ncs-esb-ble-mpsl-demo hard faults on nRF5340
I have compiled and run Torbjørn Øvrebekk's ESB MPSL sample (github.com/.../ncs-esb-ble-mpsl-demo) for the nRF5340, which works great, but the cpunet on the PTX side hard faults randomly after some hours. I made the requisite change to 'esb_peripherals.h' as indicated by the warning message printed on the console. No other changes were made. I have tried nRF Connect SDK 2.6.0 and 2.6.1.
[03:00:30.626,678] <inf> rpc_net: Send TX packet, data 0 0x31, len 8
[03:00:30.627,166] <inf> rpc_net: ESB TX success
[03:00:30.627,319] <dbg> rpc_net: rpc_esb_event_send: evt send ok
[00:00:00.000,488] <dbg> rpc_net: serialization_init: nRF RPC init begin
[00:00:00.101,074] <err> nrf_rpc_ipc: IPC endpoint bond timeout
[00:00:00.101,104] <err> NRF_RPC: Failed to initialize transport, err: -32
[00:00:01.101,226] <err> NRF_RPC: Not all groups are ready to use.
*** Booting nRF Connect SDK v3.5.99-ncs1 ***
[00:00:01.101,348] <inf> main: ESB BLE Multiprotocol Example - Netcore project
[00:00:01.101,409] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
36 f0 e5 0e 87 68 48 fb 02 fd 9f 82 cc 32 e5 7b |6....hH. .....2.{
91 b1 5c ed |..\.
[00:00:01.101,806] <inf> bt_hci_raw: Bluetooth enabled in RAW mode
[00:00:01.102,050] <wrn> main: Change ESB_EVT_IRQ and ESB_EVT_IRQHandler in esb_peripherals.h to use SWI3 instead of SWI0!
  • Hi John
    Are you just running the default example, without making any changes to the appcore or netcore projects?
    Are you running the code on a standard nRF5340DK?
    Do you not get any more logging output from the netcore when the crash occurs?
    Best regards
    Torbjørn
  • Default example, no changes except as noted regarding SWI3. I tried both a standard build and with debug optimizations, in an attempt to set a breakpoint, but I haven't been able to figure out how to make that happen yet. I will run it again this evening to get more output for you. Each time I've run it before, I failed to enable logging in the serial terminal, and then accidentally resized the terminal and lost my output before taking a screenshot.
  • [00:41:01.386,718] <dbg> rpc_net: rpc_esb_event_send: evt send ok
    [00:41:02.883,148] <inf> rpc_net: Send TX packet, data 0 0x69, len 8
    [00:41:02.883,636] <inf> rpc_net: ESB TX success
    [00:41:02.883,789] <dbg> rpc_net: rpc_esb_event_send: evt send ok
    [00:41:04.383,819] <inf> rpc_net: Send TX packet, data 0 0x6a, len 8
    [00:41:04.384,307] <inf> rpc_net: ESB TX success
    [00:41:04.384,460] <dbg> rpc_net: rpc_esb_event_send: evt send ok
    [00:41:05.884,490] <inf> rpc_net: Send TX packet, data 0 0x6b, len 8
    ASSERTION FAIL @ WEST_TOPDIR/external/zephyr/include/zephyr/spinlock.h:136
    [00:41:05.884,674] <err> os: ***** HARD FAULT *****
    [00:41:05.884,704] <err> os: Fault escalation (see below)
    [00:41:05.884,704] <err> os: ARCH_EXCEPT with reason 4
    [00:41:05.884,735] <err> os: r0/a1: 0x00000004 r1/a2: 0x00000088 r2/a3: 0x00000002
    [00:41:05.884,765] <err> os: r3/a4: 0x21002358 r12/ip: 0x00000010 r14/lr: 0x0102c7ad
    [00:41:05.884,765] <err> os: xpsr: 0x4100001c
    [00:41:05.884,765] <err> os: Faulting instruction address (r15/pc): 0x0103038c
    [00:41:05.884,826] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
    [00:41:05.884,857] <err> os: Fault during interrupt handling
    [00:41:05.884,887] <err> os: Current thread: 0x21003fc0 (unknown)
    ÿ[00:00:00.000,488] <dbg> rpc_net: serialization_init: nRF RPC init begin
    *** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
    91 b1 5c ed |..\.
  • Hi John
    What about the hardware? Are you using a normal devkit, or some other board?
    Best regards
    Torbjørn
  • both sides are just a stock nRF5340DK, with a small whip antenna attached
