Maximum settings partition size estimation
Hi there,
I need help finalizing the size of my product's settings partition. I only store Bluetooth bonds on the settings partition: 20 bonds to other Nordic devices via the Nordic UART service and 10 bonds to BLE HID devices. These connections must be securely encrypted.
According to what I see, the following settings keys are stored:
- bt/sc/0123456789abc 4 bytes, stored for one device
- bt/cf/0123456789abc - 2 bytes, stored for one device
- bt/keys/0123456789abc - 80 bytes, stored for all devices
- bt/ccc/0123456789abc - 12-32 bytes, stored for all devices
The reason I can't estimate the maximum storage size for my needs is because of the following:
- Some keys are present for all devices I tested, while others are only for one. I don't know which keys are stored in which cases.
- Some keys vary in size, and I don't know their minimum and maximum size.
- There may be additional keys that are used on select occasions, which I don't know.
- I don't know the storage overhead of NVS.
- Can NVS be fragmented? If so, it should be accounted for.
Thanks in advance!
- Laci
    How much flash is used by settings is very application depended (number of setting entries and how frequent they are updated). I recommend using the nvs_calc_free_space() to help profile the flash usage for your application. Flash wear should also be considered: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/services/storage/nvs/nvs.html#flash-wear
    You can use this function to retreive the NVS instance used by the settings module: https://github.com/nrfconnect/sdk-zephyr/commit/ccf8c547d090ad3f76dbfa64744f32333658dcdb
    Vidar
  • Hi Vidar,
    I've included the following in my main():
    	void *storage;
        int rc = settings_storage_get(&storage);
        ssize_t size = nvs_calc_free_space((struct nvs_fs *)storage);
        printk("Free space: %d\n", size);
    According to the printed result, the free space doesn't exceed 4K, even though I've allocated 8K for storage.
    my-board.dtsi:
    &flash0 {
        partitions {
            #address-cells = <1>;
            #size-cells = <1>;
            boot_partition: partition@0 {
                label = "mcuboot";
                reg = <0x0 0x10000>;
            slot0_partition: partition@10000 {
                label = "image-0";
                reg = <0x10000 0xdd000>;
            hardware_config_partition: partition@ed000 {
                label = "hardware-config";
                reg = <0xed000 0x1000>;
            user_config_partition: partition@ee000 {
                label = "user-config";
                reg = <0xee000 0x10000>;
            storage_partition: partition@fe000 {
                label = "storage";
                reg = <0xfe000 0x2000>;
    pm_static.yml:
    app:
      address: 0x10200
      end_address: 0xfe000
      region: flash_primary
    mcuboot:
      address: 0x0
      end_address: 0x10000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0x10000
      end_address: 0x10200
      placement:
        align:
          start: 0x1000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0x10000
      orig_span: &id001
      - app
      - mcuboot_pad
      span: *id001
    mcuboot_primary_app:
      address: 0x10200
      orig_span: &id002
      - app
      span: *id002
      address: 0xed000
      end_address: 0xee000
      address: 0xee000
    settings_storage:
      address: 0xfe000
      end_address: 0x100000
      placement:
        align:
          start: 0x1000
        before:
        - end
    sram_primary:
      address: 0x20000000
      end_address: 0x20040000
      region: sram_primary
    Thanks in advance for your help!
    As mentioned in the NVS documentation, NVS will always keep one page empty to allow copying of existing data. Therefore, it is not possible to allocate less than 2 flash pages to NVS.
    This extra flash page enables safe updating of existing data.
