hello there i want to put my nrf51822 in sleep mode when it is not advertising. can you tell me how to do it?
you can see it in most demo.
I can tell you most of this operation occur is when the ADV (fast ADV / Slow ADV / direct ADV, etc.) time out. So you can find it in the adv time out call back function. And slow ADV is always the last ADv type, then go to sleep. You can find what you want by search BLE_ADV_EVT_IDLE.
case BLE_ADV_MODE_SLOW:
m_adv_evt = BLE_ADV_EVT_IDLE;
LOG("[ADV]: Timed out from slow advertising, stopping advertising.\r\n");
if (m_evt_handler != NULL)
m_evt_handler(m_adv_evt);
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
can we add time? like after 5 s nrf51822 goes into sleep mode
hello there link text .in this timer example. they used __WFE(); for sleep mode. can i use timer and __WFE(); with advertising ??
In BLE uart application. i also find function for sleep mode
// Prepare wakeup buttons.
i think i can use it
hello,
when ADV, the time out timer is defined automatically when you do the adv_init. You need don't add another timer to do this.
I advise you go deep into the xxx_init function. And you can see many MACROs in main.c in each demo, there's many time_out define.
