ble central and peripheral dfu +freertos DFU service not working
The device can be connected normally and can also be connected to a slave. But the DFU service is not working properly.
  • Hi Jon,
    That is very less information to give you any sensible suggestions for debugging. Can you please describe describe
    • Your current setup. Which nRF product you are using, which SDK version.
    • What changes you made to the application.
    • What is the serial logs you get?
    • What attempts of debugging have you made?
    • what does "not working" mean? Normally this can be interpreted in many ways, can you please be more specific on what is not working.
  • 3632.sdk_config.h8422.FreeRTOSConfig.h
     * Copyright (c) 2016 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdio.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include "nordic_common.h"
    #include "app_error.h"
    #include "ble_db_discovery.h"
    #include "app_timer.h"
    #include "app_util.h"
    #include "ble.h"
    #include "ble_gap.h"
    #include "ble_hci.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "ble_nus_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_ble_scan.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "ble_hrs_c.h"
    #include "ble_conn_state.h"
    #include "app.h"
    #include "crc.h"
    #include "ble_advertising.h"
    #include "nrf_ble_qwr.h"
    #include "ble_conn_params.h"
    #include "nrf_power.h"
    #if DFU_SUPPORT
    #include "nrf_bootloader_info.h"
    #include "ble_dfu.h"
    #include "FreeRTOS.h"
    #include "task.h"
    #include "queue.h"
    #include "nrf_sdh_freertos.h"
    #include "TaskRunConfig.h"
    /** @brief The maximum number of peripheral and central links combined. */
    #define NRF_BLE_LINK_COUNT              (NRF_SDH_BLE_PERIPHERAL_LINK_COUNT + NRF_SDH_BLE_CENTRAL_LINK_COUNT)
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
    #define DEVICE_NAME                     "MYtool"                            /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define APP_BLE_OBSERVER_PRIO   3                                       /**< BLE observer priority of the application. There is no need to modify this value. */
    #define APP_ADV_INTERVAL        64                                      /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION        0                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    extern QueueHandle_t      SendDebugMessageToPC_Queue;
    typedef struct
        bool           is_connected;
        ble_gap_addr_t address;
    } conn_peer_t;
    NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                        /**< BLE GATT Queue instance. */
                   NRF_SDH_BLE_CENTRAL_LINK_COUNT,
                   NRF_BLE_GQ_QUEUE_SIZE);
    NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
    NRF_BLE_QWRS_DEF(m_qwr, NRF_SDH_BLE_TOTAL_LINK_COUNT);                  /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                     /**< Advertising module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< Database discovery module instance. */
    NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
    BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE Nordic UART Service (NUS) client instance. */
    static volatile uint16_t  m_conn_handle_num_comp_central     = BLE_CONN_HANDLE_INVALID;  /**< Connection handle for the central that needs a numeric comparison button press. */
    static volatile uint16_t  m_conn_handle_num_comp_peripheral  = BLE_CONN_HANDLE_INVALID;  /**< Connection handle for the peripheral that needs a numeric comparison button press. */
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static conn_peer_t        m_connected_peers[NRF_BLE_LINK_COUNT];
    static char * roles_str[] =
        "INVALID_ROLE",
        "PERIPHERAL",
        "CENTRAL",
    void scan_start(void);
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
    /**@brief Function for handling asserts in the SoftDevice.
     * @details This function is called in case of an assert in the SoftDevice.
     * @warning This handler is only an example and is not meant for the final product. You need to analyze
     *          how your product is supposed to react in case of assert.
     * @param[in] line_num     Line number of the failing assert call.
     * @param[in] p_file_name  File name of the failing assert call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for handling Service Client errors.
    static void service_error_handler(uint32_t nrf_error)
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
            err_code = sd_ble_gap_disconnect(p_evt->conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
    /**@brief Function for handling errors from the Connection Parameters module.
    /**@brief Function for handling Scanning Module events.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        ret_code_t err_code;
        switch(p_scan_evt->scan_evt_id)
            case NRF_BLE_SCAN_EVT_FILTER_MATCH:
             case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                  err_code = p_scan_evt->params.connecting_err.err_code;
             } break;
             case NRF_BLE_SCAN_EVT_CONNECTED:
                  ble_gap_evt_connected_t const * p_connected =
                                   p_scan_evt->params.connected.p_connected;
                 // Scan is automatically stopped by the connection.
