I would like to confirm this procedure and hopefully correct me if I miss any steps.
So to add FEM nrf21 (only active by gpio mode) to new nrf53 board:
first step:
add fem node to nrf5340_cpunet.dts
first step:
Here is a thread covering the same question(s):
Using nrf5340dk with the nrf21540 EK
CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB_POUTA=20
You should keep this value to the default, as described here:
CONFIG_BT_CTLR_TX_PWR_ANTENNA=127
This line shall be equal to your expected/wanted output power.
If you are targeting your product for europe, please note that +10 dBm is the max, as stated here in this comment:
RE: Using nrf5340dk with the nrf21540 EK
Håkon
Thank you Håkon!
Just for clarification, to add nrf21 fem we need only to add the gpio declaratin and radion node only in nrf5340_cpunet.dts right?
after that I noticed some examples where CONFIG_MPSL_FEM_xxxxx settings are placed either in main proj.conf or in hci_rpmsg ? which one is the correct file for those settings?
Besides that I got a lot of warnings when I enabled gpio mode using CONFIG_MPSL_FEM_NRF21540_GPIO , is that the correct config to do that or I need to add more dependencies?
Best regards
It should go in the network core image, which is "hci_rpmsg" for NCS v2.4 or older, while it is named "hci_ipc" in ncs v2.5.x and newer.
If you look at this answer, it shows how to verify that your configurations have been applied properly: RE: Using nrf5340dk with the nrf21540 EK
Håkon
