I am working on building a BLE peripheral using the nRF52 DK board. I want to create both connectable advertisement and unconnectable advertisement (beacon type) on it.
I have searched on this forum for a solution and only found the possibility of using the Time slot API and the multiactivity example.
However, I am facing difficulties in finding a proper and recent example of using the time slot API specifically for advertisement. The multiactivity example seems to have disappeared in the latest SDK, and I couldn't find it in SDK 17.1.0 S132. I have been using the code from this project https://github.com/xueliu/nRF52/tree/master/nRF52_SDK_0.9.2_dbc28c9/examples/ble_peripheral/experimental_ble_app_multiactivity_beacon/hrs_advertiser as a reference.
Currently, I can activate the beacon and the normal connectable advertisement separately, but I cannot activate them both at the same time. Also I can activate the beacon only once: if start, stop it and then start it again the fw crashes. I have added advertiser_beacon.h and advertiser_beacon.c to my project, but only added the `app_beacon_start()` and `app_beacon_stop()` , beacon_adv_init() functions in my main.
static void on_ble_evt(ble_evt_t * p_ble_evt)
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
app_beacon_start();
app_beacon_stop();
// No implementation needed.
}I believe that I need to add something like this in my main function to use the timeslot, but I am not sure if it is done automatically:
/**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
* @details This function is called from the BLE Stack event interrupt handler after a BLE stack
* event has been received.
* @param[in] p_ble_evt Bluetooth stack event.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
dm_ble_evt_handler(p_ble_evt);
ble_hrs_on_ble_evt(&m_hrs, p_ble_evt);
ble_bas_on_ble_evt(&m_bas, p_ble_evt);
ble_conn_params_on_ble_evt(p_ble_evt);
bsp_btn_ble_on_ble_evt(p_ble_evt);
ble_advertising_on_ble_evt(p_ble_evt);
/**@brief Function for dispatching a system event to interested modules.
* @details This function is called from the System event interrupt handler after a system
* @param[in] sys_evt System stack event.
static void sys_evt_dispatch(uint32_t sys_evt)
pstorage_sys_event_handler(sys_evt);
app_beacon_sd_evt_signal_handler(sys_evt);
ble_advertising_on_sys_evt(sys_evt);
uint32_t err_code;
// Initialize the SoftDevice handler module.
SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);
// Enable BLE stack
ble_enable_params_t ble_enable_params;
memset(&ble_enable_params, 0, sizeof(ble_enable_params));
#if (defined(S130) || defined(S132))
ble_enable_params.gatts_enable_params.attr_tab_size = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
err_code = sd_ble_enable(&ble_enable_params);
// Register with the SoftDevice handler module for BLE events.
err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
However, I believe many of the functions used in this example are not available in the latest version of the SDK. Do you have any suggestions on how I can implement this?
Best Regards,
Lara
