Error when writing with J-Link
If you try to write a program on a board with nRF5340 installed, an error will occur.
I can write to other boards using the same J-Link, so I don't think it's a J-Link problem.
When writing with VSCODE, the following error is displayed.
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: c:\Users\TSP_M1\nrf5340_audio_demo6\build\zephyr\zephyr.hex
[error] [Client] - Encountered error -12: Command select_coprocessor executed for 30 milliseconds with result -12
ERROR: Failed when selecting coprocessor APPLICATION
[error] [Worker] - Low voltage 0 detected in target device.
ERROR: Low voltage detected at the target. Please make sure the device is
ERROR: properly supplied.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 43: nrfjprog --program 'c:\Users\TSP_M1\nrf5340_audio_demo6\build\zephyr\zephyr.hex' --sectorerase --verify -f NRF53 --coprocessor CP_APPLICATION --snr 821007475
Add --log and attach the generated log.log file.
Please tell me the cause of the error.
[2024-May-13 19:21:25] [debug] --------------------------------------------------------------------------------
[2024-May-13 19:21:25] [debug] nrfjprog --program C:\Users\TSP_M1\nrf5340_audio_demo6\build\dev_gateway\build_release\zephyr\net_core_app_signed.hex -f NRF53 -q --snr 821007475 --sectorerase --coprocessor CP_NETWORK --log
[2024-May-13 19:21:25] [debug] nrfjprog version 10.24.0 external
[2024-May-13 19:21:25] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
[2024-May-13 19:21:25] [ info] Library loaded, loading member functions.
[2024-May-13 19:21:25] [ info] Member functions succesfully loaded.
[2024-May-13 19:21:25] [debug] [ Client] - open
[2024-May-13 19:21:25] [debug] [ Client] - start
[2024-May-13 19:21:25] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 146b4c1f-65a5-4c9f-a7ab-348e30d1312e.
[2024-May-13 19:21:26] [trace] [ Client] - Command open executed for 71 milliseconds with result 0
[2024-May-13 19:21:26] [debug] [ Client] - config
[2024-May-13 19:21:26] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2024-May-13 19:21:26] [debug] [  JLink] - Logger sink registered in JLink logger
[2024-May-13 19:21:26] [debug] [  nRF53] - open
[2024-May-13 19:21:26] [debug] [  nRF53] - just_check_family
[2024-May-13 19:21:26] [debug] [SeggerBackend] - open_dll
[2024-May-13 19:21:26] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2024-May-13 19:21:26] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V794e\JLink_x64.dll.
[2024-May-13 19:21:26] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2024-May-13 19:21:26] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2024-May-13 19:21:26] [debug] [SeggerBackend] - Set batch mode
[2024-May-13 19:21:26] [debug] [SeggerBackend] - dll_version
[2024-May-13 19:21:26] [ info] [SeggerBackend] - Segger dll version 7.94.e loaded.
[2024-May-13 19:21:26] [trace] [ Worker] - Command open executed for 7 milliseconds with result 0
[2024-May-13 19:21:26] [debug] [  nRF53] - config
[2024-May-13 19:21:26] [debug] [SeggerBackend] - enum_emu_snr
[2024-May-13 19:21:26] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
[2024-May-13 19:21:26] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
[2024-May-13 19:21:26] [debug] [ Client] - enum_emu_snr
[2024-May-13 19:21:26] [debug] [  nRF53] - enum_emu_con_info
[2024-May-13 19:21:26] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
[2024-May-13 19:21:26] [debug] [SeggerBackend] - is_connected_to_emu
[2024-May-13 19:21:26] [debug] [SeggerBackend] - enum_emu_con_info
[2024-May-13 19:21:26] [trace] [ Worker] - Command enum_emu_con_info executed for 3 milliseconds with result 0
[2024-May-13 19:21:26] [debug] [ Client] - connect_to_emu_with_snr
[2024-May-13 19:21:26] [debug] [  nRF53] - connect_to_emu_with_snr
[2024-May-13 19:21:26] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2024-May-13 19:21:26] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2024-May-13 19:21:26] [debug] [SeggerBackend] - ---just_get_num_emus
[2024-May-13 19:21:26] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2024-May-13 19:21:26] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2024-May-13 19:21:26] [debug] [SeggerBackend] - Segger logging enabled.
