IsOpen()
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.002ms returns 0x01
[2024-May-04 16:51:44] [debug] [SeggerBackend] - read_connected_emu_snr
[2024-May-04 16:51:44] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2024-May-04 16:51:44] [trace] [ Client] - Command enable_coprocessor executed for 12 milliseconds with result 0
[2024-May-04 16:51:44] [debug] [ Client] - select_coprocessor
[2024-May-04 16:51:44] [debug] [  nRF53] - enable_coprocessor
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.007ms returns 0x01
[2024-May-04 16:51:44] [debug] [  nRF53] - Just_enable_coprocessor
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.035ms
[2024-May-04 16:51:44] [trace] [ Worker] - Command enable_coprocessor executed for 0 milliseconds with result 0
[2024-May-04 16:51:44] [debug] [  nRF53] - select_coprocessor
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.003ms returns 0x01
[2024-May-04 16:51:44] [debug] [SeggerBackend] - is_connected_to_device
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_IsConnected()
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.001ms returns FALSE
[2024-May-04 16:51:44] [debug] [  nRF53] - Just_select_coprocessor
[2024-May-04 16:51:44] [ info] [  nRF53] - Loading new coprocessor data.
[2024-May-04 16:51:44] [debug] [  nRF53] - Just_load_coprocessor_data
[2024-May-04 16:51:44] [debug] [SeggerBackend] - set_core_data
[2024-May-04 16:51:44] [debug] [SeggerBackend] - Set core data:
[2024-May-04 16:51:44] [debug] [SeggerBackend] -   Device ID: Cortex-M33
[2024-May-04 16:51:44] [debug] [SeggerBackend] -   Expected core: 235012351
[2024-May-04 16:51:44] [debug] [SeggerBackend] -   Existing Expected core: 235012351
[2024-May-04 16:51:44] [debug] [SeggerBackend] -   Coprocessor: APPLICATION
[2024-May-04 16:51:44] [debug] [SeggerBackend] -   AHB AP index: 0
[2024-May-04 16:51:44] [debug] [SeggerBackend] -   Core base address: 4294967295
[2024-May-04 16:51:44] [debug] [  nRF53] - Just_readback_status
[2024-May-04 16:51:44] [debug] [SeggerBackend] - read_access_port_register
[2024-May-04 16:51:44] [debug] [SeggerBackend] - ---just_read_access_port_register
[2024-May-04 16:51:44] [debug] [SeggerBackend] - coresight_configure
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.442ms returns 0
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.419ms returns 0
[2024-May-04 16:51:44] [debug] [SeggerBackend] - read_debug_port_idr
[2024-May-04 16:51:44] [debug] [SeggerBackend] - read_debug_port_register
[2024-May-04 16:51:44] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2024-May-04 16:51:44] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2024-May-04 16:51:44] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2024-May-04 16:51:44] [trace] [  JLink] - - 1.127ms returns 0
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
[2024-May-04 16:51:44] [trace] [  JLink] - Value=0x2BA01477
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.407ms returns 0
[2024-May-04 16:51:44] [error] [ Client] - Encountered error -5: Command select_coprocessor executed for 6 milliseconds with result -5
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.878ms
[2024-May-04 16:51:44] [error] [ Worker] - Encountered unexpected debug port ID 2, expected 6
[2024-May-04 16:51:44] [trace] [ Worker] - Command select_coprocessor executed for 3 milliseconds with result -5
[2024-May-04 16:51:44] [debug] [  nRF53] - close
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.004ms returns 0x01
[2024-May-04 16:51:44] [debug] [SeggerBackend] - close
[2024-May-04 16:51:44] [debug] [SeggerBackend] - disconnect_from_emu
[2024-May-04 16:51:44] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2024-May-04 16:51:44] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.210ms returns 0
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
[2024-May-04 16:51:44] [trace] [  JLink] - Value=0xF0000040
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.417ms returns 0
[2024-May-04 16:51:44] [debug] [SeggerBackend] - unpower_debug_and_system_regions
[2024-May-04 16:51:44] [debug] [SeggerBackend] - ---just_write_debug_port_register
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x01, 0x00000000)
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.411ms returns 0
[2024-May-04 16:51:44] [trace] [  JLink] - Value=0x00000040
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.887ms returns 0
[2024-May-04 16:51:44] [trace] [  JLink] - - 0.006ms
[2024-May-04 16:51:44] [trace] [  JLink] - JLINK_Close()
[2024-May-04 16:51:44] [debug] [SeggerBackend] - Segger Backend closed.
