query about sorted list from nrf5 SDK
Hi there,
I want to manage certain devices that have an address and a value. I would like to dynamically add and remove devices from my data structure. I believe that using a linked list would be the best choice for this task. It's essential that I use the nRF5 SDK for development purposes, as switching to nRF Connect is not feasible due to ongoing development efforts.
Initially, I considered using the Sorted List library from the nRF5 SDK, but despite a thorough search, I couldn't find any relevant examples in the SDK examples folder or on the web, and I also found that the online documentation was quite sparse and there seemed to be some bugs, link2. Nevertheless, I created a simple example that seems to work reasonably well.
Example:
typedef struct {
 uint32_t data;
 uint8_t address[8];
 nrf_sortlist_item_t item;
} item_t;
bool compare_function(nrf_sortlist_item_t * p_item0, nrf_sortlist_item_t * p_item1)
 item_t * _p_item0 = CONTAINER_OF(p_item0, item_t, item);
 item_t * _p_item1 = CONTAINER_OF(p_item1, item_t, item);
 return (_p_item0->address > _p_item1->address) ? true : false;
NRF_SORTLIST_DEF(example_list, compare_function);
int main(void) {
    uint32_t err_code;
    // Initialize Logs, Power & Timer.
    log_init();
    timers_init();
    power_management_init();
    item_t item0, item1, item2, item3;
    item0.data = 100;
    int64_t address = 1;
    memcpy(item0.address, &(address), sizeof(address));
    item1.data = 110;
    address++;
    memcpy(item1.address, &(address), sizeof(address));
    item2.data = 120;
    address++;
    memcpy(item2.address, &(address), sizeof(address));
    nrf_sortlist_add(&example_list, &item0.item);
    nrf_sortlist_add(&example_list, &item1.item);
    nrf_sortlist_add(&example_list, &item2.item);
    item3.data = 115;
    address++;
    memcpy(item3.address, &(address), sizeof(address));
    nrf_sortlist_add(&example_list, &item3.item);
    NRF_LOG_INFO("Test 1: iteration throught");
    nrf_sortlist_item_t const * pp_curr = nrf_sortlist_peek(&example_list);
    item_t * p_item;
    while(pp_curr != NULL)
        p_item = CONTAINER_OF(pp_curr, item_t, item);
        NRF_LOG_INFO("p_item:data: %d, address:%d",p_item->data, p_item->address[0]);
        pp_curr = nrf_sortlist_next(pp_curr);
   NRF_LOG_INFO("Test 2: iteration throught a removed element.");
    nrf_sortlist_remove(&example_list, &item2.item);
    NRF_LOG_INFO("Finished");
    for (;;) {
        app_sched_execute();
        idle_state_handle();
In this implementation I would also need to deal with memory allocations. Is there an example of how should I allocate heap memory?
Also, I'm curious if there are any additional examples or resources related to sorted linked lists that I may have missed.
Would Nordic recommend that I use a different library or approach?
Thanks for the help!!!
  • Hi J0sh1101,
    It's great that you have found the information about the bug. Unfortunately, the unfixed bug and absence of example have been and will remain to be the state of things.
    This is because the nRF5 SDK is in maintenance mode; features, examples, as well as documentation will not be updated.
    On this note, if you are at the very early stage of your project, we recommend using the nRF Connect SDK instead.
    There is also the Memory Manager library for this. As far as I can see, there is no example for it though.
    Speaking on behalf of the company is quite the pressure. I would recommend the Memory Manager library for the dynamic allocation topic.
    For Sorted List, I think the current library, or any open source one would work.
    Hieu
  • Hi Hieu,
    your answer was spot on.
    Looking at the implementation of the memory manager, I feel a bit cheated, but hey, this is how things are done in embedded world. The memory manager defines memory region in the .bss section with a static variable and from this memory it returns chunks of it. I am not completely sure, but this is not how heap should be created.
    I think you did a good job. Thanks!
    Best Regards,
    Josh
  • Hi Josh,
    You are right, it is not real heap memory allocation, but an illusion of that created by allocating memory in a dedicated region.
    Thank you for the kind words. Please feel free to close this case at your convenience Slight smile
    Hieu
