after set GPIO pin as active low exception fatal error occurred in debugging mode
Hi
     For nRF7002-DK, SDK Version 2.52,I gernate gpio port and set it as active low as below. after gpio pin set as active low, on debugging mode occurred exception fatal error, I can't add any break point for debug after that.it's only simple output gpio pin setting why cause fatal error as below?
yaml for binding
include: base.yaml
compatible: "nordic,custom-device"
description: Custom devicetree device
properties:
  in-gpios:
    type: phandle-array
    description: input gpio pins
    required: true
  out-gpios:
    type: phandle-array
    description: output gpio pins
    required: true
overlay
	custom_device: custom_device {
        compatible = "nordic,custom-device";
        status = "okay";
		in-gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>;
        out-gpios = <&gpio1 11 GPIO_ACTIVE_HIGH>;
static const struct gpio_dt_spec output_gpio = GPIO_DT_SPEC_GET(CUSTOM_DEVICE, out_gpios);
   if (!device_is_ready(output_gpio.port))
        printk("Output GPIOs not ready\n");
        return;
gpio_pin_set(&output_gpio,output_gpio.pin,GPIO_ACTIVE_LOW);
Error Fatal in debugging mode
Best Regards
    Tina
