I have found a bug in SDK v2.6.0 at zephyr/drivers/flash/nrf_qspi_nor.c while erasing the external MX25R64 flash.
Environment:
- nRF5340 DK Hardware (MX25R64 external flash over QSPI with nordic,qspi-nor driver)
- NCS SDK v2.6.0 (sdk-zephyr tag v3.5.99-ncs1)
I have a custom project which uses the FLASH_MAP API to erase the external flash in a loop at 64KB increments (offsets: 0x0, 0x10000, etc...). The first one succeeds, but the second one fails at offset 0x10000. I am pretty sure this is a timing issue. This does NOT occur on the nRF7002 DK, which communicates to the same flash chip via SPI instead of QSPI (which also uses the generic JEDEC compatibility SPI NOR driver instead of a Nordic driver).
I tracked the failure down to zephyr/drivers/flash/nrf_qspi_nor.c:qspi_nor_write_protection_set() on the first call which uses SPI_NOR_CMD_WREN. There's a couple issues with the original function:
- The return code from qspi_send_cmd() is ignored and replaced with -EIO in all failure cases; this makes it impossible to distinguish the root cause.
- In the problem case, qspi_send_cmd() returns -EBUSY; so this means the chip is likely not ready for the operation to be performed yet.
static int qspi_nor_write_protection_set(const struct device *dev, bool write_protect) { int rc = 0; struct qspi_cmd cmd = { .op_code = ((write_protect) ? SPI_NOR_CMD_WRDI : SPI_NOR_CMD_WREN), }; if (qspi_send_cmd(dev, &cmd, false) != 0) { rc = -EIO; } return rc; }
I implemented a local workaround which solves the issue by retrying the operation while -EBUSY is received up to a maximum number of attempts; it fails with -EBUSY on the first attempt and then returns 0 on the second attempt:
static int qspi_nor_write_protection_set(const struct device *dev, bool write_protect) { int rc = 0; unsigned int attempts = 3; struct qspi_cmd cmd = { .op_code = ((write_protect) ? SPI_NOR_CMD_WRDI : SPI_NOR_CMD_WREN), }; while(attempts) { rc = qspi_send_cmd(dev, &cmd, false); LOG_ERR("Write protect[0x%02x]: %d (%u)", cmd.op_code, rc, attempts); if(!rc) { break; } else { if(rc != -EBUSY) { break; } rc = -EIO; } --attempts; } return rc; }
Possible solutions:
- Send in a loop while -EBUSY is received
- Query the WEL bit in the status register after the command has been sent to verify the status is updated.
- From the data sheet, the Write Status Register Cycle time is ~10ms up to 20ms max.
- Query the chip before doing an erase to see if it is in a state where the commands may fail.
- Macronix data sheet v1.6 section 8 states that "Before a command is issued, status register should be checked to ensure device is ready for the intended
operation.". See also section 10.8 "Status Register" (p30).
