wanted to do dfu ota from.net maui
hi there i hope you are doing fine and best of your health. actually i am developing the custom app to communicate with nrf 52840 soc device through bluetooth, which is working fine at the moment. now i wanted to perform dfu.. so can you please tell me any compatible library for that. plus i currently u am using Laerdal.Dfu but it gives error as soon as i upload the zip file and log returns this
[DOTNET] File selected: /data/data/com.companyname.bluetoothcourse/cache/2203693cc04e0be7f4f024d5f9499e13/1c8e89218872463aa3de5e71a30f02d6/dfu_application.zip
[0:] File path exists: True
[0:] Attempting to start DFU process...
[ViewRootImpl@69f7d86[IntermediateActivity]] stopped(false) old=true
[ViewRootImpl@69f7d86[IntermediateActivity]] stopped(false) old=false
[SurfaceControl] assignNativeObject: nativeObject = 0 Surface(name=null)/@0x3f2fe3 / android.view.SurfaceControl.readFromParcel:1121 android.view.IWindowSession$Stub$Proxy.relayout:1830 android.view.ViewRootImpl.relayoutWindow:9005 android.view.ViewRootImpl.performTraversals:3360 android.view.ViewRootImpl.doTraversal:2618 android.view.ViewRootImpl$TraversalRunnable.run:9971 android.view.Choreographer$CallbackRecord.run:1010 android.view.Choreographer.doCallbacks:809 android.view.Choreographer.doFrame:744 android.view.Choreographer$FrameDisplayEventReceiver.run:995
[SurfaceControl] assignNativeObject: nativeObject = 0 Surface(name=null)/@0x5cb7647 / android.view.SurfaceControl.readFromParcel:1121 android.view.IWindowSession$Stub$Proxy.relayout:1840 android.view.ViewRootImpl.relayoutWindow:9005 android.view.ViewRootImpl.performTraversals:3360 android.view.ViewRootImpl.doTraversal:2618 android.view.ViewRootImpl$TraversalRunnable.run:9971 android.view.Choreographer$CallbackRecord.run:1010 android.view.Choreographer.doCallbacks:809 android.view.Choreographer.doFrame:744 android.view.Choreographer$FrameDisplayEventReceiver.run:995
[ViewRootImpl@69f7d86[IntermediateActivity]] Relayout returned: old=(0,0,1080,2340) new=(0,0,1080,2340) req=(1080,2340)4 dur=11 res=0x1 s={false 0} ch=false fn=-1
[bluetoothcours] Explicit concurrent copying GC freed 22003(1059KB) AllocSpace objects, 10(624KB) LOS objects, 49% free, 5051KB/10102KB, paused 110us total 34.109ms
[ViewRootImpl@3983e16[MainActivity]] stopped(false) old=true
[System] A resource failed to call close.
[ViewRootImpl@3983e16[MainActivity]] stopped(false) old=false
[SurfaceControl] assignNativeObject: nativeObject = 0 Surface(name=null)/@0x3a32195 / android.view.SurfaceControl.readFromParcel:1121 android.view.IWindowSession$Stub$Proxy.relayout:1840 android.view.ViewRootImpl.relayoutWindow:9005 android.view.ViewRootImpl.performTraversals:3360 android.view.ViewRootImpl.doTraversal:2618 android.view.ViewRootImpl$TraversalRunnable.run:9971 android.view.Choreographer$CallbackRecord.run:1010 android.view.Choreographer.doCallbacks:809 android.view.Choreographer.doFrame:744 android.view.Choreographer$FrameDisplayEventReceiver.run:995
[ViewRootImpl@3983e16[MainActivity]] Relayout returned: old=(0,0,1080,2340) new=(0,0,1080,2340) req=(1080,2340)0 dur=20 res=0x7 s={true 488039866368} ch=true fn=-1
[DfuBaseService] DFU service created. Version: 2.3.0
Thread started: #17
[0:] DFU process started successfully.
[ViewRootImpl@69f7d86[IntermediateActivity]] Relayout returned: old=(0,0,1080,2340) new=(0,0,1080,2340) req=(1080,2340)8 dur=10 res=0x1 s={false 0} ch=false fn=-1
[ViewRootImpl@3983e16[MainActivity]] MSG_WINDOW_FOCUS_CHANGED 1 1
[InputMethodManager] prepareNavigationBarInfo() DecorView@9dac42e[MainActivity]
[InputMethodManager] getNavigationBarColor() -855310
[InputMethodManager] Starting input: tba=com.companyname.bluetoothcourse ic=null mNaviBarColor -855310 mIsGetNaviBarColorSuccess true , NavVisible : true , NavTrans : false
[InputMethodManager] startInputInner - Id : 0
[InputMethodManager] startInputInner - mService.startInputOrWindowGainedFocus
[InputTransport] Input channel constructed: 'ClientS', fd=91
[SurfaceControl] nativeRelease nativeObject s[488271482528]
[SurfaceControl] nativeRelease nativeObject e[488271482528]
[SurfaceControl] nativeRelease nativeObject s[488271482432]
[SurfaceControl] nativeRelease nativeObject e[488271482432]
[DfuBaseService] Starting DFU service in foreground
[ViewRootImpl@69f7d86[IntermediateActivity]] dispatchDetachedFromWindow
[InputTransport] Input channel destroyed: '755b839', fd=86
[DfuArchiveInputStream] Manifest failed to be parsed. Did you add
[DfuArchiveInputStream] -keep class no.nordicsemi.android.dfu.** { *; }
[DfuArchiveInputStream] to your proguard rules?
[DfuBaseService] An exception occurred while calculating file size
[DfuBaseService] java.io.IOException: The ZIP file must contain an Application, a Soft Device and/or a Bootloader.
[DfuBaseService] at no.nordicsemi.android.dfu.internal.ArchiveInputStream.<init>(ArchiveInputStream.java:269)
[DfuBaseService] at no.nordicsemi.android.dfu.DfuBaseService.openInputStream(DfuBaseService.java:1457)
[DfuBaseService] at no.nordicsemi.android.dfu.DfuBaseService.onHandleIntent(DfuBaseService.java:1201)
[DfuBaseService] at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:77)
[DfuBaseService] at android.os.Handler.dispatchMessage(Handler.java:106)
[DfuBaseService] at android.os.Looper.loop(Looper.java:246)
[DfuBaseService] at android.os.HandlerThread.run(HandlerThread.java:67)
Thread finished: #17
[DfuBaseService] DFU service destroyed
    The Laerdal.Dfu is a third party library that we have no experience with, so we are unfortunately not ablet to support this directly. Perhaps someone from the community has some input? (That said, the errors seem like generic Android errors, so I expect you should be able to debug it if you are used to working with Android).
  • but it still throwing this exception which i am not been able to understand or fix it
    Reading the bold text I suspect you are not using a valid zip file? But again, this library is not made by us nor have we worked with it, so I am not able to say anything specific, unfortunately.
