Problems with BLE Mesh in a C++ project.
I am using NCS Connect SDK version 2.6.0
I am trying to create an array of models and found a problem with using Zephry macros in C++ projects. My main.cpp is as below
#include <zephyr/bluetooth/mesh.h>
        printk("Hello Worlds! %s\n", CONFIG_BOARD);
       static const struct bt_mesh_model models[] =
            BT_MESH_MODEL_CFG_SRV,
        return 0;
BT_MESH_MODEL_CFG_SRV is defined in cfg_srv.h as
#define BT_MESH_MODEL_CFG_SRV	\
		BT_MESH_MODEL_CNT_CB(BT_MESH_MODEL_ID_CFG_SRV,	\
			     bt_mesh_cfg_srv_op, NULL,	\
			     NULL, 1, 0, &bt_mesh_cfg_srv_cb)
BT_MESH_MODEL_CNT_CB is defined in access.h
 *  @brief Composition data SIG model entry with callback functions
 *	   with specific number of keys & groups.
 * This macro uses compound literal feature of C99 standard and thus is available only from C,
 * not C++.
 *  @param _id        Model ID.
 *  @param _op        Array of model opcode handlers.
 *  @param _pub       Model publish parameters.
 *  @param _user_data User data for the model.
 *  @param _keys      Number of keys that can be bound to the model.
 *		      Shall not exceed @kconfig{CONFIG_BT_MESH_MODEL_KEY_COUNT}.
 *  @param _grps      Number of addresses that the model can be subscribed to.
 *		      Shall not exceed @kconfig{CONFIG_BT_MESH_MODEL_GROUP_COUNT}.
 *  @param _cb        Callback structure, or NULL to keep no callbacks.
#define BT_MESH_MODEL_CNT_CB(_id, _op, _pub, _user_data, _keys, _grps, _cb)	\
	.id = (_id),								\
	.pub = _pub,								\
	.keys = (uint16_t []) BT_MESH_MODEL_KEYS_UNUSED(_keys),			\
	.keys_cnt = _keys,							\
	.groups = (uint16_t []) BT_MESH_MODEL_GROUPS_UNASSIGNED(_grps),		\
	.groups_cnt = _grps,							\
	BT_MESH_MODEL_UUIDS_UNASSIGNED()					\
	.op = _op,								\
	.cb = _cb,								\
	.user_data = _user_data,						\
Which is where the problem lies. The macro is defined for C language only and cannot be used with a C++ compiler as it uses compound literals.
Does anyone have any suggestion to resolve this impase
Appreciate any suggestions.
Thanks
