Flash partitioning
The MCUboot, Slot0, and Slot1 flash partitions are defined in the board file. E.g., nrf52840dk_nrf52840.dts has boot_partition at 0 with length 0xC000, slot0_partition at 0xC000 with length 0x76000, slot1_partition at 0x82000 with length 0x76000, and storage_partition picking up at 0xF8000, right after Slot1.
In a Sigurd Hellesvik git repo, I learned about partition_manager_report; "west build -t partition_manager_report", which seems to say that Slot 0, for the primary image, is at 0xC000 with a length of 0x7A000 (starting with a 0x200 "pad") and Slot 1, for the secondary image, is at 0x86000 with a length of 0x7A000. It would seem the partition manager is free to allocate flash0 in nrf52840_qiaa.dtsi however it likes. Is the stuff in the DTS just a suggestion? This would seem to conflict with CONFIG_USE_DT_CODE_PARTITION=y in the prj.conf.
If I put stuff like USB in MCUboot and have to grow the partition to fit it by setting CONFIG_PM_PARTITION_SIZE_MCUBOOT, it reworks Slot0 and Slot1 lengths to fit in the 1Mbyte flash.
If I set CONFIG_NVS=y, partition_manager_report now has a nvs_storage block, not starting at 0xF8000 per the DTS file, but actually CONFIG_PM_PARTITION_SIZE_NVS_STORAGE from the end. So we really can't use the DTS macros to determine where a user-defined constant in flash might be.
The application I'm working on currently reserves some memory at the very end, to be loaded with a device serial number via nrfjprog. I'm "reserving" it in a DTS overlay and giving it a symbol that can be recovered with a DT macro. But if partition manager isn't really paying attention to the partition allocations in DT, how would I tell partition manager to reserve the space and not potentially overwrite it with a DFU or some NVS operation?