                 NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                          p_connected->peer_addr.addr[0],
                          p_connected->peer_addr.addr[1],
                          p_connected->peer_addr.addr[2],
                          p_connected->peer_addr.addr[3],
                          p_connected->peer_addr.addr[4],
                          p_connected->peer_addr.addr[5]
             } break;
             case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
                 NRF_LOG_INFO("Scan timed out.");
                 scan_start();
             } break;
    /**@brief Function for initializing the scanning and setting the filters.
    static void scan_init(void)
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.connect_if_match = true;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_ADDR_FILTER, false);
    /**@brief Function to start scanning. */
        ret_code_t ret;
        ret = nrf_ble_scan_start(&m_scan);
        APP_ERROR_CHECK(ret);
    #if DFU_SUPPORT
    /**@brief Handler for shutdown preparation.
     * @details During shutdown procedures, this function will be called at a 1 second interval
     *          untill the function returns true. When the function returns true, it means that the
     *          app is ready to reset to DFU mode.
     * @param[in]   event   Power manager event.
     * @retval  True if shutdown is allowed by this power manager handler, otherwise false.
    static bool app_shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_DFU:
                NRF_LOG_INFO("Power management wants to reset to DFU mode.");
                // YOUR_JOB: Get ready to reset into DFU mode
                // If you aren't finished with any ongoing tasks, return "false" to
                // signal to the system that reset is impossible at this stage.
                // Here is an example using a variable to delay resetting the device.
                // if (!m_ready_for_reset)
                //      return false;
                // else
                //    // Device ready to enter
                //    uint32_t err_code;
                //    err_code = sd_softdevice_disable();
                //    APP_ERROR_CHECK(err_code);
                //    err_code = app_timer_stop_all();
                // YOUR_JOB: Implement any of the other events available from the power management module:
                //      -NRF_PWR_MGMT_EVT_PREPARE_SYSOFF
                //      -NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
                //      -NRF_PWR_MGMT_EVT_PREPARE_RESET
                return true;
        NRF_LOG_INFO("Power management allowed to reset to DFU mode.");
        return true;
    //lint -esym(528, m_app_shutdown_handler)
    /**@brief Register application shutdown handler with priority 0.
    NRF_PWR_MGMT_HANDLER_REGISTER(app_shutdown_handler, 0);
    static void buttonless_dfu_sdh_state_observer(nrf_sdh_state_evt_t state, void * p_context)
        if (state == NRF_SDH_EVT_STATE_DISABLED)
            // Softdevice was disabled before going into reset. Inform bootloader to skip CRC on next boot.
            nrf_power_gpregret2_set(BOOTLOADER_DFU_SKIP_CRC);
            //Go to system off.
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
    /* nrf_sdh state observer. */
    NRF_SDH_STATE_OBSERVER(m_buttonless_dfu_state_obs, 0) =
        .handler = buttonless_dfu_sdh_state_observer,
    static void advertising_config_get(ble_adv_modes_config_t * p_config)
        memset(p_config, 0, sizeof(ble_adv_modes_config_t));
        p_config->ble_adv_fast_enabled  = true;
        p_config->ble_adv_fast_interval = APP_ADV_INTERVAL;
        p_config->ble_adv_fast_timeout  = APP_ADV_DURATION;
    static void disconnect(uint16_t conn_handle, void * p_context)
        UNUSED_PARAMETER(p_context);
        ret_code_t err_code = sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        if (err_code != NRF_SUCCESS)
            NRF_LOG_WARNING("Failed to disconnect connection. Connection handle: %d Error: %d", conn_handle, err_code);
            NRF_LOG_DEBUG("Disconnected connection handle %d", conn_handle);
    // YOUR_JOB: Update this code if you want to do anything given a DFU event (optional).
    /**@brief Function for handling dfu events from the Buttonless Secure DFU service
     * @param[in]   event   Event from the Buttonless Secure DFU service.
    static void ble_dfu_evt_handler(ble_dfu_buttonless_evt_type_t event)
        switch (event)
            case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE:
                NRF_LOG_INFO("Device is preparing to enter bootloader mode.");
                // Prevent device from advertising on disconnect.
                ble_adv_modes_config_t config;
                advertising_config_get(&config);
                config.ble_adv_on_disconnect_disabled = true;
                ble_advertising_modes_config_set(&m_advertising, &config);
                // Disconnect all other bonded devices that currently are connected.
