Buzzer beep in Immediate Alert Service
Hi. I am adding buzzer beeping in Immediate Alert Service of ble_app_proximity example. Event thought Immediate Alert signal is sent from nRF Master Control, there is no beeping. I would like to know the reason and how to solve it.
The code is as follows: (1) In alert_signal() function:
    static void alert_signal(uint8_t alert_level) {
    uint32_t err_code;
    switch (alert_level) {
        case BLE_CHAR_ALERT_LEVEL_NO_ALERT:
            err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
	    pwm_stop();
        case BLE_CHAR_ALERT_LEVEL_MILD_ALERT:
            err_code = bsp_indication_set(BSP_INDICATE_ALERT_0);
	    pwm_start();
        case BLE_CHAR_ALERT_LEVEL_HIGH_ALERT:
            err_code = bsp_indication_set(BSP_INDICATE_ALERT_3);
	    pwm_start();
            // No implementation needed.
(2) In main() function, before calling advertising_start(), the following statement is added:
init_pwm(1000L, BUZZER);
(3) The following C file is linked:
APP_PWM_INSTANCE(PWM1, 1);                   // Create the instance "PWM1" using TIMER1.
static volatile bool ready_flag;            // A flag indicating PWM status.
void pwm_ready_callback(uint32_t pwm_id) {   // PWM callback function
    ready_flag = true;
uint32_t init_pwm(uint32_t perior, uint8_t pin) {
	uint32_t err_code = 0;
	nrf_gpio_pin_dir_set(pin, NRF_GPIO_PIN_DIR_OUTPUT);
	nrf_gpio_pin_clear(pin);
	/* 2-channel PWM, 200Hz, output on DK LED pins. */
	app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(perior, pin);
	pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_LOW;
    /* Initialize and enable PWM. */
    err_code = app_pwm_init(&PWM1, &pwm1_cfg, pwm_ready_callback);
	app_pwm_enable(&PWM1);
	while (app_pwm_channel_duty_set(&PWM1, 0, 50) == NRF_ERROR_BUSY);
    return err_code;
void pwm_start(void) {
	nrf_drv_gpiote_out_task_enable(BUZZER);
void pwm_stop(void) {
	 ret_code_t err_code;
	app_pwm_disable(&PWM1);
	nrf_drv_gpiote_out_task_disable(BUZZER);
	err_code = app_pwm_uninit(&PWM1);
	nrf_gpio_cfg_output(BUZZER);
	nrf_gpio_pin_clear(BUZZER);
According to Immediate Alert signal, LED is indicated. So, the Immediate Alert signal is received. Also, when the last comment in int_pwm() function is uncommented, by calling init_pwm() the buzzer is beeped. But after connection is established, the beeping is stopped. This seems to indicate that some configuration is incorrect. But I am not sure what kind of setting should be modified.
I didn't modify ble_app_proximity except alert_signal() function. That is, ble_app_proximity itself works well. The program is compiled by Keil using SDK 9.0. It runs on SoftDevice S110 8.0. I tried to use SDK10.0, but the result was same.
I would appreciate having your helps and suggestion. Best regards.
  • Hi shin
    Try the following code where I have combined PWM with ble_app_proximity example. It is for nRF51 SDK 10.0.0 and PCA10028
    ble_app_proximity_with_pwm.zip
    Connect to the device and write 0x00, 0x01 or 0x02 to the Immediate Alert Service in order to change the alert level and to change PWM duty cycle on LED_4
    Update 10.2.2016 Below is a similar example, but with 4x PWM channels connected to 4 LEDs on the nRF51-DK board. All PWMs are generated with the app_pwm library which uses TIMER+PPI+GPIOTE peripherals. Use the same procedure as before to change the duty cycle of the PWMs.
    ble_app_proximity_with_4xPWMs.zip
  • @shin Just to mention again, I am using the ble_app_proximity_with_pwm example for S110 8.0.0 softdevice and nRF51 SDK 10.0.0. Android 5.0, but that should not matter, as long as you have Android 4.3+
    First, go to Bluetooth settings, disable bluetooth and enable it again.
    Try first to use the nRFToolbox - proximity app. Connect to the device, wait for the device to pair to the phone and for the lock to open. LED_4 on the nRF51-DK board should give weak light, indicating NO ALERT (0x00). Click FIND ME button on the app in order to send HIGH ALERT (0x02) to the device, where LED_4 should fully light up.
    A few times it has been necessary for me to restart my Android phone to have the Bluetooth hardware up and running. Try that if the nRFToolbox and/or Master Control Panel are not working
