in our application we use SDCard and USB stack with the following configuration:
#Peripherals CONFIG_GPIO=y CONFIG_SPI=y CONFIG_I2C=y CONFIG_ADC=y CONFIG_SERIAL=y CONFIG_UART_INTERRUPT_DRIVEN=y # Flash CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_MPU_ALLOW_FLASH_WRITE=y CONFIG_PRINTK=y CONFIG_LOG=y # Infrared timer CONFIG_COUNTER=y CONFIG_COUNTER_RTC0=y # This timer is used only for read IR competitor protocol CONFIG_NRFX_TIMER1=y CONFIG_NRFX_TIMER2=y # SDCard & Filesystem CONFIG_DISK_DRIVERS=y CONFIG_DISK_DRIVER_SDMMC=y CONFIG_DISK_ACCESS=y CONFIG_FILE_SYSTEM=y CONFIG_FAT_FILESYSTEM_ELM=y # Bootloader CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_IMG_MANAGER=y CONFIG_MCUBOOT_IMG_MANAGER=y #CONFIG_IMG_ERASE_PROGRESSIVELY=y # Bluetooth configuration CONFIG_BT=y CONFIG_BT_OBSERVER=y #CONFIG_BT_BROADCASTER=y CONFIG_BT_HCI=y # BT LE White list CONFIG_BT_FILTER_ACCEPT_LIST=y # Test filter by UUID # CONFIG_BT_PERIPHERAL=y # CONFIG_BT_CENTRAL=y # CONFIG_BT_SCAN=y # CONFIG_BT_SCAN_FILTER_ENABLE=y # CONFIG_BT_SCAN_WITH_IDENTITY=y # Accelerometer # CONFIG_SENSOR=y #CONFIG_LIS2DH=y # +/- 2g #CONFIG_LIS2DH_ACCEL_RANGE_2G=y # 10Hz #CONFIG_LIS2DH_ODR_2=y # Low Power Mode - 8bit #CONFIG_LIS2DH_OPER_MODE_LOW_POWER=y # Enable Low Power CONFIG_PM=y CONFIG_PM_DEVICE=y CONFIG_REBOOT=y #USB related configs CONFIG_USB_DEVICE_STACK=y CONFIG_USB_DEVICE_PRODUCT="SGuide V3" CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y CONFIG_USB_MASS_STORAGE=y CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y CONFIG_USB_MASS_STORAGE_LOG_LEVEL_ERR=y CONFIG_APP_MSC_STORAGE_SDCARD=y #CONFIG_USB_DEVICE_PID=0x0008 # Used on AM131 Board CONFIG_NFCT_PINS_AS_GPIOS=y CONFIG_BOARD_ENABLE_DCDC_APP=n CONFIG_BOARD_ENABLE_DCDC_NET=n CONFIG_BOARD_ENABLE_DCDC_HV=n CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=n CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y # Other CONFIG_MAIN_STACK_SIZE=8192 CONFIG_IDLE_STACK_SIZE=4096 CONFIG_SIZE_OPTIMIZATIONS=n # Reset on hard fault CONFIG_RESET_ON_FATAL_ERROR=y
The communication with the nRF5340 is done by using a Linux Embedded systems. When the device is connected to Linux, I copy a folder inside the SDCard without any problem.
When I remove the folder and put into a new one the copy fails and the linux systems told us that the memory was corrupted.
Instead, if I remove the folder directly from the OS (by removing the SDCard from the board with the nRF5340), and after that I write the folder by using the nRF5340 it works correctly.
The device are in production and we don't know how solve this issue!! Can you help us?
Best
Marco
