Which Complier is default used? Both SES and NCS
Hello everyone~
I'm now trying to use a third-party software (BSEC, Bosch Sensortec Environmental Cluster,a lib for gas sensor BME680). It limits the complier to arm-none-eabi-gcc. Is nRF5 SDK configed as arm-none-eabi-gcc by default? And is NCS configed as arm-none-eabi-gcc or clang by default?
    The nRF5 SDK is in maintenance mode and we do not recommend any new project to use it.
    It uses arm-zephyr-eabi-gcc by default. However, the SDK supports BME680. I am guessing that you want to use a binary to work with the sensor here. It should work. Please refer to this past case.
    It depends on your environment. If you use Keil uVision or SEGGER Embedded Studio, then arm-none-eabi-gcc is used by default; note that it is meant to support and only tested with only a rather old version of the compiler.
    You can also use a manually installed copy of arm-none-eabi-gcc and Makefile.
    nRF5 SDK also supports IAR. I actually have never used IAR before, but it looks like it uses the IAR C/C++ Compiler.
    Hieu
  • Thank you!