[2024-May-04 16:51:44] [debug] [  nRF53] - nRF family DLL closed
[2024-May-04 16:51:44] [trace] [ Client] - Command close executed for 48 milliseconds with result 0
[2024-May-04 16:51:44] [debug] [ Client] - terminate
[2024-May-04 16:51:44] [trace] [ Client] - Command terminate executed for 6 milliseconds with result 0
[2024-May-04 16:51:44] [trace] [ Worker] - Command close executed for 43 milliseconds with result 0
[2024-May-04 16:51:44] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2024-May-04 16:51:44] [trace] [ Worker] - Executed 9 commands for 474 milliseconds
    Based on the logs, it seems to detect the core, but fails after that.
    Could you share a log when trying to recover the board?
    "nrfjprog --recover -f nrf53 --coprocessor cp_network --log"
    and for the app core:
    "nrfjprog --recover -f nrf53 --coprocessor cp_application --log"
    Håkon
  • Hey, I'm getting the same error when I'm flashing the blinky program. Here's the error log from running the commands
    [2024-Sept-18 17:16:38] [debug] --------------------------------------------------------------------------------
    [2024-Sept-18 17:16:38] [debug] nrfjprog --recover -f nrf53 --coprocessor cp_application --log
    [2024-Sept-18 17:16:38] [debug] nrfjprog version 10.24.2 external
    [2024-Sept-18 17:16:38] [ info] Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib.
    [2024-Sept-18 17:16:38] [ info] Library loaded, loading member functions.
    [2024-Sept-18 17:16:38] [ info] Member functions succesfully loaded.
    [2024-Sept-18 17:16:38] [debug] [ Client] - open
    [2024-Sept-18 17:16:38] [debug] [ Client] - start
    [2024-Sept-18 17:16:38] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 2e0bf545-4781-4040-8983-11ef43c55b92.
    [2024-Sept-18 17:16:38] [trace] [ Client] - Command open executed for 18 milliseconds with result 0
    [2024-Sept-18 17:16:38] [debug] [ Client] - config
    [2024-Sept-18 17:16:38] [trace] [ Client] - Command config executed for 12 milliseconds with result 0
    [2024-Sept-18 17:16:38] [debug] [ Client] - enum_emu_snr
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2024-Sept-18 17:16:38] [debug] [  JLink] - Logger sink registered in JLink logger
    [2024-Sept-18 17:16:38] [debug] [  nRF53] - open
    [2024-Sept-18 17:16:38] [debug] [  nRF53] - just_check_family
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - open_dll
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2024-Sept-18 17:16:38] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.dylib.
    [2024-Sept-18 17:16:38] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2024-Sept-18 17:16:38] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - Set batch mode
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - dll_version
    [2024-Sept-18 17:16:38] [ info] [SeggerBackend] - Segger dll version 7.94.e loaded.
    [2024-Sept-18 17:16:38] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0
    [2024-Sept-18 17:16:38] [debug] [  nRF53] - config
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - enum_emu_snr
    [2024-Sept-18 17:16:38] [trace] [ Worker] - Command config executed for 4 milliseconds with result 0
    [2024-Sept-18 17:16:38] [trace] [ Client] - Command enum_emu_con_info executed for 6 milliseconds with result 0
    [2024-Sept-18 17:16:38] [debug] [ Client] - connect_to_emu_with_snr
    [2024-Sept-18 17:16:38] [debug] [  nRF53] - enum_emu_con_info
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - enum_emu_con_info
    [2024-Sept-18 17:16:38] [trace] [ Worker] - Command enum_emu_con_info executed for 1 milliseconds with result 0
    [2024-Sept-18 17:16:38] [debug] [  nRF53] - connect_to_emu_with_snr
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - ---just_get_num_emus
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2024-Sept-18 17:16:38] [debug] [SeggerBackend] - Segger logging enabled.
