I have an nrf52833 that interfaces with an external flash module. It is configured to store mcuboot's secondary partition. I am able to write the secondary image and after it swaps, it does boot into this image correctly, but I am not able to confirm the image.
I am using the dfu target api for the firmware image and the mcuboot image control api to confirm the image. The function ` boot_write_img_confirmed` returns 0 which supposedly means that it was successful, however reading the `mcuboot_swap_type` function still returns `revert` and the next time the chip is reset, it reverts to the old image.
I am using this same process on the Laird P100 which also uses an external flash and it works correctly.
I found other posts with this issue where the solution was switching from a dynamic partition to a static one. I am indeed already using a static partition, although it might be another related issue.
Here is the output of `west build -t partition_manager_report`
external_flash (0x80000 - 512kB): +------------------------------------------+ | 0x0: external_flash (0x80000 - 512kB) | | 0x0: mcuboot_secondary (0x6e000 - 440kB) | +------------------------------------------+ flash_primary (0x80000 - 512kB): +--------------------------------------------------+ | 0x0: mcuboot (0x12000 - 72kB) | +---0x12000: mcuboot_primary (0x6e000 - 440kB)-----+ | 0x12000: mcuboot_pad (0x200 - 512B) | +---0x12200: mcuboot_primary_app (0x6de00 - 439kB)-+ | 0x12200: app (0x6de00 - 439kB) | +--------------------------------------------------+ sram_primary (0x20000 - 128kB): +--------------------------------------------+ | 0x20000000: sram_primary (0x20000 - 128kB) | +--------------------------------------------+
and here's the full `pm_static.yml`
mcuboot:
address: 0x0
end_address: 0x12000
placement:
before:
- mcuboot_primary
region: flash_primary
app:
address: 0x12200
end_address: 0x80000
mcuboot_pad:
address: 0x12000
end_address: 0x12200
mcuboot_primary:
address: 0x12000
orig_span: &id001
- mcuboot_pad
sharers: 0x1
span: *id001
mcuboot_primary_app:
address: 0x12200
orig_span: &id002
- app
span: *id002
sram_primary:
address: 0x20000000
end_address: 0x20020000
region: sram_primary
external_flash:
address: 0x0
region: external_flash
device: AT25X
mcuboot_secondary:
address: 0x0
device: AT25X
Here are the mcuboot configs that we are using
CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_PERIOD=6000 CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_MAX_SKIP=20 CONFIG_MAIN_STACK_SIZE=10240 CONFIG_FLASH=y CONFIG_SPI=y CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=y CONFIG_BOOT_SIGNATURE_KEY_FILE="@MCUBOOT_KEY_FILE@" CONFIG_CLOCK_CONTROL_NRF=y CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y CONFIG_REBOOT=y CONFIG_MULTITHREADING=y CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_SPI_NOR_IDLE_IN_DPD=y CONFIG_PM=n CONFIG_PM_DEVICE=y CONFIG_CPP=y CONFIG_STD_CPP20=y CONFIG_RTT_CONSOLE=n CONFIG_LOG_MODE_MINIMAL=n CONFIG_CONSOLE=y CONFIG_LOG_PRINTK=y CONFIG_USE_SEGGER_RTT=y CONFIG_STDOUT_CONSOLE=y CONFIG_LOG_BACKEND_RTT=y CONFIG_LOG_BACKEND_UART=n CONFIG_DEBUG=y CONFIG_LOG=y CONFIG_LOG_MODE_IMMEDIATE=y # former CONFIG_MODE_MINIMAL ### Ensure Zephyr logging changes don't use more resources CONFIG_LOG_DEFAULT_LEVEL=3 CONFIG_THREAD_NAME=y ### Decrease footprint by ~4 KB in comparison to CBPRINTF_COMPLETE=y CONFIG_CBPRINTF_NANO=y CONFIG_BOOT_UPGRADE_ONLY=n CONFIG_DISABLE_FLASH_PATCH=y CONFIG_BOOT_BOOTSTRAP=n CONFIG_FPROTECT=n CONFIG_BOOT_SWAP_SAVE_ENCTLV=n CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
It is configured using CMake and added like so:
set(mcuboot_CONF_FILE
${gen_dir}/mcuboot.conf
