I was programming wifi scan example with nrf7002dk_nrf5340_cpuapp configuration. The mac address was not setting by default so I did it manually by using the function provided below.
Still not working.
Still not working.
I am sorry I didn't get you.
Also the page you shared is not available
The module which I am using to for WIfi is MS12SF1. I can't set a mac address as the mac address can be different for the module.
Tested the wifi scan code with thingy53 and the mac address which it got was different from the one which is hardcoded
A bit confused here what to do as not even sure that whether the mac address is even hard coded in the module or not and also can't set it
So what to do?
Hi Rakshita,
Did you try exactly the codes mentioned in this reply?
RE: samples/wifi/scan broken without programmed OTP
Charlie
Yes I went through the code
Actually the module which I am using doesn't have any serial port so if I even want to change it through otp command I am not able to as I don't know where to run the command
After adding the code also to set the mac address manually, it gives me the below result
[00:00:00.016,479] <err> wifi_nrf: hal_rpu_reg_read: Error !! Value read at addr_offset = 400 is = FFFFFFFF
[00:00:00.016,571] <err> wifi_nrf: hal_rpu_irq_enable: Reading from Root interrupt register failed
[00:00:00.016,632] <err> wifi_nrf: nrf_wifi_hal_dev_add: hal_rpu_irq_enable failed
[00:00:00.016,815] <err> wifi_nrf: nrf_wifi_fmac_dev_add: nrf_wifi_hal_dev_add failed
[00:00:00.016,845] <err> wifi_nrf: nrf_wifi_fmac_dev_add_zep: nrf_wifi_fmac_dev_add failed
[00:00:00.016,845] <err> wifi_nrf: nrf_wifi_if_init_zep: nrf_wifi_fmac_dev_add_zep failed
[00:00:00.031,616] <err> wifi_nrf: hal_rpu_reg_read: Error !! Value read at addr_offset = 400 is = FFFFFFFF
[00:00:00.031,707] <err> wifi_nrf: hal_rpu_irq_enable: Reading from Root interrupt register failed
[00:00:00.031,738] <err> wifi_nrf: nrf_wifi_hal_dev_add: hal_rpu_irq_enable failed
[00:00:00.031,921] <err> wifi_nrf: nrf_wim