                // This is required to receive a service changed indication
                // on bootup after a successful (or aborted) Device Firmware Update.
                uint32_t conn_count = ble_conn_state_for_each_connected(disconnect, NULL);
                NRF_LOG_INFO("Disconnected %d links.", conn_count);
            case BLE_DFU_EVT_BOOTLOADER_ENTER:
                // YOUR_JOB: Write app-specific unwritten data to FLASH, control finalization of this
                //           by delaying reset by reporting false in app_shutdown_handler
                NRF_LOG_INFO("Device will enter bootloader mode.");
            case BLE_DFU_EVT_BOOTLOADER_ENTER_FAILED:
                NRF_LOG_ERROR("Request to enter bootloader mode failed asynchroneously.");
                // YOUR_JOB: Take corrective measures to resolve the issue
                //           like calling APP_ERROR_CHECK to reset the device.
            case BLE_DFU_EVT_RESPONSE_SEND_ERROR:
                NRF_LOG_ERROR("Request to send a response to client failed.");
                APP_ERROR_CHECK(false);
                NRF_LOG_ERROR("Unknown event from ble_dfu_buttonless.");
    #if DFU_SUPPORT
        uint32_t           err_code;
        ble_dfu_buttonless_init_t dfus_init = {0};
    #if DFU_SUPPORT
        dfus_init.evt_handler = ble_dfu_evt_handler;
        err_code = ble_dfu_buttonless_init(&dfus_init);
    /**@brief Function for handling characters received by the Nordic UART Service (NUS).
     * @details This function takes a list of characters of length data_len and prints the characters out on UART.
     *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    /**@brief Callback handling Nordic UART Service (NUS) client events.
     * @details This function is called to notify the application of NUS client events.
     * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
     * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
        switch (p_ble_nus_evt->evt_type)
            case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_INFO("Discovery complete.");
                err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
                err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
                NRF_LOG_INFO("Connected to device with Nordic UART Service.");
            case BLE_NUS_C_EVT_NUS_TX_EVT:
                ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            case BLE_NUS_C_EVT_DISCONNECTED:
                NRF_LOG_INFO("Disconnected.");
                scan_start();
    /**@brief Function for checking whether a link already exists with a newly connected peer.
     * @details This function checks whether the newly connected device is already connected.
     * @param[in]   p_connected_evt Bluetooth connected event.
     * @return                      True if the peer's address is found in the list of connected peers,
     *                              false otherwise.
    static bool is_already_connected(ble_gap_addr_t const * p_connected_adr)
        for (uint32_t i = 0; i < NRF_BLE_LINK_COUNT; i++)
            if (m_connected_peers[i].is_connected)
                if (m_connected_peers[i].address.addr_type == p_connected_adr->addr_type)
                    if (memcmp(m_connected_peers[i].address.addr,
                               p_connected_adr->addr,
                               sizeof(m_connected_peers[i].address.addr)) == 0)
                        return true;
        return false;
    /** @brief Function for handling a numeric comparison match request. */
    static void on_match_request(uint16_t conn_handle, uint8_t role)
        // Mark the appropriate conn_handle as pending. The rest is handled on button press.
        NRF_LOG_INFO("Press Button 1 to confirm, Button 2 to reject");
        if (role == BLE_GAP_ROLE_CENTRAL)
            m_conn_handle_num_comp_central = conn_handle;
        else if (role == BLE_GAP_ROLE_PERIPH)
            m_conn_handle_num_comp_peripheral = conn_handle;
    /**@brief Function for assigning new connection handle to the available instance of QWR module.
     * @param[in] conn_handle New connection handle.
    static void multi_qwr_conn_handle_assign(uint16_t conn_handle)
            if (m_qwr[i].conn_handle == BLE_CONN_HANDLE_INVALID)
                ret_code_t err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr[i], conn_handle);
    /**@brief Function for handling BLE Stack events that are common to both the central and peripheral roles.
     * @param[in] conn_handle Connection Handle.