    [2024-Sept-18 17:16:38] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Apr 11 2024 17:44:26
    [2024-Sept-18 17:16:38] [trace] [  JLink] - Hardware: V1.00
    [2024-Sept-18 17:16:38] [trace] [  JLink] - S/N: 1050083709
    [2024-Sept-18 17:16:38] [trace] [  JLink] - OEM: SEGGER
    [2024-Sept-18 17:16:38] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2024-Sept-18 17:16:38] [trace] [  JLink] - Bootloader: 2021 May 18
    [2024-Sept-18 17:16:38] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2024-Sept-18 17:16:38] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2024-Sept-18 17:16:38] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2024-Sept-18 17:16:38] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2024-Sept-18 17:16:38] [trace] [  JLink] - Looking for J-Link GUI Server exe at: /Applications/SEGGER/JLink_V794e/JLinkGUIServerExe
    [2024-Sept-18 17:16:38] [trace] [  JLink] - Forking J-Link GUI Server: /Applications/SEGGER/JLink_V794e/JLinkGUIServerExe
    [2024-Sept-18 17:16:39] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V7.94e "
    [2024-Sept-18 17:16:39] [trace] [ Client] - Command connect_to_emu_with_snr executed for 611 milliseconds with result 0
    [2024-Sept-18 17:16:39] [debug] [ Client] - read_connected_emu_snr
    [2024-Sept-18 17:16:39] [trace] [ Client] - Command read_connected_emu_snr executed for 6 milliseconds with result 0
    [2024-Sept-18 17:16:39] [debug] [ Client] - enable_coprocessor
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 583.095ms returns "O.K."
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_HasError()
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_Lock()
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.002ms returns 0x01
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.001ms returns 0x00
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.004ms returns 0
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.548ms returns 0x00
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2024-Sept-18 17:16:39] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.061ms
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_GetSpeed()
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.001ms returns 2000
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_GetSN()
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.001ms returns 1050083709
    [2024-Sept-18 17:16:39] [debug] [  nRF53] - read_device_family
    [2024-Sept-18 17:16:39] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 608 milliseconds with result 0
    [2024-Sept-18 17:16:39] [debug] [  nRF53] - read_connected_emu_snr
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_IsOpen()
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - read_connected_emu_snr
    [2024-Sept-18 17:16:39] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2024-Sept-18 17:16:39] [trace] [ Client] - Command enable_coprocessor executed for 6 milliseconds with result 0
    [2024-Sept-18 17:16:39] [debug] [ Client] - select_coprocessor
    [2024-Sept-18 17:16:39] [debug] [  nRF53] - enable_coprocessor
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.003ms returns 0x01
    [2024-Sept-18 17:16:39] [debug] [  nRF53] - Just_enable_coprocessor
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.207ms
    [2024-Sept-18 17:16:39] [trace] [ Worker] - Command enable_coprocessor executed for 0 milliseconds with result 0
    [2024-Sept-18 17:16:39] [debug] [  nRF53] - select_coprocessor
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.004ms returns 0x01
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - is_connected_to_device
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_IsConnected()
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.001ms returns FALSE
    [2024-Sept-18 17:16:39] [debug] [  nRF53] - Just_select_coprocessor
    [2024-Sept-18 17:16:39] [ info] [  nRF53] - Loading new coprocessor data.
    [2024-Sept-18 17:16:39] [debug] [  nRF53] - Just_load_coprocessor_data
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - set_core_data
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - Set core data:
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] -   Device ID: Cortex-M33
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] -   Expected core: 235012351
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] -   Existing Expected core: 235012351
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] -   Coprocessor: APPLICATION
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] -   AHB AP index: 0
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] -   Core base address: 4294967295
    [2024-Sept-18 17:16:39] [debug] [  nRF53] - Just_readback_status
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - read_access_port_register
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - coresight_configure
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.186ms returns 0
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 100.374ms returns 0
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - read_debug_port_idr
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - read_debug_port_register
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.567ms returns -1
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2024-Sept-18 17:16:39] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.468ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.467ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.476ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.454ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.459ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.465ms returns -1
    [2024-Sept-18 17:16:39] [error] [ Client] - Encountered error -102: Command select_coprocessor executed for 133 milliseconds with result -102
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.437ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.447ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.439ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.443ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.494ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.444ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.535ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.474ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.497ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.489ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.477ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.488ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.481ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.484ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.482ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.466ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.473ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.500ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.491ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.487ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.486ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.472ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.479ms returns -1
    [2024-Sept-18 17:16:39] [error] [ Worker] - An unknown error.
