I‘m tring to run nRF5340 Audio applications with two nRF5340 Audio boards, following at: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.6.0/nrf/applications/nrf5340_audio/doc/building.html
I met two problems:
Gateway Device:
*** Booting nRF Connect SDK v3.5.99-ncs1 *** GW [00:00:00.270,294] <inf> board_version: Compatible board/HW version found: 1.0.0 GW [00:00:00.294,738] <inf> audio_usb: Ready for USB host to send/receive. GW [00:00:00.294,769] <inf> fw_info: nRF5340 Audio nRF5340 Audio DK cpuapp NCS base version: 2.6.0 Cmake run : Wed May 15 17:20:18 2024 GW [00:00:00.294,769] <inf> fw_info: ------- DEBUG BUILD ------- GW [00:00:00.294,769] <inf> fw_info: Compiled for GATEWAY device GW [00:00:00.311,920] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 5.4 (0x0d), Revision 8591 GW [00:00:00.312,103] <inf> bt_mgmt: Local identity addr: CD:28:C4:0F:1F:AE (random) GW [00:00:00.313,018] <err> bt_bap_unicast_client: bt_iso_cig_create failed: -134 GW [00:00:00.313,049] <err> unicast_client: Failed to create unicast group: -134 GW [00:00:00.313,049] <err> main: ERR_CHK Err_code: [-134] @ line: 499 GW [00:00:00.313,049] <err> os: r0/a1: 0x00000003 r1/a2: 0x0000000b r2/a3: 0x0000000a GW [00:00:00.313,079] <err> os: r3/a4: 0x0005e54f r12/ip: 0x200039d8 r14/lr: 0x0005e5d9 GW [00:00:00.313,079] <err> os: xpsr: 0x69100000 GW [00:00:00.313,079] <err> os: s[ 0]: 0x20001c10 s[ 1]: 0x0005e773 s[ 2]: 0x20002d88 s[ 3]: 0x00000004 GW [00:00:00.313,079] <err> os: s[ 4]: 0x20002ef8 s[ 5]: 0x0003e449 s[ 6]: 0x00000000 s[ 7]: 0x2001ecc0 GW [00:00:00.313,110] <err> os: s[ 8]: 0x2001ec90 s[ 9]: 0xffffffff s[10]: 0xffffffff s[11]: 0x0005e7bf GW [00:00:00.313,110] <err> os: s[12]: 0x00007651 s[13]: 0x0006f36c s[14]: 0xffffff7a s[15]: 0x000001f3 GW [00:00:00.313,110] <err> os: fpscr: 0x2001ec90 GW [00:00:00.313,110] <err> os: Faulting instruction address (r15/pc): 0x00003afa GW [00:00:00.313,140] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0 GW [00:00:00.313,140] <err> os: Current thread: 0x20005d38 (main) GW [00:00:00.313,171] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
Headset Left Device:
HL [00:00:00.269,958] <inf> board_version: Compatible board/HW version found: 1.0.0
HL [00:00:00.322,326] <inf> fw_info:
Cmake run : Wed May 15 17:06:53 2024
HL [00:00:00.322,326] <inf> fw_info: ------- DEBUG BUILD -------
HL [00:00:00.322,326] <inf> fw_info: HEADSET left device
HL [00:00:00.340,270] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 5.4 (0x0d), Revision 8591
HL [00:00:00.340,454] <inf> bt_mgmt: Local identity addr: C6:94:B2:0B:35:28 (random)
HL [00:00:00.341,217] <err> bt_ascs: Failed to register ISO server -134
HL [00:00:00.343,627] <wrn> bt_hci_core: opcode 0x2036 status 0x01
HL [00:00:00.343,627] <err> bt_mgmt_adv: Unable to create a connectable extended advertising set: -5
HL [00:00:00.343,627] <err> main: ERR_CHK Err_code: [-5] @ line: 531
HL [00:00:00.343,658] <err> os: r0/a1: 0x00000003 r1/a2: 0x0000000b r2/a3: 0x0000000a
HL [00:00:00.343,658] <err> os: r3/a4: 0x0005a0e9 r12/ip: 0x20002e90 r14/lr: 0x0005a173
HL [00:00:00.343,658] <err> os: xpsr: 0x69100000
HL [00:00:00.343,658] <err> os: s[ 0]: 0x200016ec s[ 1]: 0x0005a30d s[ 2]: 0x2001cbd8 s[ 3]: 0x00000004
HL [00:00:00.343,688] <err> os: s[ 4]: 0x00000000 s[ 5]: 0x00000000 s[ 6]: 0x00039f7d s[ 7]: 0x2001cc08
HL [00:00:00.343,688] <err> os: s[ 8]: 0x2001cbd8 s[ 9]: 0xffffffff s[10]: 0xffffffff s[11]: 0x0005a359
HL [00:00:00.343,688] <err> os: s[12]: 0x00000000 s[13]: 0x0006aebc s[14]: 0xfffffffb s[15]: 0x00000213
HL [00:00:00.343,688] <err> os: fpscr: 0x00039f7d
HL [00:00:00.343,719] <err> os: Faulting instruction address (r15/pc): 0x00003da6
HL [00:00:00.343,719] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
HL [00:00:00.343,750] <err> os: Current thread: 0x200049a8 (main)
HL [00:00:00.343,750] <err> error_handler: Caught system error -- reason 3. Entering infinite loop
The SDK version is 2.6.0. What could be causing this? Maybe should change some config_files?Thanks in advance.