[2024-May-13 19:21:26] [trace] [  JLink] - Firmware: J-Link V11 compiled Dec  4 2023 10:22:45
[2024-May-13 19:21:26] [trace] [  JLink] - Hardware: V11.00
[2024-May-13 19:21:26] [trace] [  JLink] - S/N: 821007475
[2024-May-13 19:21:26] [trace] [  JLink] - OEM: SEGGER
[2024-May-13 19:21:26] [trace] [  JLink] - Feature(s): GDB
[2024-May-13 19:21:26] [trace] [  JLink] - Bootloader: 2019 Jul 04
[2024-May-13 19:21:26] [trace] [  JLink] - USB speed mode: High speed (480 MBit/s)
[2024-May-13 19:21:26] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2024-May-13 19:21:26] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2024-May-13 19:21:26] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
[2024-May-13 19:21:26] [trace] [  JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V794e\JLinkGUIServer.exe
[2024-May-13 19:21:26] [trace] [  JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V794e\JLinkGUIServer.exe
[2024-May-13 19:21:26] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V7.94e "
[2024-May-13 19:21:26] [trace] [ Client] - Command connect_to_emu_with_snr executed for 110 milliseconds with result 0
[2024-May-13 19:21:26] [trace] [  JLink] - - 79.769ms returns "O.K."
[2024-May-13 19:21:26] [debug] [ Client] - read_connected_emu_snr
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_HasError()
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_Lock()
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2024-May-13 19:21:26] [trace] [  JLink] - - 0.001ms returns 0x01
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2024-May-13 19:21:26] [trace] [  JLink] - - 0.000ms returns 0x00
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2024-May-13 19:21:26] [trace] [  JLink] - - 0.003ms returns 0x00
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2024-May-13 19:21:26] [trace] [  JLink] - - 0.011ms returns 0
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2024-May-13 19:21:26] [trace] [  JLink] - - 3.088ms returns 0x00
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_GetSpeedInfo()
[2024-May-13 19:21:26] [trace] [  JLink] - 180000000 Hz / n, n >= 12
[2024-May-13 19:21:26] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 15000kHz
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2024-May-13 19:21:26] [trace] [  JLink] - - 0.924ms
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_GetSpeed()
[2024-May-13 19:21:26] [trace] [  JLink] - - 0.003ms returns 2000
[2024-May-13 19:21:26] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_GetSN()
[2024-May-13 19:21:26] [trace] [  JLink] - - 0.004ms returns 821007475
[2024-May-13 19:21:26] [debug] [  nRF53] - read_device_family
[2024-May-13 19:21:26] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 105 milliseconds with result 0
[2024-May-13 19:21:26] [debug] [  nRF53] - read_connected_emu_snr
[2024-May-13 19:21:26] [trace] [ Client] - Command read_connected_emu_snr executed for 15 milliseconds with result 0
[2024-May-13 19:21:26] [debug] [ Client] - enable_coprocessor
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_IsOpen()
[2024-May-13 19:21:26] [trace] [  JLink] - - 0.011ms returns 0x01
[2024-May-13 19:21:26] [debug] [SeggerBackend] - read_connected_emu_snr
[2024-May-13 19:21:26] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2024-May-13 19:21:26] [debug] [  nRF53] - enable_coprocessor
[2024-May-13 19:21:26] [trace] [  JLink] - - 0.012ms returns 0x01
[2024-May-13 19:21:26] [debug] [  nRF53] - Just_enable_coprocessor
[2024-May-13 19:21:26] [debug] [SeggerBackend] - is_secure_debug_available
[2024-May-13 19:21:26] [debug] [SeggerBackend] - read_access_port_register
[2024-May-13 19:21:26] [debug] [SeggerBackend] - ---just_read_access_port_register
[2024-May-13 19:21:26] [debug] [SeggerBackend] - coresight_configure
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2024-May-13 19:21:26] [trace] [  JLink] - - 0.631ms returns 0
[2024-May-13 19:21:26] [trace] [  JLink] - JLINK_Close()
[2024-May-13 19:21:26] [warning] [  nRF53] - Ignore error while fetching secure transfer state. -12: Low voltage 0 detected in target device.
[2024-May-13 19:21:26] [debug] [  nRF53] - Just_readback_status
[2024-May-13 19:21:26] [error] [ Worker] - Cannot call read_access_port_register when connect_to_emu_without_snr or connect_to_emu_with_snr has not been called.