    [2024-Sept-18 17:16:39] [trace] [ Worker] - Command select_coprocessor executed for 124 milliseconds with result -102
    [2024-Sept-18 17:16:39] [debug] [  nRF53] - close
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - close
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - disconnect_from_emu
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.002ms returns FALSE
    [2024-Sept-18 17:16:39] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.480ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.434ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.458ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.446ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.441ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.433ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.492ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.442ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.435ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.430ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.427ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.450ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.483ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.438ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.428ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.431ms returns -1
    [2024-Sept-18 17:16:39] [trace] [  JLink] - - 0.448ms returns -1
    [2024-Sept-18 17:18:11] [debug] --------------------------------------------------------------------------------
    [2024-Sept-18 17:18:11] [debug] nrfjprog --recover -f nrf53 --coprocessor cp_network --log
    [2024-Sept-18 17:18:11] [debug] nrfjprog version 10.24.2 external
    [2024-Sept-18 17:18:11] [ info] Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib.
    [2024-Sept-18 17:18:11] [ info] Library loaded, loading member functions.
    [2024-Sept-18 17:18:11] [ info] Member functions succesfully loaded.
    [2024-Sept-18 17:18:11] [debug] [ Client] - open
    [2024-Sept-18 17:18:11] [debug] [ Client] - start
    [2024-Sept-18 17:18:11] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 97744c0e-09f8-43dd-b717-eb00ba908a62.
    [2024-Sept-18 17:18:11] [trace] [ Client] - Command open executed for 35 milliseconds with result 0
    [2024-Sept-18 17:18:11] [debug] [ Client] - config
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2024-Sept-18 17:18:11] [debug] [  JLink] - Logger sink registered in JLink logger
    [2024-Sept-18 17:18:11] [debug] [  nRF53] - open
    [2024-Sept-18 17:18:11] [debug] [  nRF53] - just_check_family
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - open_dll
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2024-Sept-18 17:18:11] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.dylib.
    [2024-Sept-18 17:18:11] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2024-Sept-18 17:18:11] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - Set batch mode
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - dll_version
    [2024-Sept-18 17:18:11] [ info] [SeggerBackend] - Segger dll version 7.94.e loaded.
    [2024-Sept-18 17:18:11] [trace] [ Worker] - Command open executed for 19 milliseconds with result 0
    [2024-Sept-18 17:18:11] [trace] [ Client] - Command config executed for 12 milliseconds with result 0
    [2024-Sept-18 17:18:11] [debug] [ Client] - enum_emu_snr
    [2024-Sept-18 17:18:11] [debug] [  nRF53] - config
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - enum_emu_snr
    [2024-Sept-18 17:18:11] [trace] [ Client] - Command enum_emu_con_info executed for 5 milliseconds with result 0
    [2024-Sept-18 17:18:11] [trace] [ Worker] - Command config executed for 4 milliseconds with result 0
    [2024-Sept-18 17:18:11] [debug] [  nRF53] - enum_emu_con_info
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - enum_emu_con_info
    [2024-Sept-18 17:18:11] [trace] [ Worker] - Command enum_emu_con_info executed for 0 milliseconds with result 0
    [2024-Sept-18 17:18:11] [debug] [ Client] - connect_to_emu_with_snr
    [2024-Sept-18 17:18:11] [debug] [  nRF53] - connect_to_emu_with_snr
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - ---just_get_num_emus
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2024-Sept-18 17:18:11] [debug] [SeggerBackend] - Segger logging enabled.