     * @param[in] p_ble_evt  Bluetooth stack event.
    static void on_ble_evt(uint16_t conn_handle, ble_evt_t const * p_ble_evt)
        char        passkey[BLE_GAP_PASSKEY_LEN + 1];
        uint16_t    role = ble_conn_state_role(conn_handle);
            case BLE_GAP_EVT_CONNECTED:
                m_connected_peers[conn_handle].is_connected = true;
                m_connected_peers[conn_handle].address = p_ble_evt->evt.gap_evt.params.connected.peer_addr;
                multi_qwr_conn_handle_assign(conn_handle);
                memset(&m_connected_peers[conn_handle], 0x00, sizeof(m_connected_peers[0]));
                NRF_LOG_INFO("%s: BLE_GAP_EVT_SEC_PARAMS_REQUEST", nrf_log_push(roles_str[role]));
            case BLE_GAP_EVT_PASSKEY_DISPLAY:
                memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, BLE_GAP_PASSKEY_LEN);
                passkey[BLE_GAP_PASSKEY_LEN] = 0x00;
                NRF_LOG_INFO("%s: BLE_GAP_EVT_PASSKEY_DISPLAY: passkey=%s match_req=%d",
                             nrf_log_push(roles_str[role]),
                             nrf_log_push(passkey),
                             p_ble_evt->evt.gap_evt.params.passkey_display.match_request);
                if (p_ble_evt->evt.gap_evt.params.passkey_display.match_request)
                    on_match_request(conn_handle, role);
            case BLE_GAP_EVT_AUTH_KEY_REQUEST:
                NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_KEY_REQUEST", nrf_log_push(roles_str[role]));
            case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
                NRF_LOG_INFO("%s: BLE_GAP_EVT_LESC_DHKEY_REQUEST", nrf_log_push(roles_str[role]));
             case BLE_GAP_EVT_AUTH_STATUS:
                 NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                              p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                              p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                              p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                              *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                              *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
                ret_code_t err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys);
            } break;
                // No implementation needed.
    /**@brief Function for handling BLE Stack events that are related to central application.
     * @details This function keeps the connection handles of central application up-to-date. It
     * parses scanning reports, initiates a connection attempt to peripherals when a target UUID
     * is found, and manages connection parameter update requests. Additionally, it updates the status
     * of LEDs used to report the central application's activity.
     * @note        Since this function updates connection handles, @ref BLE_GAP_EVT_DISCONNECTED events
     *              must be dispatched to the target application before invoking this function.
    static void on_ble_central_evt(ble_evt_t const * p_ble_evt)
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        ble_gap_evt_adv_report_t const * p_adv_report = &p_ble_evt->evt.gap_evt.params.adv_report;
        BaseType_t xHigherPriorityTaskWoken = pdFALSE;
        SendToHost	ScanEchoResData = {0};
        uint8_t  xQueueBuffer[SendDebugMessageToPC_QueueLEN] = {0};
            // Upon connection, check which peripheral is connected (HR or RSC), initiate DB
            //  discovery, update LEDs status, and resume scanning, if necessary.
                // start discovery of services. The NUS Client waits for a discovery result
                err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
                if (ble_conn_state_central_conn_count() < NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                    scan_start();
                sd_ble_gap_rssi_start(p_gap_evt->conn_handle, 0, 0);
            } break; // BLE_GAP_EVT_CONNECTED
            // Upon disconnection, reset the connection handle of the peer that disconnected, update
            // the status of LEDs, and start scanning again.
                NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                             p_gap_evt->params.disconnected.reason);
                    scan_start();
            } break; // BLE_GAP_EVT_DISCONNECTED
            case BLE_GAP_EVT_TIMEOUT:
                // Timeout for scanning is not specified, so only connection attemps can time out.
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_DEBUG("CENTRAL: Connection Request timed out.");
            } break;
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accept parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                            &p_gap_evt->params.conn_param_update_request.conn_params);
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
                NRF_LOG_DEBUG("CENTRAL: GATT Client Timeout.");
            case BLE_GATTS_EVT_TIMEOUT:
                NRF_LOG_DEBUG("CENTRAL: GATT Server Timeout.");
            case BLE_GAP_EVT_ADV_REPORT:
    /**@brief Function for handling BLE Stack events that involves peripheral applications. Manages the
     * LEDs used to report the status of the peripheral applications.
    static void on_ble_peripheral_evt(ble_evt_t const * p_ble_evt)
                NRF_LOG_INFO("PERIPHERAL: Connected, handle %d.", p_ble_evt->evt.gap_evt.conn_handle);
                NRF_LOG_INFO("PERIPHERAL: Disconnected, handle %d, reason 0x%x.",
                             p_ble_evt->evt.gap_evt.params.disconnected.reason);
                NRF_LOG_DEBUG("PERIPHERAL: GATT Client Timeout.");
                NRF_LOG_DEBUG("PERIPHERAL: GATT Server Timeout.");
        uint32_t err_code;
        // Prepare wakeup buttons.
