Hi there,
I've got a problem with getting the sample applications (and our primary application, but I'll focus on just the sample application) to run. I've got the bootloader running and with the pre-built hex files within the SDK, that is working as expected. I'm using the nrf5 SDK 17.1.0 for DFU reasons (I do have an application built on the nrf Connect SDK 2.5.0, but need DFU)
Setup:
- MCU: nrf52832 (nRF52 DK/PCA10040)
- Compiler: arm-none-eabi-gcc (11.2 2022.02)/make
- Development platform/IDE in use: Windows 10 64-bit/Visual Studio Code
There is nothing in the debug log to indicate the application (in this case the ble_peripheral\ble_app_uart\pca10040\s132\armgcc application/build) started compared with the prebuilt hex:
<info> app: Inside bl main <debug> app: In nrf_bootloader_init <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()... <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend. <debug> nrf_dfu_settings: Using settings page. <debug> nrf_dfu_settings: Copying forbidden parts from backup page. <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping. <info> nrf_dfu_settings: Backing up settings page to address 0x7E000. <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping. <debug> app: Enter nrf_bootloader_fw_activate <info> app: No firmware to activate. <debug> app: App is valid <debug> app: Attempting to launch app <debug> app: DFU Settings Backup <info> nrf_dfu_settings: Backing up settings page to address 0x7E000. <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping. <debug> app: Running nrf_bootloader_app_start with address: 0x00001000 <debug> app: Disabling interrupts. NVIC->ICER[0]: 0x4
Only change made was to remove the -Werror argument from the Makefile; everything else is unmodified.
Running "nrfjprog.exe --readregs" showed:
R0: 0x00000004 R1: 0x0002AB3A R2: 0x00026000 R3: 0x0002CF77 R4: 0x00050000 R5: 0x00000000 R6: 0x00030004 R7: 0x00000000 R8: 0x00000000 R9: 0x00000000 R10: 0x20000000 R11: 0x00000000 R12: 0x00000000 SP: 0x2000FEC8 LR: 0xFFFFFFF9 PC: 0x0002CF76 xPSR: 0x21000003 MSP: 0x2000FEC8 PSP: 0x00000000 RAZ: 0x00000000 CFBP: 0x00000001 APSR: 0x20000000 EPSR: 0x01000000 IPSR: 0x00000003
And looking at the map file to go with the program counter; it's looking as if it's Hard Faulted:
.text 0x0002cf4c 0x3c _build/nrf52832_xxaa/gcc_startup_nrf52.S.o 0x0002cf4c Reset_Handler 0x0002cf74 NMI_Handler 0x0002cf76 HardFault_Handler 0x0002cf78 MemoryManagement_Handler 0x0002cf7a BusFault_Handler 0x0002cf7c UsageFault_Handler 0x0002cf7e SVC_Handler
Any suggestions on a potential configuration issue/build issue to get the ble_app_uart working? Using the nrf Desktop - Flash Programmer utility to program. Hex files, sdk_config and map file attached.
Kind Regards,
Trystan