[2024-May-13 19:21:26] [trace] [ Worker] - Command enable_coprocessor executed for 14 milliseconds with result -2
[2024-May-13 19:21:26] [error] [ Client] - Encountered error -2: Command enable_coprocessor executed for 31 milliseconds with result -2
[2024-May-13 19:21:26] [debug] [  nRF53] - close
[2024-May-13 19:21:26] [debug] [SeggerBackend] - close
[2024-May-13 19:21:26] [debug] [SeggerBackend] - disconnect_from_emu
[2024-May-13 19:21:26] [debug] [SeggerBackend] - Segger Backend closed.
[2024-May-13 19:21:26] [debug] [  nRF53] - nRF family DLL closed
[2024-May-13 19:21:26] [trace] [ Worker] - Command close executed for 28 milliseconds with result 0
[2024-May-13 19:21:26] [trace] [ Client] - Command close executed for 45 milliseconds with result 0
[2024-May-13 19:21:26] [debug] [ Client] - terminate
[2024-May-13 19:21:26] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2024-May-13 19:21:26] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2024-May-13 19:21:26] [trace] [ Worker] - Executed 8 commands for 159 milliseconds
[2024-May-13 19:21:26] [debug] [ Client] - Worker process exited with code: 0
[2024-May-13 19:21:26] [debug] [ Client] - Child process terminated with result 0
[2024-May-13 19:21:26] [trace] [ Client] - Executed 8 commands for 302 milliseconds
    Have you checked if there's an issue with your power supply?
    Håkon
  • Håkon Thank you.
    I made a mistake in posting the error.
    Actually it will be as follows.
    [error] [Client] - Encountered error -102: Command select_coprocessor executed for 155 milliseconds with result -102
    [error] [Worker] - An unknown error.
    ERROR: JLinkARM DLL reported an error. Try again. If error condition
    ERROR: persists, run the same command again with argument --log, contact Nordic
    ERROR: Semiconductor and provide the generated log.log file to them.
    FATAL ERROR: command exited with status 33: nrfjprog --program 'c:\Users\TSP_M1\nrf5340_audio_demo6\build\zephyr\zephyr.hex' --sectorerase --verify -f NRF53 --coprocessor CP_APPLICATION --snr 821007475
    Try to recover your device:
    # Net core first
    nrfjprog --recover -f nrf53 --coprocessor CP_NETWORK --log
    # App core second
    nrfjprog --recover -f nrf53 --coprocessor CP_APPLICATION --log
    If that still fails, please share the updated .log file(s)
    Håkon
  • Thank you, Mr. Haakon.
    Executing two commands will result in an error.
    The error display is
    (base) PS C:\Users\TSP_M1\nrf5340_audio_demo6\tools> nrfjprog --recover -f nrf53 --coprocessor CP_NETWORK --log
    [error] [Client] - Encountered error -102: Command enable_coprocessor executed for 78 milliseconds with result -102
    Failed to enable coprocessor with unknown error.
    (base) PS C:\Users\TSP_M1\nrf5340_audio_demo6\tools> nrfjprog --recover -f nrf53 --coprocessor CP_APPLICATION --log
    [error] [Client] - Encountered error -102: Command select_coprocessor executed for 62 milliseconds with result -102
    I will share the .log at that time.
    10123.log.log
  • I found out a little bit about the cause.
    The customer's board has the DCCD terminal, DECD terminal, DCC terminal, and DECR terminal open.
    Even though I was in LDO mode, the following settings were not made in the prj.conf file.
    CONFIG_BOARD_ENABLE_DCDC_APP=n
    CONFIG_BOARD_ENABLE_DCDC_NET=n
    Therefore, it seems to be Resetloop.
    Please tell me how to cancel Resetloop.
    You can try to run this batch file, while powering on/off your custom board.
    :loop
    goto loop
    Save this to "nrfjprog_recover_loop.bat" and run this.
    This will continuously run the recover process while you power cycle your custom board. It can usually take a minute or two, but you are usually able to recover your board this way.
    Could you try this and report back?
    Håkon
  • Deer Håkon
    Thank you for answering.
    You can now write in the following way before receiving an answer.
    1.Add the following to prj.conf
    2. Run the build
    3.Run SEGGER's J-Link Commander
    ⇒Check the voltage value of the board
    4. After running Connect at the above prompt, select nRF5340 on the selection screen
    5. Execute writing