    #if DFU_SUPPORT
        //Disable SoftDevice. It is required to be able to write to GPREGRET2 register (SoftDevice API blocks it).
        //GPREGRET2 register holds the information about skipping CRC check on next boot.
        err_code = nrf_sdh_disable_request();
    #else
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                 sleep_mode_enter();
        uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
        if (    (p_ble_evt->header.evt_id == BLE_GAP_EVT_CONNECTED)
            &&  (is_already_connected(&p_ble_evt->evt.gap_evt.params.connected.peer_addr)))
            NRF_LOG_INFO("%s: Already connected to this device as %s (handle: %d), disconnecting.",
                         (role == BLE_GAP_ROLE_PERIPH) ? "PERIPHERAL" : "CENTRAL",
                         (role == BLE_GAP_ROLE_PERIPH) ? "CENTRAL"    : "PERIPHERAL",
                         conn_handle);
            (void)sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            // Do not process the event further.
            return;
        on_ble_evt(conn_handle, p_ble_evt);
            // Manages peripheral LEDs.
            on_ble_peripheral_evt(p_ble_evt);
        else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
            on_ble_central_evt(p_ble_evt);
    /**@brief Function for initializing the Nordic UART Service (NUS) client. */
    static void nus_c_init(void)
        ble_nus_c_init_t init;
        init.evt_handler   = ble_nus_c_evt_handler;
        init.error_handler = service_error_handler;
        init.p_gatt_queue  = &m_ble_gatt_queue;
        err_code = ble_nus_c_init(&m_ble_nus_c, &init);
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for initializing the GAP.
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device, including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        gap_conn_params = m_scan.conn_params;
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
            NRF_LOG_INFO("ATT MTU exchange completed.");
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @details A pointer to this function is passed to each service that may need to inform the
    /**@brief Function for initializing the Queued Write instances.
    static void qwr_init(void)
        nrf_ble_qwr_init_t qwr_init_obj = {0};
        qwr_init_obj.error_handler = nrf_qwr_error_handler;
            err_code = nrf_ble_qwr_init(&m_qwr[i], &qwr_init_obj);
    /**@brief Function for initializing the Connection Parameters module. */
        cp_init.start_on_notify_cccd_handle    = BLE_GATT_HANDLE_INVALID; // Start upon connection.
    /**@brief Function for handling database discovery events.
     * @details This function is a callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function forwards the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
    /** @brief Function for initializing the database discovery module. */
    static void db_discovery_init(void)
        ble_db_discovery_init_t db_init;
        memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
        db_init.evt_handler  = db_disc_handler;
        db_init.p_gatt_queue = &m_ble_gatt_queue;
        ret_code_t err_code = ble_db_discovery_init(&db_init);
    /**@brief Function for initializing the advertising functionality. */
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
     * @details Handles any pending log operations, then sleeps until the next event occurs.
            nrf_pwr_mgmt_run();
        bool erase_bonds;
    #if DFU_SUPPORT
        uint32_t err_code;
        err_code = ble_dfu_buttonless_async_svci_init();
        // Initialize.
        timer_init();
        uart_init();
        power_management_init();
        ble_stack_init();
        scan_init();
        gap_params_init();
        gatt_init();
        conn_params_init();
        db_discovery_init();
        qwr_init();
        services_init();
        nus_c_init();
        advertising_init();
        // Start execution.
        NRF_LOG_INFO("BLE UART central example started.");
        nrf_sdh_freertos_init(advertising_start, &erase_bonds);
        vTaskStartScheduler();
        // Enter main loop.
        for (;;)
            APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
    hello,I am using the SDK nrf5_sdk_17.1.0_ddde560。
    I am using SEGGER Embedded Studio for ARM 5.42a IDE。
    c_preprocessor_definitions="BOARD_PCA10056;CONFIG_GPIO_AS_PINRESET;FLOAT_ABI_HARD;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52840_XXAA;NRF_SD_BLE_API_VERSION=7;S140;SOFTDEVICE_PRESENT;BL_SETTINGS_ACCESS_ONLY;NRF_DFU_SVCI_ENABLED;NRF_DFU_TRANSPORT_BLE=1;CONFIG_NFCT_PINS_AS_GPIOS;FREERTOS;"
    I use the nrf connect app and after selecting the compressed file to upgrade, I start upgrading, but I haven't started yet.
  • My Colleague will be helping you for this in the other thread. Please do no open duplicate threads I will be closing this thread as duplicate.
