I need a way to decide on which Api to use for UARTE (configured as uart1) once in main(). I am not intending to switch between them nor to use them at the same time. I am aware that it is not possible to use both simultaneously on the same uart. I am using the the nRF52840 with the following configuration
/ { chosen { zephyr,console = &uart0; }; }; &uart0 { compatible = "nordic,nrf-uart"; current-speed = <115200>; status = "okay"; pinctrl-0 = <&uart0_default_alt>; pinctrl-1 = <&uart0_sleep_alt>; pinctrl-names = "default", "sleep"; }; &uart1 { compatible = "nordic,nrf-uarte"; current-speed = <115200>; status = "okay"; pinctrl-0 = <&uart1_default_alt>; pinctrl-1 = <&uart1_sleep_alt>; pinctrl-names = "default", "sleep"; /* Used for communication on modbus sensor */ test_dev: modbus0 { compatible = "zephyr,modbus-serial"; status = "okay"; }; };
- Uart0 is chosen for the console debugging.
- Uart1 needs to work using
- the interrupt driven api if the sensor is of type x
- and work with the async api if the sensor is of type y.
Any help, even a hacky workaround, will be much appreciated.
