Unable to decrypt Zigbee Shell traffic in Wireshark
I'm using nRF Connect v2.6.2 with Wireshark (3.6) and it is setup with the nRF sniffer + Nordic network keys configured.
I can decrypt packets from another Zigbee network (Pi + SkyConnect based using the added Home Assistant network key)
I have performed a full flash erase before flashing the shell firmware on my nrf52840.
The command sequence I'm using is as follows (it is/should be re-using the Nordic example network key already configured in Wireshark):
bdb start
bdb factory_reset
# nRF HW Reset at this point and reconnect to shell cli
nvram disable
bdb nwkkey abcdef01234567890000000000000000
nvram enable
bdb role zc
bdb start
At this point any packets appearing in Wireshark are never decrypted.
Is anyone able to help point out what steps I have missed or am I doing wrong?
Thank you,
Wayne
  • Hi Wayne,
    The sniffer log is decrypted on my side as well.
    Wayne said:
    Prior to trying out the steps you've suggested I've performed a 'recovery' and 'erase' flash but the result is the packets remain encrypted in Wireshark, log:
    Have you tried setting the network key after performing an erase?
    I'm not sure why you can't decrypt the packets in the sniffer log. I've tested with the same commands as you, but I can't reproduce the issue. Are you starting the sniffer before the coordinator starts the network? If the sniffer is running while a device is commissioned to the network, it should be able to pick up the network key and use it to decrypt the packets regardless of the keys you have configured in Wireshark.
    Just to verify, are you using install codes?
    Marte
  • Hi Marte,
    The network key is set after the erase, I have just tried a test with the sniffer running prior to my testing. I'm going to upgrade to WS 4.x to see if that makes a difference.
    What are "install codes"?
    Thanks
    Wayne
  • Hi Wayne,
    Install code is a security feature in Zigbee that allows you to configure the network so that only devices with install codes can join it. When using this, the install code and extended address of a joining device must be added to the coordinator before the device can join, and during joining, the device's install code is used to generate a unique trust center link key for the device. If you were using this, it could explain why the packets are encrypted since the sniffer would not be able to decrypt the packets of a network using install codes with just the network key.
    With Zigbee shell, you can manually enable and add install codes, but it does not seem like you are doing so, so you can just ignore my question regarding it Slight smile
    Marte
  • Hi Marte,
    Thanks for letting know.
    Please could you also let me know which version of: the nRF Connect SDK, Wireshark and the nRF MCU you are using to test please ?
    Thanks
    Wayne
  • Hi Wayne,
    I tested with nRF Connect SDK v2.6.1, Wireshark v4.2.4 on Ubuntu 22.04, and nRF52840 DK.
    Marte
