Hello all smart people.
Currently I am working with SMS sample and I want to toggle LED with pwm after receiving message, but I can not get sms on the "live" only after restart I see that message is received on terminal.
What did I wrong or how to get sms on controller live time?
Thank you, fizz drink on me
/* * Copyright (c) 2021 Nordic Semiconductor ASA * * SPDX-License-Identifier: LicenseRef-Nordic-5-Clause */ #include <stdio.h> #include <zephyr/kernel.h> #include <string.h> #include <modem/sms.h> #include <modem/nrf_modem_lib.h> #include <modem/lte_lc.h> #include <zephyr/drivers/gpio.h> #include <zephyr/drivers/pwm.h> static struct k_work sms_workk; static const struct pwm_dt_spec pwm_led0 = PWM_DT_SPEC_GET(DT_ALIAS(pwm_led0)); /* 1000 msec = 1 sec */ #define SLEEP_TIME_MS 2500 /* The devicetree node identifier for the "led0" alias. */ #define LED0_NODE DT_ALIAS(led0) /* * A build error on this line means your board is unsupported. * See the sample documentation for information on how to fix this. */ static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios); static void sms_callback(struct sms_data *const data, void *context) { if (data == NULL) { printk("%s with NULL data\n", __func__); return; } if (data->type == SMS_TYPE_DELIVER) { gpio_pin_toggle_dt(&led);// /* When SMS message is received, print information */ struct sms_deliver_header *header = &data->header.deliver; printk("\nSMS received:\n"); printk("\tTime: %02d-%02d-%02d %02d:%02d:%02d\n", header->time.year, header->time.month, header->time.day, header->time.hour, header->time.minute, header->time.second); printk("\tText: '%s'\n", data->payload); printk("\tLength: %d\n", data->payload_len); if (header->app_port.present) { printk("\tApplication port addressing scheme: dest_port=%d, src_port=%d\n", header->app_port.dest_port, header->app_port.src_port); } if (header->concatenated.present) { printk("\tConcatenated short message: ref_number=%d, msg %d/%d\n", header->concatenated.ref_number, header->concatenated.seq_number, header->concatenated.total_msgs); } } else if (data->type == SMS_TYPE_STATUS_REPORT) { printk("SMS status report received\n"); } else { printk("SMS protocol message with unknown type received\n"); } } int main(void) { int handle = 0; int ret = 0; uint32_t period = 1000000U; uint32_t pulse_width = period/100*100; uint32_t dummy =0; printk("\nSMS sample starting\n"); ret = nrf_modem_lib_init(); if (ret) { printk("Modem library initialization failed, error: %d\n", ret); return 0; } ret = lte_lc_connect(); if (ret) { printk("Lte_lc failed to initialize and connect, err %d", ret); return 0; } handle = sms_register_listener(sms_callback, NULL); if (handle) { printk("sms_register_listener returned err: %d\n", handle); return 0; } printk("SMS sample is ready for receiving messages\n"); /* Sending is done to the phone number specified in the configuration, * or if it's left empty, an information text is printed. */ if (strcmp(CONFIG_SMS_SEND_PHONE_NUMBER, "")) { printk("Sending SMS: number=%s, text=\"SMS sample: testing\"\n", CONFIG_SMS_SEND_PHONE_NUMBER); ret = sms_send_text(CONFIG_SMS_SEND_PHONE_NUMBER, "SMS sample: testing"); if (ret) { printk("Sending SMS failed with error: %d\n", ret); } } else { printk("\nSMS sending is skipped but receiving will still work.\n" "If you wish to send SMS, please configure CONFIG_SMS_SEND_PHONE_NUMBER\n"); } if (!gpio_is_ready_dt(&led)) { return 0; } ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE); if (ret < 0) { return 0; } /* if (!pwm_is_ready_dt(&pwm_led0)) { printk("Error: PWM device %s is not ready\n", pwm_led0.dev->name); return 0; } ret = pwm_set_dt(&pwm_led0, period, pulse_width); if (ret) { printk("Error %d: failed to set pulse width\n", ret); return 0; } */ for(;;) { //ret = pwm_set_pulse_dt(&pwm_led0, pulse_width); k_msleep(SLEEP_TIME_MS); dummy++; } /* In our application, we should unregister SMS in some conditions with: * sms_unregister_listener(handle); * However, this sample will continue to be registered for * received SMS messages and they can be seen in serial port log. */ return 0; }