    [2024-Sept-18 17:18:11] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Apr 11 2024 17:44:26
    [2024-Sept-18 17:18:11] [trace] [  JLink] - Hardware: V1.00
    [2024-Sept-18 17:18:11] [trace] [  JLink] - S/N: 1050083709
    [2024-Sept-18 17:18:11] [trace] [  JLink] - OEM: SEGGER
    [2024-Sept-18 17:18:11] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2024-Sept-18 17:18:11] [trace] [  JLink] - Bootloader: 2021 May 18
    [2024-Sept-18 17:18:11] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2024-Sept-18 17:18:11] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2024-Sept-18 17:18:11] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2024-Sept-18 17:18:11] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2024-Sept-18 17:18:11] [trace] [  JLink] - Looking for J-Link GUI Server exe at: /Applications/SEGGER/JLink_V794e/JLinkGUIServerExe
    [2024-Sept-18 17:18:11] [trace] [  JLink] - Forking J-Link GUI Server: /Applications/SEGGER/JLink_V794e/JLinkGUIServerExe
    [2024-Sept-18 17:18:12] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V7.94e "
    [2024-Sept-18 17:18:12] [trace] [ Client] - Command connect_to_emu_with_snr executed for 757 milliseconds with result 0
    [2024-Sept-18 17:18:12] [debug] [ Client] - read_connected_emu_snr
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 719.495ms returns "O.K."
    [2024-Sept-18 17:18:12] [trace] [ Client] - Command read_connected_emu_snr executed for 6 milliseconds with result 0
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_HasError()
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_Lock()
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.173ms returns 0x01
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.000ms returns 0x00
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.010ms returns 0x00
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.003ms returns 0
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.585ms returns 0x00
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2024-Sept-18 17:18:12] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.253ms
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_GetSpeed()
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.001ms returns 2000
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_GetSN()
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.001ms returns 1050083709
    [2024-Sept-18 17:18:12] [debug] [  nRF53] - read_device_family
    [2024-Sept-18 17:18:12] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 750 milliseconds with result 0
    [2024-Sept-18 17:18:12] [debug] [  nRF53] - read_connected_emu_snr
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_IsOpen()
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.002ms returns 0x01
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - read_connected_emu_snr
    [2024-Sept-18 17:18:12] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2024-Sept-18 17:18:12] [debug] [ Client] - enable_coprocessor
    [2024-Sept-18 17:18:12] [debug] [  nRF53] - enable_coprocessor
    [2024-Sept-18 17:18:12] [debug] [  nRF53] - Just_enable_coprocessor
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - is_secure_debug_available
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - read_access_port_register
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - coresight_configure
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.178ms returns 0
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 100.614ms returns 0
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - read_debug_port_idr
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - read_debug_port_register
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.495ms returns -1
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.478ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.469ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.468ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.473ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.463ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.494ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.448ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.458ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.465ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.440ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.480ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.470ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.476ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.486ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.467ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.447ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.477ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.466ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.483ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.464ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.475ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.496ms returns -1
    [2024-Sept-18 17:18:12] [error] [ Client] - Encountered error -102: Command enable_coprocessor executed for 146 milliseconds with result -102
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.453ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.462ms returns -1
    [2024-Sept-18 17:18:12] [warning] [  nRF53] - Ignore error while fetching secure transfer state. -102: An unknown error.
    [2024-Sept-18 17:18:12] [debug] [  nRF53] - Just_readback_status
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2024-Sept-18 17:18:12] [trace] [  JLink] - failed
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.492ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.460ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.455ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.445ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.451ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.485ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.484ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.482ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.450ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.442ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.443ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.456ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.488ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.498ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.516ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.487ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.471ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.504ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.503ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.479ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.400ms
    [2024-Sept-18 17:18:12] [error] [ Worker] - An unknown error.
    [2024-Sept-18 17:18:12] [trace] [ Worker] - Command enable_coprocessor executed for 145 milliseconds with result -102
    [2024-Sept-18 17:18:12] [debug] [  nRF53] - close
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.003ms returns 0x01
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - close
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - disconnect_from_emu
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2024-Sept-18 17:18:12] [debug] [SeggerBackend] - is_connected_to_device
    [2024-Sept-18 17:18:12] [trace] [  JLink] - JLINK_IsConnected()
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.001ms returns FALSE
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.461ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.423ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.427ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.444ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.452ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.436ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.433ms returns -1
    [2024-Sept-18 17:18:12] [trace] [ Client] - Command close executed for 54 milliseconds with result 0
    [2024-Sept-18 17:18:12] [debug] [ Client] - terminate
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.518ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.449ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.481ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.499ms returns -1
    [2024-Sept-18 17:18:12] [trace] [  JLink] - - 0.489ms returns -1
    Your logs show no contact at all, typical if the device is not powered or similar.
    Could you check if one of the jumpers are missing on the current measurement headers?
    If those are in-place, try to power cycle your board a couple of times while running the recover routine.
    Håkon
